October 4th, 2012, 11:55 AM | #81 | |
once you get everything else sorted.
October 4th, 2012, 11:58 AM | #82 |
Jigglin' your Jiglets
MOTM - Apr '13
Here's my dyno with an area p race pipe and k&n intake. As you can see its far from being appropriately tuned. Since this dyno I've smoothed out the **** spot in the lower rpms but I'm still way too rich EVERYWHERE. I'm waiting for my relay to come in so I can wire up my O2 sensor and dial in my jetting.
The ideal AFR ratio for max power is about 12.8 so that's what I'm shooting for. I'd imagine once I'm able to attain that I can get at least 31hp at peak
October 4th, 2012, 12:04 PM | #83 |
Who's jealous now?
Join Date: Jun 2012 Motorcycle(s): Ninja 250R 2012 Posts: 54
Thanks for the physics lesson... maybe I should consistently use the term "torque curve" to keep you happy but we did get some nice artwork on this thread so I guess that's a win-win.
The point is that using these carbs the bike is a lot more responsive, accelerates harder, is quicker and pulls away from my buddies bike easily even though the maximum HP of his bike dyno'd slightly higher on the same day on the same machine with the same idiot dyno'ing it. We were a little confused at first. Perhaps you can explain why. |
October 4th, 2012, 12:08 PM | #84 |
MOTM - Apr '13
Final drive ratio perhaps? Maybe he has different gearing? Though changing gears will not alter your torque or HP it will change your rate of acceleration
Also max hp isn't the end all be all, if your bike is producing a consistant and flat torque curve and your buddies bike has a very peaky torque curve then he may have higher hp at that top rpm but you may have more hp throughout the lower rpms
October 4th, 2012, 12:10 PM | #85 | |
October 4th, 2012, 12:27 PM | #86 |
MOTM - Apr '13
I haven't changed anything yet, I'm still at 118 keihns, gna do 115s since 112s are too small
October 4th, 2012, 06:35 PM | #87 | |
Who's jealous now?
Therefore the difference probably is the torque curve due to the carbs. We could not test to top speed due to the roads around here. What you said just above "max hp isn't the be all and end all" is exactly what I meant to say. |
October 4th, 2012, 06:41 PM | #88 | |
MOTM - Apr '13
Like say, if you tuned for just max hp, highest torque at the highest rpm, didn't care about the torque curve at lower rpms then it would be feasible for another bike with a flat torque curve to be faster at the lower but slower at the higher. It would have to be 2 very different setup bikes for it to be very prominent, like say a bike set up for the highest top speed possible versus a bike set up for the track
January 16th, 2013, 01:27 PM | #89 | |
CVMA #74 WSMC #750
Join Date: Oct 2009 Motorcycle(s): All of them Posts: A lot.
Hahaha...This product fails. And the main reason why I said this product was a waste (considering the price and all) is because I knew in advance the 300 was coming out.
January 16th, 2013, 01:35 PM | #90 |
they are good carbs,
its just the fact that they are wayyy overpriced. if they were 3-$400 they would be worthwhile, but not $900...
January 16th, 2013, 01:48 PM | #91 |
CVMA #74 WSMC #750
It produced 29HP and they're still good? You can get that using a jetkit @ $80
January 16th, 2013, 02:58 PM | #92 | |
if you don't do enough to make it work, then i agree that its not worth it.
January 16th, 2013, 04:09 PM | #93 | |
CVMA #74 WSMC #750
But I agree at that cost you might as well sell your bike and buy a 300.
January 16th, 2013, 04:41 PM | #94 | |
was going to upgrade to FCRs as well, but fuel injection was actually more cost effective for me, so i went with that option. like i said they are priced way out of proportion, and are not a magical performance booster.
