February 18th, 2016, 09:16 AM | #121 | |
Finally have a friend in the area and my sister lives there. She's moving soon, so I'll be visiting again in May after graduation, most likely. |
February 18th, 2016, 09:32 AM | #122 |
Join Date: Aug 2015 Motorcycle(s): 05 Ninja 250, 04 KTM 625 SMC, 01 Xc250 Posts: A lot.
I will be there around that time, But likely in April. It all depends on when I have to go to camp pendleton.
Because Unregistered sucks at riding. |
February 18th, 2016, 10:48 AM | #123 |
Yepp yepp, I'm just really hoping it's not snowing next weekdn.
February 18th, 2016, 11:14 AM | #124 |
Join Date: Mar 2015 Motorcycle(s): 14 Ninja 300 (Track Only), 07 CRF150RB Posts: 281
Well PM when you guys come in, im a local so i can meet up with ya, not sure if the bike will be running but im sure i can find one to ride haha.
February 19th, 2016, 09:37 AM | #125 |
Will do. Will be trying to meet up with TnNinjaGirl as well.
February 19th, 2016, 09:42 AM | #126 |
If I can remember your username I will, but I will likely just have to post in general. I do look forward to riding with a fellow ninjetter though. I plan to hit up 129 and cherohala skyway, maybe I will learn some new roads?
February 19th, 2016, 10:00 AM | #127 |
February 19th, 2016, 11:00 AM | #128 |
February 19th, 2016, 11:15 AM | #129 | |
Cant wait to meet some of you guys. |
February 19th, 2016, 11:21 AM | #130 | |
I will get my suspension rough tuned her in IN, but I'm sure I will have adjustments to make while I'm there.
February 19th, 2016, 11:29 AM | #131 | |
February 22nd, 2016, 06:02 AM | #132 |
Ms. Personality
Huh? What'd I miss?
February 22nd, 2016, 07:13 AM | #133 |
She Lives!!!
So much stress has been relieved! THis is the first time that i have ever done a tear down like this and she started up pretty easily. I still have a ton of little stuff to do but what i was worried about is over... Just hope there arent any flat spots higher in the rpms. I cant wait to get to actually ride her soon!
February 22nd, 2016, 07:14 AM | #134 |
February 22nd, 2016, 03:13 PM | #135 |
She already knows. But you know 100 things going on at once.
March 1st, 2016, 03:12 PM | #136 |
So update... She runs! Took her out on the dragon on Sunday. Have a small flat spot from 7.5-9k but i think that ill be able to sort that out with some needle shims. The new suspension feels amazing compared to what it used too.
So we trailered the bike up there and unloaded it, rode about half way through with no issues. Pulled off to help my buddy setup his camera spot, then went to cruise the rest of the road for my first pass. Made it about two corners in and then it died. Pulled off and started her back up but would die as soon as i put in in gear. Knew it had something to do with my clutch switch delete. So pulled the tank and made the repair and was on my way again. So i removed the switch and just connected the wires.. I still cannot start my bike in gear, not sure whats going on here. IMG_1265.jpg So i went to make my first pass with a little bit of speed, nothing close to normal pace as i was still getting a feel for the new bike.. and i made a mistake Came in a little hot into "2 Square" and there was a truck going the opposite way, i got a little rattled and attempted to trail brake pretty heavily. The old suspension was pretty forgiving of this but the new setup is not. Asked too much of the front and down i went, about 40ish mph i would guess. Slid across the other lane and stopped in a well placed pull off. I am unharmed, except a bruise on my elbow and ego. Bike was pretty much fine also, i twisted my right clip on on the fork tube and knocked my banjo bolt out of my M/C. Went to the store and got some brake fluid and got everything back lined up. IMG_1272.jpg IMG_1271.jpg So took the bike out and made sure that everything was in order and then started making a couple runs. Didn't take me very ling to get my groove back. The pic below is actually the same corner i went down in but i was going the other way. IMG_1270.jpg |
March 9th, 2016, 02:26 PM | #137 |
Looks like ill be changing stuff around to make the bike WERA legal since i cant hang with the fast guys on the 300s. They pull on me on the straights an the corners... Onto reading and understanding how wera works.
March 9th, 2016, 04:55 PM | #138 |
Bummer you went down but glad it all worked out ok.
March 18th, 2016, 12:41 PM | #139 |
Added another shim to each needle and the flat spot is gone cant wait to get it test it out some more!
2009 Build Thread | Bloody wheels | 2008 - 2012 Ninja 250R Farkles | 1 | October 1st, 2015 05:50 AM |
What's your favorite build thread? | Hero Danny | Off-Topic | 2 | July 24th, 2015 11:53 PM |
Christmas Build thread | ds650rida | 1986 - 2007 Ninja 250R Tech Talk | 84 | June 10th, 2014 02:46 PM |
Saddle up-prepping for a winter build | Kscreations08 | General Motorcycling Discussion | 7 | May 27th, 2014 07:42 PM |
Epic build thread | Alex | Off-Topic | 8 | April 8th, 2013 04:57 PM |
