February 7th, 2012, 08:17 AM | #921 |
Join Date: Nov 2011 Motorcycle(s): 2007 Ninja 650R Posts: 317
The 4MM washers I used got hung up in the needle retainers, causing some REALLY bad running. Get them outa there.
I have noticed a dead spot in the very low rpm range when trying to pull slowly away from a stop. It's definitely a new condition since shimming the needles. Does drilling the slides cure this? |
February 7th, 2012, 09:26 AM | #922 | |
Join Date: Sep 2009 Motorcycle(s): '09 Ninja 250R Posts: 2
Ok i changed to the 3mm and its waaay better, but now i am having the same issue as you, when i try to pull from a stop i also get the same condition as you, like it hesitates to go away... any thoughts? |
February 7th, 2012, 09:41 AM | #923 |
Join Date: Jan 2012 Motorcycle(s): 2012 Ninja 250R Posts: 365
How many washers are you using? try taking one out on each side and see what happens
February 7th, 2012, 10:19 AM | #924 | ||
If you still don't have them by the first week of march, I'll send you some when I'm on spring break.
Don't drill pregen slides. I had a bad experience with that in the 6k range. The reason I had issues with that was at small throttle openings where the slides normally come up, they wouldn't, then they would snap open when I gave it gas. I plugged the holes. I'll try it again later when I can play around with needle height to compensate for the slide not rising. That spot you're feeling is where the needles and pilot jets overlap. You can fiddle with your mix screws in very small increments and it gets better, but never goes away completely. Quote:
They aren't going to be perfect because you're still on the stock needles. I think that area is where the taper of the needle comes into play. I'm personally just too cheap to pay for a jet kit to get rid of one tiny little spot that I'm only at for 0.001% of my riding. |
February 7th, 2012, 10:35 AM | #925 |
Thanks a ton for the info. I may not even mess with it. It's a very minor & brief hesitation, and my needles are still capped :-(
February 7th, 2012, 10:43 AM | #926 |
Well next time you're in there for a valve adjustment or something big like that, take the carbs out and pull the EPA plugs. It's not too hard, just be easy with the drill so you don't try and drill through the mix screw
February 7th, 2012, 12:51 PM | #927 |
dammit2hell.....I just did a valve adjustment on 1/28. HA!
February 7th, 2012, 12:55 PM | #928 |
Oh well that's no good then hmmmmm what other maintenance could you do as an excuse to have other work to do so that pulling the carbs doesn't seem like such a big deal? is it time for a uni-trak linkage clean/lube job?
February 7th, 2012, 01:35 PM | #929 |
LOL. The bike just cleared 3,000 miles so I dunno if anything really needs to be done. I'll probably pull them someday for a cleaning and pop out the covers then. It runs really good right now other than that .5 second dead spot, and I know what's causing that, so I hate to fix what ain't broke. Occasionally, I make things worse when I start messing with things that don't need to be messed with. ;-)
February 7th, 2012, 01:36 PM | #930 |
Avid Kitteh Poster
Join Date: Sep 2011 Motorcycle(s): 2006 Yamaha TTR 50 SUCK IT Posts: A lot.
yeah I could only find 4mm washers, glad I didnt get those... lol
I powdercoat stuff Help me pay for my addiction I say funny stuff. http://twitter.com/JustinPWNSyou sometimes... I write like a 12 year old too, http://justinpwnsyou.wordpress.com/ |
February 7th, 2012, 06:32 PM | #931 |
Finally got sick of the low-end dead spot and removed the shims. SO worth it. Much easier to modulate the throttle, and the throttle off / throttle on transition is smooth again.
I guess this isn't such a great mod for the pre-gen....or it wasn't for mine, anyway. |
February 7th, 2012, 08:58 PM | #932 |
How many did you have on? It works fantastically on mine. It's also the method for jetting that faq.ninja250.org suggests. It's a pretty common jetting trick.
February 8th, 2012, 06:46 AM | #933 |
I had no luck finding anything smaller than #4 stainless, (the ones that got stuck in the needle retainers) so I used a couple of rubber o-rings (I think they were off the mixture screws from my 94 250) I had left over from some carb work I did a few years ago. They fit snug at the tops of the needles. I think they may have been a hair thicker than the stainless washers. Only used one per side.
