June 16th, 2013, 08:46 PM | #561 |
Join Date: Mar 2012 Motorcycle(s): Ninja 250r 2010 SE Posts: 573
Thanks but my tuner doesn't think thats the problem, a mechanic also said it don't matter. I'm going to put in the stock cams, airbox and the brt and take it down again by the end of the week. I am waiting for a head gasket atm.
By playing around with the brt we should be able to figure out if I have enough comp. Also he thinks that the cams may be the problem because they have been designed for a stock engine. |
June 18th, 2013, 04:06 PM | #562 |
Board Member
My #1 carb took a poop. So I got a sweet used set off ebay for $130. Best I can tell....one of yhe horrible backfires I received killed it as all new jets and a full cleaning did nothing. Every now and again it cuts in but I'm not going to count on it.
@tubarney how is your stuff coming? Don't you love being pioneers? |
June 19th, 2013, 04:31 AM | #563 |
I received the head gasket today. The stock cams are in and the timing is set. I just got to check clearances. Should be ready for dyno on Friday.
June 19th, 2013, 04:52 AM | #564 |
Board Member
Sweet. My carbs should be in fri or over the weekend. I hope to dyno after a few test runs.
June 19th, 2013, 06:48 PM | #565 |
I had to order shims. I'll have them tomorrow. Dyno will have to wait till Monday morning, unless he going to be open on Saturday.
June 20th, 2013, 05:46 AM | #566 |
Turns out my tuner has shims. I'll be there tomorrow, just finished putting it together. Will post the results.
June 20th, 2013, 08:12 PM | #567 |
Board Member
So after getting new carbs and rebuilding everything again, I come to find out that my Takai coil failed. WTF?
I have the stock coils in and she runs fine and #1 is hot again. However, she is now a bitch to start again? How can it be easy to start on one cylinder and then when I get the other running it is hard again? boy this is something.... |
June 21st, 2013, 12:24 AM | #568 |
why did your coil fail? its probably hard to start because your jetting is wrong.
I couldn't get to the dyno today. I will have to go Monday morning. |
June 21st, 2013, 08:13 AM | #569 |
Board Member
my jetting is as follows right now"
40 pilot 115 mains FP needles 3rd clip air screw set to 2 turns out I have to start the bike with no choke and the idle screw (what moves the plates and changes RPM) set at a point where I get 4000 rpm on setup. I assume that the large need for air means I need leaner jetting, but I was running 40 pilots at 2 turns out before....? I have also retarded my timing back to 10 degrees BTDC which is the same as stock and the BRT units. Any thoughts on the jetting I should be at? I am returning my coil for warranty evaluation....but I will run them when I get it back. |
June 21st, 2013, 04:36 PM | #570 |
Board Member
@tubarney have we lost all interest in this thread? Maybe its because it is taking too long to fine tune and pioneer this level of tuning on a 250? Or maybe it's because of this and that we have not posted the dyno sheets yet that everyone wants to see?
The best I can tell my jetting should have been just fine, but obviously it is not. It seems really weird to me that it would start better on one cylinder with the takai coils then it does on 2 cylinders with a stock set of coils. Does anyone want to weigh in? |
June 21st, 2013, 06:29 PM | #571 |
dirty boy
MOTM - Apr '14
^ i wish i could help but i am probably in no position to offer advice,
But IMO your jetting should be fine for starting the bike unless it is way to rich....which it should not be. I was running my stock engine with pod filters more rich than your current setting and it started just fine. Only trouble i had starting my bike ever was when my pod filter got so wet that it was not pulling any air. Is your vacuum working correctly? My only thought is that you still might have something electrical hiding somewhere, might explain the bad coil. Have you tried each cylinder individually? If so does one start much easier than the other? IDK Just trying to throw some idea's out there. Good luck |
June 21st, 2013, 06:37 PM | #572 |
How are your plugs?
June 22nd, 2013, 02:38 AM | #573 |
I think the problem is that we have so much to the engine that no one can really help us. There are too many variables in the equation.
Also the time it's taken to get these bikes on the road is a joke. Im starting to wish I just left it alone. As far as my nightmare goes, I swapped in a stock set of cams and now my engine makes a ticking noise not like before. I think its the cams because they are out of another engine or cct. I'll swap the beet cams back in a see if it goes away, if not it's either the chain or cct. Then I will put the stock cams from my engine back in. Long story why I didn't put them in the first time. Last futzed with by tubarney; June 22nd, 2013 at 03:55 AM. |
0 out of 1 members found this post helpful. |
June 22nd, 2013, 04:01 AM | #574 | |
You won't harm it by going lean or rich. |
June 22nd, 2013, 05:17 AM | #575 |
MOTM - Sep '18, Feb '16
Don't give up guys.
