March 13th, 2012, 06:45 PM | #1 |
Join Date: Mar 2012 Motorcycle(s): 2008 Ninja 250r Red Posts: 93
battery dead?
Hey guys, so I went to start up my bike today only to find the key still in the ignition. It appears the battery is dead and wont start. None of the lights work. Can't believe this happened.
Any help is appreciated. Like how to fix the battery? I have a car battery charger BTW. Hoping I can use that. Thanks! |
March 13th, 2012, 06:51 PM | #2 |
Join Date: Jan 2012 Motorcycle(s): 2008 Kawasaki Ninja 250R Posts: 347
Just pop off the seat and trickle charge it with one if you have it. Also, if you have jumper cables, just connect them to your car, but leave your car OFF then connect the other end to your bike, and give her a sec, and push the start button Should work everytime!
March 13th, 2012, 06:53 PM | #3 |
if you don't have a trickle charger, get one. In the mean time, you can bump start your bike, and then be prepared to go ride it for a solid hour and your battery will be as good as new
March 13th, 2012, 06:53 PM | #4 |
Oh and another option is to push/jump start it! Find a friend or a hill, and with your ignition and switch turned on, and your choke as well, get on the bike and put it in first or second gear. Then hold the clutch in while you roll down the hill or while your friend pushes you, and then release the clutch, that should start it up and recharge your battery as well!
March 13th, 2012, 07:10 PM | #5 |
So, where's the reverse?
Only if your charger has the option to switch it to a 2 amp rate or lower. A charger built for car batteries supplies much more current than our tiny batteries require and can possibly damage the plates.
March 13th, 2012, 07:11 PM | #6 |
Thanks for all the quick replies guys!
I know its a noob question, bit I never imagined i would be careless enough to leave the key in the ignition and on. * smacks forehead* Anyhow, I will jump start the bike tonight, but is there anyway of getting the battery back to regular operation mode? Can I use the car charger to restore the battery power or will running the bike after the jumpstart for an Hour. Really get it fully charged once again? Again, thanks to all who reply. It's good learning opportunity for Me. |
March 13th, 2012, 07:31 PM | #7 |
Join Date: Mar 2012 Motorcycle(s): 2012 Ninja 250 Posts: 80
March 13th, 2012, 07:53 PM | #8 | |
Just ride it and it will be fully charged again. Just keep the rpms higher than like 4k and it will charge the battery up just fine! |
March 13th, 2012, 08:01 PM | #9 | |
basically prepare to go for a ride, bump start it, and then go ride as you normally would. Just make sure to take a good long ride so it's charged when you're done. |
March 13th, 2012, 08:36 PM | #10 |
The only thing taught in the MSF courses that I completely disagree with is to turn your bike off with the kill switch. And this is exactly why.
They say it's safer to turn the bike off with the kill switch so that your hand never has to leave the handle bar. But seriously, if you're stopped, and already in the process of exiting the bike, just turn the key. As stated by @choneofakind, bump start it and then go for a nice long ride. These bikes is incredibly easy to bump start. If you're really desperate, you don't even need a friend or a hill. Even though it's much easier with one of the two. If you don't have either of the two, get the bike into second gear if you can (I know it's difficult when not moving), if not, 1st will work. Get off the bike, push it about as fast as you can safely go, dump the clutch then immediately pull it back in. Then hop on, and ride away.
SOLD MY NINJETTE and got THIS |
March 13th, 2012, 09:43 PM | #11 |
Hey thanks for all the tips and advice you guys!! ( I read all of it and soaked it in.)
Can't thank you all enough. I'm off tommorow but. Might find myself going out tonight just to make sure she can run and is okay. Haha I'll be sure to let you all know how it goes!!!! P.R. LA |
March 14th, 2012, 07:13 PM | #12 |
Hey I just picked up the batttery charger and it has a 2a Trickle charge setting! For a 200a engine start. So u will be able to charge it.
My only question now is, once the seat is off. Where do I connect everything? Or do I need to unhook the battery from the bike? I took pics but since its on a mobile I can't upload.. Last futzed with by ProdigyRacingLA; March 14th, 2012 at 07:26 PM. Reason: grammer? |
March 14th, 2012, 07:24 PM | #13 | |
Join Date: Dec 2008 Motorcycle(s): 1988 Honda Hawk NT650, 1989 Honda Hawk NT650, 1997 GSXR750 Track Bike Posts: 890
March 14th, 2012, 07:28 PM | #14 | |
So I did remove the black side skirts, and the seat is off. I'm starring at the battery. Should I take the screws holding the battery in place off? Or is it possible to charge it without removing the battery from.the bike? ( conducting surgery via internet is tough, but thanks for helping!! Haha) |
March 14th, 2012, 07:32 PM | #15 |
If it has clips you can just clip them onto the battery while it's in the bike. Make sure you put them on the correct terminals. The colors should match.
March 14th, 2012, 07:34 PM | #16 |
March 14th, 2012, 08:37 PM | #17 |
2 Amp charging? That's high
March 14th, 2012, 08:42 PM | #18 |
Possible dead battery | roc0487 | 2008 - 2012 Ninja 250R Tech Talk | 22 | April 14th, 2015 01:37 PM |
[motorcyclistonline] - Dead Motorcycle Battery | Ninjette Newsbot | Motorcycling News | 0 | March 20th, 2013 02:50 PM |
Battery dead, I have an old charger.... | Kurgan | 2008 - 2012 Ninja 250R Tech Talk | 5 | January 5th, 2012 10:11 AM |
she dont like a dead battery | 03slime250 | 1986 - 2007 Ninja 250R Tech Talk | 5 | June 3rd, 2010 07:49 AM |
Less than 4k mi. on '09 ninjette . Battery already dead | 00v_Lucky | 2008 - 2012 Ninja 250R Tech Talk | 10 | June 17th, 2009 06:21 AM |
