January 20th, 2015, 06:23 AM | #41 |
dirty boy
MOTM - Apr '14
if you are going that far I see no reason to stick with the stock carbs, seems kinda silly
JMO
January 20th, 2015, 08:18 AM | #42 |
Join Date: Jan 2012 Motorcycle(s): Race bikes:08 Ninja 250,11 R6,16 ZX6,SV650.3 HD-1947,2-2003,2010. 1946 Indian and a lot of dirt bikes.2 Posts: 999
I only discussed the internals of the engine as far as the build is concerned. The carbs will add another $400 to the build and although not necessary will most likely benefit the package. If I had the fuel curve graph from the dyno runs you would be able to see that in the upper RPM range the stock carbs went rich. I attribute that to the air bleeds in the carb mouth being to small. You still have to be impressed with what was done with the stockers, or not. If the latest version makes it past the overheating issues it will get different carbs. Stay tuned.
January 20th, 2015, 08:25 AM | #43 | |
Add to the list stronger clutch springs. Although they don't advertise it Barnetts replacement springs are stiffer. |
January 20th, 2015, 08:26 AM | #44 | |
Fighting Texas Aggie '05
January 20th, 2015, 08:45 AM | #45 | |
dirty boy
MOTM - Apr '14
my comment was more directed at Corksil
January 20th, 2015, 09:54 AM | #46 |
My point was that you can always install carbs after the build with relative ease. What I think in my head never seams to make into my post.
January 20th, 2015, 10:30 AM | #47 |
Join Date: Apr 2011 Motorcycle(s): 2015 636 ABS - 69 Honda 305 Posts: A lot.
Or just switch it over to the 300's EFI while your at it
January 20th, 2015, 11:02 AM | #48 |
MOTM - Sep '18, Feb '16
I was amazed what I got from the stock carbs. I absolutely love my CR specials but unless you are pulling so much fuel and air the carbs are the restriction there is not much to gain. Except the ability to change jets and needles in seconds. One thing also with the special carbs a good set of needles and pilot main and air jets will add up to 300 dollars real quick.
January 20th, 2015, 11:18 AM | #49 |
January 20th, 2015, 06:05 PM | #50 | |
January 20th, 2015, 08:13 PM | #51 |
So... Are weiso pistons of quality that should be worried about? I've read conflicting things and can never remember who on ninjette has had what experience with them.
January 21st, 2015, 08:58 AM | #52 |
I used the Wiesco pistons in mine and had the same head interference issues that Racerx did. I just used a die grinder and surface prep disc to remove the necessary material.
January 22nd, 2015, 11:22 AM | #53 | |
Thanks.
Just batshit crazy. All his posts are endless diatribes. Some are actually entertaining but mostly batshit crazy. |
January 22nd, 2015, 07:30 PM | #54 |
Maybe .030". There is an excess of material in the area that hits.
January 28th, 2015, 10:31 PM | #55 |
Careful hands with a dremel and a scale to double check that the same amount of material/weight has been removed from each piston to keep the crankshaft balanced?
This build is becoming a reality, almost ready to order parts.
January 28th, 2015, 11:17 PM | #56 |
Join Date: Jan 2015 Motorcycle(s): 1999 Triumph Legend "Arwen", 2006 Ninja 650 "Matsuo Hotaru". 2010 Ninja 250 "Firefly" - sold. Posts: 338
And add a turbo.
Screw the inscrutable, eff the ineffable. |
[motorcyclenews.com - news] - Who said retirement had to be boring? | Ninjette Newsbot | Motorcycling News | 0 | March 19th, 2014 01:40 PM |
First freeway ride...kinda boring actually | YORCHI | Ride Reports | 20 | August 30th, 2011 11:33 AM |
Most Boring Intro Thread Ever. | Jakester9500 | New Members | 15 | February 24th, 2010 02:40 PM |
My first commute to work - boring i know. | karlosdajackal | Ride Reports | 9 | October 17th, 2009 01:59 PM |
[ama directlink] - Very Boring Rally should be anything but | Ninjette Newsbot | Motorcycling News | 0 | July 31st, 2008 01:28 PM |
