Old February 8th, 2012, 10:38 PM   #41
treetrimmerguy1977
Motorcycle(s): 2011 Kawasaki Ninja 1000, 2003 Kawasaki ninja 250r
Thanks!!
treetrimmerguy1977 is offline   Reply With Quote
Old June 14th, 2012, 01:38 AM   #42
Jester23
Motorcycle(s): 2009 Ninja 250, 2007 Daytona 675
Thanks a ton for the the writeup! Just an FYI for everyone out there doing this on a 2009 (maybe it's the same on the 2008+ bikes) that there is no U shaped markings on the clutch hub so stop looking for it for almost an hour
Just make sure you line up all the U shaped cut outs on the edge of the friction plates with each other.
Jester23 is offline   Reply With Quote
Old June 14th, 2012, 07:27 AM   #43
Good info, thx!
Old June 14th, 2012, 12:41 PM   #44
davenay67
davenay67's Avatar
That was a pictorial how-to and a half....awesome.
What kinda mileage are folks getting from their 250's before needing new clutch packs..??
Old June 14th, 2012, 12:45 PM   #45
headshrink
headshrink's Avatar
Mine was 20-25K
Old June 14th, 2012, 01:25 PM   #46
it depends on how you use the clutch. i have over 20k miles and my clutch plates look brand new (i also dont hardly use the clutch) however my friends bike has around the same mileage but his clutch plates were completely spent.
Old June 22nd, 2012, 04:32 PM   #47
n4mwd
n4mwd's Avatar
Nice DIY. I will use it to try to figure out whats wrong with my bike's clutch.
My Ninja Blog
Old June 22nd, 2012, 05:48 PM   #48
eddiekay
eddiekay's Avatar
Motorcycle(s): 300, WeeStrom
Wow.....Who needs an FSM with guys like you on board...excellent + +
Old June 28th, 2012, 11:10 PM   #49
Palero
Palero's Avatar
Motorcycle(s): 1988 Honda Hawk GT 1989 EX250F (Died from left-turning car) 2011 EX250J (Died from SAME left-turning car)
Just replaced the plates in my Ninja today, thanks to this guide!
Thanks again.
Note, remember to torque the clutch springs at 78inch pounds, not 77foot pounds like I did.
Looking to take some motorcycle classes this Summer?
Palero is offline   Reply With Quote
Old June 28th, 2012, 11:35 PM   #50
headshrink
headshrink's Avatar
LOL, for some reason I thought you were joking about replacing your license plate for a sec...... it's late. night, night.
Old July 26th, 2012, 09:05 PM   #51
kingkang204
Motorcycle(s): Bike-less, Can I ride yours?
Does anyone with an 08+ know the part number for the paper gasket?
RR stands for Responsible Riding... Right?
kingkang204 is offline   Reply With Quote
Old July 27th, 2012, 04:12 AM   #52
n4mwd
n4mwd's Avatar
look it up on ronayers.com.
Posted via Mobile Device
Old July 27th, 2012, 09:08 AM   #53
kingkang204
After some digging through Ron Ayers I found it.
For future info its under Engine Cover(s).
Thanks for recommending Ron Ayers! It's about $30 less for the plates than where I was looking.
Old July 27th, 2012, 09:41 AM   #54
n4mwd
n4mwd's Avatar
The clutch plates are available aftermarket for even less. There are also numerous sources for clutch springs that squeeze a little harder so you can get a little more life out of the existing plates. They are usually about $15 a set.
See if this link works...$53.99
Generally you only replace the fiber plates. The metal ones only get replaced if they are out of spec.
EDIT: Oops, I just realized you have the newgen. The links are to the pregen plates, but they probably have newgen plates as well.
My Ninja Blog
Old July 27th, 2012, 11:45 AM   #55
kingkang204
I read on one of the 250 (sub)forums that the aftermarket plates are of lesser quality than the OEM ones.
Old August 4th, 2012, 01:36 PM   #56
headshrink
headshrink's Avatar
I have a set of plates, gasket, and upgraded springs that I didn't use when I broke my first motor. I would have to double-check, but I'm pretty sure they are the EBC plates. They haven't been installed, but I did pre-soak them in oil (it's been a while, so it's a good idea to do it again though before installing them). I'm not currently putting them up for sale, but might consider it if someone wanted them.... maybe, since I'll eventually need to do mine.
Old August 16th, 2012, 07:54 PM   #57
John D
Motorcycle(s): ninja
How do I know if my springs are weak should I be able to sqeeze them with my hand because I can.Not like collapse them but able to move them I would think by hand no way should I be able to to so
John D is offline   Reply With Quote
Old August 17th, 2012, 04:54 AM   #58
n4mwd
n4mwd's Avatar
The proper way to test them is with a caliper. The springs shrink as the get weaker.
