Old August 24th, 2013, 04:03 PM   #4361
ashman
Motorcycle(s): 2013 Ninja 300
Installed m4 exhaust bracket, removed passenger pegs. Installed 15T CS sprocket. Rained off and on all day. Maybe a test ride tomorrow.
ashman is offline   Reply With Quote
Old August 24th, 2013, 07:55 PM   #4362
ninjamunky85
Que Buenos Son!!!
ninjamunky85's Avatar
MOTM - Nov '14
Went for an "end of summer ride", did about 200 miles. Hit some good twisties and had perfect weather.
Old August 25th, 2013, 01:33 PM   #4363
menikmati
crash 250, get supersport
Motorcycle(s): 2010 250R SE (Sold 6/9/14), 2009 ZX-6R (Sold 6/25/14), Subaru BRZ
Replaced triples and found out that my steering lock wasn't broken, I just had to tighten the top nut (right before the steering stem nut) down more.
New front fairing (needs decals eventually) and found out that either my speedometer assembly or speedometer cable are broken. Fixing the speedometer is the last thing I need to do before taking it on my commutes again to see if the steering/tracking is back to normal. Also, those bearings on the lower part of the triples are a pain in the ass to put back in without them falling out, took me a good 30 minutes of frustration and grease to get that **** back together.
Also went back to a 14T front sprocket, will keep the 15T in case I ever want to change it out down the road.
menikmati is offline   Reply With Quote
Old August 26th, 2013, 06:57 AM   #4364
allanoue
allanoue's Avatar
MOTM - Sep '14
Lost two header bolts for the exhaust on the way to work. Anyone know what size bolts I need?
Edit: I need two 8mm nuts
Last futzed with by allanoue; August 26th, 2013 at 08:23 AM.
Old August 26th, 2013, 07:31 AM   #4365
menikmati
Motul chain lube (road) is now my new favorite thang. Been stocking up on both Road and Factory Line ever since STG and Motorcycle Superstore have had their free shipping promo.
Old August 26th, 2013, 09:17 AM   #4366
lgk
Originally Posted by menikmati View Post
motul chain lube (road) is now my new favorite thang. Been stocking up on both road and factory line ever since stg and motorcycle superstore have had their free shipping promo.
pics of chain?
Old August 26th, 2013, 10:26 AM   #4367
menikmati
Originally Posted by lgk View Post
pics of chain?
I posted a pic of my new ERV3 a couple of pages back.
Old August 26th, 2013, 01:19 PM   #4368
lgk
i thought the motul lube left a white residue.
guess i was wrong,
good looking chain though
Old August 26th, 2013, 02:05 PM   #4369
menikmati
guess i was wrong,
Factory Line dries a milky white and Road dries clear.
Old August 26th, 2013, 02:09 PM   #4370
BRad704
Big Dreams, Small Wallet
BRad704's Avatar
Motorcycle(s): 08 Ninja 250R (Sold), 93 VFR750F (In Pieces)
Rode around aimlessly for "lunch" then filled her up.
244 miles (not all today) on that tank, 4.48 gallons. ~54mpg. and that's with 2 washers per needle, intake snorkel removed and a modded GSXR muffler.
~BRad
BRad704 is offline   Reply With Quote
Old August 26th, 2013, 05:39 PM   #4371
tfkrocks
tfkrocks's Avatar
MOTM - Jan '18, Sep '13
Had a pickup truck noticeable swerve towards me right as I passed by lane-splitting Nothing happened, but really dude?
Old August 27th, 2013, 04:10 PM   #4372
tfkrocks
tfkrocks's Avatar
Ok I'm tired of adjusting this damn piece of **** chain. I swear I'm adjusting it nearly every time I ride for any sort of distance. Also, despite my frequent cleaning and lubing, it constantly looks completely coated in rust and showers the whole back end of my bike with the **** too. Using a non o-ring chain was a mistake. (Made an error ordering but decided to use it anyway). **** this ****. I'm getting a new chain.
Old August 27th, 2013, 11:10 PM   #4373
NevadaWolf
Certified looney toon
NevadaWolf's Avatar
MOTM Jul '13, Jul '14
Installed a new accessory fuse box and hooked up a relay to run the thing with the ignition switch. Still need to mount it and clean up the connections and tomorrow I'll start plugging in the gizmos!
<-- Linky
Old August 28th, 2013, 12:31 PM   #4374
BRad704
BRad704's Avatar
You are officially no longer allowed to say that you are incapable of shimming the needles in your carbs.
