Go Back   ninjette.org > Marketplace > Motorcycle-related
Old August 7th, 2009, 06:08 PM   #41
im_a_ninja
im_a_ninja's Avatar
ninja decals
Could you do this?
This is "ninja" in kanji and I would LOVE to have these on my bike.
im_a_ninja is offline   Reply With Quote
Old August 7th, 2009, 07:00 PM   #42
kevins_garage
Motorcycle(s): 2008 Ninja 250R, 2007 Aprilia SR50R scooter
Originally Posted by im_a_ninja View Post
Could you do this?
It would depend on what resolution/quality of file you can send me and what format it is in. If you want to e-mail the image file to me and let me know what color and size you want, I can let you know what I can do.
kevins_garage is offline   Reply With Quote
Old August 7th, 2009, 07:10 PM   #43
im_a_ninja
im_a_ninja's Avatar
what's the best file format?
I just found that picture and copied it. I'm not extremely familiar with file formats but I would guess that I could find it in a right fomat or convert it somehow.
Although I could be wrong.
I'll email you what I have and we can go from there.
Old August 7th, 2009, 07:20 PM   #44
kevins_garage
Ideally, line art .ai or .eps files are best, as long as that is how they were originally created. I can convert other image files, but they are not nearly as clean as an .ai or .eps that was created as "line art" to begin with.
Depending on the resolution/quality of non .ai and non .eps files, it can take anywhere from 15-20 minutes all the way up to hours and hours to clean up the converted image so it cuts nicely. Usually, the higher the resolution on .bmp or jpg files, the cleaner they convert and the less time they take to fix up - 600x600 to 800x800 or higher is usually better.
Old August 8th, 2009, 01:43 PM   #45
kevins_garage
Could you do this?
Here's a sample that's ready to cut if anyone wants these.
Old August 8th, 2009, 08:44 PM   #46
im_a_ninja
im_a_ninja's Avatar
YAY, it looks SO good! You are awesome for sure.
I will be measuring out the places I want them on my bike and I'll let you know ASAP.
I'm very excited.
Old August 11th, 2009, 01:48 PM   #47
Grn99Kawi
Grn99Kawi's Avatar
Motorcycle(s): 2000 Honda CBR600F4 (sold) 1999 Ninja 250 (sold)
Here's a question..
I'd like 2 Kawasaki scripts (can you do 10in long in white?), the 2 standard Ninjas and then 2 smaller Ninja scripts.. specifically for the windscreen.. they might be 4in long.. not sure.. in white too... I only need one for the windscreen in reality, but it would be great to have a spare just in case.. here is a pic of a stock windscreen for comparison..
Can you do those and how much for all of them?
Thanks,
Adam
2000 Honda CBR600F4 Silver and Red
1999 Kawi Racing Green Ninja 250 sold
Grn99Kawi is offline   Reply With Quote
Old August 11th, 2009, 07:22 PM   #48
mike_sema
mike_sema's Avatar
Motorcycle(s): ninja 250r
could you make a Kawasaki decal for the tank that would go over the stock one, I have an 08 blue but hate the white Kawasaki sticker, I just do not want to sand the tank down to change the color
08 250R: sportisi VR full exhaust, Dynojet, custom seat, kleen air rmvd, rim tape, grips, fender chop,zg db windscreen,k&n air filter,15t front sprocket,sportisi-usa clipons,solo seat cowl
mike_sema is offline   Reply With Quote
Old August 11th, 2009, 08:20 PM   #49
kevins_garage
That's not an easy one as it seems as though there is some variance from bike to bike on the tank stickers. I could probably cut something slightly larger than what's on there to make sure it covers, but you will pretty much have to install each letter individually.
I have had a few bikes painted over the years and I never put stickers under the clearcoat. It boggles my mind why any bike manufacturers still do that.
Old August 11th, 2009, 08:32 PM   #50
Snake
Snake's Avatar
I don't like the fact that my bike has an orange stripe sticker on the tank that I can't remove because it is clear coated but I understand that the reason they have to put clear coat over it is so that any fuel that is spilled will not make the sticker fall off. With that said I am not sure if your stickers are able to stand up to fuel spills.
Old August 11th, 2009, 08:40 PM   #51
kevins_garage
I've been riding for over 20 years and I've never spilled fuel when filling up my bike tanks. I also use the same vinyl/stickers on my jet skis also and those I have spilled fuel on when refilling from gas cans in rough/wavy water. The vinyl I use has held up well to those gas spills though. The only time I can envision it being a problem is if the stickers were repeatedly soaked in gas - it would probably adversely affect their longevity to some extent - but my jet ski stickers have been on for 3-4 years now without issue.
