February 24th, 2012, 03:40 PM | #41 | ||
Join Date: Dec 2011 Motorcycle(s): 2010 Ninja 250r (RIP) Posts: 258
February 24th, 2012, 03:57 PM | #43 | |
He used the OEM throttle body which comes with 200 cc/min Kawasaki fuel Injectors. That's the only way to install the kit and do it right. He was up and running in only 5 hours.
February 24th, 2012, 04:01 PM | #44 | |
February 24th, 2012, 04:12 PM | #45 |
Join Date: Nov 2011 Motorcycle(s): 2007 Ninja 250 (sold), '06 Ninja 650R Posts: 455
Earlier in the threads there was discussion that the 200 cc/min injectors were borderline too big for the 250. How does your idle mixture look?
February 24th, 2012, 04:50 PM | #46 |
I'm not sure I completely understand your question (I am kind of new to procal and fuel injection in general). I was under the impression that with the narrowband sensors it could only detect if it was rich or lean, I didn't realize you could look at the mixture value. If you tell me how I can go look it up, I have a laptop so its a matter of 2 minutes to walk to my garage and start it up and take a look.
February 24th, 2012, 05:15 PM | #47 | |
If you ever need a replacement for whatever reason, they are the same identical injectors that are used in the ZX-6R.
February 24th, 2012, 05:54 PM | #48 | ||
February 24th, 2012, 05:55 PM | #49 |
Great write up! Hopefully you can get the kit working reliable and find a good set-up. Keep us updated!
February 24th, 2012, 05:59 PM | #50 |
Join Date: Dec 2011 Motorcycle(s): Ninja ex250 1990 Posts: 761
technically with procal program is still programed for 170 or what ever it is. so its going to treat them so pluse wise. But my experience putting bigger injectors on a system that is made for smaller injectors can run it rich. Keep that in mind. I have done this on my cars temporary till i adjust the map, otherwise it might wash the cylinder walls and run it rich. but my jump was from 220 to 440cc so not that big of a difference. ill think u will be fine but ask Matt just in case.
1990 250F. ex300 motor swap, 15/42 gearing, flush side markers, newgen intergrated front fairing, rear integrated turn signals, DB Touring Bubble, zx600 rear shock, Custom DanMoto Exhaust |
February 24th, 2012, 06:01 PM | #51 | |
February 24th, 2012, 06:05 PM | #52 | |
So if the injector is too small, you'll have power drops at high RPM. If its oversized, you'll have poor fuel economy because the minimum squirt is bigger too. All in all, the OEM injectors are simply better.
February 24th, 2012, 06:11 PM | #53 | |
This is the previous post I was talking about. |
February 24th, 2012, 06:59 PM | #54 | ||
February 24th, 2012, 07:49 PM | #55 | |||
February 24th, 2012, 08:08 PM | #56 | |
Basically the secondary butterfly assembly acts like the slides in a CV (constant velocity) carb like the U.S. EX-250 has. The secondary butterfly assembly servomotor also acts as part of the bike's "automatic choke" system. For startup the ECU commands the secondary butterfly servomotor to rotate all the way around to "full-open" position which brings a small metal "cam" into contact with an arm that extends off the back of the throttle pulley. When this cam contacts the arm it causes the throttle to open slightly. In addition to this action the ECU also commands the correct amount of fuel, taking into account temperature and elevation (it figures out elevation by taking a "reference" reading on the Manifold Absolute Pressure sensor before the engine is cranked over. That's just another of those "pre-start" items that occur every time you key-switch the bike to "on") |
February 24th, 2012, 08:11 PM | #57 |
I removed the secondary butterfly servomotor, the secondary butterfly plates and the driveshaft that connected them to the servomotor. And then I sealed the driveshaft hole with JB weld.
I also cut off the mounting point for the servomotor. Ended up looking like this: |
February 24th, 2012, 08:16 PM | #58 | |
February 24th, 2012, 09:12 PM | #59 | ||
If no one else bids on it, I might just to have an extra one laying around :-) Quote:
http://www.amazon.com/mod-smart-Illu...374470&sr=1-29 |
February 24th, 2012, 09:14 PM | #60 |
/linked from main DIY sticky
February 24th, 2012, 09:53 PM | #61 |
Awesome, I will definitely try to keep it up to date. By next weekend I should have it completed with my final fuel line setup and spiffy green colored pushbutton. I will also keep updating so that there are long term results from such a setup (well, after I can drive again). Next on the list I am going to install an integrated taillight (hopefully it will be here next week) and I might get a new exhaust. I was thinking of an area-p setup but he said they couldn't weld on the bungs for me, so I might go with a Sportisi instead.
