Old March 17th, 2012, 06:36 PM   #41
leed
leed's Avatar
Motorcycle(s): Time will tell
It was to the better of my understanding that the heat shrink goes onto the bars to provide insulation (keeps the heat from transferring directly to the bars).
I am not sure about the tape provided, it may be to hold both ends of the adhesive heat-pad down and prevent it from coming undone when putting the grips on. Needless to say, the grips should not melt, even on the highest setting. I've had mine on all winter without issue.
Old March 17th, 2012, 08:42 PM   #42
bkh2
bkh2's Avatar
Motorcycle(s): 2006 GSXR 750; 1983 CB750SC
Thanks. Also, is there a connection point closer to the front of the bike that I can attach the leads to? Because the wires are way too short to reach the battery, should I extend them? Sorry for so many questions...
bkh2 is offline   Reply With Quote
Old January 14th, 2013, 06:28 PM   #43
BlackNinja8
BlackNinja8's Avatar
Motorcycle(s): 2011 250R (Sold); 2012 Vulcan 900; 2009 Harley Iron 883; 2004 SV650s; and a bunch of others over the years...
So what was the final verdict on these things? Did they last, burn out, short in the wet? @Jiggles, @dubojr1, anyone else?
BlackNinja8 is offline   Reply With Quote
Old January 14th, 2013, 06:52 PM   #44
bkh2
bkh2's Avatar
They don't get hot enough for my liking. It's a good thing I bought two, because I layered them and that allowed it to get hotter. Definitely usable now, but still not as hot as I'd like.
Poor wiring caused mine to short out, but that's totally my fault. The pads were fine, just the wiring got damaged. I'm going to redo the wiring soon. If you're super cheap and don't mind using a little finesse, I would recommend these.
Old January 14th, 2013, 07:14 PM   #45
BlackNinja8
Thanks, sounds like one of those "you get what you pay for" deals. Super cheap? Check. Finesse? Not so much.
Amazon has what looks to be very similar model for $20 and the reviews seem great. May go that route rather than buying 2 ebay cheapos and keeping my fingers crossed.
Old January 14th, 2013, 08:00 PM   #46
Jiggles
Jigglin' your Jiglets
Jiggles's Avatar
MOTM - Apr '13
I gave them away
AFM #676
Supersports are for n00bs
DIY - Hot Grips Heated Grips Install NathanF 2008 - 2012 Ninja 250R Farkles 26 January 23rd, 2014 03:37 PM
Anyone using heated grips? caineroad General Motorcycling Discussion 5 September 24th, 2013 06:05 AM
tried these heated grips? smackenz 2008 - 2012 Ninja 250R Farkles 7 October 17th, 2012 03:11 PM
heated grips bhalv 1986 - 2007 Ninja 250R Farkles 10 January 17th, 2011 09:39 PM
Heated Grips sudadoda 2008 - 2012 Ninja 250R Farkles 7 May 4th, 2010 07:15 AM
