September 16th, 2012, 02:14 PM | #1281 | |
Now it's changing to a 3 tiered system, ages are increasing & so are hp limits, but there is a new restriction coming in, no bike can be taken below half it's stated power & the middle level test is to be done on a 400 (Which I predicted would be announced this year alongside the 250) |
September 16th, 2012, 02:35 PM | #1282 | |
September 17th, 2012, 02:45 AM | #1283 |
Join Date: Apr 2009 Motorcycle(s): 2014 Z250 Posts: A lot.
yeah someone buy the 300, crash it (safely) and sell me the engine block for a good price please
ill just have to figure out how to smuggle the bugger into the country, ha ha
Kawasaki Z250, Bored up to 300cc with 12.8 CR, 41hp at wheel 27nm torque, Two bros full exhaust with DB killer Dynojet Power Commander V, KnN Open filter, intake and exhaust ported, Puig Windshield |
September 17th, 2012, 03:56 AM | #1284 |
Would love to know what we're getting in South Africa.
Here we had the 250 FI already. Already confirmed we're not getting the 400. |
September 17th, 2012, 12:24 PM | #1285 | |
I have a moderate amount of experience with aerodynamics via human-powered vehicles. Wind resistance is partly Cd, but there's more to it. Focus on what's causing the drag, not the Cd number. Near the surface of the body, there's region of flow called the "boundary layer." If it stays evenly attached to the body, then drag is low. If it separates, eddies (vortices) form and drag skyrockets. This is what happens when an airplane wing stalls. There are two ways to keep the boundary layer attached. One is to go for laminar flow -- very, very smooth surfaces almost parallel to the flow direction. That means no seams cross-wise to the flow (even a decal can trip the layer), glass-smooth surfaces, no sharp lines or transitions. A polished egg, basically. Laminar flow is very low-drag but very delicate and easy to destroy. The other way is to energize the layer (make it turbulent) but keep it attached. Again, no abrupt transitions, steep angles or gaps... but you create turbulence with dimples (think golf ball), vortex generators, etc. Much less sensitive than laminar flow but not as low-drag. Once the boundary layer flow detaches from the surface of the bodywork, you might as well just have a trash can covering the frame of your bike. How it looks is unimportant if the air flowing over it is detached. The surface is effectively "invisible" to the airflow. On a factory bike, there are so many creases, gaps, seams, ledges, edges, fasteners etc. that there's no way the boundary layer is going to stay attached past, say, the headlight and windscreen. Fact of the matter is that as sexy as the bodywork may be, a motorcycle is pretty lousy aerodynamically. Any Cd differences between pregen, newgen and next-gen bodywork are most likely trivial in their net effect, especially when you put a rider on board. Next time you see a squid with his T-shirt riding up his back, think about the energy that's making it happen. Where's it coming from? Answer: It's coming from vortices created by the passage of the bike through the air. Totally detached flow. They suck huge amounts of energy... and no amount of good-looking bodywork at the front or sides of the machine is going to make them go away. To make a real difference aerodynamically, the whole thing has to be more enclosed, with a tail, top, doors... |
September 17th, 2012, 02:27 PM | #1286 |
Sounds like a good argument to pass a law requiring all female riders wear tight fitting leathers in order to save fuel.
Anyhow, regarding dimples, didn't they prove on Mythbusters that a car with a dimpled skin is more aerodynamic than smooth skin? It was something to do with why they put dimples in golf balls. The argument for requiring female riders to wear aerodynamic leathers is starting to look bad.
September 17th, 2012, 02:29 PM | #1287 |
Jigglin' your Jiglets
MOTM - Apr '13
They should be wearing aerodynamic leathers, with holes
September 17th, 2012, 02:38 PM | #1288 |
Ok, the dimple argument is looking better.
