July 25th, 2014, 12:23 AM | #41 |
Join Date: Feb 2014 Motorcycle(s): Rebel 250s, Ninja 250s VN750s (currently nine total) Posts: 465
Good suggestion!
July 25th, 2014, 09:14 AM | #42 |
Join Date: Apr 2014 Motorcycle(s): 2003 Ninja Cafe Posts: 56
Update* replaced the gasket on the drain plug with a rubber one and there is no no more leaking. Now to just get my radiator to work....
August 19th, 2014, 01:30 PM | #43 |
If you are talking about the aluminum crush washer, it is supposed to be replaced every time anyway, though you can get away with reusing it every now and then.
August 30th, 2014, 03:19 PM | #44 |
So update. I replaced the chain, did the friction and steel plates of the clutch and the clutch springs just now. Although I think it may be sticky and when I change into first gear it isn't doing anything when I release the clutch lever and apply any throttle. HELP!!! also still leaking oil.... -.-
Also when tightening down the bolts holding the clutch springs I did not have a torque wrench and simply tightened it down. is it possible that tightening it down too much is causing the problem with it not going into gear? |
August 31st, 2014, 06:57 AM | #45 |
Join Date: Jul 2014 Motorcycle(s): 2006 Honda ST1300, 2001 Ninja 250 Posts: 53
If it was working before replacing the plates and springs, and now it is not, I would definitely go back in and use a torque wrench. I always use a torque wrench on important parts on the bike. It is very difficult to "judge" the correct torque. If you have a Harbor Freight Tools store close by, they have decent torque wrenches for about $10.
As for the oil leak, the drain plug is not supposed to have a rubber o-ring. It is supposed to have an aluminum crush washer.
Current vehicles: 2001 Ninja 250, 2007 Honda ST1300, 2013 Mustang GT, 1998 Firebird convertible, 2003 Jeep Grand Cherokee |
August 31st, 2014, 01:58 PM | #46 |
Join Date: Sep 2013 Motorcycle(s): 2006 Ninja 250, 2004 Buell XB12s, Honda 110 Elite Posts: 332
The clutch pressure plate is installed incorrectly. There is a "dot" on the pressure plate, and a "Dot" on the clutch basket that have to align, or the pressure plate will not grip the plates. VERY common reassembly error on a Pre Gen.
Take the pressure plate off and look at the back side, it is pretty easy to figure out.
"They don't pay me enough to ride this thing!" Kenny Roberts after winning the Indy Mile on the TZ750 powered Grand National bike. |
August 31st, 2014, 07:48 PM | #47 |
You were right, I got it all sorted out, thanks for the tip! Also took the time to rebuild the carbs and clean then out and holy hell you wouldn't imagine the gunk and rust residue in the sink and we'll everywhere... cleaned it out and it runs like new!
August 31st, 2014, 08:22 PM | #48 |
September 1st, 2014, 02:28 PM | #49 |
Alright so I have replaced everything to no avail to get the fan to work. Replaced the fan, water sensor, thermostat, thermostat switch, the fuse is good and I can only think wiring must be the cause. Does anyone know where I can find a wiring diagram or can you post a pic so I can take a look and try to figure this out, its too warm this summer to ride without a fan... my coolant has been reaching 220 in stopped traffic which is not okay...
September 1st, 2014, 03:13 PM | #50 | |
Have you applied power directly to the fan to make it spin? That would confirm the fan is working. Temporarily, you could wire a switch in to manually turn it on until you have isolated the problem. Use an Ohm meter to check wires between connectors. You have confirmed the level of the coolant (when cold) in the radiator is correct - right? If you've emptied the cooling system you can easily get air pockets that will disrupt cooling and possibly the temp sensor. |
September 1st, 2014, 03:24 PM | #51 |
Coolant levels are fine, I will get back to you about fan operations after further testing, thanks for the information!
September 2nd, 2014, 10:08 AM | #52 |
So after testing everything i learned the problem was not related to any of the parts. I am using a trail tech vapor and the temp sensor for the coolant fluid is located in the hose between the thermostat (above the engine) and the radiator, where you insert radiator fluid. The reading on my trail tech reaches 215 *F before the fan turns on. That is why i thought it was not working.. i had checked the fan everytime when it read below 200... Is 215 really hot for that area of the hose?
Also after cleaning out my carb i had to readjust the air mixture screw (the one located underneath each carb. I currently have them set out 3 full turns, is going out further leaning or richening it out? i don't want to run it too lean and fry a piston or my engine. Also in order to start my bike cold i have to not only pull the choke all the way out but also give it some gas in order for it to start... Current carb settings are Stock pilot, and main jets, needles are raised with a few very thin washers, and 3 turns out on the screws for each. I only ask about carb tuning because at idle my bike reached 215 (coolant fluid) and the fan kicked in. it's about 80 degrees here and i feel that it shouldn't get that hot idling Last futzed with by Caliboy2010; September 2nd, 2014 at 11:36 AM. |
September 2nd, 2014, 12:59 PM | #53 | |
Because you need to open the throttle to get it started, it may be too rich. Turn the screws in 1/2 turn and see if it's better, if so, go anther 1/2 in and see if that made it even better. Carb tuning is a lot of trial-and-error. Make an adjustment, then determine if you made an improvement or not - if not go back the other way. You may also not need full choke when starting in that temp range. As far as reaching 215 when idling - is that after running a while? When you are moving you are getting cooling. When you are stopped you are not. That's why the fan kicks on - to move air through the radiator when you are not moving. I would check a few things. Is the coolant mixed 50/50? Is the thermostat correct? |
September 2nd, 2014, 01:27 PM | #54 | |
September 2nd, 2014, 01:42 PM | #55 | |
Maybe someone here can tell us if that temp range (205-215) is the normal operating temp. I'm thinking it probably is. I regularly see 210 or so on my SV650. Fan doesn't turn on until over 220 (so I'm told, never had it run that I know of). |
SOS: Help Removing Rear Axle Boly | The_Otter | 2008 - 2012 Ninja 250R Tech Talk | 27 | September 6th, 2013 11:21 AM |
New definition for SOS | ai4px | Off-Topic | 4 | April 20th, 2013 05:48 PM |
SOS - Shimmed needles now idle is messed up | dznuts | 2008 - 2012 Ninja 250R Tech Talk | 5 | March 6th, 2011 12:44 PM |
Need quick advise, help, SOS | Cab305 | General Motorcycling Discussion | 18 | April 4th, 2010 06:23 PM |
