Old June 29th, 2017, 03:02 PM   #7801
Put the exhaust on. Might be a tight fit with the fairing, who knows?
Airbox, chain, carb cleaning, caliper service, add coolant, change oil all coming next.
Old June 29th, 2017, 06:27 PM   #7802
Ghostt
Ghostt's Avatar
So the other day when I was swapping out the 30s with the 32s carbs, when I was hook up my hand vacuum pump, to prime them, I did notice that it wasn't holding a vacuum.
So it's time to rebuild it, I heard that K & l Supply now offers a kit for the 88~07, as apposed to ordering 2 kits. So I ordered it (Part # 18-2702) and it's true.
So if you need to rebuild your fuel shut off valve, your all set with one kit.
Side note :ive updated the Wiki on Ninja 250 Riders Club to reflect this.
https://faq.ninja250.org/wiki/Rebuil...tcock/fuel_tap
violente et ignorantia
ZX-2R BLOG
Old June 29th, 2017, 10:25 PM   #7803
CaliGrrl
CaliGrrl's Avatar
Motorcycle(s): Ninja650
With assistance, changed out my shock. We didn't set up the pre-load yet (set one click from the lightest setting), it was getting dark and blood sugars were crashing all around, but even so, it's better than it was.
Bike's back on the road!!!!!
Old June 30th, 2017, 06:12 AM   #7804
Ram Jet
Ram Jet's Avatar
Thanks Ghost, that's good to know since a replacement petcock costs about $90.00.
Bill
Old June 30th, 2017, 06:14 AM   #7805
Ram Jet
Ram Jet's Avatar
Do you have to remove the shock to adjust the preload?
Bill
Old June 30th, 2017, 09:13 AM   #7806
CaliGrrl
CaliGrrl's Avatar
Bill
Doesn't look like it. There's a ring that looks like it will turn and click into the next notch. We'll see.
Old June 30th, 2017, 09:22 PM   #7807
KikRox
KikRox's Avatar
Motorcycle(s): 2011 Ninja 250r se
synced my carbs bang on the finally nailed down a richer version of the stock idle mixture settings, then took it for an abusive high rpm ride out front, me and my ol nag almost got creamed by a person passing. here is a photo
KikRox is offline   Reply With Quote
Old June 30th, 2017, 09:25 PM   #7808
mgentz
Board Member
Bench shimmed my cylinder head after the rebuild
Old July 1st, 2017, 05:42 AM   #7809
New sprockets. Old chain cut off. Carbs cleaned (shinyyyyyyyy). New air box, cut the battery box off, put a new UNI drop in filter in, cut open the intake lid, and plugged the cali hole in the side because I'm not using no KLEEN air system!
Carbs gotta go back in, I still need to figure out the radiator, I have a new chain ready to go thanks to Corey Beth, and then it's just some PM work like brakes and coolant and maybe a uni track service even though my mileage isn't very high.
Can someone do me a huge favor so I don't have to search a bunch...? Can I get a picture of the front sprocket, washer, and lock nut on a newgen? Just want to make sure I get them all on there facing the right directions
I also need to find all the torque values for the new stuff I'm putting on from the newgen and/or wing it based upon the pregen values
Old July 1st, 2017, 03:43 PM   #7810
cbinker
Track Clown
cbinker's Avatar
MOTM - Sep '15
got some new goodies for next race season!
TEAM ALFALFA
www.apexassassins.com
Old July 1st, 2017, 04:33 PM   #7811
Ram Jet
Ram Jet's Avatar
Nice looking rear-sets. Be aware that rear-sets usually get badly broken in the event you dump your bike. At least most do.
Have fun'
Bill
Old July 1st, 2017, 07:18 PM   #7812
cbinker
Track Clown
cbinker's Avatar
MOTM - Sep '15
Have fun'
Bill
and bent and twisted, these are my second set, just like the body work.
TEAM ALFALFA
Old July 1st, 2017, 07:42 PM   #7813
Ram Jet
Ram Jet's Avatar
Good man. A veteran!
Bill
Old July 4th, 2017, 11:20 PM   #7814
Ram Jet
Ram Jet's Avatar
Originally Posted by Rosie View Post
Couldn't take her to work today due to the fact I had a customer meeting and had to drive myself and my manager to the customer site, but I walked past her and petted her
Tell your manager to buy a bike or loan your manager a helmet. You need a manager?You must be a "wild child".
