Old August 25th, 2016, 04:33 PM   #7601
JohnnyBravo
Certifiable nontundrum
JohnnyBravo's Avatar
MOTM - Sep '13, Sep '16
I love hitting the super slab!!!
Old August 25th, 2016, 05:26 PM   #7602
tfkrocks
tfkrocks's Avatar
MOTM - Jan '18, Sep '13
I'll post this here too cuz I'm excited about it. Yay fox shock. I got a basic set up for it today.
My Ninja 300
Old August 25th, 2016, 08:45 PM   #7603
cbinker
Track Clown
cbinker's Avatar
MOTM - Sep '15
exhaust upgrade!
TEAM ALFALFA
www.apexassassins.com
Old August 25th, 2016, 08:53 PM   #7604
plasmagrid
Motorcycle(s): 2006 Ninja 250
Upgrade to what else?
Originally Posted by cbinker View Post
exhaust upgrade!
Are those pipes a little bigger than the stock?
What are you going to be putting on for the muffler.
Will it be slip on?
plasmagrid is offline   Reply With Quote
Old August 26th, 2016, 06:42 AM   #7605
cbinker
Track Clown
cbinker's Avatar
MOTM - Sep '15
Will it be slip on?
http://areapnolimits.com/home.html
bigger then stock, still looking on what I want to do for a muffler, no slip-on, its my race bike.
TEAM ALFALFA
Old August 26th, 2016, 12:26 PM   #7606
plasmagrid
How much bigger, or rather what is the size you have. I can look can measure mine with my calipers.... Looking at trying to get an idea as I have to have my mechanic make the 2 in 1 pipe and the more info the better.
Old August 26th, 2016, 01:08 PM   #7607
Some information that you're looking for is here:
http://faq.ninja250.org/wiki/Will_a_...it_my_88-07%3F
Work smarter, not harder.
Old August 26th, 2016, 01:39 PM   #7608
JohnnyBravo
exhaust
Looks good
Old August 26th, 2016, 03:58 PM   #7609
cuong-nutz
cuong-nutz's Avatar
Got my inspection finally. I had a memory lapse as to when I did my last one and then found out I couldn't renew my registration. 7 dollars later I'm partially legal to be on the road.
HalfFast Racing Team
Old August 27th, 2016, 07:17 AM   #7610
DEFY
ᗧ•••ᗣ•ᗣᗣ•••ᗣ
DEFY's Avatar
Took the bike to NYST, flagged all day yesterday so during lunch break took it out on the track for a good hour. They ran downtown so got to experience the track backwards lol. Nice and fun time, now need to go and just ride the whole time.
Spoiler for topic:
It might just be the [you] tag
Old September 1st, 2016, 07:25 AM   #7611
sp3ak
Suppose this isn't "today" but rather this week.
Carb rebuild! Bowl gaskets started leaking like crazy. Bought the bike with less than 2,000 miles on it a month ago so with all the sitting it did I should have expected the ethanol to do it's dirty deeds.
It's been a good learning experience though, the 250 Wiki has yet again proven more valuable than gold for me when it comes to working on the bike. Went ahead and threw a couple new spark plugs in as it was only $5 and the tank is already off and I also wiped up the frame and everything that's now exposed.
Hoping to smell smoke today and get the bike back home this weekend!
*EDIT* Smoke has been smelt! Running good, rides good, no sign of leaks, will call this a win.
Last futzed with by sp3ak; September 1st, 2016 at 06:12 PM.
sp3ak is offline   Reply With Quote
Old September 1st, 2016, 10:39 PM   #7612
cuong-nutz
cuong-nutz's Avatar
Performed a valve adjustment in this sweltering Texas heat and humidity. 105 degrees in the shade. I was showering in sweat. Intake aide was all in spec so I left them as-is. Exhaust were all tight so i swapped two of them and replaced two. Also replaced the plugs with iridiums. I also found out my rear brake pressure sensor is dead and it isn't a wiring issue as I hoped it would be. I also noticed that my Apex fittings are rusting.
My Harbor Freight battery operated drill crapped out. The battery is done. I was trying to drill for my crash cage. Oil change tomorrow.
Old September 2nd, 2016, 08:42 PM   #7613
daverdfw
had to fix my fairings after my lowside, So added the green color. was all black before
daverdfw is offline   Reply With Quote
Old September 4th, 2016, 02:51 AM   #7614
NevadaWolf
Certified looney toon
NevadaWolf's Avatar
MOTM Jul '13, Jul '14
I'll post more tomorrow (today?) but I did this ..
