#41 |
I can see how many of you prefer to use programs to kill/remove viruses/trojans and for someone with computer knowledge it might be the way to go but personally, I cant stand thinking that if i have one virus... what are the chances I have another that I dont know about?
Once I think about it this way, I just say screw it and do the reinstall. I'm picky like that though. You also have the added benefit of starting fresh. In anycase, good luck. I hate wasting time on things that arent productive. Not mention its incredibly frustrating. |
#42 | |
Join Date: Apr 2010 Motorcycle(s): Yahama v star 650 classic Posts: A lot.
#43 |
Look at the bottom of your laptop and see what your license is for. If it says WinXP home then any WinXP Home disc you can get will work even if it's your friend's.
#44 |
#45 |
Wartown, USA
Join Date: Nov 2009 Motorcycle(s): 2009 Ninja 250R SE, 2007 Ninja 650R, and assorted other bikes Posts: A lot.
You need to boot into safe mode first.
Then go into internet explorer, and click on Tools Then click on internet options Then click on the connections tab Then click on the LAN settings Then uncheck the "Proxy Server" check box. This disables that "anti-virus virus" programs ability to connect to its server and keep poping up those "blah blah blah is infected" messages. Then while still in safe mode run Malwarebytes (and make sure its updated) If that doesnt work.... Then boot into safe mode, and run combofix. and repeat above steps. Combofix is an extremely powerful program, you dont have to understand it to use it. Just let it do its thing, and then continue on from there. |
#46 | |
Join Date: Mar 2011 Motorcycle(s): 2007 ninja 250r Posts: 374
Op if you still have not gotten the issue taken care of pm me. My store does mail in service and I will give any ninjette members 15% off. |
#47 |
Really? That's what i've always done. As long as it's not a Recovery disc made specifically by the manufacturer. I'm just saying that a license for XP home will license any installation from any retail disc.
#48 |
Windows xp home or pro retail will not activate with an oem key or vice versa.
#49 |
Really? Hmm strange. Has always worked for me. Ok well since it's not my field of expertise by any means. You have my apologies. In any case, I'm still advocating the reformatting/reinstall option over any software based cleaning.
#50 |
The any disc/key install Brian is talking about is referred to as a system builder's disk. The disk was given to system builders when they purchased a batch of keys. The OS could be installed using any key because the disk was not specifically tied to an individual key and the system was considered valid since Microsoft didn't have an online authentication process. The problem is that builders were making copies of the disc and giving it to friends and family, allowing them to install the OS on every system in their house using the same key. Microsoft caught on and switched to an online key authentication system back in '06 or '07. Since then, the XP system builders disks have been worthless since they kick back an unauthorized product popup, cutting them off from the Microsoft update servers.
#51 | |
#52 | |
But here's the whole story: Before XP was released, a warez group known as "TheDevil'sOwn" released an XP VLK ISO along with the famous "FCKGW" volume license key (those are the first five characters). Shortly after, there was even a working keygen, though it generated many non-working keys as well. Another so-called "keygen" would just spit out the FCKGW key. ![]() Now, Windows Vista used an encrypted and signed flag in the BIOS called an SLIC rather than having different OEM versions of Vista and this would exempt them from the activation limits. People would install hacked BIOSes with an OEM's SLIC so that they could then install with the OEM's leaked installation disc. For the corporate customers, they made system administrators set up local VLK "activation servers" to activate multiple PCs without each PC phoning home to Microsoft. Both of these are still in use with Windows 7. Most people ripping it off are using hacked BIOSes with SLIC 2.0. FWIW, I just visit the tech conferences and earn free NFR copies. They are not for resale, but the same goes for any OEM copy. I hope this helps clear things up. ![]() |
#53 | |
#54 |
Okay, talking to my wife's dad, (works for some U.S goverment comp program), he gave me a cd with a antivirus program that they use. So i'm going to give that a try tonight.
#55 | |
#56 |
I got my computer back!! So I started it up yesterday to install that Anti Vir program, and when I got to my home screen, well it wasn't mine. I was missing programs and when I clicked to open anything on my "start menu" a box poped up asking what program it wanted me to open it with. I had no programs on my bottom right corner, (Norton, Wireless, Vol, ect.), even that "XP" window wasn't comming up. So I restarted it into safe mode and retried doing the system restore to an eariler day. It worked and now the computer runs normal.
I am in the process of downloaded that updated Norton Anti Vir to my laptop, but it wont let me download it because I have Norton on my computer already. Any tips? Thanks for everyone's help on this. This has been a bad week between painting/moving into a new home, breaking my thumb yesterday, and my computer crapping on me. ![]()
#57 |
http://www.nortonremovaltool.org/
Restoring you computer to a prior date will only be temporary. You must remove all the prior restore points. What ever infection you have also stores itself in the System Restore. Be sure to utilize Malwarebytes as well. Good Luck. |
#58 | |
Join Date: Apr 2009 Motorcycle(s): 2000 250 sold; 2005 636 sold. BIKELESS IN ATLANTA Posts: 753
#59 | |
#60 | |
#61 |
You don't need the Norton Removal Tool unless you plan on replacing Norton with another AV software. I may have missed that, but I don't remember you saying you wanted to do that.
#62 |
BTW, here are 3 free online virus scanners, if that is what you are looking for.
http://housecall.trendmicro.com/ http://www.bitdefender.com/scanner/online/free.html http://www.eset.com/us/online-scanner As far as the firewall, I would suggest something other than Windows Firewall (Comodo, which is my favorite, ZoneAlarm, etc). |
#63 | |
#64 |
It should allow you to download it, but it most cases you can't install it. 2 AV programs is no-no. You won't get double the protection, they end up 'fighting' each other for a lack of better terms. If you go that route, be sure that the cd version is the most recent version. You wouldn't want to uninstall 2010 and find out that the cd version is 2005.
#65 |
There are some older versions of Norton AV that may not uninstall completely the conventional way or by installing a newer version. Norton Removal tool solves that issue it also make the process easy and convenient.
#66 |
Right, but I don't think he is trying to remove Norton.
#67 |
The Norton on my computer right now is 2008..The cd I have is a 2010 Norton. I'm on my laptop now, (YAY!) and will be looking at the above links!
#68 |
Great! I'm working on one now that has the Internet Security Virus on it.
#69 |
Well, I ended up using this link, (http://www.eset.com/us/online-scanner) and scanned my commputere. Took a few hours, but it found the viruses and I deleted them all. I can already tell the differnce in my computeres performance. I can't seem to figure out this whole downloading thing with Nortan, so my wifes dad is going to do it for me.
![]() Thanks again for everyones help! Saved me a few dollars i'm sure!
#70 |
Good deal. Happy to hear that it's starting to work again.
Any Computer Geeks out There? | Scattcatt | Off-Topic | 17 | January 11th, 2013 06:57 PM |
Computer Weirdness | Jiggles | Off-Topic | 36 | August 15th, 2012 04:40 PM |
Computer issues | Jiggles | Off-Topic | 4 | March 8th, 2012 02:33 PM |
Question for you computer geeks… I mean… computer experts | THE BIG SITT | Off-Topic | 10 | January 28th, 2012 12:18 AM |
How to fix a computer | Alex | Off-Topic | 2 | April 20th, 2011 05:57 PM |
