Old February 11th, 2014, 03:38 AM   #41
fast1075
Motorcycle(s): 2006 Ninja 250, 2004 Buell XB12s, Honda 110 Elite
HA! I gots skull valve stem caps and a chrome chain, that's at least 40 more horsepower!
"They don't pay me enough to ride this thing!" Kenny Roberts after winning the Indy Mile on the TZ750 powered Grand National bike.
fast1075 is offline   Reply With Quote
Old February 19th, 2014, 02:54 PM   #42
LCR
Motorcycle(s): Cruiser, street, and track
Originally Posted by mgentz View Post
I love oil threads. Do what you will Unregistered, my bike is still faster as I have more stickers.
Was that a reference to me?
Either way I agree with most of the posts here if he steered you away from syn because it made his clutch slip on his race 250 something is wrong with his clutch.
Although I sell Amsoil now I used it before that. I and multiple people in the pits around here have done 6 and 8 hour endurance races with zero problems. One guy even get oil analysis done on them regularly and no issues running the Amsoil multiple race weekends.
If you don't want to spend $10/qt on Amsoil just use a quality motorcycle oil that you like.
LCR is offline   Reply With Quote
Old February 19th, 2014, 04:00 PM   #43
fast1075
Exclamation
When I had clutch trouble with Castrol Syntec, it wasn't a 250 Ninja.
1327 cc Kawi Z-1 with a 100 hp nitrous shot. (165 hp on motor alone, you get the picture). The clutch was an MTC 3 stage slider. I had been using Mobil 1 in 5w-30 in it. I spun the tire which kicked a shift fork. I pulled the pan off and changed the shift fork (you can't do that with a set of stock cases).
When I put it all back together, the only oil I could get was the Castrol without running all over. Any way, the clutch slipped like a madman and fried the pack. Put it back in the trailer and went home. Damn good slippery oil, but not good for a wet clutch.
I changed back to Mobil 1 the next week, replaced the clutch pack and went 50 rounds over the next 8 events without a single problem. It was definitely the oil.
Old February 20th, 2014, 10:22 AM   #44
Were both standard 5W-30 auto oils? If so then, yes, it certainly could be the oil. Both of those oils contain Friction Modifiers.
In that application, with that much power being transmitted through the clutch plates, using an oil with Friction Modifiers will cause slipping. Even if you didn't have that much power, it could still be a problem.
As I've said before, DO NOT USE AUTO OILS IN A CYCLE ENGINE! Friction Modifiers may cause clutch slipping, but more importantly the lack of proper levels of additives can easily cause damage to valvetrain components.
For what you had there, an Ester-based synthetic racing oil like Motul or Redline would be a much better choice.
Old February 20th, 2014, 11:28 AM   #45
RBN
RBN's Avatar
Motorcycle(s): Frankenstein
Luckily I can speak from many years experience using car oil, and it's certainly not a one size fits all yes or no answer.
Over here cheapo 20/50 car oil was until recently about 1/4 the price of bike oil so I ran all my bikes on it and changed it regularly, I did this for many many years and hundreds of thousands of miles.
Over the years I found that the amount of clutch slip (if any) was really hit and miss, some bikes would slip with certain oils more than others and other bikes wouldn't slip at all regardless of what oil went in. But even when an oil did cause slip it was still completely rideable for me as I am a very sedate rider who changes gear at relatively low RPM 99% of the time. I'm sure that if I was the type of rider who liked fast paced riding and aggressive gear shifts I'm sure it would have been a different story all together.
The ONLY time I had clutch slip that it was a problem to ride with was when I used a top brand oil (Magnatec or some such thing) which caused very bad slip. But again with that said I have a friend who uses it in his bike (completely different make and model to mine) and gets no slip at all.
Then about a year or two ago the price of all the cheap oils went up so I no longer use it, why bother with any clutch slip at all just to save £20 a year.
Being a ratbiker many of the people I ride with run their bikes on a shoestring budget and as such use only car oil in their bikes. Many report no clutch slippage at all or clutch slip only when "giving it a right handful". Neither my friends ancient XJ , his equally decrepit Goldwing or VFR750 have any issues running car oil, all of which have well exceeded the life expectancy of their particular engines and are still going strong.
As such my view is that the amount of clutch slip is entirely dependent on the bike/oil combination. And that if the clutch does indeed slip it will usually just reduce the amount of rpm you can change at (how much of a reduction will again be bike/oil dependent), whether or not you can live with the reduction is entirely personal preference. And lastly that car oil certainly doesn't seem to cause excessive wear providing it's changed regularly of course, as most of our bikes would have been dead or at least very knackered a long time ago.
RBN is offline   Reply With Quote
Old February 20th, 2014, 11:32 AM   #46
Aodrn
It's a long boring story
Aodrn's Avatar
Motorcycle(s): 2012 Ninja 250
My guess (without any research data) is that 9/10 will total the bike before oil changes become an issue. Just saying
#41 MCRA
alex.s :crashing is a normal part of life... people are just in denial about that.
Aodrn is offline   Reply With Quote
Old February 20th, 2014, 12:21 PM   #47
Actually it is - no is the answer.
The REAL issue isn't Friction Modifiers and clutch slippage - Modifiers are only used in oil grades up to 30 so no 40-grade has them anyway.
Back-in-the-day auto oils had higher levels of additives (ZDDP) that you really need for a cycle engine - not any more.