This stuff is not easy and everything does not just work because you bolted it together. Mike when the engine starts on one cylinder . Which one? Did you swap the coil side to side? Do you use starting fluid to start it? When did it first do the no start thing?
Top speed 123.369mph. Ohio mile Worlds fastest 250 ninja Last futzed with by Racer x; June 22nd, 2013 at 10:12 AM. |
June 22nd, 2013, 05:42 AM | #576 |
Board Member
#2 started right up. #1 was cold. Switching changed this.
Actually I used no starting fluid and she fired right up and that just seemed odd. It has been hard to start all along. I think I will lean out the mj and tighten the air screws .5 and go from there. |
June 22nd, 2013, 06:13 AM | #577 |
is it possible for an new gen cam chain to stretch?
June 22nd, 2013, 06:20 AM | #578 |
Board Member
Yes. Any chain can stretch. That is what originally started me on all this since the case has to be split.
My chain and cct are both new now. |
June 22nd, 2013, 06:31 AM | #579 |
dirty boy
MOTM - Apr '14
the main jet has next to nothing to do with start up and idle
Your idle screws, pilot and needle taper in relation to needle height are primary, The only way the main jet should affect the engine at start up and idle is if your needle is messed up, and or way to high. Are the other needle jets in the carb good? Not the actual needle but the 2 circuits that are directly above the main jet, the cylinder part and the piece that sits on top of it? |
June 22nd, 2013, 06:57 AM | #580 |
Board Member
I had this problem with my carbs and still with my "new" ones with only 1500 miles. I don't think its the carbs but the jets. The question is where to start? I too think that I need help in the starting circuit but wonder which way to go...
June 22nd, 2013, 07:07 AM | #581 |
Board Member
I will turn my pilot screws in to 1 turn out and .5 and 0 and see what happens. My theory is that I am pulling more air (volume) through the same size venturi therefore increasing velocity and actually getting too much fuel. Will post results....
June 22nd, 2013, 08:39 AM | #582 |
dirty boy
MOTM - Apr '14
since you can start with no choke, and choke makes it works, it makes sense that you are to rich on start up... but why. You are either not getting air flow through filter through carbs or that is fine but you are just getting to much fuel.
I would play with screws initially just to see if any adjustment could be noticed. If leaning it out helps then i would set screws back to 2.5, change pilot jet and look for changes. Again adjust idle after look for more changes then adjust pilot accordingly if necessary. I see you have FP needles, i moved to the FP needles after awhile, I started on the 4th clip position which is pretty rich. I ended up on the 2nd clip position with a shim and it is just barely lean 1/8th-1/2 throttle in cooler temps. I probably should be running 3rd clip position it is literally .012" higher on the needle than my current position but it makes a noticeable difference in my bike |
June 22nd, 2013, 09:33 AM | #583 |
Your starter jets were not clogged?
http://www.ninjette.org/forums/showthread.php?t=123000 Hook back up the stock CDI if you haven't and see how the bike runs. How do your spark plugs look? Any fouling? Are you positive that throttle plates are not stuck slightly open with the MP throttle? Choke plunger isn't sticking?
June 22nd, 2013, 09:45 AM | #584 | |
Board Member
June 22nd, 2013, 10:47 AM | #586 |
compressed air and cleaner may not be sufficient at cleaning it out. It's a possibility you could have just packed it in. I had some 22 gauge speaker wire laying around and used a few strands. I twisted it in and out removing the crud slowly each time.
June 22nd, 2013, 12:34 PM | #587 |
Board Member
Would that have made me rich?
June 22nd, 2013, 12:47 PM | #588 |
Board Member
okay here is the report: it started with the pilot screws all the way in. However I still need to have the idle adjustment at about 3000 rpm. The choke, any choke at all, made it die. therefore I think I need at least 38 Pilots if not smaller.
June 22nd, 2013, 02:43 PM | #589 |
Board Member
Ok...38 pilots helped but its still not perfect. I think I will need 35 or smaller. See my post #581....