I noticed a dramatic difference this morning on the way to work with a slow take-off from the first stop light. I much rather sacrifice whatever midrange I may have gained with the washers for a much nicer low end without them. |
February 8th, 2012, 07:53 AM | #934 |
OK, well SAE #4 washers are like half a mm thick. I'm betting that those o-rings were thicker. Likely 2 or 3 washers.
February 8th, 2012, 07:58 AM | #935 |
Avid Kitteh Poster
wait so is someone going to send me some or do I have to drive to Chico?
February 8th, 2012, 08:14 AM | #936 |
I won't be home for spring break till March 3rd or something. If you don't have them by then, I can send you some. You'd likely be better to just drive to Chico though
February 8th, 2012, 08:19 AM | #937 |
Avid Kitteh Poster
blehhh maybe Ill just try and see how it sounds without... but I was going to remove the snorkel too.. so maybe not.
February 8th, 2012, 08:26 AM | #938 |
February 8th, 2012, 08:44 AM | #939 |
Avid Kitteh Poster
theyll take to long to get here!!!
February 8th, 2012, 08:55 AM | #940 |
Join Date: Mar 2010 Motorcycle(s): Blue 10 250r Posts: 697
This was a pretty easy DIY. I walked up to the counter and told the guy "hey, I want a jet kit installed and tuned on my 250" he said "no problem, come back in 2 days"
February 8th, 2012, 08:55 AM | #941 |
you're so impatient.
February 8th, 2012, 09:13 AM | #942 |
Avid Kitteh Poster
I bought them hopefully they will be here this weekend. If not oh well ill shim and de-snorkel later
February 13th, 2012, 11:29 AM | #943 |
Did mine the other weekend, but when i opened it up it already had 1 washer under 1 of the needles (the one on the left) Im the 1st owner so im guessing the workshop did it although why only one im not sure, i removed the snorkle and put 2 under each, but im thinking since there was one already under one needle should i have set it up as a 3 - 2 combo or a 2 - 1 combo maybe? Im at sea level with about 50% humidity most of the time, just giving it a run now and will check the plugs on my next tank of gas to see how its running
February 13th, 2012, 11:57 AM | #944 |
ex-ninjette.org guru :o
Join Date: Jun 2010 Motorcycle(s): 2003 SV1000 S Posts: 475
I found my washers at a hobby shop (r/c airplanes, helis, cars, etc) and I believe it cost me a whopping $1 for 10 pcs.
February 16th, 2012, 09:01 AM | #945 |
I think I may have stripped one of the screws on my carbs -.- Anyone know what I can do to get it out? Will I have to take it to a shop?
Sorry this is my first post (I think) but I have been watching and reading for quite a few months. Any help is appreciated. Thanks |
February 16th, 2012, 09:09 AM | #946 | |
Join Date: Jul 2011 Motorcycle(s): 2012 Ninja 250, 2006 Ninja ZX6R-636 Posts: 661
It worked for me to initially crack it loose then used a screwdriver to finish removing the screw. |
February 16th, 2012, 09:13 AM | #947 |
Dremel is next. Have to grind a straight slot in it and remove it with a straight-head screwdriver. GL!
February 16th, 2012, 09:26 AM | #948 |
I initially had to do the needle nose on one, but its the center screw on the left carb and the frame, and plastic piece of the carb are in the way so i cant get a good angle with the needle nose. This also rules out the dremel in this case. Does it mean Im going to have to completely remove the carbs? ive look for a couple of guides but the few ive found have people who have pods, which is useless to me seeing as I still have my air box :\
February 16th, 2012, 10:01 AM | #949 |
The airbox really isn't as hard to work around as people make it out to be unless you're removing/installing the carbs all the time.
take off the carbs. Use a dremel to slot the head of the screw. (make sure to apply enough pressure with the flat head that you don't strip that too) Then replace all the screws with M4x16 hex screws and you'll never have this problem again. |
February 16th, 2012, 10:11 AM | #950 | |
KThanksBye
Join Date: Mar 2011 Motorcycle(s): 2006 zx636r Posts: A lot.
Do yourself a favor and get the pods, I even have jets for ya
----> My Youtube! <---- Unregistered, watch my youtube page! |
February 16th, 2012, 10:17 AM | #951 |
Yes I have. The carbs have been out quite a few times, and the airbox has been taking apart and removed to have the battery box cut off of it to make carb removal easier so that I don't have to loosen the fender every time.