~BRad
Old August 28th, 2013, 12:41 PM   #4375
NevadaWolf
NevadaWolf's Avatar
Er, um, err...
<-- Linky
Old August 28th, 2013, 07:16 PM   #4376
IF13
WOT WOT WOT
Motorcycle(s): '12 Ninja 250R
Bar ends slapped on, still waiting for my darn headlight bracket
Scheduled to get a quote on fairings to be painted.
White.
Yah baby
IF13 is offline   Reply With Quote
Old August 28th, 2013, 07:18 PM   #4377
kirk595x
kirk595x's Avatar
Motorcycle(s): 03' Ninja 250ex
Adjusted chain, Polished her up and Rode to work like everyday.
Perform Random Acts of Coolness!!ATGATT
kirk595x is offline   Reply With Quote
Old August 28th, 2013, 08:06 PM   #4378
odn3
odn3's Avatar
Motorcycle(s): 2011 SE 250
I just installed new tires, went with the pirelli sport demons 140rear/110front.. can not wait to break them in and hit the twistys!
odn3 is offline   Reply With Quote
Old August 28th, 2013, 08:57 PM   #4379
kirk595x
kirk595x's Avatar
You wont be dissapointed!
Old August 29th, 2013, 05:40 PM   #4380
cuong-nutz
cuong-nutz's Avatar
50 tooth for my bike
HalfFast Racing Team
Old August 29th, 2013, 08:07 PM   #4381
NinjaRed
NinjaRed's Avatar
New windshield
So today I replaced the stock windshield with one of the double bubbles windshields I found online for about 16 bucks which I came across in one of the forums on here which decent reviews. I decided to change it to double bubble because ive started riding it on freeways and the wind is kind of an issue. Ill be riding back to south jersey end of the weekend so ill notice the true difference then if theres any.
NinjaRed is offline   Reply With Quote
Old August 31st, 2013, 12:31 PM   #4382
Had the ECU replaced for the 300 recall. Felt fine before, feels fine now.
Old August 31st, 2013, 02:02 PM   #4383
EternalNewb
EternalNewb's Avatar
Motorcycle(s): 2012 Ninja 250R, 2007 Ninja 650R, 2001 F650 Dakar
Pulled off the tank/fairings again, and rutted around looking for some obvious leak. Again failed to figure out why I'm only getting 30mpg.
EternalNewb is offline   Reply With Quote
Old August 31st, 2013, 07:21 PM   #4384
NevadaWolf
NevadaWolf's Avatar
w00t!! I have two weatherproof USB ports from BurnsMoto and the Blue Sea 12V and dual USB ports from Amazon!
Go me and my bad electrical self! Nothing blew up on my ride tonight.
<-- Linky
Old August 31st, 2013, 07:25 PM   #4385
ninjamunky85
Que Buenos Son!!!
MOTM - Nov '14
Do you weigh 300 lbs? Seriously, that is some bad gas mileage.
Old August 31st, 2013, 08:55 PM   #4386
EternalNewb
I know. I used to get 65mpg. My mechanic friend rode it around and said it wasn't doing anything mechanically funky. Said it seemed smooth. Blaaaaah.
Old August 31st, 2013, 09:17 PM   #4387
Obsidia
Quantum Creatrix
Obsidia's Avatar
Motorcycle(s): 2012 Ninja 250R Special Edition
I took a beautiful ride from Portland, OR up over Mount Hood over to Tygh Valley via 26 to 216 to 197 and then took forest road 48 back over the mountain back to Portland :-) It was an awesome ride!! All said and done it was about a 230 mile trip in one day which is a huge accomplishment for me
Obsidia is offline   Reply With Quote
Old September 1st, 2013, 03:35 PM   #4388
tfkrocks
tfkrocks's Avatar
Group ride! Guess the number of ninjettes in this picture
Old September 1st, 2013, 04:12 PM   #4389
rojoracing53
Fast-Guy wannabe
rojoracing53's Avatar
MOTM - Jan '13
orangealishious
Old September 1st, 2013, 04:14 PM   #4390
rojoracing53
Fast-Guy wannabe
MOTM - Jan '13
not sure about ninjette's but there seems to be a lot of cell phones
Old September 1st, 2013, 09:51 PM   #4391
tfkrocks
tfkrocks's Avatar
Patched up cracks in fairings from both bikes with ABS cement. I noticed that the 300's fairings are flimsier than the 250's fairings. The plastic is noticeably thinner.