Old July 4th, 2017, 11:24 PM   #7815
Ram Jet
Ram Jet's Avatar
2007 250
Installed new rear brake pads, adjusted fork oil level, checked tire pressures, and bled the front brake.
Bill
Old July 5th, 2017, 09:42 AM   #7816
Sold the last of the Ninja 250s - the Ninja Beater - yesterday.
Looked bad, but ran good. Sonic Springs, Pirelli tires, New Gen shock, adjusted and tuned.
My oldest boy rode it for almost 4 years and a couple sets of tires. Commuted on the hwy about 75 mi to and from school on occasion, and rode it like a Supermoto for the most part.
He's saving his money for a XR650R that will eventually be a Supermoto.
Still have 1 Ninja left (youngest boy), but it's a 500, and is for sale. He's looking to go 600. I've got a couple SVs and a few vintage bikes, so I'm good for now - but you never know.
Old July 5th, 2017, 04:43 PM   #7817
Chain on, thanks to CB!!!!
Also air box modified and carbs on.
Old July 6th, 2017, 11:18 PM   #7818
algs26
Motorcycle(s): ex300, gave up looking for a 250
Installed some Vesrah RJL/JL pads.
It was so hot the hand tools were almost burning my hands.
Showered and went to Rita's to get Italian ice afterwards.
algs26 is offline   Reply With Quote
Old July 7th, 2017, 02:18 AM   #7819
Ram Jet
Ram Jet's Avatar
It must have been worse in So. Cal.
Bill
Old July 7th, 2017, 03:54 AM   #7820
mgentz
Board Member
Installed the head and everything else. Got her started again!!! Now, chasing a carb or other issue where she dies at idle.
Old July 7th, 2017, 06:43 AM   #7821
Ram Jet
Ram Jet's Avatar
You may want to get Ducatiman involved with a carb rebuild. He really doesn't rebuild your carb - he remanufatures it.
Bill
Old July 7th, 2017, 08:46 AM   #7822
mgentz
Board Member
Bill
This is probably just a float level adjustment away. No cleaning needed yet, I would feel 100% comfortable eating out of my carbs....but that would make them dirty.
Old July 10th, 2017, 01:06 AM   #7823
djerwin02
Motorcycle(s): ninja 300
Installed my new brake pads. I also ordered new tires at 4wheelonline.
djerwin02 is offline   Reply With Quote
Old July 13th, 2017, 08:23 AM   #7824
A.J.
A.J.'s Avatar
Motorcycle(s): 2001 Kawasaki Ninja 250r(SOLD) 2006 Kawasaki Ninja 250r full Muzzy(my pride and joy)
Went to the shop where she's awaiting her new engine parts got everything but the head gasket and cylinder base gasket. Anyway had to finish off the replacement air box that was missing a few key pieces. Put the new lid on and installed the rubber strap that holds the battery and airbox in place. Got both pieces off eBay cheap. Lid came off a '98 strap was brand new. Oh the joys of the little things. She will be getting her new heart next week. Holed a piston. New pistons are in. Problem that caused it has been addressed. I get to help rebuild her to cut labor costs and I'm super excited. My first engine rebuild and what I'm about to learn and experience can't be measured. Even bought a notebook solely for this project. After next week I will have the knowledge to rebuild a top end
"A car or truck will get you from point A to B. But a motorcycle, that is the point." -unknown
A.J. is offline   Reply With Quote
Old July 15th, 2017, 03:27 PM   #7825
KikRox
KikRox's Avatar
Took it for a savage blast, and bought her a new set of pirelli diablo rosso II's.
They should give me my own section called kik rox is a silly **** who breaks stuff.
Old July 16th, 2017, 01:17 PM   #7826
Dave Wolfe
CCS Amateur #501
Dave Wolfe's Avatar
Motorcycle(s): '09 250 SE 'Booger'
Modded my razor pit scooter with a big pimmpin 80t sprocket. Now it will take me up small hills.
Still tryin to figure out how to mount my go pro knock off on my upper triple clamp.
