February 27th, 2012, 07:25 PM | #81 | |
Join Date: Dec 2011 Motorcycle(s): 2010 Ninja 250r (RIP) Posts: 258
February 28th, 2012, 07:59 AM | #82 | |
The pros for a big injector is: you have a lot of room on the top end, but the cons is that you will be running rich at idle, and can even have rough idle, because you simply hit the smallest pulse-width of an injector. A typical auto injector minimum pulse-width is set at 1.5ms (milli-sencond). Anything below that, the linearity of the injector characteristics gets very poor, meaning, you don't know how much fuel is exactly injected at 1ms pulse-width. As Greg pointed out, a typical injector requires 1ms to open even, and then it almost immediately closes for that short period. No manufacturer's injector can do a good job at such a small pulse-width. Greg also pointed out that he tuned his idle fuel pulse width to < 1.0ms to get a good AFR. And that is kind of hitting the injecotr lower limit already. Ecotrons 170cc/min is a better size for Ninja 250r, it can provide enough fuel at the top end, and at same time, have a good pulse-width of 2ms at idle. AFR at the top end is not always the richer, the better, as everybody knows. A relative rich mixture provides the best power, but the over-rich will just flood your engine. 170cc/min injectors have not hit the upper limit to provide rich mixture at top end for Ninja 250r. Again, it is not "the bigger, the better." |
February 28th, 2012, 10:22 AM | #83 | |
I made a mistake when I said the Kawasaki OEM injector used EV1 connectors. It turns out that the Kawasaki injectors are Bosch Licensed Nippon Denso. So the connectors are Nippon Denso Connectors and not EV1. As far as I can tell, the ecotrons injectors are the ones that use EV1 connectors. Here is what a Nippon Denso Connector looks like: The Kawasaki OEM UK Ninja 250R uses the Top slot version. (The top slot is on the bottom in the picture below). If you don't like cutting into the wiring harness, you can get a pair of these EV1 to Denso adapters.
February 28th, 2012, 11:49 AM | #84 | |
Join Date: Jun 2011 Motorcycle(s): 2001 ninja ex250 Posts: 8
February 28th, 2012, 01:00 PM | #85 | |
http://connectorsfast.net/catalog/pr...2054cf70f7aaee |
February 28th, 2012, 02:53 PM | #86 |
Yes, the gray colored top slot is correct for the OEM injectors on the FI EX-250.
And I do think that 170cc/min injectors are a better fit for a 125cc displacement cylinder than the OEM 200cc/min injectors. If you can find them in that size to fit the OEM throttlebody and fuel rail, that is. That would be a bonus if you're using the Ecotrons ECU and firmware because you'd be tuning with the same basic parameter as everyone else (those using the Ecotrons throttlebody). |
February 28th, 2012, 05:19 PM | #87 | |
Last I heard, your bike had a wideband O2 sensor and real time display. Wouldn't that tell you if your 200cc OEM injectors were running rich at idle?
February 28th, 2012, 06:09 PM | #88 | |
But it can not be installed into OEM TB. You may be able to find some injectors in the 160-180cc/min range and also can be fitted into OEM TB. |
February 28th, 2012, 06:45 PM | #89 | |
Remember that it isn't whether the 200cc/min injectors can be tuned to idle with a good fuel/air ratio on the EX-250's 125cc cylinders, because we've proven that they can. The issue is that the 200cc/min injectors are right at the edge of tunability (if that is a word) in the idle range. Working with the 200cc/min injectors I ended up with a 1.7ms idle pulsewidth. And you have to take into account the fact that injector-opening-time accounts for 0.9ms of that 1.7ms pulsewidth. So here's the crux of the issue: As you get down to a shorter and shorter idle pulsewidth you can see that any 0.1ms change becomes a larger and larger percentage change, which can result in you chasing your tail trying to tune the bike. a slightly smaller injector alleviates this condition. |
February 28th, 2012, 08:35 PM | #90 | |
But it would seem that, based on your comment, that the ECU resolution is only 0.1ms. And this results in tail chasing. But if the ECU had 0.01 ms resolution, then this would be less of an issue. Anyhow, I don't know about anybody else, but my bike doesn't spend a whole lot of time idling. So I'm probably good with the OEM injectors.
