Old July 8th, 2015, 08:41 PM   #6721
NevadaWolf
Certified looney toon
NevadaWolf's Avatar
MOTM Jul '13, Jul '14
Changed the oil, cleaned and lubed the chain, lubed the clutch cable, and installed my second hydration bag in my new prototype system.
<-- Linky
Old July 8th, 2015, 08:59 PM   #6722
Hercules Zanzibar!!!
Motorcycle(s): That's a silly question
Adjusted my clutch lever down a smidge; Seafoam'd the fuel, but I don't have a lot of faith it will work. Not a knock against Seafoam, but the bike sat before I bought it (3.5 weeks ago), so I'm thinking a carb cleaning is in order; finally, I cleaned my mirrors!
Hercules Zanzibar!!! is offline   Reply With Quote
Old July 9th, 2015, 06:51 AM   #6723
sharky nrk
Fighting Texas Aggie '05
sharky nrk's Avatar
rode her to work instead of taking a cage
Old July 11th, 2015, 05:57 PM   #6724
cbinker
Track Clown
cbinker's Avatar
MOTM - Sep '15
I removed roughly 5 pounds of wires today that are completely useless now that the bike is my race bike.
TEAM ALFALFA
www.apexassassins.com
Old July 11th, 2015, 08:35 PM   #6725
cuong-nutz
cuong-nutz's Avatar
bought oil and filter. oil still smells like fuel but not as strong as before. I need to replace the rear brake pads. I need to find a good weekend to do my valve adjustment. debating if i should gopro it lol.
HalfFast Racing Team
Old July 11th, 2015, 11:18 PM   #6726
johnydecali
johnydecali's Avatar
Motorcycle(s): '12 Ninja 250r
Fought against the traffic caused by the Doyle Drive closure.
I'm not imperfect. However my imperfections are what creates my value and makes me unique - johnydecali
johnydecali is offline   Reply With Quote
Old July 14th, 2015, 06:30 AM   #6727
The Red Scourge
The Red Scourge's Avatar
Motorcycle(s): '76 Yamaha RD400, '71 Kawasaki G3SS, '88 Honda CBR400RR, '90 Yamaha FZR400/600 hybrid
Drained old coolant and replaced with Engine Ice. Snapped off one of the drain plug bolts in the hole. Luckily Asheville has an awesome specialty bolt place that stocks 6x10mm bolts with the correct thread pattern. I also replaced the gauge cluster bulbs which I've Ben putting off for a while.
"When in doubt, gas it!"
The Red Scourge is offline   Reply With Quote
Old July 15th, 2015, 02:18 PM   #6728
Bob2010
Bob2010's Avatar
HUGE THANKS to Forceofwill
Got a nice surprise in the mail today - all the extra bits I needed and was looking for
Thank you bud !
2010 Red Ninja 250
2009 Black Ninja 250
Old July 16th, 2015, 06:39 AM   #6729
allanoue
allanoue's Avatar
MOTM - Sep '14
Got it to a new top speed. 120! (indicated so actual will be 7% less, calculated to 111?)
Old July 16th, 2015, 09:07 AM   #6730
iamjacob
iamjacob's Avatar
Motorcycle(s): 2011 250R SE
120?!?! Was this going downhill with a 20mph tail wind?
iamjacob is offline   Reply With Quote
Old July 16th, 2015, 09:09 AM   #6731
allanoue
allanoue's Avatar
MOTM - Sep '14
this hill
https://www.google.com/maps/@39.7492...2!8i6656?hl=en
but it was empty
not sure of wind
checked weather, wind was 3 to 6
Old July 16th, 2015, 02:28 PM   #6732
this hill
but it was empty
not sure of wind
Welcome to the dark side of speed, old fart
Old July 16th, 2015, 02:37 PM   #6733
PSA, check the little things first!!
Well, I feel both badass for solving my problem , and REALLY STUPID for having this problem in the first place.
I'm redoing my jetting and was having some weird idle issues. Like idling irregularly at 3000 rpm weird. popping & flames on decel, poor throttle response off the line but fine up top, etc. Equally bad when hot and cold, but overall not something I've dealt with before. So I started doing some research and came to the conclusion that I had a vacuum leak. Great, I just put these hoses on!!! I put my hose clamps on, and the problem persisted, worse even!!!
Ordered some new hose clamps, got the bike torn apart, and found this:
can you spot my vacuum leak?
Turns out I had a baby leak before the clamps, then forgot to connect the hose to the bottom of my coasting enricher, and made the problem worse.
Now that everything is hooked up properly and has proper clampage, it's doing much better.
Old July 17th, 2015, 04:16 AM   #6734
allanoue
allanoue's Avatar
MOTM - Sep '14
I am just an infrequent visitor.
