November 7th, 2011, 12:01 PM | #441 |
Join Date: Jul 2011 Motorcycle(s): 2010 250R FI, 2006 ZX10R Posts: 175
thanks for the write up, would love to replace mine with this woodcraft clip on
I'm Selling wider (4.5" & 5") aftermarket Wheel for N250r/N300r/Z250/Z250r |
January 1st, 2012, 12:14 AM | #442 |
February 23rd, 2012, 04:08 PM | #443 |
Join Date: Jan 2012 Motorcycle(s): 2012 Ninja 250R Posts: 365
Woodcraft Clip ons
Installed my woodcrafts, thought I'd put up some pics
in the last pic you can see that with the bars turned as far as they go, the brake lever just ever so slightly touches(it's the same on both sides) But it's no big deal as the bars will never get turned that far while riding. |
February 23rd, 2012, 04:31 PM | #444 |
OMRRA 701
Hey Chris, what kind of bar ends are those?
February 23rd, 2012, 04:42 PM | #445 | |
February 23rd, 2012, 04:44 PM | #446 |
I don't remember what brand they are, I want to say driven? but not sure. I did get them from my local shop so who knows how long they had em sitting around. These were made for the stock type bars but with a longer screw and some rubber hose, they work just fine with these bars.
February 23rd, 2012, 05:06 PM | #447 |
Join Date: Jul 2011 Motorcycle(s): 2009 Kawasaki Ninja 250R Red Posts: 316
I love my WC clip ons
My YouTube Channel |
February 23rd, 2012, 05:14 PM | #448 | |
Last futzed with by ator; February 24th, 2012 at 02:15 PM. |
February 23rd, 2012, 08:58 PM | #449 | |
February 24th, 2012, 09:53 AM | #450 |
Can I merge this with the main Woodcraft install DIY?
http://www.ninjette.org/forums/showthread.php?t=12960
February 24th, 2012, 10:45 AM | #451 | |
March 7th, 2012, 03:38 PM | #452 |
March 7th, 2012, 05:50 PM | #453 |
I saw today that a Triumph Daytona 955i has clipons with a rise very similar to the SV650 clipons that many people use instead. The only problem I see is that the forks are 45mm, so it'd need a bit more shimming.
March 31st, 2012, 10:31 PM | #454 |
Just a warning: "universal" bar-ends don't always work with Woodcraft clip-on bars. They DO fit the SV650 clip-ons that I never got around to installing (found a deal on these first).
The blue "universal" bar-ends that I bought have two aluminum sleeves that expand as a cone-shaped piece is threaded onto the bolt (the sleeves are slotted to allow this). Even before expansion, the outer sleeve is just too big to fit the inner diameter of the WC bars despite being the same outer diameter as the compatible SV650 bars. There's also a spacer against the bar end itself that's too thick to fit inside the bars. If I remove both the spacer and the outer sleeve, I can get it in but the cone has to expand the inner sleeve an extreme amount to contact the walls and, even then, it's only the tip, which allows the bar-end to wobble excessively. I'm thinking about wrapping it with tape or something to fill most of the gap before it expands or just switching to the SV650 bars and selling these. If I do try to fit them, I'll measure the inner diameter and get washers to make my own fitted spacer to stabilize it at the end of the bar and push the expanding sleeve deeper. The original spacer was solid but I'm going to try rubber. The Woodcraft bars already had the plastic plug bar-ends removed when I bought them. |
March 31st, 2012, 11:09 PM | #455 |
I hate driving...
Join Date: Jul 2010 Motorcycle(s): 13 Triumph Street Triple R, 09 Ninja 250r (Sold 4/20/12) Posts: A lot.
Yeah I had the same problem. But to get my bar ends on I just greased up the rubber expansion piece, that is supposed to make a snug fit, and jammed it in there. It hasn't budged since.
09 ninja 2fiddy SE Driving slow things fast |
March 31st, 2012, 11:18 PM | #456 |
Mine has no rubber. I'll see if I can find an appropriately sized rubber tube.
April 2nd, 2012, 09:48 PM | #457 |
I hate driving...
oh, yeah that would complicate things. I think kkim posted about using 5/32 fuel hose or something like that a while back (I think its in the DIY list tread)
April 11th, 2012, 04:15 PM | #458 |
I always like to read the official instructions first and then read the DIY to see where they may differ and decide which to follow from there, but I didn't get a sheet like kkim because I bought mine used. The Woodcraft website has a "Instructions" tab on the page for our product, but all I see is a big blank spot when I click it as if there were none. I even tried to look up instructions for other bikes (tried CBR 250R) and the same thing happens. Does anyone have the original instructions for me? I would appreciate it. Thanks!
Having read kkim's DIY anyway (it's all I had), I still have to wonder: Are there any tips for aligning them at the same angles on both sides? Also, are there any instructions for how I am supposed to tighten the clip ons onto the fork pistons? I mean, there is a gap between the two clamp pieces and randomly tightening down one side before the other will simply leave a gap twice as large on the other side. I doubt it has to be even, but I don't know if there is a preferred side to tighten down first or if I should aim for keeping them even or what. |
April 16th, 2012, 09:38 PM | #459 | |
I hate driving...
April 17th, 2012, 09:04 AM | #460 |
Turn the wheel as far as it will go. Get one bar snug where it should be, and measure its distance relative to a fixed point on the bodywork. Then turn the wheel back, and do the same for the other side, and make sure both measurements are the same. That should get it pretty close. The tricky part is eyeballing the angle of the levers to be the same.