February 28th, 2012, 09:20 PM | #91 | |
The firmware load in the Microsquirt ECU that I use is limited to .1ms increments. |
February 29th, 2012, 08:12 AM | #92 | |
0.1ms resolution is kind of coasre for engine controls. All modern car ECUs control fuel pulse at micro-second level. It is not the ECU pulsewidth resolution that is limiting the minimum pulse width of the injector, but the injector itself. The injector is simply NOT fast enough to open / close in 0.1ms or 0.01ms. A typical auto injector takes 0.8ms to open and 0.5ms second to close. With a big inejctor, your idle pusle width is too small, like 1ms. As Greg said, 0.1ms difference at 1ms usable pulse width is already 10% error. It is a big percentage for the idle control. That is the real problem to use a big injector for a small cylinder. Last futzed with by ecotrons; March 1st, 2012 at 08:37 AM. |
February 29th, 2012, 11:44 AM | #93 |
Does that mean the stock efi idles rich with the 200?
February 29th, 2012, 12:21 PM | #94 |
Not necessarily. OEM EFI can pre-set the throttle openning (leakage air) bigger than needed to provide more air, then retard the ignition angle to maintain the target idle speed. The drawback is the sacrifice of the fuel economy at idle.
February 29th, 2012, 12:33 PM | #95 |
Join Date: Aug 2011 Motorcycle(s): 2008 Kawasaki Ninja 250R Posts: 771
This page would be great for anyone just needing to remove the fairing, tank, ect. Bravo!
February 29th, 2012, 01:40 PM | #96 |
No, it doesn't mean that. The 200cc/min injectors work fine in the EX-250 engine.
Remember that this conversation thread got started when I mentioned that the 170cc/min injector is a better match for the EX-250's 125cc cylinders. Very tunable at idle with plenty of capacity for the bike's top end needs. Nothing more that that. Just a better match for the bike's range of fuel needs. |
February 29th, 2012, 04:57 PM | #97 |
Thanks. I was actually thinking of that when I wrote it, but there are already other walkthroughs out there. I just wanted to make an all inclusive walkthrough to make it easier and to avoid confusion.
March 2nd, 2012, 05:14 PM | #98 |
For those of you interested in installing a pushbutton type switch, I installed mine and I updated my walkthrough to show pics. Its at the end of my 2nd post. I ended up using the plastic piece on the left side because it looked like it would work the best for protection against the weather, and I spliced the LED to the trouble light, so if it is glowing the trouble light is on. I was planning on installing another light for the maintenance light, but I realized this would work perfectly. I can also see installing this up by the instrument cluster, but I like how this looks.
March 2nd, 2012, 05:31 PM | #99 |
I like it! Looks like a natural location for a newgen.
March 2nd, 2012, 05:45 PM | #100 |
Loving it! Thanks for testing the switch out for us.
You still have the airbox installed. I installed pod filters and am having trouble with stalling. I wonder if it's an autotuning thing. I'll give it some time and see if it fixes itself. Your setup looks fantastic!
2009 Ninja 250R SE Green Sport Touring Style: ZG ST; Symtec heated grips; RAM GPS w/ mUSB; DIY reshaped seat; DIY Givi E21 Sidecases; 15T sprocket |
March 3rd, 2012, 12:33 AM | #101 | ||
March 3rd, 2012, 12:44 AM | #102 | |
It's crazy embedded in there with nowhere to shift back or forward.
March 3rd, 2012, 12:57 AM | #103 | |
March 3rd, 2012, 01:04 AM | #104 | |
Still, awesome walthrough. Much appreciated. Now if only I had one of those super rare OEM throttlebodies. Haha, us EFI people are already rare, and here we have 2 categories... the OEM vs the Aftermarket with like under 10 people in each category. I'm sure there are more but they are definitely not part of this forum.
March 3rd, 2012, 01:34 AM | #105 | |
March 23rd, 2012, 03:23 PM | #106 |
I finally got my license (well, restricted) back, so I was able to test out the bike finally. For my first ride I took it down a straight section of highway just to get a feel for it, then I rode it back through the city for some stop/go action, and finally returned on the freeway. Overall impression, I am happy with it. It started right up, idles nice and low, never stalled out (Note: I do have the fuel decel cutoff changed to 3000 across the board), and responds nicely. The biggest difference, which in my opinion is huge, is that the throttle is smooth, from idle to WOT. Power wise, I would say it feels more powerful at highway speeds, I can't say I notice any more power at city speeds, but I have also noticed that since the throttle response is so much nicer I actually was riding at much lower RPMs than I was using the carbs. Its a night and day difference when it comes to handling, I haven't actually taken it out in a month and I rode better than I ever had before. I will post updates every so often to address issues such as long term reliability and gas mileage.
