Old July 5th, 2014, 10:24 PM   #81
Somchai
Freedom for Germany
Motorcycle(s): Ninja 250R-FI
In the attached pdf giving some informations about the weight of aftermarket wheels from what I found in the web and also measured my own oem wheels (w/o bearings and everything else except valves and balancing weights 15 grams).
My aftermarket wheels (Power Racing) from Indonesia together are app. 3 kg heavier than the oem's.
Maybe others can jump in and give their infos too.
At least to look for the weight of rims is the half way only, since we also should take a look for that value of the tires because they are the most outside weight.
Here are the weight informations I found and please keep in mind that the weight shown is the average weight for Pirelli tires (the oem should be around 0.5 kg+ heavier).
110/70R17 = 3.691 kg
130/70R17 = 4.740 kg
140/70R17 = 4.900 kg
120/60R17 = 3.778 kg
150/60R17 = 4.947 kg
160/60R17 = 5.774 kg
Last futzed with by Somchai; July 13th, 2014 at 09:32 PM.
Old July 5th, 2014, 10:28 PM   #82
verboten1
verboten1's Avatar
MOTM - June '15
I really want a set of the old vrossi...I liked them lots!
Ride more, worry less.
Old July 6th, 2014, 12:36 AM   #83
MirinNinja
Motorcycle(s): Ninja 300
Wow this thread just gave me brain cancer.
MirinNinja is offline   Reply With Quote
Old July 22nd, 2014, 02:18 AM   #84
SouthHalfrican
Motorcycle(s): Ninja '07 250, '03 500, Ducati '01 M750, '03 999 base, 1198S corse, Honda 77CB750F2
Or... you could just eat like a bird for a while and forget about fast food.
It's cheaper :thumbsup:
SouthHalfrican is offline   Reply With Quote
Old August 1st, 2014, 07:36 AM   #85
micoulisninja
modaholic junkie
more excellent info Somchai !! thank you !! Bt-003rs is an extra 100 grams for front 110 and 230 grams (!!) for 140 rear (size and crown more like a 150/70)
Old August 5th, 2014, 12:13 PM   #86
fred smoot
fred smoot's Avatar
Motorcycle(s): 1996 Ducati 900SS/SP 45k miles
wheels . . .
bigger wheels weigh more than smaller wheels, tires equally so.
'09 Ninja 250R track only SOLD
"If everything seems under control, you're not going fast enough." -Mario Andretti
fred smoot is offline   Reply With Quote
Old September 13th, 2014, 11:17 AM   #87
Qomomoko
Motorcycle(s): 1995 Ninja 250, 2005 R6, 2002 Ducati Monster S4
cool and entertaining information....
my 1995 ninja 250 has 16 rims. I assume that is EOM.... was thinking of swapping to 17 inch rims but wont.. I'll just wait and buy my newer 2008+ 250cc and it should come with 17" rims and then see what track tyres to get for it front and back
Qomomoko is offline   Reply With Quote
[RoadRUNNER] - Two (Wheels) are Better than One: Christini All Wheel Drive Motorcycle Ninjette Newsbot Motorcycling News 0 July 8th, 2014 03:10 AM
Aftermarket V-Rossi wheels bearings are cheap NinjaZX6R123 2008 - 2012 Ninja 250R Farkles 3 June 24th, 2014 12:35 PM
[motorcycle-usa.com] - Method Race Wheels UTV Wheel Lineup Ninjette Newsbot Motorcycling News 0 December 20th, 2013 06:50 PM
[sportrider - tech] - Aftermarket Wheels, Overheating And Oil Changing Ninjette Newsbot Motorcycling News 0 April 13th, 2010 04:00 AM
[sportrider - tech] - Aftermarket Wheels, Overheating And Oil Changing Ninjette Newsbot Motorcycling News 0 January 16th, 2009 01:23 PM