September 17th, 2012, 02:49 PM | #1289 | |
I love Mythbusters. Their methodology was sound but they would have gotten better results with smaller dimples. The boundary layer isn't that thick. Also, you don't need to bother past a certain point on the body... the flow will separate anyway. But they don't have the resources or time to go into that much detail. Cool story about laminar flow... possibly apocryphal. When building an airplane, you can use flush rivets (smooth surface) or conventional, round-headed rivets. The latter take less work (so faster to build the plane) and cost less but cause drag. In WWII Supermarine wanted to figure out how many flush rivets they actually needed on the Spitfire, so they built a plane that was entirely flush riveted and glued thousands of dried split peas over the surface to simulate round head rivets. They then did a series of test flights, removing more and more peas starting at the wing leading edges, until they got no further improvement in handling or performance. Very clever. |
September 17th, 2012, 04:52 PM | #1290 |
That particular hot chick gets my vote
I was with Alex.S and Jiggles last night and they had sex....the video is on utube. :-) |
September 17th, 2012, 06:32 PM | #1291 |
Women are already equipped with two aerodynamic devices an ex coworker labelled as "windsplitters" that men just dont have.
September 17th, 2012, 06:42 PM | #1292 |
MOTM - Apr '13
Can also be used as emergency airbags
September 17th, 2012, 10:01 PM | #1293 |
The A Team
Join Date: Aug 2012 Motorcycle(s): Z50, CB125, RZ500, MC22, R3. Posts: 394
http://www.bikesales.com.au/reviews/...inja-300-32492
First Aussie test, The new 300 has caught up to the Honda but not as impressive as first thought. Dammit I really wanted it to be miles better. I only ride my cbr on the track and yes it suffers on the straight bits (like any small bike) but it really makes ground where it matters. Got some thinking to do before changing over. |
September 17th, 2012, 10:20 PM | #1294 |
MOTM - Apr '13
Caught up to the honda? That was a bad joke
September 17th, 2012, 10:28 PM | #1295 | |
Finding some curves....
Join Date: Sep 2012 Motorcycle(s): 2013 300 Ninja Posts: 268
September 17th, 2012, 10:36 PM | #1296 |
The A Team
Honda has outsold the Ninja bigtime in Oz.
They are the same price since the introduction of the cbr early last year. And no Ninja has ever passed me on the track days , so no joke there either. I am looking to swap to a 300 (now that 250 production racing in my state looks like it wont happen) because I just like riding small bikes, and prefer to just go for my monthly blast in a safe environment. If its going to be a whole lot quicker which makes it nicer for the ever closing and widening gap between the big bikes at different parts of the circuit (which becomes dangerous for all) then I'm there.. the New 300 is only $200 more than the dinosoar it replaces. |
September 17th, 2012, 10:45 PM | #1297 |
MOTM - Apr '13
I'll bet that if you rode a ninja 250 no ninja would pass you either. A superior bike won't make up for a riders lack of skill. Put two racers of equivalent skill on the cbr and ninja and the ninja will win, it's a superior bike.
September 17th, 2012, 11:49 PM | #1298 | |
The A Team
September 17th, 2012, 11:50 PM | #1299 |
MOTM - Apr '13
September 18th, 2012, 02:46 AM | #1300 |
^^ lolz~
September 18th, 2012, 05:50 AM | #1301 |
The ninja is definitely the better bike even with the old gen.
Thats not saying the cbr is bad. The ninja is just that good
September 18th, 2012, 06:56 AM | #1302 | |
Join Date: Nov 2010 Motorcycle(s): KTM 390 Duke Posts: 428
So, dimples will work with some girls and not the others: if they're teardrop-shaped or slender, skin friction is good... if they're ball-shaped, separation is likely |
September 18th, 2012, 09:37 AM | #1303 | |
chicks should go without dimples. Posted via Mobile Device |
September 18th, 2012, 10:44 AM | #1304 |
Name: I'm a ninja!
Join Date: Jul 2011 Motorcycle(s): 2009 Ninja 250 Posts: 453
n4wmd, how did we go from talking about the new 300 to you thinking about girls in leather?
September 18th, 2012, 10:53 AM | #1305 |
Join Date: Jan 2012 Motorcycle(s): Ninja 250r - Track whore, Ninja 300 - SOLD, KTM RC390 - Orange Hulk, Ducati 899 Panigale - Red Devil. Posts: A lot.
It was always about the girls in leather... The 300 was just an excuse :P
September 18th, 2012, 11:10 AM | #1306 |
The 300 is for the fatter chicks. The hot chicks can still fit on a 250.
The odds are that the 300 is more aerodynamic than the newgen and newgen more aerodynamic than the pregen. That's simply saying that a better Cd is one of the things that evolves in sport bikes. Putting a hot chick on it with tight one piece leathers and dimples just makes it go that much faster. I signed up with T-mobile too.
