Old February 2nd, 2012, 12:20 PM   #41
akima
Nooblet
akima's Avatar
MOTM - Oct '13
Originally Posted by hackeron View Post
So? - how did it go?
I set off to find out on Sunday but it was way too misty out, so I backed out. Really bad day to see how fast you can go. I couldn't see more than 4 car lengths ahead of myself.
Old February 2nd, 2012, 01:18 PM   #42
Nemesis
CVMA #74 WSMC #750
Nemesis's Avatar
Motorcycle(s): All of them
Maybe lose some weight?
Old February 2nd, 2012, 02:01 PM   #43
hackeron
Motorcycle(s): Ninja 250r (2009)
Originally Posted by Pyro View Post
Close to sea level taking the snorkel off is probably not neccesary. If you're high above sea level it might help though.
Any idea how high you are?
Also - your bike is still pretty low on kms, might loosen up a bit over time and get more speed out of it.
I've got no idea what my top is Cruised pretty well at 140km/h indicated, although I needed a bit of a downhill to get to 160km/h.
I'll take it on the highway again sometime after I've done the 15000km service.
I'm about 100-150m above sea level (330-500 feet). Think removing the snorkel will make any difference?
My bike is currently at 3900 miles (6,300km).
http://www.fuelly.com/driver/hackeron/ninja-250r
hackeron is offline   Reply With Quote
Old February 3rd, 2012, 04:37 AM   #44
Pyro
Motorcycle(s): EX-250K
I'm not experimental enough to know, but you might just get slightly more power.
Thing is, at 1700m where I am, you get about 20% less power due to the lower air pressure. I could most likely gain because the bike was designed to work with more air than I'm getting. It was not designed to get in say 10% more air than it would at sea level.
If the snorkel did not have a purpose, the designers would not have fitted it, so I'm a bit reluctant to remove it.
Pyro is offline   Reply With Quote
Old February 3rd, 2012, 08:09 AM   #45
It's purpose was intake noise suppression
Old February 7th, 2012, 03:52 AM   #46
dave_boo
Motorcycle(s): 2008 Ninja 250R, 2006 CBR 150
FWIW, I weigh 100 kg and have reached 162 km/h (gps verified, so some 175? indicated) on my Thai spec Ninja. Only mods have been the snorkel removal, Pirreli Dragon Supercorsas, and a Powercommander V. This happened on the Asian 1 north of Kamphaeng Phet while riding with a Versys.
dave_boo is offline   Reply With Quote
Old February 7th, 2012, 04:40 AM   #47
Slono
Slono's Avatar
Motorcycle(s): 2011 Kawasaki Ninja 250R (sold), 2007 SV650s (deer wrecked), 2010 Suzuki SV650S
I guess there are a lot of people going downhill while doing the top speed run :P. I'm going to find the highest hill on a long road and try the same tests lol!
Slono is offline   Reply With Quote
Old February 7th, 2012, 04:52 AM   #48
dave_boo
See many elevation changes on this route?
Old February 7th, 2012, 05:14 AM   #49
Racer x
Racer x's Avatar
MOTM - Sep '18, Feb '16
With stock 14 /45 gearing the 13500 rpm rev limit will hit at 109 mph. So on a long 20% grade down hill that is where it will end. Please don't try to go down a hill as fast as you can. The suspension and brakes will not react well to suprises.
Old May 28th, 2012, 09:57 AM   #50
akima
Nooblet
akima's Avatar
MOTM - Oct '13
Originally Posted by akima View Post
I just found a gps speedometer app on my phone that will record my max speed. Looking forward to my speed run on Sunday! Hope it goes to 100 indicated... then I can tell people "my bike does AT LEAST 100MPH... probably tops out at like 300" ^_^
My first attempt it only got to 93MPH. Someone told me that tucking down makes a big difference, so on my second attempt I did and the needle touched 100MPH.
Further info:
* I was on a flat road (no incline)
* the wind speed was low.
* my bike has no performance mods
* it's a fuel injected bike
* stock tyres
* tyre pressure was set to the recommended levels (28psi front, 32psi rear)
* I wasn't using any power-ups
Am I the world's fastest squirrel now?
Old May 28th, 2012, 11:40 AM   #51
hackeron
Further info:
* stock tyres
Very nice - What was the indicated speed when you hit real 100mph?
Old May 28th, 2012, 11:59 AM   #52
akima
Nooblet
akima's Avatar
MOTM - Oct '13
Sorry, forgot to mention. That was the indicated speed. I think my indicated speed is quite accurate though. Something about it having an electronic speed sensor.
Old May 28th, 2012, 12:00 PM   #53
LoneRonin
LoneRonin's Avatar
Motorcycle(s): 09 Ninja 250r
same here, so far...I've got the carbed one with 2 shims snorkel removed, Pilot Powers...
I'm about 72kg
LoneRonin is offline   Reply With Quote
Old May 28th, 2012, 01:26 PM   #54
TnNinjaGirl
Ms. Personality
TnNinjaGirl's Avatar
Further info:
* stock tyres
I think the real difference is that you use the faster tyres, while we use the slower tires. Makes a difference!
Posted via Mobile Device
Old May 28th, 2012, 01:32 PM   #55
Jiggles
Jigglin' your Jiglets
Jiggles's Avatar
MOTM - Apr '13
Those are just thank you tyres, they are very polite in England
AFM #676
Supersports are for n00bs
Old May 28th, 2012, 01:48 PM   #56
akima
Nooblet
akima's Avatar
MOTM - Oct '13
I'm sure I'll be calling them "tires" without realising it before long. I'm constantly getting "wtf"-looks from British riders when I'm talking to them. I've picked up all these American biking terms in here that confuse my fellow trouser-wearing, rain-drenched, English peoples.
Old May 28th, 2012, 01:49 PM   #57
Whiskey
Further info:
* stock tyres
Watch out for a done up black fireblade if you're trying any more speed runs, your local plod has one as it's undercover speed enforcment bike... apparently it's rider is a right prick with ears
Old May 28th, 2012, 02:07 PM   #58
akima
Nooblet
akima's Avatar
MOTM - Oct '13
Thanks for the heads-up, but I wont be furthering my career as a speed-demon! It was a bit of a kick going that fast, but it's not that great. I like to ride for other reasons: the community, the learning experience, the excitement I get without even going above 50mph, the freedom and the beautiful ninjette!
That bobby can forcibly insert his fireblade up his bum! I'm the one the got away
[roadracingworld.com] - Pedrosa Goes 216.858 mph, Sets New MotoGP Top Speed Record Fo Ninjette Newsbot Motorcycling News 0 August 10th, 2014 07:40 AM
[roadracingworld.com] - Pedrosa Goes 2016.858 mph, Sets New MotoGP Top Speed Record F Ninjette Newsbot Motorcycling News 0 August 10th, 2014 06:50 AM
[motorcycle.com] - 2014 Vectrix VT-1 Electric Scooter Boasts 62 MPH Top Speed Ninjette Newsbot Motorcycling News 0 November 1st, 2013 07:20 PM
[motorcyclistonline] - SWIGZ Electric Motorcycle Achieves Top Speed of 190.6 MPH And Ninjette Newsbot Motorcycling News 0 April 11th, 2011 02:20 PM
[roadracingworld.com] - Hayabusa Streetbike Sets Top-Speed Record At 272.340 mph On M Ninjette Newsbot Motorcycling News 0 April 13th, 2010 01:10 PM