<-- Linky
4 out of 4 members found this post helpful.
Old September 5th, 2016, 08:34 AM   #7615
tfkrocks
tfkrocks's Avatar
Bixenon projectors! I am very happy with the increased light output
My Ninja 300
Old September 6th, 2016, 05:00 PM   #7616
iamjacob
iamjacob's Avatar
Motorcycle(s): 2011 250R SE
Put on a new set of grips, washed and serviced ma chain.
iamjacob is offline   Reply With Quote
Old September 6th, 2016, 05:11 PM   #7617
mgentz
Board Member
Those are good grips.
Old September 6th, 2016, 06:57 PM   #7618
snot
sammich maker
snot's Avatar
MOTM - Apr '15
Got my new brake lines... I will put them on in a few weeks.
Old September 6th, 2016, 09:03 PM   #7619
JohnnyBravo
Did a burnout on the wet pavement... Needs a new tire anyhow
Old September 6th, 2016, 09:47 PM   #7620
Bob2010
Bob2010's Avatar
Removed the remote controlled LED kit that was installed by a car audio shop before I owned the bike.
Lost the fob years ago. No markings on the kit. No one could tell me jack about the replacement.
Installing new led strips. Flexible ones. More leds. Single color - red.
Now my issue is - the switch. I cannot find a small diameter rocker switch like what is on my 2009.
2010 Red Ninja 250
2009 Black Ninja 250
Old September 7th, 2016, 05:26 AM   #7621
Dave Wolfe
CCS Amateur #501
Dave Wolfe's Avatar
Motorcycle(s): '09 250 SE 'Booger'
Replaced a handlebar mount bolt I lost at trackday. I also locktite'd all 4 of 'em.
Next up is cutting kicksyand mount & new exhaust & rearset plates so I can lean wayyyy over.
Dave Wolfe is offline   Reply With Quote
Old September 7th, 2016, 07:20 AM   #7622
Bob2010
Bob2010's Avatar
To be continued
2010 Red Ninja 250
Old September 7th, 2016, 11:08 AM   #7623
CaliGrrl
CaliGrrl's Avatar
Motorcycle(s): Ninja650
Well, not "today" but this past weekend:
Put 250 miles on her odo with the local group, and lubed the chain. I thought it had been a long time since I did that, but looking at my records, it was right on schedule. Good thing I keep notes.
Old September 7th, 2016, 02:12 PM   #7624
Bob2010
Bob2010's Avatar
Continued here - https://www.ninjette.org/forums/show...=109816&page=2
2010 Red Ninja 250
Old September 7th, 2016, 10:58 PM   #7625
Abu_Mishary
The Asian Caucasian
Abu_Mishary's Avatar
Name: Abu Mishary Mohd Fairus
Motorcycle(s): Kawasaki Ninja 250 SE 2015 (sold); Honda ADV160 (current)
MOTM - Jan '17
Got this today via ebay!
Can't wait to reverse shift!
But need to get a new rearset first... lol..
Wohooooooo!!!!
Losing someone is not painful. They are a part of us all this while and will always be with us. But missing them is.
Abu_Mishary is offline   Reply With Quote
Old September 8th, 2016, 09:44 PM   #7626
cbinker
Track Clown
cbinker's Avatar
MOTM - Sep '15
Tach and lap timer mounted!
TEAM ALFALFA
Old September 9th, 2016, 08:13 AM   #7627
cuong-nutz
cuong-nutz's Avatar
Installed Impaktech stunt cage. What a pain. It's going to be more of a pain just to do simple maintenance when I pull the fairings to check valve clearances and carbies.
So far I've been banging my shins up against it since the bars do not hug the body line.
Old September 9th, 2016, 03:53 PM   #7628
JohnnyBravo
Took it on a fun run right quick
Old September 12th, 2016, 01:12 PM   #7629
Flying
Took the forks out and knocked off bits of surface rust with a brass brush.
Anyone have any tips for getting the fork cap + snap-ring out? I cracked my back trying to push the top in with a socket.
Old September 12th, 2016, 01:51 PM   #7630
allanoue
allanoue's Avatar
MOTM - Sep '14
your so bad
Old September 12th, 2016, 03:23 PM   #7631
Bob2010
Bob2010's Avatar
Ran 3.2 gallons of 91 ethanol free gas.
See I was out in the country and my gauge said E but I only traveled 175 miles.
So I proceeded to find gas and all I could obtain was the 91. Then it only took 3.2 gallons. So my fuel gauge is totally whack. I filled it pretty close to the metal brace that hangs below the fill hole.
