Old February 9th, 2012, 12:08 PM   #41
ROADandTRACK
R&T Suspension
ROADandTRACK's Avatar
And that design doesn't work
ROADandTRACK is offline   Reply With Quote
Old February 9th, 2012, 12:18 PM   #42
Nemesis
CVMA #74 WSMC #750
Nemesis's Avatar
Motorcycle(s): All of them
Old February 9th, 2012, 08:00 PM   #43
smokinsingle
L8APEX
smokinsingle's Avatar
Motorcycle(s): 07 KTM 950SMR, 06 KTM 450SMR, 99 KTM 300MXC, 00 Derbi GPR 50, 09 Ninja 250 racebike, race with www.cra-mn.org!
Don't you ride pre-gens?
www.joemillersmoderngarage.com www.starr-cycle.com
***The most important concept of science isn't memorizing facts, it's observation of phenomena.***
smokinsingle is offline   Reply With Quote
Old February 9th, 2012, 09:54 PM   #44
ROADandTRACK
R&T Suspension
I build all types of road race bikes. I've built quite a few EX250's that have won in CMRA. Also did the suspension on the CBR250 that has been doing well out there. Basically same suspension as the EX. But the CBR has a better chassis.
I haven't ridden an old gen in a couple of years.
The last one I rode had new gen forks w/ new gen rear wheel. We built it because our old gen had a couple more hp, but when the motor finally let go it was parked.
Only pic I have on a new gen.
http://www.flickr.com/photos/9479484@N02/6849984643/
Last futzed with by ROADandTRACK; February 23rd, 2012 at 04:55 PM.
Old March 15th, 2012, 10:20 AM   #45
Kangxi
OMRRA 701
Motorcycle(s): 'jette, R6
ArmourBodies Fender attachments
Further to this conversation, I am wondering if it is required/necessary to attach a race bodywork fender (such as ArmourBodies) to the two mounting points along the top of the fender on the back side.
It is still unclear how much of the bracket needs to be retained even if one makes the decision to "get rid of it".
Any pix of various race set ups on the front fender and bodywork would be greatly appreciated!
Kangxi is offline   Reply With Quote
Old March 15th, 2012, 03:14 PM   #46
samw
Motorcycle(s): 2005 HON CBR1000RR Repsol, 2012 KAW Ninja 250R
My Sharkskinz front fender does not use those mounting points... see attached pic. Stock on left, Sharkskinz on right.
samw is offline   Reply With Quote
Old March 17th, 2012, 10:05 AM   #47
RSPILOT
RSPILOT's Avatar
Motorcycle(s): Too many. Some are in the house.
I run the brace. I guess I'm not going fast enough.
RSPILOT is offline   Reply With Quote
Old March 19th, 2012, 04:34 PM   #48
ROADandTRACK
R&T Suspension
The stock "brace" is a fender mount.
and maybe.
Old March 19th, 2012, 04:50 PM   #49
FishaRneked
Motorcycle(s): 2011 Ninjer 250, 2002 TL1000R, 2009 Concourse14, 2009 ZX6, 2006 SV650
The EX's handle better at speed w/o a fork brace. Believe it or not.
The little advantage was under braking, but you can deal w/ the twisting under braking. The binding up/chatter fast sweeper runing off track problem sucks.
Better w/o it if you are a front runner
Originally Posted by smokinsingle View Post
That "fender mount" is a fork brace. Designed to keep the front end from twisting up like a pretzel on the track. It adds a substantional amount of stiffness to the front of the bike, especially on the brakes. Leave it alone! I'm trying to wrap my head around a way to make a stiffer one that looks stock!
Just me or are these two exactly opposide statements
FishaRneked is offline   Reply With Quote
Old March 20th, 2012, 08:14 AM   #50
ROADandTRACK
R&T Suspension
You are correct.
I think what is getting confusing is when I am talking about a fork brace I usually think of a real fork brace not that fender bracket. That bracket is huge and Kawi may have intended it as a kind of "fork brace" but it is not strong enough to affect much at race speed.
Old March 20th, 2012, 09:50 AM   #51
675Raisinator
675Raisinator's Avatar
Name: Zander the Expander
Motorcycle(s): 2010 Kawasaki 250 (Track scooter) 2012 Triumph Daytona 675
so should i ditch this thing or what?
675Raisinator is offline   Reply With Quote
Old March 20th, 2012, 03:12 PM   #52
you guys are confusing me. at what point are you getting chatter? fork braces on standard forks are supposed to help keep the fork lowers from twisting around the uppers and twisting the wheel, right? that doesn't seem to me like it effects braking much, considering the front stays rather calm in terms of sway movement under hard braking until it starts locking from too much brake... now if you are talking about twisting on turn in when trail braking, i could understand that being helped by a fork brace. the force of braking is on one side of the tire... could cause it to twist a little bit... or if you are heavy on the bars with your turn in... a fork brace would definitely help keep that from happening (excess twisting of the wheel compared to the bars). though, when this is all happening, the forks are compressed, so a fork brace is almost completely useless... what effect the front wheel twisting a little bit has on handling or performance... i almost want to say it has none outside of wear on the forks... if someone can explain otherwise please by all means... i mean, yes the bars will twist more than they "should" when its flexing like that. but that seems like the only difference? doesn't really effect handling...
Old March 20th, 2012, 03:15 PM   #53
Rexbo
CVMA / AFM / M1GP #250
Rexbo's Avatar
Motorcycle(s): 2009 Ninja 250r, 2011 Zero S, 2009 KLR 650
At all times, everywhere. Just the way 2fiddys roll
Rexbo is offline   Reply With Quote
Old March 20th, 2012, 03:24 PM   #54
getting chatter while sitting on the stand. plz fix.
Old March 21st, 2012, 01:16 AM   #55
I sat on the bike after it had been sitting all winter and thought I was getting chatter at a stand-still until a couple of Akima's angry friends came out of the fairings and started harassing me.
Old March 21st, 2012, 06:05 PM   #56
samw
If you ditch it you need to find a way to mount the front fender, assuming you want a front fender. I believe some folks cut out the center part of the bracket?
Old March 22nd, 2012, 05:17 PM   #57
ROADandTRACK
R&T Suspension
Nothing wrong w/ keeping the OEM bracket.
Old March 22nd, 2012, 06:48 PM   #58
Nemesis
CVMA #74 WSMC #750
Nemesis's Avatar
Werd.
I can vouch for Wes.
Old October 20th, 2015, 02:30 PM   #59
Dsheumaker
Dsheumaker's Avatar
Motorcycle(s): 14 Ninja 300 (Track Only), 07 CRF150RB
So to relive a super old post... Did anyone do this? With that results?
Dsheumaker is offline   Reply With Quote
Old October 20th, 2015, 07:47 PM   #60
cbinker
Track Clown
cbinker's Avatar
MOTM - Sep '15
TEAM ALFALFA
www.apexassassins.com
5 - 7 inch piece of bent metal on my bike IF13 2008 - 2012 Ninja 250R Tech Talk 3 August 21st, 2013 02:51 PM
Front Fender - Metal Bracket Removal Rollin.. 2008 - 2012 Ninja 250R Tech Talk 4 August 14th, 2013 06:35 AM
metal stock alex.s Off-Topic 4 April 14th, 2011 02:39 PM
2008/2009 Stock Blue Front Fender FREE! TygaUSA.com Motorcycle-related 4 July 16th, 2010 12:36 PM
Selling - Stock '09 Fender/Blinkers (Front) Brently7785 Items Wanted 5 June 1st, 2010 09:49 PM
