Old April 18th, 2016, 06:27 PM   #41
mgentz
Board Member
how's it coming @bruce71198?
Old April 19th, 2016, 03:43 PM   #42
bruce71198
bruce71198's Avatar
With my con rods complete I got the 67mm piston in the cylinder without it protruding. Working on squish and comp. ratio tonight
[IMG][/IMG]
Old April 19th, 2016, 04:22 PM   #43
Racer x
Racer x's Avatar
MOTM - Sep '18, Feb '16
Wow.
That is perfect. Pointy high top pistons are problematic in controlling detonation. Those look fantastic.
If the bigger valves hit the cylinder walls you can notch the walls above the ring travel.
Worlds fastest 250 ninja
Old April 19th, 2016, 08:23 PM   #44
mgentz
Board Member
What block is that?
Old April 20th, 2016, 04:42 AM   #45
HoneyBadgerRy
HoneyBadgerRy's Avatar
It appears to be an all aluminium block like the ninja 300, but I don't think they made rings that will mate up to a chrome plated block over stock bore?
Old April 20th, 2016, 09:57 AM   #46
bruce71198
bruce71198's Avatar
What block is that?
In due time....
Old April 20th, 2016, 03:06 PM   #47
Racer x
Racer x's Avatar
I think I know but will not say.
Old April 20th, 2016, 03:18 PM   #48
RacinNinja
Vintage Screwball
RacinNinja's Avatar
MOTM - Mar '16
It's liner-less.....that should tell you everything you need to know.
Goin' fast on slow bikes!
Old April 20th, 2016, 04:17 PM   #49
HoneyBadgerRy
That OP had a custom all cast iron block machined for him? /S.
On a serious note, he either had custom rings made, that block is just for a test, or he is doing something wrong.
Old April 20th, 2016, 04:21 PM   #50
bruce71198
bruce71198's Avatar
Its Nikasil and Kawasaki actually makes the rings for it.
Old April 20th, 2016, 04:22 PM   #51
HoneyBadgerRy
Wait, I forgot he didn't bore the motor over, sorry disregard everything I said about the block or rings above.
Old April 20th, 2016, 04:34 PM   #52
mgentz
Board Member
Is it:http://www.technical-inc.net/products/detail843.html
Old April 20th, 2016, 05:03 PM   #53
HoneyBadgerRy
5mm over bore, ceramic coated, aluminium block, paired up with a 7.8mm longer stroke for a total of 345.51cc's. That might make the power level you wanted. (Along with valves and ported head.)
The stock 250 bore to stroke ratio was 1.5:1, stock 300 is 1.27:1, and your bike is 1.36:1, you a can use this info to help predict the torque curve.
Old April 20th, 2016, 06:42 PM   #54
Racer x
Racer x's Avatar
I thought it was a Kawahana block
Old April 21st, 2016, 07:55 AM   #55
bruce71198
bruce71198's Avatar
Yes, but did you read the fine print? I actually picked this up from someone on here just to see what the quality was and if I could make something out of it.
I used the 3 layer head gasket that came with it on my last engine to help increase the squish and prevent the head gasket failures I was experiencing. It worked. Unable to procure more of these head gaskets I have Cometic making some. Back to the fine print, the pistons are cast not forged and although nicely machined they where soft, heavy and way to tall for the stroked crankshaft. With the amount of material between the top ring groove and piston crown I chucked them up in the lathe and started cutting. When they finally fit the top of the piston was to thin, into the scrap bin they went @Somchai gave me the idea to try ZX6 pistons and rods. The 2010 parts where the closest so with a little modification i'm pretty close to something that may work. Stay "tuned".
Old April 21st, 2016, 07:59 AM   #56
HoneyBadgerRy
2010 zx6 rods end up being the right length?
Old April 21st, 2016, 08:08 AM   #57
bruce71198
bruce71198's Avatar
About .012" to short
Old April 21st, 2016, 08:13 AM   #58
HoneyBadgerRy
Was there not enough piston to crank clearance, or was the squish just gigantic? Did you end up milling some off the top of the cylinder? If you did what did you do about cam chain slack (does the CCT make up for it) and the effect on cam timing?
Old April 21st, 2016, 08:52 AM   #59
bruce71198
bruce71198's Avatar
I'm using the ZX6 piston as well, it clears the crank just fine. Squish is big and can't mill the cylinder block because it will flake the chrome, I'll take what I need off the crank case. I have slotted cam gears to rectify the cam timing issue. Cam chain slack is minimal, not an issue.
Old April 21st, 2016, 03:38 PM   #60
mgentz
Board Member
Crazy fine print.
I am sticking to 264 but you are tempting me to try 282....
Old April 21st, 2016, 04:06 PM   #61
bruce71198
bruce71198's Avatar
Crazy fine print.
It appears that Wiesco is now recommending bigger sleeves if you are going 4mm over. Mine worked ok but I talked to others that cracked the cylinders at 4mm. You could always throw a 300 crank in yours for 315cc.
Old April 21st, 2016, 05:19 PM   #62
HoneyBadgerRy
I think somebody just needs to make +4mm rings for chrome liners. Then we could use 300 cylinders. I'd imagine JE or Wiesco would make one if there was some interest and we asked politely.
