October 28th, 2012, 09:13 AM | #41 |
Good luck! I'm still watching to see if there's changes I need to make to my setup.
If you're going to get dyno tests on your bike with/without the efi, DO IT!! We need dyno numbers already!! Sheesh. I'm debating doing tests with mine once I have a good map, just to double check the AFR's, but I won't have anything to compare to |
October 28th, 2012, 09:58 PM | #42 |
Join Date: Aug 2011 Motorcycle(s): 2008 Kawasaki Ninja 250R, 2003 Honda CBR600RR Posts: 721
The injectors seem to be working okay, problem is I can't really test them at any other rpm other than idle so the idle characteristics may not apply to higher rpm. It's difficult to see the injector sprays for cylinder 2 but from my vantage point filming this I can confirm they both were performing the way that would appear normal.
ATGATT |
October 29th, 2012, 01:38 AM | #43 |
Just got back from my test run back on the carbs, zero problems over a 2-3 mile course. It's very late though so I didn't want to go out very far. This means something is up for sure with my wiring of the EFI kit. I'm going to leave the carbs on for the next week or so since transportation is very limited between my brother and myself (his bike is also down due to electrical issues) and we both go to school/work.... So we NEED two working vehicles. Next week it won't be so much of a burden, so that's when I'll resume testing and getting the EFI kit back up and running.
Yes @80MPHdownhill, you were correct all along Thanks for all the help from everyone so far. From here on out most of my help will probably come from the runner of the EFI company. I'll keep posting updates here though for those running on the same system so you can avoid whatever has happened here
ATGATT |
October 29th, 2012, 10:59 AM | #44 |
Good to know. Matt is a great help, I'm sure you'll get it all figured out!
Blew a chain! | codestp202 | General Motorcycling Discussion | 39 | July 7th, 2013 05:03 PM |
Blew a corner today | soggybottom | Riding Skills | 59 | June 5th, 2013 04:28 PM |
I blew my knee | cuong-nutz | Off-Topic | 10 | April 30th, 2013 02:54 PM |
New Headlight Blew | EsrTek | 2008 - 2012 Ninja 250R Tech Talk | 14 | August 21st, 2011 07:10 PM |
Poor girl blew | hinow41 | 1986 - 2007 Ninja 250R Tech Talk | 1 | September 12th, 2010 12:11 PM |
