February 9th, 2012, 07:53 AM | #81 |
Join Date: Aug 2011 Motorcycle(s): 2008 Kawasaki Ninja 250R Posts: 771
Am I missing something? It says there aren't any results for an 08 250R
April 4th, 2012, 07:59 AM | #82 |
So just to verify, the M4s are used for the windscreen, the M5s are used for the fairings and everything else?
April 4th, 2012, 09:38 AM | #83 |
M5 for everything. The difference was that the two on the exposed parts of the windscreen used a different rubber compound that doesn't rot. Sneaky, sneaky, Kawasaki! Because you don't have to remove them from the outside of the windscreen, the four I sent you should be enough to replace the two in your headlight and the two under your windscreen. Hopefully you can salvage some of those if you need to use them someplace else.
Last futzed with by CZroe; April 4th, 2012 at 08:04 PM. |
April 4th, 2012, 11:20 AM | #84 |
Sounds good. I actually need a crap load of them seeing how I lost at least 10 when I had the fairings off.
April 4th, 2012, 08:00 PM | #85 | |
April 14th, 2012, 07:16 AM | #86 |
So should I buy these:
http://www.amazon.com/M5-80-Rubber-W.../dp/B000NE4O78 Or these: http://www.amazon.com/Rubber-Well-Nu.../dp/B0040D2P7E |
April 14th, 2012, 07:34 AM | #87 | |
April 14th, 2012, 09:09 AM | #88 |
Intrepid Adventurer
Join Date: Jan 2012 Motorcycle(s): 2004 GSXR 750 , 71 cb350streettracker, 07 Polaris Predator 500 Posts: A lot.
Buy them both then send me the hardware you don't use!
April 14th, 2012, 09:17 AM | #89 |
April 14th, 2012, 01:18 PM | #90 |
Blind 250 Loving Whore
I have some from that ducati website and pro-bolt. The pro-bolt ones work way better. And I always have a stash of like 25 extra lol.
April 6th, 2014, 09:57 PM | #91 | |
cadd cadd cadd
MOTM - May '15
Thanks for the link!!! Just to confirm, the M5 well nuts in this link will work with 2008 fairings, correct? |
[superbikeplanet.com] - Respected Success Vs. Wretched Excess | Ninjette Newsbot | Motorcycling News | 0 | December 10th, 2013 10:40 AM |
WTB: Rubber expansion nuts, pop rivets, body screws (new 250r) | SwagenGTI | Items Wanted | 3 | April 17th, 2013 03:54 PM |
Rubber Well nuts | Daeldren | 2008 - 2012 Ninja 250R Tech Talk | 11 | February 8th, 2013 01:28 AM |
Rubber nuts on Fairings? | setasai | 2008 - 2012 Ninja 250R Tech Talk | 6 | June 21st, 2010 05:52 AM |
which thread had the info about the fairing rubber nuts? | Sound Wave | General Motorcycling Discussion | 1 | April 21st, 2009 01:12 AM |