Old August 12th, 2009, 05:35 PM   #52
mike_sema
mike_sema's Avatar
well if you can make them i will give it a try let me know how much $$ to send you thanks mike
Old August 12th, 2009, 05:46 PM   #53
kevins_garage
Let me work something up over the next few days and I'll let you know.
Old August 12th, 2009, 05:49 PM   #54
I'd be interested in changing the tank lettering, too.
Old August 12th, 2009, 06:07 PM   #55
mike_sema
mike_sema's Avatar
cool thanks
Old August 12th, 2009, 08:08 PM   #56
mike_sema
mike_sema's Avatar
hey i will order the decal pack with the black zx-2r with a red R,black ninja sides and white small kawasaki. could i also get the in and out of the decal i would like to match the decals from my bike to an extra helment that i have using the outer decal as a mask thanks mike
Old August 19th, 2009, 12:12 PM   #57
Grn99Kawi
Grn99Kawi's Avatar
just sent payment.. Kevin is quick to respond to questions, and I am anxious to see the decals.. I'm sure they will be great.
Old August 19th, 2009, 10:24 PM   #58
ASecretNinja
ATGATT Squid Killer
ASecretNinja's Avatar
Motorcycle(s): '06 CBR600
Could you possibly replicate this? I don't know if its obvious in the picture, but the pink/purple script is incredibly faded, or rather it looks very murky. I'm looking for a fresh purple/pink, not the nasty one that's on my bike. Key is on there for size comparison. It was really misty that night, hence the dew and smears on my bike.
Here is my bike's color scheme:
ASecretNinja is offline   Reply With Quote
Old August 20th, 2009, 06:59 AM   #59
tc3jg
Motorcycle(s): 08 ninja 250r
kevin I just got my cutter and have been doing some cutting ...cuddos to you for starting it up with our members on this forum. and greatwork from a fello cutter
tc3jg is offline   Reply With Quote
Old August 20th, 2009, 02:30 PM   #60
kevins_garage
That looks to be metallic or metalflake - I don't have those colors/types of vinyl right now (the only colors I have right now are on the first page of this thread).
I don't think I have that exact Ninja artwork (looks a little more jagged around the edges than the one I have), but it would be possible to do something similar with the artwork I have - it would be done by simply cutting the design out of 2 pieces of different color vinyl and then placing one over the top of the other with a little offset to create the shadow effect.
Old August 20th, 2009, 10:07 PM   #61
Momaru
Momaru's Avatar
Just wanted to say thanks again Kevin, really dig the new vinyls (will post pics soon as we have a clear day), the price and the superfast turn-around.
Had a fun time trying to get the geometry right from the original one with the new font on the fairings, but like the new look.
Proud member of the Blue Army
Last futzed with by Momaru; August 23rd, 2009 at 01:46 PM. Reason: pics
Old August 22nd, 2009, 05:13 PM   #62
Postiez
Postiez's Avatar
Motorcycle(s): Red '08 250
really quick, thanks =)
Postiez is offline   Reply With Quote
Old August 22nd, 2009, 10:33 PM   #63
watcanido
watcanido's Avatar
Anyone have a close up pic of the European "250R" decal? or know which font it is? I want to get Kevin to do that for me.
watcanido is offline   Reply With Quote
Old August 23rd, 2009, 06:26 AM   #64
Plasmatoast
Plasmatoast's Avatar
Motorcycle(s): 09 250R - 08 250R - 03 250EX - 86 KLR 250
best I could find, Pulled from the Kawasaki Australia site
Plasmatoast is offline   Reply With Quote
Old August 23rd, 2009, 08:34 AM   #65
Sound Wave
Ramen Rider
Sound Wave's Avatar
not sure if the european and japanese ones are the same, but:
http://www.kawasaki-motors.com/model...250r/index.jsp
Old August 23rd, 2009, 10:42 AM   #66
watcanido
watcanido's Avatar
Thanks a lot Ryan and Gary you guys are awesome. I emailed Kevin just waiting for a reply.
Old August 23rd, 2009, 05:11 PM   #67
kevins_garage
Small but can be zoomed easily Attachment 3644
Unfortunately, small .jpg or .bmp files do not zoom easily - they tend to become badly pixelated with very jagged edges when you zoom them to a viewable/usable size. Vector graphics files do not do that as they are essentially "line art", and they scale up or down without degradation - all lines remain smooth and straight.
In order for me to cut from .jpg or .bmp file, I need the actual image to be somewhat large - preferably 600x600 or 800x800 or larger depending on level of detail - so I can digitize it and clean it up quickly and easily. I think I've seen that 250R image floating around online, but couldn't find it just now. I'll look around and see what I can come up with. If anyone else finds one in the meantime, feel free to e-mail it to me.
