September 13th, 2012, 09:15 PM | #161 | |
Jigglin' your Jiglets
MOTM - Apr '13
June 22nd, 2013, 08:00 PM | #162 |
Join Date: Jun 2013 Motorcycle(s): 2012 ninja 250R Posts: 28
what a great help, than you, am doing this as soon as filter arrives, Man, dont look forward to all the busted skin with that air box, but being a retired sailor, I have the vocab for the job, hahaha
June 24th, 2013, 08:59 AM | #163 |
dirty boy
MOTM - Apr '14
follow the instructions and it is easy. Don't try and take short cuts. If you can't get to a screw take off what needs to be taken off to get to it.
I did this few months ago and it was a breeze, It took me longer to adjust my needles and change my jets than it did for me to pull airbox. Primarily cuz i did not have a JIS screw driver and i fumbled a bowl screw and it got jammed in by the generator? whatever and i did not have the right pliers at the time to get it out, took forever to get damn thing out with screw driver |
April 18th, 2014, 09:45 AM | #164 |
Join Date: Apr 2014 Motorcycle(s): Kawasaki 250r Ninja, Kawasaki Kz750 Posts: 6
@VeX, I know this post is dated but can you give the part # for the breather you used? I'm in the process of doing some mods and clean up and I really like the simplicity here.
May 19th, 2014, 03:19 PM | #165 |
Join Date: May 2014 Motorcycle(s): 07 Ninja 250 03 Honda CBR 600RR 97 Suzuki Bandit 1200GFS Posts: 6
Losing my mind!
After finally having removed and rebuilt carb with factory pro jets plus replaced the airbox with a K&N 0990 ---- I for the life of me cannot remember where the the idle adjusmtent knob attaches to?????
It's on the bottom of float bowl? float bowl screws? If so-- I rippin it back down! Anyone? 2007 250 |
May 19th, 2014, 08:10 PM | #166 | |
September 15th, 2016, 08:18 AM | #167 |
Join Date: Mar 2010 Motorcycle(s): Ninja 250r Special Edition 25th Anniversary Posts: 17
Hi
I know this is super old post , but which filter is better Rc 2370 or R0990? Thanks |
September 20th, 2016, 10:01 AM | #168 |
Join Date: Jun 2014 Motorcycle(s): Triumph Daytona 675 Posts: 35
Bump
April 22nd, 2017, 05:30 PM | #169 |
Oil problem with breather
Ok so I did this mod a couple years ago. Last year I could not get my bike started. (That is a separate issue now resolved). Today I got is fired up for the first time since the pod mod, rejetting etc. I went for a short ride only to have oil spewing from my breather. I mean A LOT of oil, enough to coat my entire rear wheel. Fish tailing on an oil slick is pretty unnerving. Anyway how do I eliminate oil pouring out of the breather? Anyone got a good solution?
April 22nd, 2017, 06:01 PM | #170 |
You'd probably get more help if you start a new thread, but oil pouring out the breather could be a sign that you have way too much oil in the engine, or that your rings are not sealing. Start by checking your oil level. It's not impossible that your petcock leaked gasoline into the engine all winter, for example, and now you have a lot of fuel/oil mix in the crankcase.
April 23rd, 2017, 09:27 PM | #171 |
Possibly silly question @Mhancock309, but do you have a filter over the crankcase breather port? There can be a good bit of spatter if it's not covered
April 28th, 2017, 07:05 PM | #172 |
Thanks Triple Jim. I was having trouble with my iPad not letting me start a new thread. I did check the fluid level and it was high. Drained it and found fuel mixed in. Momaru, I do have a filter on the port but it still got all over. I think problem solved...
April 28th, 2017, 08:41 PM | #173 |
What was it, leaking float valve and leaking petcock?
April 29th, 2017, 02:02 PM | #174 |
I replaced my ignition with and aftermarket unit not knowing that I needed a 100 ohm resistor for the grey wire so after cranking my bike and flooding the carbs several times gas must have gotten into the crank case. But thanks to this forum I've been able to figure these things out
April 29th, 2017, 02:21 PM | #175 |
You probably already know, but keep an eye on the oil level for a while to be sure it was just cranking that did it. It seems a little unlikely that you cranked so much you raised the oil level, but unlikely things do happen.
September 15th, 2017, 04:59 AM | #176 |
"a legend in my own mind"
Join Date: May 2017 Motorcycle(s): 2015 moto guzzi norge,2020 aprilia dorsoduro, 2014 yamaha fjr, 85 yamaha fj 1100 Posts: A lot.
MOTM - Feb '18
"trying not to get old" |
September 15th, 2017, 05:06 AM | #177 |
MOTM - Feb '18
coming over from zrx's, pods are the norm. we wired them up to hold em in case they came off. i will look into doing this on the 250. will be using stock air box runners too.
September 15th, 2017, 05:16 AM | #178 |
MOTM - Feb '18
another trick is to install this and run breather line higher up. this will eliminate condensation build up in crankcase. must run valve in vertical position. i'll post a pic when i do mine. i don't know if this is a issue with the 250r but zrx 1100/1200 under cold environment short runs would build up condensation on oil level window.
