May 10th, 2011, 09:57 AM | #121 |
Join Date: Oct 2009 Motorcycle(s): Red 08 250r Posts: 218
http://www.nycsportbikeriders.com/ Jetkit,15/43,HID |
May 10th, 2011, 01:07 PM | #122 |
Join Date: Jul 2010 Motorcycle(s): '08 Ninja 250R Posts: A lot.
MOTM - Oct '15
Now that looks spectacular! Gonna need to do some more research on this...
My therapist has 2 wheels and a seat. If you are ever in doubt to my tone, please refer to my avatar. |
May 10th, 2011, 04:53 PM | #123 |
I think ill do it this winter but need more info
May 10th, 2011, 11:23 PM | #124 |
ratlab
Join Date: May 2011 Motorcycle(s): gsxr1000,R3x2,RC390,FZ07,XR100 Posts: 132
i have been dealing with power commanders for years now,the maps on their website are there or thereabouts but never spot on -you always have to get them dynoed for perfect fueling-really there is nothing better then a perfectly jetted carb -its a pain playing around jetting-but its a lot cheaper then 6 hours on a dyno
May 10th, 2011, 11:26 PM | #125 | |
May 11th, 2011, 07:40 AM | #126 |
ModMy250.com
It is a stepping stone to adding a turbo though.
The www.ModMy250.com guy |
May 11th, 2011, 08:43 AM | #127 |
MOTM - Sep '18, Feb '16
The map sensor is 1 bar. That is probubly mesuring vacuum. 1 bar is 14.7 .you. need to have a map sensor that reads positive pressure for a turbo and like 2 bar
May 11th, 2011, 09:46 AM | #128 | ||
ModMy250.com
May 11th, 2011, 12:20 PM | #129 |
Thanks I did not read that. I am only able to get on line through my phone right now. I can't wait to talk to them. I am sereous about this.There is a lot of interest but very little need to turbo charge a 250 ninja. .
May 11th, 2011, 12:41 PM | #130 |
+1
May 11th, 2011, 01:20 PM | #131 |
self wrencher
Let's chop it in half...one cylinder carb and one cylinder EFI.... Best of both worlds... Woot!!
May 11th, 2011, 01:20 PM | #132 |
ModMy250.com
LOL, true, but you don't really need to install FI onto the carb ninja either . Just depends on the individual.
May 13th, 2011, 12:26 PM | #134 |
Join Date: Mar 2011 Motorcycle(s): 09 Ninja 250R Posts: 49
How would you mount the fuel injectors and temperature sensors? Also the would the throttle cable be PnP as well?
This would be a fun little project..after EFI comes the turbo td02 turbo looks great for this bike.. |
May 13th, 2011, 03:06 PM | #135 |
I have aluminum manifold tubes to screw injectors into. I have nitrous injectors in the stock rubber manifolds right now.
For my turbo system I am going to mount a single throttle body on the inlet side of the turbo.like if you where running a carb wet turbo system . As for throttle cable .If some one sells a 1/4 turn set up that will work for you buy it. Making custom cables that work and can be adjusted and don't look like all ass is a pain. |
May 13th, 2011, 03:18 PM | #136 |
I believe thats the "suck-through" system? Also, the engine temperature sensor scares me...how is that going to be mounted? Going to require tapping into the head?
May 14th, 2011, 02:25 AM | #137 |
I have a temp light sensor (stock) that is mounted in the thermostat housing.after that I have a water temp sensor mounted in the hose with an adapter block from Koso. It mesures the water temp coming out of the head.
If you wanted to directly mount a temp sensor in the head or block it is an easy job.just drill and tap |
May 15th, 2011, 01:25 PM | #138 |
Join Date: May 2009 Motorcycle(s): 2009 Kawasaki Ninja 650RTE & 2009 Kawasaki Ninja 250R (SOLD) Posts: A lot.
False!
I was at a local powersports dealer and Sat on a Honda CBR250RR here in Michigan! Rage42 was there with me. the HondaCBR250RR is Carb'ed just like our bikes. Its also a SINGLE piston engine! lol |
May 15th, 2011, 01:47 PM | #139 |
DIY EFI KIT for our 250r | forbitel | 2008 - 2012 Ninja 250R Tech Talk | 331 | January 30th, 2024 07:03 PM |
ECOTRONS EFI Kit Question | patriots21 | 2008 - 2012 Ninja 250R Tech Talk | 20 | October 3rd, 2015 09:19 AM |
My Experience with the EcoTrons EFI kit | lolibater | 1986 - 2007 Ninja 250R Tech Talk | 106 | February 19th, 2015 10:14 AM |
Ecotron's EFI Kit | parox91 | Motorcycle-related | 11 | August 13th, 2013 04:52 AM |
