Old June 2nd, 2016, 09:22 AM   #81
RacinNinja
Vintage Screwball
RacinNinja's Avatar
MOTM - Mar '16
Originally Posted by daverdfw View Post
I thought running 23 on the rear would be low, but I think the rear looks ok, what do yo guys think?
I think you shouldn't base tire pressures on what you see in a forum. The ideal way is a 10% increase from cold to hot. They are a decent starting point but no more than that.
Set tire pressures cold. Go ride. (Unless you have warmers, then ignore this part)
Come back in and immediately check. Should be a 10% increase.
If it doesn't go up 10%, let out air. If it goes up more than 10%, add air.
Goin' fast on slow bikes!
Old June 2nd, 2016, 09:27 AM   #82
daverdfw
Motorcycle(s): 2009 Ninja 250
this makes a lot more sense, thank you!
daverdfw is offline   Reply With Quote
Old June 2nd, 2016, 10:57 AM   #83
sharky nrk
Fighting Texas Aggie '05
sharky nrk's Avatar
Even better if your at the track and one is available - go talk to the tire vendor and show him your wear and ask about pressures and feel and grip. A relationship with the tire vendor can be all kinds of helpful when it comes to diagnosing issues.
Old June 2nd, 2016, 10:58 AM   #84
daverdfw
the only vendor at the ridesmart days is a Bridgestone rep
Old June 2nd, 2016, 11:10 AM   #85
sharky nrk
sharky nrk's Avatar
Check that one as well. Crazy Jack does push 'stones but I am pretty sure I saw the Pirelli vendor at TWS on Monday. Not sure who handles the Dunlops here now.
Old July 2nd, 2016, 10:23 AM   #86
daverdfw
just picked up some warmers from a kid that is getting out of running the Moto America RC390 cup series, he told me on this tires hot off warmers the fast kids were using 25 PSI in the rear hot off warmers, so the same thing I heard 32/23 cold. or 34/25 hot he said the dunlop website is really high on the rear for whatever reason. Just thought I would throw it out there.
Old July 5th, 2016, 08:50 AM   #87
bruce71198
bruce71198's Avatar
Run 31/front off the warmers, Alpha13's
Last futzed with by bruce71198; July 5th, 2016 at 08:51 AM. Reason: left out info
Old July 5th, 2016, 08:54 AM   #88
RacinNinja
Vintage Screwball
RacinNinja's Avatar
MOTM - Mar '16
Dunlop guy at my track said 31 front/28 rear cold. Of course, YMMV but if there is a local rep I'd ask them! Came of the track with a perfect 10% increase in pressure once the tires warmed up.
We are lucky enough to have them at almost every event.
On another note, very impressed with this tire combo. Stuck like glue and handled very well, IMO.
Old July 5th, 2016, 10:01 AM   #89
daverdfw
do you run them on warmers or cold?
Old July 5th, 2016, 10:02 AM   #90
RacinNinja
Vintage Screwball
RacinNinja's Avatar
MOTM - Mar '16
Cold.
Old July 5th, 2016, 12:16 PM   #91
bruce71198
bruce71198's Avatar
The Dunlop rep at MA had us upping the pressure to get rid of chatter problems, chased it for several rounds until going the other way, no more chatter problems with lower pressure. Just relaying my experiences.
Also we get a new Alpha13 compound this week at Laguna. I'll update
Old July 5th, 2016, 12:21 PM   #92
daverdfw
what rear pressure off warmers are they recommending?
Old July 5th, 2016, 12:23 PM   #93
RacinNinja
Vintage Screwball
RacinNinja's Avatar
MOTM - Mar '16
Ya, different track, different asphalt, different air temps too probably.
YMMV with any air pressure recommendation.
Old July 5th, 2016, 12:27 PM   #94
bruce71198
bruce71198's Avatar
I don't recall but it seemed high 30-31 maybe, They claim that the pressure is needed to maintain carcass shape and hence proper footprint and a bunch of other engineer stuff but when it came to real world results we're at 24-26 rear off the warmers and 31 front off the warmers (172 degrees F)
Old July 5th, 2016, 12:29 PM   #95
AwDang
Motorcycle(s): 286, 296, 599, 799
Thats what we settled on for the enduro
orly?