Plus I opened the intake lid and have 108 jets (instead of 105) that I'm going to test out. I'm toying with the R-0990, but idk how badly that's going to affect my mileage. Plus I just did the intake lid mod, so I wanna get that right and have some fun tuning that before I just go make more changes. *edit* I'm considering doing pods. It's only $38 on amazon including the breather. Free Prime shipping. You have a pair of 110's and 112's you'd be willing to part with for free? (pretty please?? ) Damn you Kevin. */edit* |
February 16th, 2012, 04:13 PM | #952 |
Well, I shimmed my needles today. Put 2 washers on each needle. Bike started up with no choke. Had to use the choke to warm it for a minute, then started to ride it and took the choke off. Ran noticeably better, then I realized that its only 40 out. So I decided to wait till its warmer, I'll ride it again, go from there.
Took me a total of 2 hours, and that includes installing the steering damper as well. I had no trouble getting the screws off the carb covers. Right tool for the right job. I went ahead and put the same screws back on since I didn't have any trouble getting them off and I didn't damage them. |
February 16th, 2012, 04:31 PM | #953 |
February 16th, 2012, 04:38 PM | #954 |
Well, in this cold weather, the bike wouldn't start without choke prior to the needle shimming. If it's a coincidence then so be it.
**Edit Chris, I just noticed you have this bike listed under bikes I have about 20 bicycles, you can see some of them here: http://bmxmuseum.com/user/26916 |
February 16th, 2012, 04:52 PM | #955 |
Super Noob
Join Date: Oct 2011 Motorcycle(s): '09 Kawasaki Ninja 250R, '84 Honda Spree 50cc Posts: A lot.
Ok...there have been repeated mentions of using the "right tool" to unscrew the screws on the carbs. I am getting ready to shim mine (as soon as I get my DanMoto) and I have the usual assortment of screw drivers (craftsman, and others), is there such a thing as the 'perfect' driver/tool for the job? so that I can get to buying it...tnx!
February 16th, 2012, 04:54 PM | #956 |
They're Japanese Industry Standard heads on the screws. That means you need a JIS bit if you want the "right" tool.
Personally, I just got annoyed at them and just replaced all the screws on the bowls and caps. |
February 16th, 2012, 04:56 PM | #957 |
February 16th, 2012, 05:02 PM | #958 |
Super Noob
Thanks guys. Chris, I'd rather not do any retrofitting now, maybe later, when I feel more confident about working on the carbs. Chris (sh!t...there's two of you!) tnx, I'll pick that set up tomorrow.
February 16th, 2012, 05:17 PM | #959 | |
Join Date: Aug 2011 Motorcycle(s): RED 2010 Ninja 250r Posts: 304
I'm not exactly sure what you mean by retro-fitting, but installing new screws is DEFINITELY the way to go even the first time you shim your needles. Getting those screws stripped is SUPER easy. I mean if you find it easy, keep those suckers in, but man, I wanted to kill them for putting those babies on there. I had to replace mine because 2 out of the 8 screws broke in half the third time I took the carbie covers off. I'm actually left with half of in in the very bottom of one of the holes and I can't get it out (I'm going to have to drill it...). I didn't wan't to risk it happening again. Cheers |
February 16th, 2012, 05:19 PM | #960 | |
yeah buddy that's my ride on the trails and around campus. Best bang for your buck on a full suspension bike. I wish it had a full floating suspension like the Trek Remedy and a better fork, but hey. I had a budget, and I love the bike. |
Shimming the Carb Needles... Is it for You? | kkim | 2008 - 2012 Ninja 250R Tech Talk | 93 | June 10th, 2018 05:25 PM |
Shimming the carb needles | kfilla | General Motorcycling Discussion | 2 | July 2nd, 2014 06:14 PM |
DJ Needles instead of shimming | mxman38 | 2008 - 2012 Ninja 250R Tech Talk | 7 | May 30th, 2012 07:09 PM |
Need help on shimming carb needles | RedNinja21 | 2008 - 2012 Ninja 250R Tech Talk | 6 | October 27th, 2011 10:16 AM |
FREE!!! 3MM Washers for Shimming Your Carb Needles | kkim | 2008 - 2012 Ninja 250R Tech Talk | 1 | September 10th, 2010 02:26 AM |
