March 19th, 2012, 04:16 PM | #1 |
Ninja 250 won't go over 100mph
I'm asking this question for a friend of mine who has the new body style 250. Is the bike govern so that it won't go over 100mph?
March 19th, 2012, 04:17 PM | #2 |
Join Date: Mar 2010 Motorcycle(s): Blue 10 250r Posts: 697
Yes, it's governed by the laws of physics.
It's 30hp what exactly are you expecting? |
March 19th, 2012, 04:19 PM | #3 |
I'm not expecting anything b/c I don't own it I'm just asking for a friend of mine. They state that the old body style would go over 100mph but for some reason this one won't so I figured I would ask.
March 19th, 2012, 04:22 PM | #4 |
lol sorry couldn't help myself. No there is no limiter. If you do the exhaust and jet the carbs you can just get it to crack the ton.
And even then, if the speedo says 100.... you are actually closer to 95. I've done 98mph at Palm Beach International in 6th gear at 12000rpm, thats with a gps timer. Last weekend with 45°-50° weather, she was really purring, I think I got her into the 105 range. Not sure if the older one is faster. They have smaller wheels so I don't know how that works out. |
March 19th, 2012, 04:33 PM | #5 |
Join Date: Sep 2010 Motorcycle(s): 2010 Ninja 250r Posts: 28
ive had mine doin like 175 which is around 110MPH. the wind out here helps out though haha!
March 19th, 2012, 04:36 PM | #6 |
User Title Free Since '12
Join Date: Dec 2010 Motorcycle(s): '10 Ninja 250R Special Edition Green Posts: A lot.
MOTM - Feb '12
You've clearly never dropped a ninjette from an airplane. As fast as a supersport there.
"Improvement makes straight roads, but the crooked roads without improvement, are roads of genius." — William Blake |
March 19th, 2012, 04:41 PM | #7 |
March 19th, 2012, 04:42 PM | #8 |
Gear crash test dummy
Join Date: May 2011 Motorcycle(s): 2010 Ninja 250 race bike, 2014 ZX-636r Posts: A lot.
I've got mine to indicate 110mph. Is your buddy a sumo wrestler as well?
March 19th, 2012, 04:48 PM | #9 |
110 indicated on mine. I hear the older model was lighter and made slightly more HP.
March 19th, 2012, 05:06 PM | #10 |
Join Date: Apr 2010 Motorcycle(s): 2009 Ninja 250r SE, 2007 Daytona 675 Posts: 95
Your buddy must not be trying hard enough.
March 19th, 2012, 05:07 PM | #11 |
Join Date: Nov 2011 Motorcycle(s): 2007 Ninja 250 (sold), '06 Ninja 650R Posts: 455
I believe pre-gens have a slightly higher compression ratio. That would account for the increased midrange and lower top end power.
March 19th, 2012, 05:08 PM | #12 | ||
Once you start making equivalent intake/exhaust mods, the new-gen seems to make more power... not to mention, that's all before changing the timing on the newgen so that it's similar timing to the pregen. They're the same speed pretty much |
March 19th, 2012, 05:14 PM | #13 |
Join Date: Feb 2011 Motorcycle(s): 2011 Ninja 250R Posts: 164
March 19th, 2012, 05:29 PM | #14 | |
March 19th, 2012, 05:36 PM | #15 |
Join Date: Nov 2010 Motorcycle(s): 2007 Ninja 250, 2002 Yamaha XT225 Posts: 597
If you put flame decals on, you can probably get an extra 2 or 3 mph on the top end.
www.bluepoof.com |
March 19th, 2012, 05:42 PM | #16 |
March 19th, 2012, 08:05 PM | #17 |
Join Date: Oct 2009 Motorcycle(s): 2008 Triumph Bonneville Black Posts: 627
Rev limited top speed on stock gearing is just under 110mph, so in theory your friend can reach that speed with a long enough straightaway. If the bike made 200hp it still would only go 110mph on stock gear ratios and tire sizes, it would just get there a hell of a lot faster.
'08 Bonneville Black sold->'08 Ninja 250R | OES Swingarm Spools | EBC HH brake pads | reflector delete | no-cut brake light modulator | DIY fender eliminator |
March 19th, 2012, 08:07 PM | #18 |
Always.
Join Date: Mar 2011 Motorcycle(s): '08 Ninja 250, '05 GSX-R600 Posts: A lot.