Old August 24th, 2009, 03:19 PM   #68
Grn99Kawi
Grn99Kawi's Avatar
I received my decals today.. although I bought the side ones, I dont really need them now. but the price was right for sure. I put the smaller Ninja script on my double bubble and it looks perfect.
Thanks Kevin. I'll definately contact you first for decals.
Old August 24th, 2009, 04:49 PM   #69
noche_caliente
noche_caliente's Avatar
Motorcycle(s): '08 250
Just saw Paul out randomly a bit ago - the decals were one of the first things I noticed - looks great!
Progrip tank pad, blue rim stripes, blue Pazzos, Roaring Toyz lowering kit, Puig DB in dark smoke, Cortech sport tail, super mini tank, and saddlebags, OES swingarm spools and Intuitive frame sliders
Old August 24th, 2009, 10:07 PM   #70
Postiez
Postiez's Avatar
so my dad saw my decals and hes pretty jealous, he rides a '75 rd350 and is dieing for a
so I told him I'd at least ask if you can make this, and how much
thanks =)
Old September 3rd, 2009, 07:42 PM   #71
kevins_garage
<image removed due to size>
thanks =)
Sorry for not posting a reply sooner, but I didn't get an auto notification about new posts for some reason.
No problem doing that - just e-mail to let me know what size a color you want and I can let you know a price. kevins_garage@yahoo.com
Old September 6th, 2009, 01:00 PM   #72
mike_sema
mike_sema's Avatar
hey just checkin in to see if you would still be able to make decals for the tank thanks mike
Old September 7th, 2009, 02:05 AM   #73
ninjablk08
ninjablk08's Avatar
Motorcycle(s): blk ninja 250 2008
2 bro CFSO, factory pro 3, hotbody DS , krayzie graphics rim tape, brake flasher, DIY fender chop, DIY flushmounts & LED rear, K&N filter, 15/43 Driven, DID race chain, air stuff removed, clipons
ninjablk08 is offline   Reply With Quote
Old September 8th, 2009, 09:48 AM   #74
Sound Wave
Ramen Rider
Sound Wave's Avatar
kevin,
i sent you an email for an order a few days ago. just wondering if you received it. thanks.
Old September 8th, 2009, 09:53 AM   #75
kevins_garage
Originally Posted by Sound Wave View Post
kevin,
Yep - email received Sunday - I was out of town for the holiday weekend (got back late last night) and just getting back to replying to emails today.
Old September 8th, 2009, 10:10 AM   #76
kevins_garage
I can get pretty close with the "Kawasaki" logo file that I have, but each letter would have to be applied over the top of the existing tank letters individually to make sure they are lined up and cover fully. There is enough variance tank to tank and with the curvature of the tank that it isn't going to work properly by applying all the letters (the entire sticker) at once.
In other words, it is going to be a bit of a pain to install and line up properly.
I still need to make some minor adjustments to make sure each letter completely covers the letter they will be applied over. Not enough time lately to get it done. I'll try to get a final cut-able file done by this weekend.
Old September 9th, 2009, 05:34 AM   #77
divingtigger
Pedal Power
divingtigger's Avatar
Motorcycle(s): 2008 Ninja EX250R
Do you have a close match to the Kawasaki lime green? Rethinking what I want to do with my bike
Using Pedal Power
divingtigger is offline   Reply With Quote
Old September 21st, 2009, 10:21 AM   #78
stealth250
Gearhead
stealth250's Avatar
Tapeworks makes what you are looking for...
http://www.tapeworks.com/KAWASAKI%20...2logosets.html
stealth250 is offline   Reply With Quote
Old September 21st, 2009, 10:45 AM   #79
stealth250
Gearhead
stealth250's Avatar
Kevin,
Can you do this logo? (just the 250r)
-Mike
Old September 21st, 2009, 11:34 AM   #80
kevins_garage
They're a bit pricy at $49+, don't you think.
I'm not sure how theirs work out as there is no way to guarantee that the end user is going to be able to apply them perfectly.
The letters are pretty close together and really would need to be applied essentially one at a time, which is time consuming and may not provide the desired end result. I tried a few local bikes and it was a royal pain in the ass - the best way to change the lettering on the tank is to have it repainted and then apply graphics over the top so they can be removed/changed in the future. If you don't want to repaint the entire tank, you may be able to sand in the area of the original sticker just enough to get through the clear coat, remove the stickers (hopefully the paint underneath isn't blemished), and then have the entire tank sanded and re-cleared.
I'm going to stay away from the tank overlays as they are likely to cause more problems than they are worth.
Vinyl Stickers/Decals... Who Here Can Make Some? kkim General Motorcycling Discussion 1 June 25th, 2009 11:46 PM