April 17th, 2012, 09:27 AM | #461 |
Actually, based on the style of the tripple clamp, just pull each side down (towards you, bar end side) as far as they will go. This way, they will both be the same.
The tripple clamp will only let them go so far. |
April 17th, 2012, 04:09 PM | #462 |
But is that the best position for fitment and clearance?
April 17th, 2012, 05:50 PM | #463 |
June 8th, 2012, 01:27 PM | #464 |
Join Date: Aug 2010 Motorcycle(s): Bike-less, Can I ride yours? Posts: 318
So I just got mine the other day, but I'm having trouble installing them.
For the bar ends I read that you have to heat them to help with the red loctite, I don't have a butane torch so I tried using a lighter. I heated the screw for 2 minutes or so and tried to get it, didn't happen. I repeated this with longer intervals of heating. Will I actually need to use a butane torch? Is there anything else I can try? Thanks!
RR stands for Responsible Riding... Right? |
June 8th, 2012, 01:35 PM | #465 | |
Join Date: Jul 2011 Motorcycle(s): 2012 Ninja 250, 2006 Ninja ZX6R-636 Posts: 661
June 8th, 2012, 01:37 PM | #466 |
Join Date: Aug 2011 Motorcycle(s): 2012 Ninja 250, 2008 Daytona 675 Posts: 212
Do not be afraid to drill the bolt out
June 8th, 2012, 01:38 PM | #467 |
Okay! I'll try that. Should I still heat the screw or will this work without heat?
June 8th, 2012, 01:50 PM | #468 |
Fighting Texas Aggie '05
Cut the bar end weight in half leaving the stub of the bolt, then use a vice grip and she will turn right out.
June 8th, 2012, 01:52 PM | #469 |
June 8th, 2012, 05:43 PM | #470 |
Because I don't want your lucky experience to set expectations:
Some need heat even with all the torque in the world. I went through two pencil butane torches (wouldn't stay lit; kept blowing out), which ended up being almost exactly like holding a lighter to it. I used a T-handle socket wrench (like a breaker bar with a permanent extension) with a #3PH socket that fit the bar-end bolt perfectly. I had a ton or torque with plenty of force inward and there was no slipping (I didn't cam out): The metal of the screw head just plain cracked on each blade and turned to mush! There was simply no way to put enough force through the screw head to break the threads loose. I even tried an impact driver. It simply needed heat and I simply had to buy a proper torch. Last futzed with by CZroe; June 8th, 2012 at 08:21 PM. |
June 8th, 2012, 06:59 PM | #471 |
June 8th, 2012, 07:39 PM | #472 |
June 9th, 2012, 11:35 AM | #473 |
I used a quality impact driver and broke the bit in two trying to get it loose, then it went in the bandsaw
June 9th, 2012, 12:54 PM | #474 |
Join Date: Aug 2010 Motorcycle(s): 2010 250R SE Posts: 262
June 15th, 2012, 02:55 PM | #475 |
Hi i just read this thread and OMG i want clip-ons lol i live in Aust i'm 6"11 and i know i'm abit tall but who cares...
My question is i have a 2012 Ninja 250 so am i still be able to use the woodcraft clip-ons ?? I hope so anyway i don't think i will get rearsets coz i don't do track but looking into that down the track... |
June 15th, 2012, 03:45 PM | #476 | |
imo, the posture and control seems better too. the angle of the bars are not as adjustable as other rear sets, but the vertical has some play. the rear sets are pretty durable unlike the stock ones, and the way the brake pedal is angled the you are less likely to lock up the rear brake. i think they are both good purchases. |
October 10th, 2012, 05:39 PM | #477 |
Join Date: Sep 2012 Motorcycle(s): Kawasaki ninja 250 Posts: 4
Looks Good mate, im thinking about buying some clip on's myself, just wondering how the staring was. Do the bars hit the fairing or anything? would you recommend getting them?
October 10th, 2012, 06:34 PM | #478 |
Join Date: Jan 2010 Motorcycle(s): 2007 Ninja 250 faster red Posts: 397
on top of heating it, get one of these:
http://www.harborfreight.com/7-piece...set-93481.html you will rarely use it, but it be a godsend. |
February 5th, 2013, 09:25 AM | #479 |
Join Date: Apr 2012 Motorcycle(s): '12 ninja 250r Posts: 762
So I've had mine on for about 5 months now. A couple months back I noticed a bit of fading in the exposed parts of the bar, but the other day I saw the fading was real obvious in the right light - not only the bars, but the mounting clip too. Anybody else have paint fading issues?
Attached is a pic I took last week for the stem clock. You might be able to see the fading throughout, but the fade on the right bar is super obvious and the first place it started changing color. PS - don't pay any mind to the zip ties around the clutch lever holder |
February 5th, 2013, 09:37 AM | #480 |
my bars are also faded, but it took months for it to happen.
all the other parts are good though.
Are woodcraft clipon bars hollow? | ninja2007 | Ninjettes At Speed | 11 | October 1st, 2014 08:36 PM |
Woodcraft clipon height question | Colezombie | 2008 - 2012 Ninja 250R Tech Talk | 2 | July 12th, 2011 01:45 AM |
Clipon Vortex or Woodcraft? | JaeL | 2008 - 2012 Ninja 250R Tech Talk | 16 | August 16th, 2009 05:26 PM |
woodcraft clipon towers | gizmogamez | Ninjettes At Speed | 5 | July 22nd, 2009 02:45 PM |