May 25th, 2018, 05:56 AM | #179 |
Join Date: Apr 2009 Motorcycle(s): 09 n250, 14 n300, 22 n400 Posts: 99
hey maverick just curious how you fared, especially with use of the stock airbox runners?
May 25th, 2018, 09:53 AM | #180 |
MOTM - Feb '18
no change. actually i’m working closely with member dannoxyz on jetting experiments with pod filters. so far everything we are doing is cutting edge and will turn the pod community upside down. we are going to prove the airbox must have is a myth and proper tuning can be done with pods. problem is dyno jet and factory pro are giving jet kits that are quite rich. factory pro gives 110,112,115 mains. these are are way to big! to make maximum power, lean mains need to be installed!with danno’s as a guide, the exploited ninja with uni 6”pods is now skirting near stock main jets! i’ve tried 108’s, 102’s,100’s and now heading towards 98’s. keep in mind elevation will factor in too. augusta, ga is 132’ above sea level.
May 25th, 2018, 12:09 PM | #181 |
I think there's some quantitative analysis that's overlooked here. Coming from bigger bikes, it was common to go with pods for performance-increase. Due to packaging constraints on bikes, there's limit on size of airbox and filter. Removing them on 750-1000cc bike and replacing with individual filters increases filter's surface-area and reduces restriction. This improves high-RPM flow and power.
However, on Ninja-250, with similar sized frame, tank, seat-height, etc., it has airbox and filter of roughly same size as 600cc supersport bikes! Filter on my 250R is about same size as my CBR600RR's! A bike with 5x air-flow and 5x power! So I concluded that filter and airbox on 250R doesn't pose any restrictions nor does it rob any power. Talking with other racers backs up that conclusion as none of them have removed airbox for power-gains. Perhaps use K&N-type cotton washable filter for longevity. Even racers in 250 Superbike classes which allows for airbox removal don't do it. And racers will and have tried every dirty trick possible for advantage! I've tried searching for and asking for before-and-after dyno-charts of pod-conversions on 250s, nothing. Many street riders report that pod filters cause them fuel-metering issues in partial-throttle mid-range and that bike is sensitive to crosswinds causing hiccups. Reverting them back to factory config alleviates all these problems. Such as this case: https://www.ninjette.org/forums/showthread.php?t=84623 Other topic is carb-tuning process, which I'll go over once I dig up info... |
May 25th, 2018, 12:33 PM | #182 |
Other aspect of quantitative analysis that's incomplete is with carb-tuning. We should be aware that new-gen bikes are VERY different from pre-gen bikes. Engines are tuned completely differently with different cams-profiles, head/port shapes, valves, exhausts, ignition-maps and of course, carburetor configurations. This entirely affects characteristics of engine and power-output
pre-gen 1988-2007 new-gen 2008-2012 - from Motorcyclist comparing with other small bikes And dyno-chart comparing them, roughly ~6% difference. Pre-gen vs. New-gen summary 5.75s vs 6.90s - 0-60 time 14.59s vs 15.30s - 1/4-mile time 87.82s vs 84.15mph - 1/4-mile speed Performance figures between them also roughly reflect power-differences, although lighter pre-gen takes bigger lead from stand-still.. Riding them back-to-back, I can feel differences in power-output, but barely. For butt-dyno to really distinguish, you need at least 10% variation. That ~6% power-difference is part of carb tuning configuration from factory. Which should be used as baseline for all mods and adjustments: Pre-gens = 105 main jets New-gens = 98 main jets Roughly same ~6% difference repeats itself. Be very, very aware when you are talking about jetting changes, which model you're dealing with. Pre-gen or New-gen; what works for one will not work for other! |
May 25th, 2018, 02:40 PM | #183 |
MOTM - Feb '18
uni vs k/n
i tried both. even tried k/n with airbox intake trick. no change. i left the uni’s in because they look cool!
May 25th, 2018, 02:46 PM | #184 |
One big gain can be had on new-gens by removing snorkel from air-box. That's tiny straw compared to size of air-box and filter.
May 25th, 2018, 03:07 PM | #185 | |
MOTM - Feb '18
May 30th, 2018, 12:57 AM | #186 |
Join Date: Aug 2016 Motorcycle(s): Triumph Bonneville, Ninja 300 Posts: 204
Keep in mind, a lot of racing orgs require a stock airbox. You'll be fine for trackdays with pods.
I've kind of always wondered why, but there it is...
Let he who has never re-used a crush washer cast the first stone... |
DIY- Removing the Kleen Air System Hoses and Plugging the Holes on a 08 250R | kkim | 2008 - 2012 Ninja 250R Tech Talk | 152 | March 15th, 2019 07:37 PM |
K&N air filter to stock air box | Graugaard | 2008 - 2012 Ninja 250R Tech Talk | 29 | July 28th, 2012 06:33 AM |
Air Filter Box Question | Little Green Machine | 2008 - 2012 Ninja 250R Tech Talk | 7 | July 14th, 2012 06:25 AM |
