January 9th, 2014, 02:09 PM | #41 |
Don't use carb cleaner to clean stuff containing rubber. It can cause the rubber to dry up and/or swell.
January 9th, 2014, 03:52 PM | #42 | |
Join Date: Nov 2013 Motorcycle(s): Ninja 250 2001 KX125 2001 Posts: 85
Had to look up the difference between Prime and On.. for the Petcock... I still need to do a few things to this motor. (I don't how many miles it had or the history) 1. Change or check spark plug) 2. Valve Clearance 3. Timing Chain Tension 4 Fresh Oil new filter 5. Wash the motor |
January 9th, 2014, 07:39 PM | #43 | |
January 9th, 2014, 08:09 PM | #44 |
Prime would free flow. ON only flows with a vacuum.
January 10th, 2014, 01:31 AM | #45 | |
I must of effed up the rubber gasket with carb cleaner |
January 10th, 2014, 05:26 AM | #46 |
You are welcome
January 10th, 2014, 07:44 AM | #47 |
Maybe not bad. If the membrane is torn, you'll see one or two things. First, you might see a leak from the air hole on the side. Second, when you suck on the vacuum line, you get a mouthful of gas.
If you have gas in the tank and you suck on the vacuum line and gas doesn't flow, it either means the screens are clogged or you aren't sucking hard enough. If it takes a lot of suction to open the valve, it could be that the carb cleaner "glued" the o-ring in place (the one around the metal thing attached to the membrane). If that is true, a trip to the local hardware store will fix the problem. Also, the screens need to be intact because if debris gets in there, it will jam in there. If they are bad, I don't think you can buy new ones so its time for a new petcock.
January 10th, 2014, 12:10 PM | #48 | |
I had the vacuum hose wrong and now i get good fuel deliver. Did a 30 mile ride with the replacement motor and it seems to ride nice. I did keep the RPMS below 10,000 tho just to be safe. I am not sure how long this motor has sat around for. |
January 10th, 2014, 12:59 PM | #49 |
Here is a picture of her.
ALLL DONE this nightmare is over |
January 10th, 2014, 01:54 PM | #50 |
Glad to hear it.
January 16th, 2014, 04:22 PM | #51 |
Today I hit 400 miles since the motor swap.
January 16th, 2014, 04:52 PM | #52 |
January 16th, 2014, 05:18 PM | #53 |
Private Joker
MOTM - Mar '14
I had a similar experience with my 250, I had a slow oil leak and didn't notice because when I washed the bike (every other week, along with other regular maintenance i.e. cleaning the chain) I washed away the oil trail. The only real way to know you have a leak other than checking the oil as part of your pre-ride (a good thing to do) is to take the fairings off before you wash your bike, you'll see it almost immediately if you do that. That way you'll know if anything is up and you can avoid redoing this whole fiasco, it sucks and I have mad respect for you being able to fix it up. I've had my engine opened up for a while debating if its worth it for me to get a connecting rod and a piston to try to rebuild it or just junk it and keep a few parts as a memento (the tank (has a decal that I really like on it) and keys are the only thing that really strike me as being worth it to keep)
January 16th, 2014, 05:35 PM | #54 | |
My post may show that it was a piece of cake finding the motor and doing the swap. The most difficult aspect is finding a donor motor that won't break the bank. I hope you are able to get your bike up and running. If i get my old motor to run you'll be the first to know |
January 16th, 2014, 05:40 PM | #55 |
Private Joker
MOTM - Mar '14
Really it's for financial reasons that I would prefer to rebuild rather than replace, at least for now. If/when I get it running again it'll either become a track bike or I'll give it to my older brother as a gift since he's interested in riding motorcycles but doesn't really have the budget to go out and get one himself. As it is there are other things that would also need to be fixed and while none of it is really that big of a deal replacement parts are a lot easier to get when you don't drop $3-500 on an engine. Thankfully this thread has shown me that it is reasonably possible to do when I have the budget free for it down the line so long as I don't junk the bike to free up shed space.
January 16th, 2014, 06:05 PM | #56 | |
January 16th, 2014, 06:10 PM | #57 |
Private Joker
MOTM - Mar '14
yep, funny thing is that I would probably have fixed my 250 by now if I hadn't gotten it, but it should all work out someday down the road. My 300 is my main bike now and my 250 would either make a sick track bike or an amazing birthday gift to my brother. I keep getting hung up on things that I want for my 300 and continuously getting more gear with my free money though hahaha
January 16th, 2014, 06:26 PM | #58 | |
how is the upgrade? Are the 50cc worth it? I am thinking of buying a Ninja 300 myself. |
January 16th, 2014, 06:35 PM | #59 |
Private Joker
MOTM - Mar '14
The power upgrade isn't that big up top, with my gearing altered my 250 was topping out at higher speeds than my 300. Then again I haven't really pushed my 300 nearly as long for a top speed. The extra power is felt with a passenger and when cruising around you can pull a bit more to pass people, it's much better but it's not night and day power difference like a 600 would be. What I noticed was the better stock suspension and fuel injection. Those two things make it a massive improvement over the pregen 250, the tire sizes are much better too (140 rear and can fit 150 so you have easy access to some very sticky rubber) I love the modern feel of the bike and with riding 2up from time to time the extra 50cc is great. I'd change out the front brake pads pretty quickly though for better braking feel. Also having abs is so convenient when you tend to smash the rear brake pedal a bit too hard. The tank feels better (it's a bit bigger) but stomp grip puts them fairly even in that respect. Really the biggest reason to get a 300 after owning a 250 is for the fuel injection, being able to start right up regardless of the weather is awesome.
January 16th, 2014, 07:34 PM | #60 | |
Thanks! Its nice hearing a review from someone who actually upgraded from the exact same bike as mine. |
[visordown.com] - Helmets that increase chance of death seized | Ninjette Newsbot | Motorcycling News | 0 | May 20th, 2014 02:10 AM |
[visordown.com] - Sean Emmetts phone and laptop seized | Ninjette Newsbot | Motorcycling News | 0 | January 7th, 2014 09:50 AM |
[visordown.com] - Council releases video of seized motorcycles being crushed | Ninjette Newsbot | Motorcycling News | 0 | December 19th, 2013 10:00 AM |
Seized engine | Hawaiininja | 1986 - 2007 Ninja 250R Tech Talk | 28 | December 7th, 2012 05:57 PM |
[topix.net] - This supermodel seized a million hearts | Ninjette Newsbot | Motorcycling News | 0 | May 11th, 2010 09:10 AM |
