February 11th, 2010, 10:27 AM | #41 | |
Join Date: Jun 2009 Motorcycle(s): 2009 Ninja 250R Posts: 60
February 11th, 2010, 10:52 AM | #42 |
self wrencher
Cool. How to get speed signal for the calculation?
Posted via Mobile Device |
February 11th, 2010, 10:53 AM | #43 |
February 11th, 2010, 01:06 PM | #44 | |
You are sleeping
Sort of difficult without GPS. Which is why our bikes have mechanical speedo. (pretty sure) Or you could go the hall effect sensor way and measure rpm of the wheel. even a program like this for a GPS unit will be fairly complex to handle. As for my chips talking to yours.. they can do so online around the world.
<Yeah, it's a 250. LMFAO! Weaksauce |
February 11th, 2010, 01:12 PM | #45 | |
February 11th, 2010, 01:26 PM | #46 | |
You are sleeping
I was trying to help explain to John how you can use the RPM to get speed for further calculations. (such as gear) Have you guys seen the current gear indicator gauge additions on the market and the process you have to go through to set them up?
February 11th, 2010, 01:29 PM | #47 | |
I havent? You got ideas? |
February 11th, 2010, 01:40 PM | #48 | ||
You are sleeping
I think I read about the shift gauges that work on our bikes go crazy (read false) when you push in the clutch. This is because they are based from RPM and or speed.
This is why I like the idea of a physical button on the shifter. I took my lil deely out for a spin today but I still have a little work to prove it is viable. Those switches have to be aligned perfect, but once they are it will be golden. I may have to transfer to atmel soon but shouldn't slow me down too much. The guy here says Quote:
Not to mention I think the magnet RPM gear indicator that does work on our bike on the market currently is like a super pain to set up and you either have to do it while on the bike rolling or the bike on a dyno or roller wheels or something. I was reading the directions and said to myself "Whaaat?! I wouldn't buy that thing if all that was involved". It's all speculation. This stuff is pretty difficult and I'm lost in my programming at the moment. lol Just adding some input. Currently I can make my gear shifter count gears and reset to neutral without touching anything when needed but sometimes it skips only the first upshift into second from first. I'm pretty sure I just have to bend the switch tab and I'm set? I think the most accuracy could be obtained with a combination of reading RPM (or speed) against actual shifter switch presses. Either way the shifter will need dedicated sensors of it's own to always be right. Quote:
Also, I'm not positive, but I think GPS is accurate to within 15 feet or so. This might put a few little debug gremlins in the scheme of things.
February 11th, 2010, 04:51 PM | #49 |
self wrencher
...and until then, let's all continue search for the 7th gear
February 11th, 2010, 06:02 PM | #50 | |
You are sleeping
7th gear does not exist on my project. It would first have to be created in the program.
February 11th, 2010, 08:07 PM | #51 |
Haha, I found a couple of those micro switches tonight... I really need to order some... Where did you get yours from KC?
I cleaned up a bit of my code today and my GPS is working again |
February 11th, 2010, 08:22 PM | #52 |
You are sleeping
I haven't played with any of the GPS modules yet. Good to hear you have it crackin' again.
I got the switches from the electronics store in a package. Check my thread for the name on the package and google 'em. I forgot what they were called already. Two I bought had rollers and two I bought were normal lever action. the name on the switch is "Highly ss05" but the name on the package (supplier?) was different. If you can't find any, let me know. The local shop has more I can pick up. Gotta be something else out there that will work similar or better too.
February 11th, 2010, 08:27 PM | #53 | |
Okay Thanks, The GPS I am using is this one: http://cgi.ebay.ca/MICROSOFT-STREETS...item2a04ba5b60 You can probably find it cheaper... it is the microsoft sirf 3 gps, comes with most streets and trips... Iv seen it for under $15 shipped on ebay before I cracked open the plastic and attached 3 wires (5V, GND, tx) I found a GPS library that was already written and used that. |
February 13th, 2010, 06:42 AM | #54 |
You are sleeping
Just thought o an idea. You could also have your bike pc display battery voltage through the v-ref line of your atmel chip. Always thought it was cool how those things know what their voltage is.
February 16th, 2010, 07:10 AM | #55 | |
I will def have to look into it. I am not sure how many sensor spots I have left! |
February 16th, 2010, 10:38 AM | #56 |
You are sleeping
Yeah I remember they have a low voltage adjustable reset. You could adjust at which voltage they would reset, which means they have to know what voltage they are running. This was dealt with from the "Vref" pin on the atmel chips I used. You might want to see if it's doable in your project.
If I remember right you could actually write to the routine of what happened when the vref was triggered and adjust when it triggered.
February 25th, 2010, 08:08 AM | #57 |
Just a small Update...
I was testing the GPS speed in my car. As you can see I have put everything into a cardboard box for now. http://www.youtube.com/watch?v=XX3L3sadiDM |
February 25th, 2010, 10:23 AM | #58 |
You are sleeping
Very nice!
You got me thinking I should go to an LCD. At least then I could see it in the day time with basically no effort and minimal power draw. I have never played with the LCD instruction set on the AVR's yet either. Where are you getting the libraries? I wonder if that would work with my compiler. I can include referential libraries like "delay" etc in the program but haven't researched other libraries much.
February 25th, 2010, 10:24 AM | #59 |
I just find libraries on google. I went with a serial LCD for its simplicity, power, ground, signal
March 16th, 2010, 11:39 AM | #60 |
Join Date: Jul 2009 Motorcycle(s): 2008 Ninja 250r(sold), 2007 650R (sold), 2013 Ninja 300 Posts: 199
Cool project, I actually have an Arduino sitting at my house that I never got around to messing with. A gear indicator would be a nice feature. Would a magnetic switch (Reed switch) work for that? It wouldn't require physical contact, just magnets on the shifter... Ill have to get an LCD for mine and start messing with it...
June 1st, 2011, 05:15 PM | #61 |
Join Date: Apr 2010 Motorcycle(s): 2009 250 Ninja Posts: 24
I see it's been a little over a year since anyone posted here. I wonder where this bike-pc project landed to?
My first bike project! | Kruse08 | 1986 - 2007 Ninja 250R Farkles | 76 | May 21st, 2015 08:23 AM |
Rebuild Bike is officially a project bike | antwan718 | 1986 - 2007 Ninja 250R Tech Talk | 4 | December 18th, 2012 10:32 AM |
WTB: 2008+ 250R salvage bike for track bike project | htdub | Items Wanted | 0 | April 25th, 2012 11:12 AM |
Anyone in the Northeast looking for a project bike? | adouglas | General Motorcycling Discussion | 6 | November 21st, 2009 08:37 AM |
Help me pick out a project bike!! | M-Oorb | General Motorcycling Discussion | 34 | November 18th, 2009 12:09 PM |