Dave Wolfe is offline   Reply With Quote
Old July 16th, 2017, 07:17 PM   #7827
Drill a hole and tap it. Seems over half, maybe even 80% of yellow-flags are due to someone destroying their GoPro/knock-off. Every one of those dumped on track, is because they used double-sided tape.
Old July 16th, 2017, 07:44 PM   #7828
Dave Wolfe
CCS Amateur #501
Dave Wolfe's Avatar
I went to Lowes and picked up a piece of 1/8" aluminum about an inch wide. One end is bolted to one of the holes for the orig handlebars, the other end sticks up in front of triple and holds the camera mount. It'll be stuck with double stick and also get wrapped with something so it wont peel off.
My race club requires tethers for cameras.
Old July 18th, 2017, 08:44 AM   #7829
maverick9611
"a legend in my own mind"
maverick9611's Avatar
MOTM - Feb '18
starting fuel gauge to fuel tank/mileage test. just got the exploited ninja back together
"trying not to get old"
Old July 23rd, 2017, 11:05 AM   #7830
A.J.
A.J.'s Avatar
I had a major job today. Those little 250r decals put on Lucy. Phew that was a lot of work.
Uncle @Ram Jet what do you think?
Old July 23rd, 2017, 11:08 AM   #7831
A.J.
A.J.'s Avatar
Effing beautiful bike
Old July 23rd, 2017, 11:44 AM   #7832
Ram Jet
Ram Jet's Avatar
Very cool. I want a set. Too bad the "250" wasn't in silver. If you think that was tough wait till you do your first valve adjustment.
Bill
Old July 23rd, 2017, 11:55 AM   #7833
A.J.
A.J.'s Avatar
Bill
UB I'm skeered lol
No more decals. I like clean looking bikes. However those tank pads look pretty cool.
Yay or nay?
Old July 23rd, 2017, 04:05 PM   #7834
Ram Jet
Ram Jet's Avatar
UB I'm skeered lol
Yay or nay?
Yay. They look factory installed - classy and understated. I got rid of the Kawasaki and the "Ninja" on the upper fairing. I'd get rid of the flames on the chin spoiler, side covers and tail section too but that involves too much repainting. Where did you get them?
Bill
Old July 23rd, 2017, 10:14 PM   #7835
Yeah! I'm going to paint my street250 to match that! Perhaps witha brighter red... Ferrari Charro Rosso red...
Old July 24th, 2017, 10:31 AM   #7836
Ghostt
Ghostt's Avatar
Starter solenoid started to get wonky, new one is on its way.
Changed the oil, pretty boring day LoL
ZX-2R BLOG
Old July 24th, 2017, 11:44 AM   #7837
Ram Jet
Ram Jet's Avatar
How can you tell when your starter solenoid is getting wonky. Just so I'll know when it happens.
Thanks,
Bill
Old July 24th, 2017, 12:00 PM   #7838
<click> <click> no spinning?
I'm getting high-speed spinning, and raspy sounds. Starter-clutch is either not engaging or I've got stripped gears....
Old July 24th, 2017, 12:15 PM   #7839
Ram Jet
Ram Jet's Avatar
It's most likely you have a starter clutch problem. I wonder what's involved with repairing that little devil.
Bill
Old July 24th, 2017, 12:25 PM   #7840
Ghostt
Ghostt's Avatar
Thanks,
Bill
Easy enough, I hit the button, click, click, then I take a screwdriver and short out the solenoid across the two poles, and it cranks over just fine.
Hence the solenoid is going bad, most likely it's not the battery because it's reading fine. The battery is on its 4th season, so it could be going as well, but the solenoid is a lot cheaper than a battery.
I'll be sure to report how it turns out.
ZX-2R BLOG
Discovered something scary about my Ninjette today... kjohng General Motorcycling Discussion 28 October 15th, 2021 01:40 PM
Sold the 2006 Ninjette today :( Renner General Motorcycling Discussion 31 October 16th, 2014 11:46 PM
Today I Gave My Ninjette Wings! BlueHairSar Pictures 5 June 20th, 2013 07:38 AM
my bro went down today on his ninjette richierich781 !%@*#$%!)@#&!%@ I crashed! 46 January 18th, 2013 11:59 AM
Ninjette. org hacked today CC Cowboy Off-Topic 9 April 3rd, 2011 08:55 AM