September 18th, 2012, 12:13 PM | #1307 |
Yep, I've been thinking about girls in leather ever since I started thinking about girls.
Starting with this one. |
September 18th, 2012, 01:24 PM | #1308 |
MOTM - Apr '13
I'd think the pregen would be the most aerodynamic considering it is the smallest
September 18th, 2012, 01:34 PM | #1309 |
Name: I'm a ninja!
Personally I prefer them like this....
September 18th, 2012, 01:36 PM | #1310 |
i'm not opposed to vinyl
September 18th, 2012, 03:15 PM | #1311 |
Join Date: Dec 2011 Motorcycle(s): 2009 Ninja 250R SE Posts: 767
Anyone think, or know if any of the 08-12 stuff will fit on the 13? Like lighting stuff (tail light, turn signals)?
September 18th, 2012, 03:33 PM | #1312 | |||
Under $5,000 on introductory year? Check. Accessorizing to add profit? Double-check (factory tanks bags and "engine guard" frame protectors/sliders and solo seat cowls and tank pads and sport-touring windscreens- OH MY!) |
September 18th, 2012, 03:52 PM | #1313 | |
I think that the wheels may fit because the swingarm looks the same, there was always room for a wider rim, and the front tire size didn't change, but that's just a guess. The little hugger might swap for the same reason. Sprocket cover looks like it may have changed a bit (fewer bolts?) but it may still swap one way, which would be cool considering that the 2012 cover actually fits a 1986 bike (pre-pregen). Sprockets, chain, air filters, etc: Dunno. The wiring harness is too different for a straight gauge swap. The handlebars and triple-tree clamps do look the same. The front fender mount may be different so the forks may have changed slightly. Windscreens and fairings obviously don't swap. |
September 18th, 2012, 04:15 PM | #1314 | |
I'm torn between buying a 2013 or staying with the 08-12. I was part of the group buy for the integrated tail light with LED turn signals. I was pretty sure I'd already have a bike by now.... Plus, living in Hawaii, I could buy two used ones for the price of a new one. (they are saying 8K OTD) I do love the FI, digital guage, and ABS. Other than that it doesn't matter. I wish they had other options for the ABS bike other than the kawi green/black. |
September 18th, 2012, 05:35 PM | #1315 |
I thought this was a good review from someone who had ridden the 250 ninja and wasn't to impressed but was turned around by the 300. Interesting note when he said 80 to 100 mph was a breeze.
http://www.pistonheads.com/doc.asp?c=52&i=26361 Enjoy the review. |
September 18th, 2012, 05:46 PM | #1316 |
Join Date: Jul 2010 Motorcycle(s): 2014 Honda CRF250L, 2010 ninja 250r Posts: 413
Thanks for posting the review. That's exactly what I expect to feel about it. Looking forward to it non the less.
September 18th, 2012, 08:03 PM | #1317 | |
September 18th, 2012, 08:05 PM | #1318 |
How do they come up with $8K OTD?
September 18th, 2012, 08:08 PM | #1319 |
Cause everything here is way more expensive. Even on the 2012 it's about 2K more than MSRP. Fees fees fees.
Last futzed with by Kstorm21; September 18th, 2012 at 08:43 PM. Reason: my phone is stupid! |
September 18th, 2012, 08:46 PM | #1320 | |
Here's a review tonight from Gabe over on BARF. He writes for City Bike and MotorcyleDaily.com, and has always been a fan of our tiny kawis.
http://www.bayarearidersforum.com/fo...&postcount=129 Quote:
Ninja 250 & 300 Valve Spring Thread | garth285 | 2008 - 2012 Ninja 250R Tech Talk | 30 | February 19th, 2017 02:42 AM |
Subjective 250 vs 300 thread to help potential buyers | cadd | General Motorcycling Discussion | 54 | September 8th, 2014 09:44 AM |
2013 Formula 1 - Official Thread | camaroz1985 | Off-Topic | 125 | January 4th, 2014 07:40 AM |
2012 Formula 1 - Official Thread | camaroz1985 | Off-Topic | 115 | November 26th, 2012 11:21 AM |
Official Area-P Pre-08 Ninja 250 Exhaust Thread | Purspeed | 1986 - 2007 Ninja 250R Tech Talk | 336 | September 19th, 2012 06:01 AM |