February 24th, 2012, 09:54 PM | #62 | |
Looks very clean and compact. BTW, do you know of a reliable source for the injector connectors? That is, other than cutting them off a wiring harness.
February 24th, 2012, 10:29 PM | #63 | |
Here is an asian ebay auction for one http://translate.googleusercontent.c...CNEDOx1ZSk4Q4Q Although I don't know if they ship worldwide. |
February 24th, 2012, 10:48 PM | #64 | |
2009 Ninja 250R SE Green Sport Touring Style: ZG ST; Symtec heated grips; RAM GPS w/ mUSB; DIY reshaped seat; DIY Givi E21 Sidecases; 15T sprocket |
February 24th, 2012, 10:50 PM | #65 |
Ha i would say 10% but bc i have alot more fun with the performance its hard to really tell lol. bc i do the same two hour trips every weekend and its about 200 miles. When i had carbs i would get around 60-70, was 60 going up the mountain and 70 coming back well around 67. and wtih the efi kit i got about 65 going up but i was having a bit more fun and about straight 70 coming down the hill but i was speeding. Ill try to be more accurate and controlling and get some more accurate results. And plus when i traveled up elevations the carbs would lean out but would hardly run right and run really slow so probably saved gas on the carbs that way. efi kit just so much better
February 24th, 2012, 10:53 PM | #66 | |
If all goes well, my EFI setup will be completely finished by next weekend and I'll update this thread. |
February 24th, 2012, 11:05 PM | #67 |
Sweet. Once you get past the setup like the rest of us, it's all about tweaking the little things and taking logs. This sunday I am going to try out some new settings and try to take some logs while riding to see if we can work out some of the in operation kinks.
February 25th, 2012, 12:54 AM | #68 | |
February 25th, 2012, 01:09 AM | #69 |
Above the gauges behind the windscreen? That place is fairly protected from rain.
February 27th, 2012, 09:54 AM | #70 |
Join Date: Jun 2011 Motorcycle(s): 2001 ninja ex250 Posts: 8
Is the software useable by a tuner? Any plans for a dyno tune?
February 27th, 2012, 10:37 AM | #71 |
You can, I'm definitely not an expert on using the software but a few other forum members have been playing with it a lot more me and know how to use it better. I am fine with it using the autolearning with the O2 sensors on the stock settings, but in the future I might try to find a dyno to use and play with it more. Probably after I upgrade the exhaust.
February 27th, 2012, 04:39 PM | #72 |
Join Date: Apr 2011 Motorcycle(s): 2015 636 ABS - 69 Honda 305 Posts: A lot.
lc, that ebay link for the tb you said you would pick up if no one bid. I noticed someone bid on it and didnt know if it was you. I placed a bid and am gonna try to snag it, unless someone else really NEEDS it, no use in us all starting a bidding war.
February 27th, 2012, 04:51 PM | #73 |
if you need it ill make sure to not place anymore bids. I put a max of 55 pounds though, i was going to go higher tomorrow but i figure ill check the forums first. No point in driving the bid up, more will come along
February 27th, 2012, 05:47 PM | #74 |
jsut to let u know Matt (ecotrons) are selling them for 199 i beleive. I see that bid going past that. Its already over 100 bc shipping
February 27th, 2012, 06:01 PM | #75 |
bidding isnt over u know. i can see that going over 70gbp bc of all the ppl on this site. Just saying. good luck bidding
February 27th, 2012, 06:48 PM | #76 | |
February 27th, 2012, 07:00 PM | #77 | |
February 27th, 2012, 07:15 PM | #78 | |||
February 27th, 2012, 07:16 PM | #79 | |
February 27th, 2012, 07:21 PM | #80 | |
LFA suspension walkthrough | alex.s | Off-Topic | 9 | December 2nd, 2014 06:00 PM |
Efi... How many installed it | sidekick10121 | 1986 - 2007 Ninja 250R Tech Talk | 6 | June 30th, 2014 02:52 PM |
Ecotron's EFI Kit | parox91 | Motorcycle-related | 11 | August 13th, 2013 04:52 AM |
EFI Question | msebastian | 2008 - 2012 Ninja 250R Tech Talk | 8 | October 3rd, 2012 09:56 PM |
EFI kit | Racer x | 2008 - 2012 Ninja 250R Tech Talk | 138 | May 15th, 2011 01:47 PM |
