February 27th, 2011, 07:19 PM | #521 | |
I like that it looks a bit more like a real swingarm and that it seems to have accomodations to keep your chain guard but, when used without the guard, it totaly kills the fake swingarm effect (makes it obviously fake with the piece that covers the front of the non-existent chain guard). They also show it without the hugger piece (green on a red bike but I am color-blind between G/R ) and, except for that bit about the chain guard cover in the fake swingarm, it still looks pretty cool! Maybe that's because I don't really like the shape of the hugger part to begin with, especially when compared to Sportisi's original. It looks like it's secured with the chain guard bolts and the spool bolts. Honestly, I'd try to bypass the spool bolts so that I could get it off more easily for chain lubrication and cleaning, but that is probably the best way to attach it on the right side (no velcro or two-sided tape). |
February 28th, 2011, 06:10 AM | #522 |
Ninjette CPT
Join Date: May 2009 Motorcycle(s): Black 08 250r Posts: A lot.
February 28th, 2011, 08:51 AM | #523 |
self wrencher
Matt,
can you source a custom faceplate for the Koso gauge for me? I got everything but the faceplate to mount that voltmeter. Shito paul screwed me on that one (and almost everyone else as well). |
February 28th, 2011, 10:58 AM | #524 |
Join Date: Aug 2010 Motorcycle(s): 2009 ninja 250R Posts: 16
want1
Check this out for the huggers. pictures on first page. http://www.ninjette.org/forums/showthread.php?t=51228 |
February 28th, 2011, 06:47 PM | #525 | |
Join Date: Apr 2009 Motorcycle(s): 2014 Z250 Posts: A lot.
might have an answer in a couple hours, just nagged them again, hehe but if matt could get it, hes already got the shipping from indo to the states all figured out, which would make it the best solution for you.
Kawasaki Z250, Bored up to 300cc with 12.8 CR, 41hp at wheel 27nm torque, Two bros full exhaust with DB killer Dynojet Power Commander V, KnN Open filter, intake and exhaust ported, Puig Windshield |
February 28th, 2011, 07:49 PM | #526 |
The Sportisi Master
Join Date: May 2009 Motorcycle(s): 2008 Ninja 250 Posts: A lot.
I'm usully the first one to curse. But please refrain from any comment regarding shinto in this thread please. You can pm if you like.
Sportisimoto USA is born. |
February 28th, 2011, 08:16 PM | #527 |
self wrencher
If anyone of you guys can help source one would be great. Can't seem to locate one in the us. I think it's only avail in Indo or Thailand.
March 9th, 2011, 08:01 PM | #528 |
The Sportisi Master
May do a gb on rearsets and shocks here in a week or two. Non Ocean freight so it would be a quick turn around.
March 9th, 2011, 08:05 PM | #529 |
im down for that!
March 10th, 2011, 08:14 PM | #530 |
The Sportisi Master
Oh boys who loves me?
Soon to be available. Plug and play rear rim. All you do is swap over the stock parts. Available from kawasaki indonesia. Fits the 150 tire with ease opening up a better and proper tire selection. Best of all I'm going to do a gb on it. Pricing will be at the $500 mark retail. Pics to come I can't upload from my android where I am right now.
March 10th, 2011, 08:36 PM | #531 |
self wrencher
Way back you mention sportisi has an undertail exhaust system under testing. Is it done & available yet? Pics?
March 10th, 2011, 08:42 PM | #532 |
Join Date: Feb 2011 Motorcycle(s): 09 Ninja 250r Posts: 8
Matt if you are putting together a hugger group order I'd like to be on it. need Candy Thunder blue!
March 10th, 2011, 08:48 PM | #533 |
The Sportisi Master
Jean it was back burnered again for cbr 250 projects. There are other factors too.
March 10th, 2011, 09:01 PM | #534 |
Join Date: Aug 2009 Motorcycle(s): '09 Ninja EX250J Posts: 177
which rearsets?
March 10th, 2011, 09:07 PM | #535 |
The Sportisi Master
Both styles
March 11th, 2011, 05:43 AM | #536 | |
What size rim and how soon we talking???
March 11th, 2011, 07:11 AM | #537 |
The Sportisi Master
Next gb. Unless you want to work something out pm me.
March 11th, 2011, 11:06 AM | #538 |
Only because I have a 650R rim conversion in progress that I have tons of questions. Let's start we these. Thanks in advance!
1. Any pics available of the rim? 2. Is it the stock spoke design and just wider at the lip where the tire bead seats? 3. Do the stock bearings switch over or is the rim coming with bearings?? 4. Is it raw or is it powder-coated/painted gloss black like stock? 5. Will the sprocket hub remain stock or will it be part of a "kit"? 6. Will the stock spacers remain the same? 7. What about the brake caliper mount? Does it remain stock?