That's like... 3 lol
I counted 8 ninjettes at the meetup spot, but one guy left so we had 7 all day
Old September 1st, 2013, 10:19 PM   #4392
EternalNewb
Cleaned and lubed the chain. Also oil change before my Tuesday thing, and an upcoming moto camping trip about which I've been very excited for the last couple months.
... Well, not the latter so much. My dad insisted I use his torque wrench. I found out the hard way that it's a busted pos from Harbor Freight or something. Basically, the drain plug bolt and the other bolt that secures the oil filter cover were both over-tightened to the point of the drain plug being embedded into the washer, and everything that either of those bolts go into being cracked to hell and back. All because of a busted torque wrench. So on to ordering more parts and buying more oil that I can't afford.
Old September 2nd, 2013, 02:03 AM   #4393
ninja250r81
ninja250r81's Avatar
Motorcycle(s): 2012 ninja 250r se
installed this today.
it has the supplied db killer in.
can't believe how deep the sound is ;-)
ninja250r81 is offline   Reply With Quote
Old September 2nd, 2013, 05:40 AM   #4394
Xorro
Xorro's Avatar
Motorcycle(s): CBR650F replacing the Ninja 300
This was yesterday (as I've only just found this thread)... said goodbye to our 250 weenie greenies and hello to our new (not so) weenie greenie 300's.
I hope our 250s aren't too sad, we were together for 4 years.
Today I am hoping to adjust the idle down on my 300 as it runs around 2000rpm whereas the other bike runs at 1500.
Current: Honda CBR650F - Pearl Metalloid White
Previous: Kawasaki Ninja 300Ninja 250RKawasaki ER5Honda Hornet CB600
Xorro is offline   Reply With Quote
Old September 2nd, 2013, 07:58 AM   #4395
EternalNewb
Nice, Xorro!
Looking for parts to replace the ones busted yesterday. Also continuing to kiss and snuggle my bike and apologize. Poor buddy.
Old September 2nd, 2013, 08:13 AM   #4396
rojoracing53
Fast-Guy wannabe
MOTM - Jan '13
That sucks
certain tools shouldn't come from the bargain bin, a torque wrench is one of them. Also precision tools require maintenance and with out it they'll quickly become POS.
Old September 2nd, 2013, 08:21 AM   #4397
EternalNewb
That sucks
Yeah, I thought I could trust my dad's tools, but I guess as a woodworker, he doesn't really maintain his precision tools for car/mechanical work. It just happened at a really inopportune time, since I have ride commitments, including a moto camping trip this weekend.
So parts hunting, I am. And apologizing to my Ninja. Poor little Ninja.
Old September 2nd, 2013, 02:32 PM   #4398
Xorro
Xorro's Avatar
Today I adjusted down the idle from 2000rpm to 1500 (and burnt my hand on the engine).
First mod: Remove information sticker from tank.
Before
After
Old September 2nd, 2013, 02:57 PM   #4399
NevadaWolf
NevadaWolf's Avatar
Found a single small wire had busted and rendered all my fancy new accessory plugs useless. Spent this morning tracking down the problem, fixing it, cleaning up a bit of my botched connections, and putting the bike back together again. Fingers crossed they all work now!
<-- Linky
Old September 3rd, 2013, 04:53 AM   #4400
gantt
gantt's Avatar
Motorcycle(s): 2019 Ninja 400, Sold 2012 Ninja 650, Sold 2009 Ninja 250r, Sold 2007 DRZ400s
pics of 300 canister swap
Originally Posted by c-dog View Post
That sounds pretty cool to me. Post pics when you finish, would love to see it.
I like the way the 300 exhaust looks personally.
As promised, though it did take a while to follow through. lol
now the canister end cap is rusting?? i've heard this was a warranty issue but I wont qualify for that.
gantt is offline   Reply With Quote
Discovered something scary about my Ninjette today... kjohng General Motorcycling Discussion 28 October 15th, 2021 01:40 PM
Sold the 2006 Ninjette today :( Renner General Motorcycling Discussion 31 October 16th, 2014 11:46 PM
Today I Gave My Ninjette Wings! BlueHairSar Pictures 5 June 20th, 2013 07:38 AM
my bro went down today on his ninjette richierich781 !%@*#$%!)@#&!%@ I crashed! 46 January 18th, 2013 11:59 AM
Ninjette. org hacked today CC Cowboy Off-Topic 9 April 3rd, 2011 08:55 AM
