February 14th, 2012, 09:50 AM | #1 |
Power Commander for FI version?
Hi guys.. sorry I dont have a clear cut answer and I've tried some searching to no luck.
I just got the Ninja250 FI version and I'm looking into modding it.. I plan on removing the snorkel and putting on a full Yoshimura exhaust on it. This in return will increase the amount of air intake, normally meaning it'll run leaner. But I believe FI can automatically adjust air/fuel ratios correct? So is it necessary I get myself a Power Commander or should I be ok as is? Thanks! |
February 14th, 2012, 12:34 PM | #2 |
If going to a full system you may want to look at what the LeoVince ECU for FI Ninjas has to offer. These units are installed on the 250 Ninjas for The WSBK European Junior Cup.
February 14th, 2012, 01:57 PM | #3 |
You're right in everything that you've stated, except that the FI is not able to adjust that much automatically. You'll need a PC or similar piggyback ecu
http://www.power-commander-shop.com/...inja-250-R.htm |
February 26th, 2012, 06:34 AM | #4 |
Old Guy, New Bike
Join Date: Jun 2011 Motorcycle(s): 2011 Blue Ninja 250R, Yamaha SRV250 Posts: 133
PCV
Chone is right, the stock FI can't adjust enough. The power commander is the best solution, in my opinion. Model number 17-035 should be the correct model for newer versions of the Ninja 250R. The PCV includes a base map for a stock setup and a map for a full exhaust upgrade. (I think it may be the Yoshimura, but don't remember.) You may need to find a map appropriate for your setup. Or you can install the auto-tuner if you have a bung for the oxygen sensor on your exhaust.
Whichever you do, be sure to keep us informed about the map you use. |
Power commander 5 | joecool | 2013 - 2017 Ninja 300 Tech Talk | 27 | October 17th, 2014 05:03 AM |
Power Commander PCV $220 | Rekognize | Motorcycle-related | 4 | September 21st, 2013 11:42 AM |
power commander? | bandit_fosky | 2008 - 2012 Ninja 250R Tech Talk | 14 | January 16th, 2013 02:05 PM |
Dynojet Power commander 5 | FvnnyL3tt3r1ng | 1986 - 2007 Ninja 250R Tech Talk | 3 | September 23rd, 2012 03:23 PM |
Power Commander for new bike? | dive1tom | General Motorcycling Discussion | 5 | December 8th, 2009 08:53 PM |