The uncompressed length of OEM springs should not be less than 31.7 mm. Many aftermarket springs are longer to start with.
My Ninja Blog
Old August 24th, 2012, 11:51 AM   #59
John D
clutch not turning
Ok I did all the obove and the pics are awesome so now im putting it back together and the clutch is not turning as im tightening the spring bolts is this a problem i dont want to put it all together and have somthing wrong or will this be ok it turn out the person that had the bike before me didnt have it indexed as you say to do here so i changed that so that why im even messing with it any ideas
Old August 24th, 2012, 11:54 AM   #60
headshrink
headshrink's Avatar
I just wanted to confirm your bike is indeed a pre-gen. It's my understanding that the '08-'12 bikes aren't indexed.
Old August 24th, 2012, 12:22 PM   #61
John D
yes it a 2003 got it from a guy that had his friend change the clutch and it did not work out so i took it off his hands for a great deal now i need to figure it out cant wait to ride it
Old August 24th, 2012, 01:38 PM   #62
you might want to make a new thread about your problem... makes things easier
Old December 10th, 2012, 05:50 AM   #63
fadownjoo
Motorcycle(s): ninja 250 07
possible?
My first gear is slipping, is it possible for me to change out just one friction disk for the first gear? Moneys tight =( . If so , which disk is supposed to be first gear?
fadownjoo is offline   Reply With Quote
Old December 10th, 2012, 06:44 AM   #64
n4mwd
n4mwd's Avatar
Its all or nothing. Try adjusting the cable first. Some people just throw in new springs. The aftermarket ones are stronger and can get more out of the plates.
My Ninja Blog
Old March 15th, 2013, 01:44 AM   #65
eksine
Motorcycle(s): 2006 ninja 250
Originally Posted by Purspeed View Post
Clutch Cover Plate TORQUE SPECS: 87 in/lbs.
somehow that doesn't seem right. I watched a youtube video of a guy doing it and he said hand tight, 10-12 lbs I think he said. I thought 10 pounds is way too weak, 15-20 pounds sounds about right. 87 pounds sounds way excessive though, those bolts look weak and might break at that force. I'm probably wrong, but does not sound right
eksine is offline   Reply With Quote
Old March 15th, 2013, 02:26 AM   #66
87 in/lbs = 7.25 ft/lbs
Old March 15th, 2013, 08:48 AM   #67
cookiebug79
n00b with the b00bs
cookiebug79's Avatar
Motorcycle(s): 2007 EX250, 2008 EX250, 2001 ZR-7S, 2010 ZX-6R
FWIW I followed this on Wednesday and everything went flawlessly. THANK YOU for the great write up and all the pictures!
cookiebug79 is offline   Reply With Quote
Old April 14th, 2013, 11:15 PM   #68
eksine
@Purspeed, thank you so much for this DIY. I have a short attention span but somewhow managed to understand this. One thing I noticed on my 2006 is that the direction of the friction plates have the "teeth" biting towards the front. like on a cutoff saw how the teeth bite down like claws onto wood, thats how the teeth on these were facing, except maybe the very last one, but I might have mixed it up so I refaced it to face the same as the rest. It might not matter which way they face but I like them to all face the same way at least and unless I mixed them up I think thats how it came from the factory cause I only have about 6000 miles on this. also how you said the smooth side of the metal plates faces inward, Im pretty sure thats how these were oriented so good call. The only reason I did this because I thought my springs were low but turned out I did it for nothing, but now I know. thanks again!
Old April 15th, 2013, 04:54 PM   #69
Kevin H
Motorcycle(s): 1997 Kawasaki EX 250, 1997 HD Road King, 1980 HD Sportster
What you need is a new set of springs. You can check the condition of the plates and discs while your'e in there, but its a safe bet that they are fine if you havent been slipping it for too long.
Kevin H is offline   Reply With Quote
Old June 12th, 2013, 04:37 PM   #70
abhijitz
Motorcycle(s): Many Two Wheels ..
Hi, so when you are referring to edges, you mean the surface, correct? As, one surface side of the metal plate is smooth/roundish other side is flat. On the 08+ manual there is no mention which surface should be placed towards the bike or away from the bike. I had put the flat surface towards the bike when i changed my clutch last year. [And that is how OEM plates were placed]. Is it specifically mentioned in the 2007 manual on the surface orientation?
Also, does the 2007 manual call for any thickness spec for the metal plates?