Given this I may need to stay around stck jetting. Crazy. And I have no restrictions on the amount of air coming in. I think the motor is just pulling that much more. |
June 22nd, 2013, 02:45 PM | #590 | |
Fast-Guy wannabe
MOTM - Jan '13
June 22nd, 2013, 03:06 PM | #591 |
Board Member
I know right, but the results don't lie
June 22nd, 2013, 07:47 PM | #592 |
I had 40 pilots, 3 washers and 115 main. It would bog and stall. It needed no choke. Choke would make it stall.
I switch up to 2 washers and 110 main. I could ride it and start like normal. Main jets and washers effect idle and low throttle settings. keep the 40, change the main and needle position. |
June 22nd, 2013, 08:04 PM | #593 |
I'm trying out a different cct to see if that fixes the noise. If not I will switch the cams back because it was fine before.
It sounds like this. http://www.youtube.com/watch?v=WWvtRoj_iHU |
June 22nd, 2013, 08:36 PM | #594 |
Board Member
when I switched down to the 38 Pilots I also changed the main jets to 100. It does seem to start better but I still need to give it a little throttle end turn up the idle rpm adjustment just a tad.
June 22nd, 2013, 10:07 PM | #595 | |
I found my problem, timing was out. |
June 22nd, 2013, 11:19 PM | #596 |
That solved that problem. Now I can put in the airbox and get it to the dyno on Tuesday. I am busy Monday.
June 23rd, 2013, 05:36 AM | #597 | |
dirty boy
MOTM - Apr '14
You need to be careful as the main jet primarily controls 1/2-WOT throttle and right now you have not had a chance to run your bike with the throttle in those positions therefore you are making changes to a circuit you know nothing about yet Not saying the 100's will be to lean but i would rather be a little cautious as the results of being to rich are not near as dangerous as being to lean the first time you actually crack the throttle wide open. the pilot jet and idle screws are intended to tune Throttle position from idle - 1/8th throttle with some tiny overlap from the actual needle, needle height and it's taper. The needle when set correctly keeps the main jet almost entirely out of the equation at those throttle positions. The needle essentially plugs the main jet circuit and does not unplug that circuit until the throttle is cracked and the needle is lifted. The higher wider parts of the needle control the throttle at 1/8 - 1/2 throttle, the high angle quick taper controls 1/2 - 3/4 throttle and then the straight thin part to the tip works with WOT. I do think your jetting is not perfect obviously for how your bike is currently running but i also think it is potentially the secondary problem. Something else is not working properly and changing the jetting is simply compensating for that problem. ^Just a guess because i can't imagine the bike would be so hard to start otherwise. I think you are running pods filters, right? Did you soak them with filter oil or anything which might prevent air flow? |
June 23rd, 2013, 05:55 AM | #598 |
Board Member
I have a panel filter in a modified airbox.
June 23rd, 2013, 12:18 PM | #599 |
dirty boy
MOTM - Apr '14
June 23rd, 2013, 01:01 PM | #600 | |
Board Member
So based on this tip I plugged back in my stock CDI. She fired up without a hint of issue. Thank you @cuong-nutz Lessons learned on this: 1) don't trust what a "tuner" puts in for a map. The maps loaded by jetting pro had WAY too much advance for idle rpms 2) my "ticking" was actually pinging at idle, this explains why it only went away up at stratospheric rpms Now she runs, starts and sounds like a champ...but I have to fix my jetting so it's back to: 40 pilot 2 turns on the screws 112 mains @tubarney of all those BR-Tis maps you posted, which one are you using? @Racer x which one are you using or what would be a good map? I cannot wait to see how she runs now that I am finally getting to the bottom of all this crap. However, I really do hate working on the carbs while they are in the bike and yes I have special tools. Those CR carbs with the cap on the bottom would sure make this easier. Hmmm? |
Shin's 250r Build Thread | Shintoxica | 1986 - 2007 Ninja 250R Farkles | 3 | August 22nd, 2013 11:10 AM |
My 250R Race Bike Build | icbm | Pictures | 5 | August 16th, 2012 11:06 AM |
Is the ninja 250r the ultimate beginner bike, or should I settle for something else? | Mulholland | General Motorcycling Discussion | 188 | April 15th, 2012 09:28 PM |
[topix.net] - Freestyler Josh Borne guest stars on Discovery's Ultimate Car Build Off | Ninjette Newsbot | Motorcycling News | 0 | June 25th, 2010 07:50 AM |
I want to buy or build an 08+ 250R racer. | Seanslides | Ninjettes At Speed | 20 | March 1st, 2010 07:34 AM |