January 16th, 2013, 10:07 PM | #95 | |
Join Date: Mar 2012 Motorcycle(s): Ninja 250r 2010 SE Posts: 573
January 17th, 2013, 06:32 AM | #96 | |
in the end, EFI was more cost effective since i didnt have to buy custom inlets/fittings, my EFI auto tune so i save on dyno time. they deliver a perfect air fuel ratio with two maps at the flip of a switch, and give both fuel economy and power. have instantaneous response, and ignition advance is tunable. i save fuel costs as well. overall it was a win win. to have similar performance you must buy the carbs $450 custom fittings $100 jet kit $50 BRT-TIS $200 dyno $100 the difference is not as great as you think, but with the yoshi carbs it would have added another $500 i love carbs, but paying $500 or even $1000 on carbs alone when they are not the bottleneck is wasteful. like nemesis said he can rejet his bike and get the same HP for $10.
January 17th, 2013, 06:52 AM | #97 |
MOTM - Sep '18, Feb '16
I would have to second all of that. The stock carbs are really good. New pilot and main jets jets cost 25 bucks and a couple washers and you are good to 35 hp!
The CR are great because you can change jets and needles at the track. And they are a little bigger. But there is no real power increase with just carbs. Power comes from compression and porting. EFI is the way to go. I had these carbs before FI came around Ina. Affordable package so I am sticking with them for now. The Yoshi carbs are more money but are better carbs come with aluminum velocity stacks and an a throttle tube. But cost 500 bucks more.
January 17th, 2013, 05:16 PM | #98 |
450 include fittings, they aint custom. But I see your point about the gains vs money spent. Have you had it put on the dyno to see how much hp or torque you got from your FI conversion?
Stock carbs should only be upgraded to support other mods. I think it is a waste if you are not going to do any porting, compression changes. Theres plenty of other ways to get Hp/torque without changing carbs. Cams for example. |
January 17th, 2013, 06:50 PM | #99 | |
currently, i'm trying to make different intake pipes to test the intake harmonics on the bike. due to me not really having any motor upgrades, i'm expecting power levels to be real similar to a well jetted carb with the rich map. the only advantage being faster response and flatter power band. and about 1-2hp less on the self tune map. the injectors and pump i have will support from idle to 45hp easily, so it'll provide enough fuel if i over bore or decide to transplant a bare 300 engine into my bike. don't get me wrong, my reasons for installing EFI on my bike was purely for fun and convenience, not power really. i'll look for power after i install cams, pistons, and my new intake.
January 17th, 2013, 07:04 PM | #100 |
Let me know how that goes, and I'll copy your intake runner length if it is significant enough to feel on the butt dyno. I'm still sorting out my fuel/ignition timing/warm-up maps.
January 17th, 2013, 07:17 PM | #101 | |
just need some free time to see what works best, should be fun.
January 17th, 2013, 07:32 PM | #102 | |
The only reason I would go EFI is for the convenience. Also if the temperature outside regularly drops below freezing. My 2 cents on making more power. Don't buy pistons unless you bore it out to 282cc. Go for a porting job (they don't polish anymore) by someone who knows what there doing. 5hp gain over 2hp gain (265cc bore kit). Not to mention pistons end up being more expensive after boring, re-sleeving and balancing. And if you do bore it out. I talked to sudco and they have even had people order the Keihin FCR 35 mm for Ninja's. Not sure how much they bored it out but, he didn't say. |
January 17th, 2013, 08:17 PM | #103 | |
coupled with the thermobob, i still get 70mpg in cold weather, about 10mpg better than my carbs. i realize the pistons are a large investment, thats why fitting 300 motor is appealing to me. if the price gets within $300 of the total cost of piston installation, i'll most likely experiment with the new motor.
January 17th, 2013, 08:37 PM | #104 |
A Ninja 250r with a ported head and camshaft will out perform a stock 300 motor with stock exhaust or slip on. So keep that in mind, unless you can fit your aftermarket full exhaust to it so you don't have to spend another 700+ on one then converting to a 300 motor would be an interesting avenue to go down.