Got a new top speed, 116 indicated. Very close to my old stock 500
K&N air filter and 20,000 more miles on the engine I think got me the extra 4 mph
areaP got me 11 more
Old July 19th, 2015, 06:34 PM   #6735
Sirref
Private Joker
Sirref's Avatar
MOTM - Mar '14
Got and installed my yoshimura rearset bracket adjusters and switched to GP shift, also solved an issue with my swingarm adjuster nuts that was causing them to not hold together on the right side. Ended up replacing the nuts and they hold together just fine now
cleaned, lubed, adjusted chain
double checked everything...I may be in dire need of a new front brake rotor and possibly more but I'll deal with that after my race tomorrow as it's been working fine so far, However the front rotor is overheating like mad on even a regular commute so I think something may be up. I also am in need of tires, my DRII rear is at the wear bars on the left side after only 1,500-2,000 miles (granted a lot of that was track)
Overall life is good and I'm looking forward to racing tomorrow
Old July 19th, 2015, 07:05 PM   #6736
Put the carbs back in after farting around with float height. Also ordered a 40 idle jet because I'm at 3 turns out on 38's and need just a bit more to get a clean revv-down to idle. While I was at it, I cleaned the fairings and wheels, attempted to RTV the valve cover gasket so I stop weeping oil, and contemplated cleaning the chain. Then I ignored the chain because something funny happened.
I had the ninja in the apartment. School apartment, not supposed to do things like this. I have a rando roomie for the summer since I'm in summer housing. Roomie was at his GF's for the weekend. They got back as I was cleaning the ninja. Her reaction when she walked in the door was, "Oh! uhhhhhhhhhhhhhhhhhhhhhhhhh..." and she froze in the doorway with the door open. I looked at her kinda funny and said, "you can come in, it doesn't bite" For goodness sake, I was cleaning a vehicle, not jerking it!!
priceless interaction. Whatever, I'll only ever know the kid for another month. Then I'm with a roommate I actually choose, and then will graduate. Silly non engineering students.
Old July 20th, 2015, 01:07 AM   #6737
Ghostt
Ghostt's Avatar
Relocated the oil cooler down, so it won't block the radiator, still have to fabricate a bracket, for now zip-ties.
violente et ignorantia
ZX-2R BLOG
Old July 20th, 2015, 09:56 AM   #6738
NevadaWolf
NevadaWolf's Avatar
I've gotten really good at swapping bulbs from under the front oddly.
My stepdad noticed that my low headlight had blown, so traded it for the spare I always carry. Then yesterday, bought a new one and moved the high to low and replaced the high with the new bulb.
I do like my Phillips bulbs.
<-- Linky
Old July 22nd, 2015, 01:12 PM   #6739
cadd
cadd cadd cadd
cadd's Avatar
Motorcycle(s): 300
MOTM - May '15
Oil Change. Had a helper. Wasn't much of a helper. Got in the way more than anything.
She made sure I got the correct oil at Walmart though.
I always stick a piece of magnet on all my vehicles' drain bolts (motor oil, tranny, rear diff, etc). Here are the metal shavings that got caught.
Riding it like I financed it.
Old July 24th, 2015, 01:56 AM   #6740
Alvin31
Motorcycle(s): Ninja 300
I installed the Throttle Rocker from Hornig (http://www.motorcycleparts-hornig.co...le-Rocker.html).
End of August I am planning a major tour and I hope that this accessory will help me.
Alvin31 is offline   Reply With Quote
Old July 25th, 2015, 12:20 PM   #6741
cbinker
Track Clown
cbinker's Avatar
MOTM - Sep '15
priming!
TEAM ALFALFA
Old July 25th, 2015, 02:32 PM   #6742
Replaced the fan temp switch with a new one. Fan works now!
Old July 27th, 2015, 07:15 AM   #6743
VaFish
VaFish's Avatar
MOTM - Jan '16
Well it was yesterday, not today,
Cleaned carbs, replaced air cut off valve, aligned clutch plate. So basically took a bike that wasn't running, or shifting and got it moving.
Next up mount the turn signals somehow and run it as a street fighter while I repair a bunch of cracked plastic and replace a handlebar.
Old July 30th, 2015, 11:29 AM   #6744
NevadaWolf
NevadaWolf's Avatar
My Scottoiler has been acting up since my vacation. It was seemingly not oiling while in motion, and once stopped would drip oil into a pool under the sprocket.
Bought a ball valve in the hopes of stopping the flow as was told there is a one way valve that Scottoiler began including in kits for hen or if you install the reservoir way higher than the nozzle.
Installed everything and noticed that the last two feet of hose the oil continued to drain out, but just a few inches above that the oil was still in the hose. Huh? Disconnected everything and pull it out. Well, looky there! A small little hole worn into the hose from the chain.
Tape, heat shrink, more tape and my system works again. Yippee!
Cleaned the chain while I was there, and swapped out the Corbin for the stock seat again. Probably going to do an oil change if I remember tonight since it's been 8000 miles.
<-- Linky
Old August 1st, 2015, 06:53 PM   #6745
After taking the purple off my wheels, I decided to put some purple back inside her
Royal Purple Max-Cycle 10W-40
Old August 1st, 2015, 09:58 PM   #6746
NevadaWolf
NevadaWolf's Avatar
Today I experienced a problem during the ride. No power at all going up hill, ran out of fuel WAY to soon, and a friendly GS rider showed me the soot in my exhaust.
