Old May 23rd, 2014, 02:30 PM   #81
Vad18
Vad18's Avatar
Motorcycle(s): 2012 Ninja 250
Originally Posted by DaBlue1 View Post
Slight touching is normal.
Alright, I think everything is okay.
I just need to stay in 5th gear longer. Just seems that the tach is not super accurate.
Vad18 is offline   Reply With Quote
Old May 23rd, 2014, 02:49 PM   #82
DaBlue1
DaBlue1's Avatar
Are you sure? or are you giving up?
Did you test it using an inductive pickup attached to the spark plug wire.
Have you verified your speed by gps or inspected your speedo cable?
Old May 23rd, 2014, 06:25 PM   #83
cadd
cadd cadd cadd
cadd's Avatar
Motorcycle(s): 300
MOTM - May '15
Changed @ 1000 miles. 10W-40.
Motor oil (cars?) or specific motorcycle oil?
Or Rotella?
Last futzed with by cadd; May 24th, 2014 at 05:03 PM.
Old May 23rd, 2014, 06:30 PM   #84
cadd
cadd cadd cadd
cadd's Avatar
Motorcycle(s): 300
MOTM - May '15
Just use my numbers as a baseline and see if you're any where close. My bike is completely stock. OEM gearing. OEM tires.
@ 6,000 rpm:
3rd gear is roughly 30mph
4th gear is roughly 40mph
Like others have mentioned, if you are completely off it could be:
gearing isn't stock
tire size (circumference) may be much smaller
clutch may be slipping
Tach is off
Speedo is off
Perhaps you can find a road (interstate) with mile markers and ride there and compare your trip meter to the mile markers on the road?
0 out of 1 members found this post helpful.
Old May 24th, 2014, 08:04 PM   #85
cbinker
Track Clown
cbinker's Avatar
MOTM - Sep '15
Miles on bike: 1183
When I move bike, I hear the front brake slightly touching, could that be it?
is it touching or slowing the wheel, right now on my ZX6R I have an issue with the brakes pistons not retracting. I got the front wheel off the ground and spun it, barely made one full revolution. if you think the brakes are an issue use a front stand and lift the wheel of the ground and spin it, it should spin freely.
TEAM ALFALFA
www.apexassassins.com
Old May 27th, 2014, 12:16 PM   #86
Vad18
Vad18's Avatar
It spins fine, and it was super mobil oil.
Everythings okay, I just needed to stay in the 5th gear for the torque, then switch to 6th
Top Speed? Mike K 1986 - 2007 Ninja 250R Tech Talk 16 September 2nd, 2014 03:51 PM
Top Speed higear223 2008 - 2012 Ninja 250R Tech Talk 14 August 3rd, 2014 09:59 AM
Top Speed Help!!!! Black Rabbit 2008 - 2012 Ninja 250R Tech Talk 68 September 3rd, 2012 03:30 PM
Top Speed Davey 2008 - 2012 Ninja 250R Tech Talk 12 July 23rd, 2011 08:12 AM
Top Speed? peter330 2008 - 2012 Ninja 250R Tech Talk 30 May 29th, 2010 03:02 AM