Needle says just over 3/4 full. Wonder if I should pull the needle and stick it up on F to calibrate it. Otherwise it's pretty useless. Just lets you know there is some gas in there lol
Another 70 miles on the ethanol free and it seems to run just as good. Maybe a little bit less popping on the de-accel
2010 Red Ninja 250
Old September 12th, 2016, 03:29 PM   #7632
Snake
Snake's Avatar
They sell ethanol free gas here as well but it's expensive. Close to $3 a gallon.
Old September 12th, 2016, 03:49 PM   #7633
Bob2010
Bob2010's Avatar
Yup that's what I paid. $3.01 /g
Not sure if it's a farm-thing but i only found one small station with gas or diesel
2010 Red Ninja 250
Old September 12th, 2016, 07:24 PM   #7634
psych0hans
psych0hans's Avatar
I used a bearing puller and a hex socket while the forks were still on the bike to push the fork caps far enough to get the circlips out. Not easy, but doable. Be careful that the puller grips lock on properly on the top triple, or it might lead to disaster
Old September 22nd, 2016, 11:31 PM   #7635
Ghostt
Ghostt's Avatar
Ordered new chain and sprockets, old chain has stretched almost out of adjustment.
On other news I'm planning on attending the Steel Horse Stampede in Burksville, Ky on Sunday, should be a great time.
http://www.steelhorsestampedeky.com/
violente et ignorantia
ZX-2R BLOG
Old September 23rd, 2016, 01:26 AM   #7636
Abu_Mishary
The Asian Caucasian
MOTM - Jan '17
Changed new sets of rubber today. can't wait for the next track day!
Old September 23rd, 2016, 04:49 AM   #7637
Dave Wolfe
CCS Amateur #501
Dave Wolfe's Avatar
Installed yoshi rearset adjusters and ordered a knox back protector for the next track day.
Old September 23rd, 2016, 01:21 PM   #7638
Ghostt
Ghostt's Avatar
SERENITY got some new sneakers today, Kenda K671s.
Went to the local tire shop, Highway 90 Tire Shop, asked the owner if he does motorcycle tires, he said NO! Then I asked if he would let me use his tire machine, and I would do them myself.
He said sure, but he wasn't going to be responsible for any damages, etc... I agreed, having done a lot of tires over the years, I did them myself using his machine, with a little help from from one of his employees.
Took about 10 minutes tops, and he only charged me $10!!! for the use of his machine, I also tipped the employee whom help me $5.
So for a total of $15 it's done, keeping in mind that motorcycle shops rape you on what the charge to do tires, I'm calling this a win.
Also installed the Dynabeads while I had them off.
ZX-2R BLOG
Old September 24th, 2016, 04:54 PM   #7639
VaFish
VaFish's Avatar
MOTM - Jan '16
Re-connected the speedometer cable that came loose on my sons bike. Replaced chain and sprockets on mine, as I was putting the rear wheel back on I knocked the brake pads loose. Ooops not much pad left. Called the local stealership, they didn't have any in stock. Called the next closest, the said they had one set left, hopped on the daughters Harley and picked up the pads, came home and they are front pads, not rear. It was 10 minutes to 5 and stealership closes at 5. So my bike will sit for a few more days until I can get the correct pads.
So then I installed a crash bar on my daughters Harley.
Old September 25th, 2016, 08:55 AM   #7640
Bk834
Motorcycle(s): 07 Ninja 250 Cafe Racer
Installed an adjustable clutch perch, from an low mileage 06 EX500. As well as a short clutch lever. Makes clutching easier and faster for me without having to reach my fingers out fully extended to grab the lever and disengage the clutch like the stock 250 lever. Also got my AGV leathers in finally. Time to hit the super slab.
'07 Ninja 250 Custom Cafe Racer
Bk834 is offline   Reply With Quote
Discovered something scary about my Ninjette today... kjohng General Motorcycling Discussion 28 October 15th, 2021 01:40 PM
Sold the 2006 Ninjette today :( Renner General Motorcycling Discussion 31 October 16th, 2014 11:46 PM
Today I Gave My Ninjette Wings! BlueHairSar Pictures 5 June 20th, 2013 07:38 AM
my bro went down today on his ninjette richierich781 !%@*#$%!)@#&!%@ I crashed! 46 January 18th, 2013 11:59 AM
Ninjette. org hacked today CC Cowboy Off-Topic 9 April 3rd, 2011 08:55 AM