Got home, and went to work. Guess my air filter was not being cleaned during my shop visits and learned where my spark plugs are and how to change them! Putting in some iridium ones.
<-- Linky
Old August 2nd, 2015, 04:30 AM   #6747
^^ has that every been changed, Teri? You have like a million miles on your bike.
I'd go ask some heavy questions about what the shop is charging you for vs what they're actually doing for you. Cuuuuuuz that's a $10 parts that only requires 30 seconds to replace...
Old August 2nd, 2015, 07:25 AM   #6748
NevadaWolf
NevadaWolf's Avatar
I know I have not changed it, nor cleaned it except when I first got the bike.
The shop already burned me where I'm not going back there. So what they did/did not do is in the past and I'll be taking over more of my own maintenance and using a different shop when needed.
<-- Linky
Old August 2nd, 2015, 07:33 AM   #6749
dcj13
Participant
dcj13's Avatar
Motorcycle(s): '94 K75 std
Originally Posted by NevadaWolf View Post
...Guess my air filter was not being cleaned during my shop visits and learned where my spark plugs are and how to change them! Putting in some iridium ones.
That air filter is disgusting! Never seen one that bad.
Good for you for doing more of your own work!
Old August 2nd, 2015, 10:54 PM   #6750
cbinker
Track Clown
cbinker's Avatar
MOTM - Sep '15
put stock front sprocket back on bike, removed rear wheel, ordered new rear sprocket 44(-1 stock) now i have 13 and 14 front, 44, 45, 47 rear.
TEAM ALFALFA
Old August 3rd, 2015, 09:51 PM   #6751
Ghostt
Ghostt's Avatar
Getting ready to do some maintenance, I scored the OEM valve adjustment tool dirt cheap. Also be doing some modifications as well.
Stay tuned......
ZX-2R BLOG
Old August 4th, 2015, 12:53 AM   #6752
johnydecali
Did some preventative care, replaced the battery since the bike has 10k miles and oil change. Ordered a new chain and sprocket that will arrive by the end of the week.
Old August 4th, 2015, 04:33 AM   #6753
Racer x
Racer x's Avatar
MOTM - Sep '18, Feb '16
My bike has been sitting since September. Before putting it away for the winter I drained the cooling system. And changed the oil. Then opened up the carb bowls. (CR carbs)
This weekend I put coolant and fuel in and charged the battery. The bike started right up and is about ready for the dyno. Sept 12 for that.
Worlds fastest 250 ninja
Old August 4th, 2015, 07:52 AM   #6754
allanoue
allanoue's Avatar
MOTM - Sep '14
10k and new chain and sprockets?
Are you going to a different number of teeth?
Old August 4th, 2015, 11:34 AM   #6755
Ghostt
Ghostt's Avatar
Stay tuned......
Valve adjustment complete, and if your gonna keep your Ninjette for awhile, I strongly recommend the valve tool from Kawasaki. All the exhaust valves were too tight, but all the intake valves except 1 was okay.
Still more to do, next up new chain and sprockets.
ZX-2R BLOG
Old August 5th, 2015, 11:55 PM   #6756
johnydecali
going 15/42, we'll see how that goes. if not have a 45t that im going to order just in case.
Old August 6th, 2015, 05:46 PM   #6757
cbinker
Track Clown
cbinker's Avatar
MOTM - Sep '15
Put the stock 14 tooth front sprocket back on and added a 44 tooth rear, just need to finish the painting and the bike is ready for racing!
TEAM ALFALFA
Old August 6th, 2015, 06:03 PM   #6758
Eh, I also got the tool cheap, kinda meh on it, honestly.
Old August 6th, 2015, 09:04 PM   #6759
Ghostt
Ghostt's Avatar
Vortex aluminum, .nice pick for the track. I was looking at vortex but in steel, which I prefer for everyday street use.
As far as the valve tool goes, I agree, but if one can pick one up cheap, and plan to keep the Ninjette for a lot of miles, it's worth it IMHO.
ZX-2R BLOG
Old August 6th, 2015, 10:36 PM   #6760
cbinker
Track Clown
cbinker's Avatar
MOTM - Sep '15
i could tell a significant weight difference from the old sprocket and new sprocket. (holding the sprockets, no riding yet)
TEAM ALFALFA
Discovered something scary about my Ninjette today... kjohng General Motorcycling Discussion 28 October 15th, 2021 01:40 PM
Sold the 2006 Ninjette today :( Renner General Motorcycling Discussion 31 October 16th, 2014 11:46 PM
Today I Gave My Ninjette Wings! BlueHairSar Pictures 5 June 20th, 2013 07:38 AM
my bro went down today on his ninjette richierich781 !%@*#$%!)@#&!%@ I crashed! 46 January 18th, 2013 11:59 AM
Ninjette. org hacked today CC Cowboy Off-Topic 9 April 3rd, 2011 08:55 AM