I couldn't get mine over 160 i believe, only weighed 130 at the time
blink-182 Last futzed with by blink; March 19th, 2012 at 08:07 PM. Reason: weight...weighed |
March 20th, 2012, 09:13 AM | #19 |
KThanksBye
Join Date: Mar 2011 Motorcycle(s): 2006 zx636r Posts: A lot.
I could get mine to 106mph GPSed, stock was 103mph. yay for spending a grand on performance for 3mph. Now I can do it in second or third gear
----> My Youtube! <---- Unregistered, watch my youtube page! |
March 20th, 2012, 09:21 AM | #20 | |
March 20th, 2012, 03:12 PM | #21 |
March 20th, 2012, 05:29 PM | #22 |
Newb..... on a steeek! :D
Join Date: Feb 2009 Motorcycle(s): 2012 Harley Davidson XL883L Sportster Superlow Posts: A lot.
You have it backwards a little. The pre-gens DO have a higher compression ratio; 12.4:1 vs 11.6:1. However, that gives the pre-gen slightly less mid-range and better top end. Pre-gen: 28.05 bhp (20.92 kW) @ 12500 rpm and 13.15 ft·lb (17.83 N·m) @ 9,000 rpm tested at rear wheel. New-gen: 26.4 hp @ 11,000 rpm (rear wheel) and 13.6 ft·lb (18.4 N·m) @ 9,750 rpm.
March 20th, 2012, 08:01 PM | #24 |
So, you're planning to blow the engine up in a quest to break 110? Good luck with that.
March 20th, 2012, 08:20 PM | #25 |
Jigglin' your Jiglets
MOTM - Apr '13
Your friend is just being a pussy, tell him to go full throttle, these things easily hit 250mph
March 20th, 2012, 08:48 PM | #26 | |
March 20th, 2012, 09:19 PM | #27 |
The valvetrain is good to more than 15,000 rpm easily (according to Sportisi), the reason Kawasaki lowered the rev limiter is because when held at 15,000 rpm (where the rev limiter was on pre-1995 bikes) for long periods of time, there were issues with oil delivery. So they stepped it down to 14,500 after '95, and down to 14,000 [citation needed] in 2003 or something like that. Unless he holds it at 15k for an hour, he'll be fine.
Last futzed with by choneofakind; March 21st, 2012 at 07:48 AM. Reason: for correctness |
March 20th, 2012, 10:30 PM | #28 |
I thought so, but with how you worded it I wasn't sure.
March 21st, 2012, 04:35 AM | #29 | |
March 21st, 2012, 06:50 AM | #30 | |
Guest
Posts: n/a
March 21st, 2012, 07:47 AM | #31 |
March 21st, 2012, 09:54 AM | #32 |
Join Date: Aug 2011 Motorcycle(s): '09 Triumph Daytona 675 Posts: 256
Actually, I would place money on the 250's terminal velocity being close to that of its top speed unless you managed to drop it and keep it going perfectly straight towards the ground, the drag would likely cause it to tumble through the air, so the 250 is still slower
April 5th, 2012, 05:41 PM | #33 | |
Join Date: Mar 2011 Motorcycle(s): 09 Ninja 250r Posts: 634
April 5th, 2012, 07:26 PM | #34 | |
Sexy Beast
Join Date: Mar 2011 Motorcycle(s): 2010 Ninja 250R, 2006 ZX-14, 2012 Ducati Monster Posts: A lot.
and a 15t sprocket should take care of your friends need for speed. |
2009 Ninja 250 won't run | Matto55 | 2008 - 2012 Ninja 250R Tech Talk | 6 | October 3rd, 2014 03:05 PM |
05 Ninja 250 won't start on its own - help! | AmyF | 1986 - 2007 Ninja 250R Tech Talk | 59 | July 8th, 2014 11:46 AM |
2007 Ninja 250 won't start | Time Mage | 1986 - 2007 Ninja 250R Tech Talk | 24 | June 17th, 2013 10:14 PM |
Ninja 250 won't start! please help me! | Black knight | 2008 - 2012 Ninja 250R Tech Talk | 4 | May 23rd, 2013 03:22 PM |
06 ninja 250 won't start | wolfpuss | 1986 - 2007 Ninja 250R Tech Talk | 7 | February 21st, 2012 05:57 PM |
