Old September 14th, 2011, 04:50 PM   #81
headshrink
headshrink's Avatar
Originally Posted by cuz View Post
can you still dyno w/out it? like get a perfect reading.
That information is above my pay-grade, BUT it is a good mod to do if you change your pipe, or get a lot of popping. The free way to do this mod is to plug the hose, but it isn't as clean and pretty.
Old September 14th, 2011, 05:01 PM   #82
cuz
cuz
cuz's Avatar
Motorcycle(s): 09 ninja 250r
so unless you hear poping it would help right but all im going to add is a slip on (leo vince) so i dont think i should right.
THE GOOD LIFE
cuz is offline   Reply With Quote
Old September 14th, 2011, 09:31 PM   #83
Momaru
Momaru's Avatar
Yeah, I don't expect a slip-on will open up your exhaust flow to sufficiently lean out the already-lean to get the popping/minor backfires that are characteristic of bikes with the Kleen Air and modded engine airflow.
It's also pretty easy to cut one of these yourself out of some steel (or even aluminum) plate with a dremel.
Proud member of the Blue Army
Old January 14th, 2012, 10:14 AM   #84
samw
Motorcycle(s): 2005 HON CBR1000RR Repsol, 2012 KAW Ninja 250R
FYI... I just checked the service manual that I got for a 2012 and the torque spec is 9.8 N-m or 87 in-lbs for the two "air suction cover bolts."
Originally Posted by headshrink View Post
IIRC, the bolts are at 115 in-lbs (but don't quote me on that).
samw is offline   Reply With Quote
Old January 14th, 2012, 04:03 PM   #85
headshrink
headshrink's Avatar
Thanks for the correction.
Old January 14th, 2012, 06:27 PM   #86
kevheads
kevheads's Avatar
Motorcycle(s): 2011 Green 250R
Question
So,if I end up taking my bike in to a shop to have the jet kit installed and dynoed (full Area-P installed). Should I get a plate and have them do it at the same time? Or can it be done later on if the bike pops and backfires?
kevheads is offline   Reply With Quote
Old January 14th, 2012, 07:19 PM   #87
samw
Block it off before the dyno or your A/F readings may be off. Or pinch off the hose when on the dyno.
DIY - Emission block off plate MikeBudd 2008 - 2012 Ninja 250R Tech Talk 29 September 6th, 2012 11:47 AM