Old April 21st, 2016, 05:47 PM   #63
mgentz
Board Member
Millennium technologies will put in different sleeves if you want.....
Old April 22nd, 2016, 08:45 AM   #64
bruce71198
bruce71198's Avatar
300 cylinders are 62mm. Or are you talking about boring the 300 cylinders and chroming them?
Old April 22nd, 2016, 08:46 AM   #65
bruce71198
bruce71198's Avatar
@mgentz didn't you post some photo's of your ported head?
Old April 22nd, 2016, 09:22 AM   #66
HoneyBadgerRy
Yes.
Old April 22nd, 2016, 09:29 AM   #67
RacinNinja
Vintage Screwball
RacinNinja's Avatar
MOTM - Mar '16
If you need custom rings and are proficient at measuring end gap, ring width, etc, just call Total Seal. They will custom make, very affordable, any rings you need out of any material you need.
We had to do this for the Venolia slugs we're running in our race bikes. No one makes rings for them any more.....
http://www.totalseal.com/
Old April 22nd, 2016, 09:38 AM   #68
HoneyBadgerRy
"Home of the gapless rings" Does anybody know how they put a gapless ring on a piston?
Old April 22nd, 2016, 09:41 AM   #69
RacinNinja
Vintage Screwball
RacinNinja's Avatar
MOTM - Mar '16
It's not truly gapless like you think.....
http://www.racetep.com/totalsealframe.html
As shown in the illustration, compression gas is deflected by the rail into the piston groove and aid in pressure loading the ring throughout the 4 stroke cycle. At the same time the rail also and most importantly closes off the combustion gas leak path created by the ring end gap. This gap is the primary cause of blow-by in a 4 cycle engine. With a conventional type ring as the ring and cylinder wear the ring end gap increases and the blow-by figures increase. The Gapless ring blow-by figures are not affected by this wear, as the ring end gap increases it is blocked by the rail portion of Total Seals patented interlocking 2 piece design stopping the blow-by at the source. Conventional style rings when newly installed will show leak down figures of 7% or higher these figures can quickly exceed 20% or higher after a surprisingly short period of time. Gapless rings on the other hand when newly installed typically show leak down figures of 2% and lower and should remain the same throughout the life of the engine.
Old April 22nd, 2016, 09:58 AM   #70
mgentz
Board Member
I did. They are in the build thread. I could probably find them, or take new ones for you. My head will be back today.
Old April 22nd, 2016, 10:16 AM   #71
mgentz
Board Member
I called total seal and asked about my 64mm application.....no dice.
Old April 22nd, 2016, 10:19 AM   #72
RacinNinja
Vintage Screwball
RacinNinja's Avatar
MOTM - Mar '16
Really?
We called them and just gave them ring specs (Thickness, end gap, ring width, etc) and the materials we wanted.
POOF! Done.
Did they say why?
Old April 22nd, 2016, 10:27 AM   #73
mgentz
Board Member
Really?
POOF! Done.
Did they say why?
Mostly due to the .8mm ring thickness and 64mm bore size. This is custom to JE. I asked if he could make me rails and modify my rings as well.
To qualify: they can do this, but it needs to be a 1000 piece minimum order.
Old April 22nd, 2016, 10:28 AM   #74
RacinNinja
Vintage Screwball
RacinNinja's Avatar
MOTM - Mar '16
Ah, that makes more sense. Thanks!
Old May 22nd, 2016, 06:37 PM   #75
mgentz
Board Member
any updates Bruce?
Old May 24th, 2016, 12:21 PM   #76
bruce71198
bruce71198's Avatar
any updates Bruce?
Soon, I had to build a 2mm, 300 crank engine for a guy (315cc), ported stock valve head, tighted up the squish. Runs real strong, I want to get it on the dyno and see what it does. After that build I got back into my SV engine (2 of them) then Moto America started up, so I've been real busy.
Old May 24th, 2016, 06:50 PM   #77
mgentz
Board Member
K. Thanks for the update.
Old May 24th, 2016, 07:02 PM   #78
Baron
Urban Legend
Baron's Avatar
Motorcycle(s): 09 Ninja 250R SE - Circe
"Life is like riding - You can either tear the fastlane in half or stay in the slipstream trying to play catch up."
-Baron
Baron is offline   Reply With Quote
Old May 29th, 2016, 06:53 AM   #79
TP Ninja
Motorcycle(s): 300 Ninja
48hp out of a 250? Hahahaha! That's called a grenade!
TP Ninja is offline   Reply With Quote
Old May 29th, 2016, 07:21 AM   #80
mgentz
Board Member
While he started with a 250, Bruce is investigating the 300+ cc range to get this amount of HP.
So far, he has been pretty successful.
Idle shooting WAAY up on start Alchemist 1986 - 2007 Ninja 250R Tech Talk 10 April 13th, 2014 01:36 PM
Connecticut school shooting OCMagnum Off-Topic 183 December 19th, 2012 11:32 AM
RE: Theater Shooting... Countersteer Off-Topic 94 July 31st, 2012 06:20 PM
Trouble Shooting a couple things x only performance 2008 - 2012 Ninja 250R Tech Talk 11 May 18th, 2012 03:48 AM
The shooting of Somali pirates HKr1 Off-Topic 5 December 30th, 2010 05:12 PM