AwDang is offline   Reply With Quote
Old July 5th, 2016, 12:39 PM   #96
bruce71198
bruce71198's Avatar
I'm not saying this is wrong, the traction wasn't bad at those pressures but if you need to push the limits lowering the pressure does the trick.
Old July 5th, 2016, 12:56 PM   #97
AwDang
no worry. I was just backing up his data point
Old July 5th, 2016, 03:01 PM   #98
bruce71198
bruce71198's Avatar
Gotcha. Who knows running at the higher pressure might make them last longer. That being said I have a bunch of take offs with one practice session and one race on them if any ones interested.
Old July 5th, 2016, 03:48 PM   #99
GregS
Motorcycle(s): Ninja 300, GSXR-750, Ducati M1100
I usually run the rear Alpha at 28 cold, but might try dropping it and see how it feels.
GregS is offline   Reply With Quote
Old July 6th, 2016, 01:21 PM   #100
bruce71198
bruce71198's Avatar
orly?
MA's Dunlop news release
Buffalo, NY: As part of Dunlop’s strategy for the continual improvement of its motorcycle racing tires, and in conjunction with its partners MotoAmerica, Dunlop will be introducing the Alpha-13 SP tire for KTM RC Cup competitors at Laguna Seca. The tire allocation for Laguna Seca will not be modified, comeptitors will still recieve 2 front and 2 rear tire stickers. The old compound tire is legal for use for this event.
“Following some very positive early season testing with the new Alpha-13 SP tires, we are excited to offer this best-in-class new product to our KTM RC Cup customers” said Mick Jackson, Senior Manager - Product Development and Road Race. “For this introductory event we are pleased to help our customers with the cost of their tires by giving them the front tire free of charge when purchasing a second set”.
Old July 6th, 2016, 02:31 PM   #101
daverdfw
I wonder whats different with the SP version
Old July 6th, 2016, 04:09 PM   #102
bruce71198
bruce71198's Avatar
Supposedly more edge grip. I'll update after the races this weekend.
Old July 6th, 2016, 04:51 PM   #103
GregS
Mmmm... can't wait
Old July 6th, 2016, 06:26 PM   #104
daverdfw
grab some take offs
Old July 11th, 2016, 10:42 AM   #105
bruce71198
bruce71198's Avatar
The new tires grip better on edge. The old ones would slide controllably and predictably. The new ones aren't sliding as desired but instead chattering. MA confiscated the top 5 qualifiers shocks and tore them down. Gave them back with new fluid, bushings, seals and a charge so finding a set up was tricky with the limited track time we had left. I think once the rear is sorted these tire will work much better than the previous version.
Old July 11th, 2016, 12:59 PM   #106
daverdfw
good stuff! Not that I am at a level where I could tell the difference, maybe the SP's will be sold to the public for next season
[roadracingworld.com] - Dunlop Launches New I RIDE Dunlop Marketing Campaign/Sweepsta Ninjette Newsbot Motorcycling News 0 May 7th, 2014 05:10 PM
[kropotkin thinks...] - Dunlop Press Release: Dunlop To Test Moto2 Tires At Phillip I Ninjette Newsbot Motorcycling News 0 February 21st, 2014 05:50 AM
[roadracingworld.com] - Dunlop Senior Road Race Manager Mincone To Transfer To Dunlop Ninjette Newsbot Motorcycling News 0 February 18th, 2014 03:40 PM
[motorcycle-usa.com] - Dunlop Names 2014 Elite Team Dunlop Squad Ninjette Newsbot Motorcycling News 0 February 4th, 2014 03:50 AM
[cyclenews.com] - Dunlop Announces Its Elite Team Dunlop Squad For 2014 Ninjette Newsbot Motorcycling News 0 January 30th, 2014 01:40 PM