I used auto oils back then also, but not any more.
EDIT: The solution to a less expensive oil that's safe for cycle engines is a 40-grade diesel oil - Rotella, Delvac, etc. It's generally a good quality base and has the higher amounts of ZDDP that are needed to protect the cams and rockers. It's also easy to find and not very expensive - win.
Last futzed with by jkv45; February 21st, 2014 at 07:19 AM.
Old February 22nd, 2014, 04:04 AM   #48
RBN
RBN's Avatar
TBH I was under the impression ZDDP percentage in car oil was on the decline since like the 80's or 90's and has been at the same low/non existent levels as today for around a decade. Though this may of course be different between Europe and the rest of the world.
Regarding Diesel oil, are there not implications resulting from the higher detergent levels? Seem to recall reading it somewhere or other but can't recall where.
Old February 22nd, 2014, 09:52 PM   #49
I haven't been able to find the exact timeline for reduction of ZDDP levels in standard auto oils, but will post it if I can.
As far as detergent levels in diesel oil, I've heard that mentioned before, but never found any evidence that their detergent package was an issue when used in a cycle engine.
I'm very confident that diesel oils are a much better choice than standard auto oils in a cycle engine.
Old March 7th, 2014, 08:25 AM   #50
RBN
RBN's Avatar
If you do find anything I'd sure appreciate seeing it as it seems to be what this whole thing rests on.
Something that struck me as interesting was that yesterday I found myself in a bike shop and while I was there I checked out some of the oils available and whilst they made no (or very little) mention of what was actually in them to my surprise around half of them featured the words:
"safe for use in engines with catalytic converters"
Wouldn't that suggest they don't have zddp in them? These were all motorcycle specific oils.
Old March 7th, 2014, 08:35 AM   #51
High (safe) levels of ZDDP don't mean instant plugging of the catalyst.
It takes time, and because auto engines typically go significantly more miles before needing major service the ZDDP limitations are based on 100,000+ mi of use. They are also factoring in oil consumption as the engine nears that mark.
In more limited use, and minimal consumption, there's no harm to the catalyst from high levels of ZDDP.
If you are unsure, most manufacturers will give you the zinc and phosphorus levels in their oil - except Castrol that is. 1200 and over is commonly considered safe for cycle engines, with some cycle oils in the 1500-1700 range. Standard auto oils are held to under 800 ppm.
Old March 7th, 2014, 06:02 PM   #52
InvisiBill
EX500 full of EX250 parts
InvisiBill's Avatar
The "Commercial (Diesel) Oil" section of http://www.calsci.com/motorcycleinfo/Oils1.html gets into why he actually prefers the "diesel" oils. They're designed for better protection and stability, with less regard for emissions equipment and gas mileage. This is in contrast to the API S standards, where newer ones removed some high temperature protection and started adding the energy-conserving stuff. The JASO M standards were actually created in response to these changes that negatively affected typical motorcycle engines. The 500's manual calls for the older API SG oil, or also having JASO MA certification along with API SH and newer.
Rotella (15W-40 dino and 5W-40 synthetic) meets the requirements listed in the manual and is cheap (I've gotten T6 for as low as $9/gallon with a sale and rebate), so that's what I use. Some modern "good" oils actually don't even meet the manual's requirements.
Originally Posted by http://www.calsci.com/motorcycleinfo/Oils1.html
Mostly JASO-MA is pretty much equivalent to SH. In fact, the JASO spec is mostly a reaction to the decrease in zinc-phosphates in SJ and SL oils, and the added molybdenum disulfide in energy conserving oils.
According to http://www.pqiamerica.com/apiserviceclass.htm, SJ was 1996-2001 and SL was 2001-2004.
Old March 7th, 2014, 06:14 PM   #53
kennetht
kennetht's Avatar
how come you mentioned me in this thread? i havent even commented on this thread until now lol...
kennetht is offline   Reply With Quote
Old March 7th, 2014, 07:18 PM   #54
mgentz
Board Member
Its the [ you ] tag
Old March 10th, 2014, 06:31 AM   #55
kennetht
kennetht's Avatar
Its the [ you ] tag
not sure what that is?
Old March 10th, 2014, 11:39 AM   #56
InvisiBill
InvisiBill's Avatar
Originally Posted by kennetht View Post
Its the [ you ] tag
If you type the [you] BB Code in a post, it will substitute the current viewer's username into the message.
For example, here's what it looks like when I type "I'm better than [you]!":
I'm better than Unregistered!
Old March 10th, 2014, 11:59 AM   #57
kennetht
kennetht's Avatar
o i gotcha. haha. so everyone sees their username in that post. gotcha. thanks
Question about Fork Oil thisisbenji General Motorcycling Discussion 16 February 23rd, 2015 08:40 AM
Quick question on Oil Daakuryu 2008 - 2012 Ninja 250R Tech Talk 16 February 22nd, 2015 09:12 AM
Oil question Maielstrom 2008 - 2012 Ninja 250R Tech Talk 1 August 10th, 2012 11:24 AM
oil change question ProdigyRacingLA 2008 - 2012 Ninja 250R Tech Talk 8 April 19th, 2012 06:46 PM
Oil question SpYd3r05 1986 - 2007 Ninja 250R Tech Talk 4 May 10th, 2010 05:14 PM