I'm interested to hear how you go with experimenting with different intake pipes. Something I think the EFI kit could benefit from because there is a reason why EFI bike's aren't putting out more power than carby ones like they should. |
January 17th, 2013, 09:22 PM | #105 | |
-the ecu controlling the secondary butterflies helps idle, but disrupts airflow at the top end. -tuning is meant for emissions and not performance -sensor placement is not optimal for response. -no closed loop or wideband o2 usage -the cooling system doesn't let the bike warmup, so the fuel map is distorted -the throttle opens too slow. there's probably more issues, but they are all problems i corrected on my bike. the hardware for the most part seems good, its mostly a tuning issue. i have some ideas on the exhaust, and most likely i'll be able to recoup the some of the cost by selling my existing exhaust. once i go the path of 300 i wont be looking back.
January 17th, 2013, 09:46 PM | #106 |
have you looked into how much a 300 motor will cost?
January 17th, 2013, 09:50 PM | #107 |
been scouring the auctions for wrecked ones.
haven't seen one yet...
January 17th, 2013, 10:13 PM | #108 |
Freedom for Germany
January 17th, 2013, 10:18 PM | #109 | |
You do know that a wideband sensor used in close-loop mode is really the best way to go if you're tuning a fuel injection system to a fuel ratio other than 14.7 right? If you're claiming that the O2 sensor restricts flow, then you're wrong. A properly installed O2 sensor does not significantly impact flow. If it does, it's not installed right. |
January 17th, 2013, 10:23 PM | #110 |
MOTM - Apr '13
Or your stock pipes are too tiny
January 17th, 2013, 10:25 PM | #111 |
...or you're using a Thai O2 sensor. Apparently those things make fake power and are HUGE!!
January 17th, 2013, 10:49 PM | #112 |
Freedom for Germany
January 17th, 2013, 10:55 PM | #113 |
Yes, but an O2 sensor is still the most important, seeing as hydrocarbons react with Oxygen in a combustion reaction. The other gasses are just present because air is not completely oxygen.
What do they stick in your exhaust pipe at the dyno? An O2 sensor. Sure there's a 4 gas sniffer that reads all 4 gasses, but that one isn't in your exhaust. |
January 18th, 2013, 12:20 AM | #114 |
MOTM - Apr '13
I'm going to have to side with chode on this one, he used the word 'hydrocarbons' compelling and scientific.
January 18th, 2013, 12:51 AM | #115 |
I think it's time to start a new thread. The Yoshi carbs are to expensive. That's for sure. I am also looking for a 300 engine. It will be a couple years for the price to drop below 2000 dollars. I payed 1500 dollars for an 08 engine in 08 my wife is still pissed. But that is the engine I am having built.
I have played with intake length and exhaust length some . From the little bit I have done I found . The carbs hit the frame with first gen intakes so length is restricted to what I wanted. But I found the length of the exhaust is also important. It would appear the longer you make both the higher the power is on the power band. Not much gain in power. It just moved it up a couple hundred rpm.
[speedTV.com] - GEARBAG: Mikuni HSR42 Performance Carburetor Kits for Sportsters and | Ninjette Newsbot | Motorcycling News | 0 | April 26th, 2013 01:10 AM |
[sportrider - latest stories] - Mikuni Carburetor Products Catalog | Ninjette Newsbot | Motorcycling News | 0 | January 3rd, 2013 02:00 PM |
[sportrider - latest stories] - Mikuni Carburetor Products Catalog 2012 | Ninjette Newsbot | Motorcycling News | 0 | January 31st, 2012 06:10 PM |
[motorcyclistonline] - New 5th Edition Sudco Mikuni Carburetor Manual | Ninjette Newsbot | Motorcycling News | 0 | September 16th, 2010 10:40 PM |
[sportrider - latest stories] - New 5th Edition Sudco Mikuni Carburetor Manual | Ninjette Newsbot | Motorcycling News | 0 | September 16th, 2010 12:10 PM |
