September 2nd, 2010, 07:12 AM | #1 |
Join Date: Aug 2010 Motorcycle(s): 09 ninja 250r Posts: 34
250 size compared to 600's
my wife and a buddy of mine had setup a ride for yesterday morning he rides an older fzr 600 when he pulled in i was a bit taken back by how close they are in size
I knew that the ninja's physical size was pretty up there but it really surprised the hell out of me to see it was bigger than the fzr length, height everything was slightly larger with the exception of seat height they were almost identical So it left me wondering what other bikes that share almost the same physical size as the 250 |
September 2nd, 2010, 07:18 AM | #2 | |
Join Date: Apr 2009 Motorcycle(s): '04 sv650s Posts: 438
There's 2 types of people in this world, those who complain and those who act. |
September 2nd, 2010, 07:34 AM | #3 |
The Ninja 500 is very similar in size.
September 2nd, 2010, 07:40 AM | #4 |
Ninjette CPT
Join Date: May 2009 Motorcycle(s): Black 08 250r Posts: A lot.
September 2nd, 2010, 07:48 AM | #5 |
Height and wheelbase can be the same, but if the triangle of seat, bars, and pegs are different the bikes will feel different.
September 2nd, 2010, 08:14 AM | #6 |
Ninjette CPT
September 2nd, 2010, 09:44 AM | #7 |
Join Date: Oct 2009 Motorcycle(s): 2008 Triumph Bonneville Black Posts: 627
I believe the new CBR600RR actually has a shorter wheelbase than the 250. 600's "look" so much bigger though.
'08 Bonneville Black sold->'08 Ninja 250R | OES Swingarm Spools | EBC HH brake pads | reflector delete | no-cut brake light modulator | DIY fender eliminator |
September 2nd, 2010, 09:55 AM | #8 |
Definitely wider with the inline 4.
September 2nd, 2010, 12:29 PM | #9 |
Join Date: Jun 2010 Motorcycle(s): 2010 Ninja 250r Special Edition Posts: 31
I noticed this with my husbands 2009 gsxr750 it's really close to the same in length and height, but like said above his is definitely wider. I'll probably move up to a 600cc next spring we'll see though!!
September 2nd, 2010, 03:59 PM | #10 |
i find that all other brand bikes look similar in size to the 250r, but the 2008 zr-6r looks humongous compared to the 250r.
September 6th, 2010, 12:30 PM | #11 |
Join Date: May 2009 Motorcycle(s): 2009 Ninja 250 (sold) Posts: 755
I had the opposite reaction when I worked with a guy that had an 08 ZX6R, it seemed much bigger than mine when parked side by side.
The Ninjette is not a disposable bike. You are not ever supposed to get rid of it. It is like a [friendly] herpes virus.... once you got it, you get keep it forever. Originally posted by-Headshrink |
September 7th, 2010, 03:05 PM | #12 |
Join Date: Jul 2009 Motorcycle(s): '09 Metallic Diablo Black Posts: 298
*short person complaint* If most dimensions are so similar, why does nobody make a 600cc bike with the same seat height as the 250?
September 7th, 2010, 06:18 PM | #13 |
Join Date: Sep 2009 Motorcycle(s): 09 Ninja 250R SE Posts: 376
I think the super-sport bikes have higher seat heights to give a more aggressive seat position which is more leaned forward and more weight on the front wheel. The higher seat height just goes with the territory. There are non super-sport 600s that have a more upright, less aggressive seat position. I'm not sure how much lower the seat is though.
September 8th, 2010, 04:25 AM | #14 |
Higher seat also allows higher pegs/greater ground clearance when turning.
I had a Ninja 500 (actually an EX500… same thing) a while back and recently sat on one for old times' sake. It felt really odd and much larger than I remembered. Ergos are everything when it comes to perceived size. |
2008+ Ninja 250 Carburetor Screw size, allen screw size! | Runeknight95 | 2008 - 2012 Ninja 250R Tech Talk | 4 | March 2nd, 2015 11:49 AM |
