March 18th, 2012, 08:57 PM | #1 |
Join Date: Mar 2012 Motorcycle(s): 2009 Ninja 250r, 2010 Ninja 250r Posts: 10
Coolant in my Oil.. what the flip??
I just bought a bunch of new parts for my 2009 ninja 250, after installing them all I went to turn it on and nothing. Checked everything I could think of and it still wouldn't turn over.
I drained the oil and out comes coolant with it. Could I have a blown head gasket? What else could it be?? Someone please help !!! |
March 18th, 2012, 08:58 PM | #2 |
/moved to new-gen tech forum
March 18th, 2012, 09:30 PM | #3 |
Sounds to me like you could... Tell us more. What new parts did you put on, and in the process, is there anything you did they MAY have allowed them to mix? I had some coolant in my oil once, but that is just because I spilled some when I had the valve cover off. Do you have a compression testor?
March 18th, 2012, 09:40 PM | #4 |
I put on a new radiator,fan, rear master brake cylinder, slip-on exhaust and a tune up. Nothing that would cause them to mix.
I had it on 2 days ago and it turned on fine but now it just turns and turns and turns but won't turn on. No i don't have a compression tester, what will that do? |
March 18th, 2012, 09:53 PM | #5 | |
Why the new radiator/fan? I'm not 100% possitive, as this is getting to the limits of my experience, but I think a compression testor would help trouble-shoot your head gasket. I got one from HF for around $20. Just make sure you get one with a connector that is sized/threaded the same as your spark plugs.
March 18th, 2012, 10:35 PM | #6 |
Join Date: Jan 2009 Motorcycle(s): 08 Ninja 250 "Wasabi", 82 Yamaha xj650j Posts: A lot.
How much coolant in the oil?
March 18th, 2012, 10:49 PM | #7 |
Join Date: Aug 2009 Motorcycle(s): '08 250R (sold), 2013 300SE Posts: 276
BEFORE YOU TRY TURNING YOUR ENGINE OVER ANYMORE!! PULL YOUR SPARK-PLUGS!! Your cylinders may be full of coolant if your head gasket is blown. Trying start your engine while it is hydro-locked could seriously damage it farther. So start with pulling the plugs. No coolant in cylinders? Check all your safety/kill-switch wires. You may have loosened them while working on your bike. Did you disconnect your battery when you worked on it? Did you tighten the cables afterwards? Hope it turns out to be something simple. Keep us posted.
March 19th, 2012, 09:50 AM | #8 |
You're not really giving enough info.
What kind of tune up did you have and who did it? Were the valves adjusted? Are there any other coolant leaks on the engine? What was the reason for changing the radiator and fan? How many miles on the engine? What color was the oil and did it smell like coolant or gas? Are you using the choke? Was the bike stored for a while? How hard do you ride the bike and has it ever overheated? |
March 19th, 2012, 11:16 AM | #9 |
Ok let me give you guys more info, my bike was wrecked by my brother. He hit a deer. Massive body damage, radiator smashed, fan smashed, rear set torn off.
Which leads to me having to replace the radiator and the fan. Now i also had my carbs cleaned because it had sat for a good 2 months. Haven't had a valve adjustment yet but it may need one soon. One of the first things I did was pull the plugs, no coolant was in there. I have spark on both. I thought it was my coiling but nope it's not. About half a cup of coolant was in my oil when i drained it. No wiring was loosened or even taken off, I simply decided to swap old parts with new ones and do a regular oil change and oil filter change. Tried using the choke, nothing happened. Shut the choke off and still nothing. the motor turns but won't turn on. If you guys need more info, feel free to ask. Any comments or ideas will help! |
March 19th, 2012, 11:41 AM | #10 | |
March 19th, 2012, 11:52 AM | #11 |
If you have spark, then your not getting fuel. Check if you are getting fuel to the carbs,(open float bowl drains)Turn you petcock to prime so your carbs fill with fuel. Try a little raw gas down the carbs. If you can get it to fire then it is a carb/fuel problem.
As for coolant leak. Do any of your auto parts stores have a tool loan service? Here in Canada, Canadian Tire shops loan specialty tools at not charge just a returnable deposit. If so get a coolant system tester, you can pressurize the system and look for leaks without running the engine. Has a gauge so it will show a drop in pressure if there is a leak. Good luck Keep us posted. |
March 19th, 2012, 12:19 PM | #12 |
So has it run at all since the accident?
March 19th, 2012, 04:20 PM | #13 | |
March 21st, 2012, 04:44 PM | #14 |
Ok so im positive its a blown gasket and a warped head. anyone know how to get my gasket out of my 2009 250 ninja?
March 21st, 2012, 04:48 PM | #15 |
Why are you convinced the head is warped?
March 21st, 2012, 04:55 PM | #16 |
Join Date: Dec 2008 Motorcycle(s): 1988 Honda Hawk NT650, 1989 Honda Hawk NT650, 1997 GSXR750 Track Bike Posts: 890
March 21st, 2012, 05:05 PM | #17 |
Depending on how bad it is, and if you do have to have a shop do work, don't forget new (used) 250 engines CAN be cheaper. I'm not suggesting that is what I think you should do, just know it is an option if things start to get expensive.
March 21st, 2012, 05:32 PM | #18 |
I took it to a friends motorcycle shop to get it confirmed. I want to do the work myself and started to look for a free manual for my make and model but do i really have to remove the motor from the frame?
March 21st, 2012, 05:35 PM | #19 | |
Of course if your head is warped you'll have to get it machined.... I haven't a clue what that costs.
March 25th, 2012, 02:48 PM | #20 |
Hey sooo i dropped my motor outta my bike tore it down to get the heads measured and check out the "bad gasket". the gasket looks fine! the top and the bottom gasket, the heads don't even look warped either so i think you might be right about the water pump being out. im going to check it today but how will i know if it's bad?
March 25th, 2012, 04:14 PM | #21 |
The water pump seal is a good thought.... I didn't think of that. You don't sound confident about the head being warped. I thought your friends shop confirmed it? Although I guess to REALLY confirm it they would have to pull it out and measure. Take a good (straight) metal ruler to lay across it, and measure any gaps with feeler gauges. Maybe you've done this, but I have no idea what your level of mechanical knowledge/skill/experience is. If you've already done this, your k/s/e is probably greater than mine.
Attempting to change oil, huge accident happened with coolant. Kinda important. | Insane Pie | 2008 - 2012 Ninja 250R Tech Talk | 15 | December 3rd, 2014 03:30 PM |
Oil and coolant leak | SwagenGTI | 2008 - 2012 Ninja 250R Tech Talk | 6 | November 16th, 2014 11:49 PM |
2008 Coolant in Oil? | First bike! Need some suggestions | champofgames | 2008 - 2012 Ninja 250R Tech Talk | 9 | October 30th, 2014 12:38 AM |
Coolant in oil - a frothy mess! | headshrink | 2008 - 2012 Ninja 250R Tech Talk | 5 | May 2nd, 2011 08:40 AM |
Oil level, suddenly too high; coolant too low | CZroe | 2008 - 2012 Ninja 250R Tech Talk | 5 | August 6th, 2010 11:18 AM |