The last image is of a new metal plate. You will want all of the "sharp" edges of the new metal plate pointed AWAY from the bike when installing. The "sharp" edge is difficult to see in the picture, but when you see them in person, you will notice that on one side of the disc edge, it is softer than the other side. This is due to the stamping process of manufacturing the metal plates. Why do you want the "sharp" edges pointed outward? Because, theoretically, when the pressure plate pushes on the discs, the "soft" edge will not sheer the hub (housing) edges and be smooth in actuation. Some say that as long as the "sharp" or "soft" edge run in the same direction, you are okay.
The Kawasaki manual states that the sharp edges should be pointed to the outside of the bike.
[ex-AFM #828 | SMUSA #828 |
Sponsors : MotionPro | LeoVince | Insurrection Racing Gloves | QstarZ Laptimers
+ OEM Parts @ 30-40% OFF : Harry @ 1-877-437-1631,17 harry@hondaeasttoledo.com
abhijitz is offline   Reply With Quote
Old August 20th, 2013, 06:17 PM   #71
ukie
Motorcycle(s): Ninja 250 2004
Center Rod Free Play
Should there be any free play (in and out) of the center rod which connects to the clutch cover lever?
ukie is offline   Reply With Quote
Old August 20th, 2013, 06:43 PM   #72
n4mwd
n4mwd's Avatar
There is a small amount of free play, but not much. Not sure what the actual measurement is, but I'd guess about 1/16".
My Ninja Blog
Old October 23rd, 2013, 06:29 PM   #73
Vince91889
Need help with my 2008 250r. There is no indexing on the plates. I have aligned all the U shaped clutch plates together and the clutch still won't grab.? What do I do?
Vince91889 is offline   Reply With Quote
Old October 23rd, 2013, 06:30 PM   #74
Vince91889
Jester what do you mean on the edge of the friction plates?
Old October 24th, 2013, 07:43 AM   #75
n4mwd
n4mwd's Avatar
You should ask this in the 2008 section.
My Ninja Blog
Old November 30th, 2013, 11:27 PM   #76
Purspeed
Purspeed's Avatar
@eksine: My pleasure!
@cookiebug79: Truly glad it worked out for you.
"This is my Ninja. There are many like it, but this one is mine..." ~ Purspeed (ca. Nov, 2008)
Purspeed is offline   Reply With Quote
Old December 1st, 2013, 12:17 AM   #77
Purspeed
Purspeed's Avatar
Hi abjijitz,
Although I realize this information is a bit late for your clutch replacement, I'm answering anyway so others with the same question can benefit, too.
The metal plates are manufactured by "stamping" them out using dies and a hydrolic press. These dies are essentially cookie cutters for metal...in this case, sheet metal. When these parts are stamped out, the outside edges are cut by the die "slamming" down on the sheet metal. Due to this process, one side of the edge will be sharp and if you flip the metal plate to the opposite side, that edge will be slightly rounded.
You can baaaaarely see it in the pics I posted, but in person, you'll certainly see it and feel it. The edge that I'm talking about is the outside edge of the metal plates.
The main issue when stacking the plates along with the friction discs when installing is that the rounded, outside edges are all pointed either away from the bike or towards the bike. What you'll do is simply pick up a metal plate, feel the edge (or look at the edge closely) place it down...then place down a friction plate...then pick up another metal plate, feel the edge and orient it the same way as the first one and so on.
Imagine it like stacking dinner plates. After washing dishes, when you stack your dinner plates, you stack them one way (because that's how they fit together best). In this case, the metal discs are totally flat on both sides, so to figure out how to stack them, look at the outside edges: you want to stack them according to the outside edge, which is a by-product of the stamping process. One edge will be a sharp 90-degree edge, the other will be a dull, ever-so-slightly rounded edge.
In terms of manufacturing spec thickness of the plates, I do not have the information or OEM plates to measure, unfortunately.
Hope that clarifies things a bit for you.
TO EVERYONE: Feel free to post questions in this thread. I'll try to pop in now and again and answer them for you. And if it's a while, at least it'll give others a chance to clear things up when I do post, so it's a win win.
DIY Replacing the clutch cable islanderman7 2008 - 2012 Ninja 250R Tech Talk 28 March 21st, 2017 08:17 AM
Clutch plates stuck? dragono 1986 - 2007 Ninja 250R Tech Talk 37 February 28th, 2015 01:58 PM
Ninja Clutch Plates Vince91889 2008 - 2012 Ninja 250R Tech Talk 9 October 24th, 2013 09:59 PM
clutch plates and steels mgentz 2008 - 2012 Ninja 250R Tech Talk 21 February 20th, 2013 08:50 PM
I think I need clutch service/friction plates replaced. :( CZroe 2008 - 2012 Ninja 250R Tech Talk 22 July 22nd, 2011 01:06 PM