March 11th, 2011, 12:22 PM | #539 |
The Sportisi Master
I will post pics up in abit. Comes with new bearings installed. Stock spoke design. Uses the oem parts off the bike . So no new hub spacers or brackets required. Its Flat black not gloss.
March 11th, 2011, 08:12 PM | #540 |
The Sportisi Master
Rim and then comparison same bt92 150/60 stock rim and new rim
March 11th, 2011, 09:36 PM | #541 |
Join Date: Feb 2010 Motorcycle(s): 2008 Ninja 250R Posts: 36
March 12th, 2011, 06:38 AM | #542 |
Any clearance issues with hugger/swing arm covers?
March 12th, 2011, 07:15 AM | #543 |
The Sportisi Master
Not anymore than there already is. Spacers are needed as with other 150 tires. But there is a new hugger coming out so can't speak to it yet
March 12th, 2011, 11:16 AM | #544 |
Hey, Matt. Got any Sportisi windscreens lying around? I sent a PM. Just wondering if I can add them to my hugger and undertail order.
March 12th, 2011, 06:59 PM | #545 |
The Sportisi Master
only a green one. I am debating on which style to stock up on next.
March 12th, 2011, 07:15 PM | #546 | |
What other style is there? It's the current style that has me interested because it looks a bit like a cockpit window and I want my bike to look like the Blue Falcon, which has a cockpit. Thanks! |
March 12th, 2011, 09:46 PM | #547 |
The Sportisi Master
its a little different the first verison which is still being made is my fav.
March 12th, 2011, 09:49 PM | #548 |
any group orders set up for the huggers matt? I'd like to be on the list....let me know
March 14th, 2011, 06:05 AM | #549 | |
Would gloss black be an option?
March 14th, 2011, 10:11 AM | #550 |
hi matt,
i got the block off plate from Santoso today. gonna install it in the next couple days once i have time to wash the bike 1st... been riding through rain and mud lately... my bike is so filthy again, uff.... lol so another item im kinda interested in; what are a set of those ceramic bearings going for? is that for the engine only, or do they also include the front and back wheel bearings? are the ball baring all ceramic in there? i heard that there are bearings that just have 1 ceramic ball (used in 2 stroke bikes i think?) and the rest are steel. was just wondering how these are... i mean besides them being appealing... thanks and catch you round!
March 15th, 2011, 07:46 PM | #551 |
The Sportisi Master
I have sets for wheels and for the transmission wayan. All ceramic balls Cerbec they are awesome.
March 15th, 2011, 07:49 PM | #552 |
The Sportisi Master
Who wants rear shocks. I will do I group buy at a barn burner price if I can get 10 people to jump on it. I'm talking 40% off one time only.
3way adjustable 320mm.
March 15th, 2011, 08:29 PM | #553 |
My friend wants an '08+ shock for his pre-gen for cheap. Even if they fit, I'm sure these won't be in his price range (~$35), but it may encourage a buyer if they know they have a buyer lined up for thier old part (helps them cover the cost).
March 15th, 2011, 08:39 PM | #554 |
sleeper
Join Date: Nov 2010 Motorcycle(s): '10 250r, '10 690 duke Posts: 558
do you have a website for all of this stuff? the hugger, the shock, the rear wheel,etc??
March 15th, 2011, 08:42 PM | #555 |
The Sportisi Master
hahahaha. whats the title of this tread? I don't have the wheel up there yet. I was hoping to get someone to get one for a write up first in exchange for getting it at cost.
March 15th, 2011, 09:12 PM | #556 |
Whats the price for the shocks for gb?
I might go for one |
March 15th, 2011, 09:13 PM | #557 |
The Sportisi Master
$297
March 16th, 2011, 04:51 AM | #558 |
Interested. PM sent
March 16th, 2011, 10:19 AM | #559 |
meow?
March 17th, 2011, 04:42 PM | #560 |
Hey, Matt. Got an integrated tail light in stock? If so, how much to add to my hugger/undertail order?
Where is Matt from Sportisimoto USA? | samw | Motorcycle-related | 25 | August 18th, 2012 12:50 PM |
Sportisimoto VR Carbon FSE | NathanUc | 2008 - 2012 Ninja 250R Farkles | 12 | July 28th, 2011 08:10 AM |
My Sportisimoto Bodywork | ztrack157 | Motorcycle-related | 6 | May 18th, 2011 02:39 PM |
Sportisimoto BRT Ignitions GB | ztrack157 | Motorcycle-related | 77 | July 27th, 2010 10:36 PM |
Got a big box from Sportisimoto USA today | 2WheelGuy | 2008 - 2012 Ninja 250R Tech Talk | 25 | February 14th, 2010 08:27 AM |