Also, while bored waiting to get my driving privileges back, I installed these handles... ...They were $35 shipped and only took about 2 weeks to get here. They are amazing, I used to never use my clutch, now that I have the awesome throttle response and these set up to how I like them I am using it for every shift. The shifts have been so buttery smooth that most the time I honestly couldn't tell if I even shifted. In the beginning of my ride I kept looking at the RPM to make sure I even did anything. |
March 23rd, 2012, 04:47 PM | #107 |
Could you video some 0-60 runs and post the results?
March 23rd, 2012, 05:43 PM | #108 |
Thats actually a great idea, I don't have a camera though. I might see about getting one and finding a good spot to do it thats between here and work, having a restricted license still greatly limits what I can do, but I have no problem taking the scenic route to work It probably wont be until after I find out how much its going to cost me to fully carbon fiberize my ride, but maybe sometime relatively soon, I want the ECU to have a chance to self adjust anyways.
March 23rd, 2012, 05:57 PM | #109 |
Join Date: Apr 2011 Motorcycle(s): '09 250R, '13 CBR500R Posts: 709
awesome write up! if i ever feel like the need to convert to efi, i will definitely use this.
March 26th, 2012, 09:35 AM | #110 |
So today was the first time I was able to take it out in colder temps. It was 42 degrees out (which always sucked with carbs) and I was able to start it up and drive without any problems. It didn't stall out (idles at ~1200), it ran like a champ, and I am definitely happy with the results (this was one of 2 main reasons I even performed the conversion, the carbs are just terrible in cold weather.) After leaving it out for a couple hours in the cold (while in class, as opposed to it being in the garage) it still started up and I was able to instantly ride without problems.
April 21st, 2012, 06:46 AM | #111 |
okay, so I'm officially going to Bangkok this summer at the end of June. does anybody know of any junkyards/shops that would have the throttle body? All I have found so far is http://www.bkkriders.com/shops/index.html which I'll hit up all the part shops on there and even kawasaki headquarters. I'll also hit up redbaronbkk.com even though they emailed me saying they don't carry 250r parts. if anybody else can help out and knows of places to look, I'll bring back as many as I can find.
April 21st, 2012, 07:24 AM | #112 |
Freedom for Germany
D, you can go to Kwaki and try to get them there. The Orderno. is 16163-0113 and the price was last summer 10,674 THB, that's app. 340 USD.
I've been asking for Matt, but that price was understandable to high for him, because so he couldn't keep his low price for the kit. The prob is that the dealer is asked by the headquarter what for he needs the TB. After a long discussion my dealer told me he would sell 10 sets to me but not all at one time. So it's not that easy to get them here. After Matt didn't want them I told my dealer that we have to stop this. PS: One more thing, here is one in Germany at tha Bay: http://www.ebay.de/itm/Kawasaki-EX-2...item589381345c If he bought them all the time, then Matt should already got some in Germany after I told him the link. You can look in Germany 'ebay.de' and search for: ninja 250* einspr* (it's called Einspritzanlage). Good luck. |
April 21st, 2012, 01:02 PM | #113 | |
April 21st, 2012, 01:21 PM | #114 |
You might want to wait a little bit. Matt says he'll have a new TB available the first week in May. I'm going to give him a chance to make good on this before I buy an OEM one.
April 21st, 2012, 08:22 PM | #115 |
Freedom for Germany
Sorry, I don't know breakers around BKK since I live in CNX. Here in the city all broken ninjettes go to kwaki and they don't sell them. I've been already looking to buy all the TB's, but no chance until now.
LFA suspension walkthrough | alex.s | Off-Topic | 9 | December 2nd, 2014 06:00 PM |
Efi... How many installed it | sidekick10121 | 1986 - 2007 Ninja 250R Tech Talk | 6 | June 30th, 2014 02:52 PM |
Ecotron's EFI Kit | parox91 | Motorcycle-related | 11 | August 13th, 2013 04:52 AM |
EFI Question | msebastian | 2008 - 2012 Ninja 250R Tech Talk | 8 | October 3rd, 2012 09:56 PM |
EFI kit | Racer x | 2008 - 2012 Ninja 250R Tech Talk | 138 | May 15th, 2011 01:47 PM |
