#121 |
Join Date: Jan 2014 Motorcycle(s): Had a 2008 Ninja 250, til some low-life stole it. Now riding a 2013 red cbr250. Posts: 274
At dealership now. Jerk doesn't want to let me test ride, but an employee has one himself and will let me in a few min.
#122 |
Just rode a 2013 300 ABS model. Drove it in-town and also on a curvy strip of asphalt near the dealership.
I wasn't wowed. I wasn't wowed! ![]() |
#123 |
Private Joker
MOTM - Mar '14
As I said, it's better than a 250 but not amazingly so. Most of the things that make it better just make it more useable as a daily bike. FI + better midrange torque = better daily rider.
#124 |
Maybe I should just improve the 250 and be done with it.
If you had, say, $1,000 in order to improve the 250, what would you spend it on, from stock? |
#125 | |
Join Date: Jun 2012 Motorcycle(s): 12' Ninja 250 Posts: 831
id really looove to have FI on my 250 |
#126 |
Private Joker
MOTM - Mar '14
#127 |
Motorcycle Hypermiler
Join Date: Jan 2012 Motorcycle(s): 1999 & 2005 Kawasaki Ninja 250R's Posts: A lot.
I'm glad you decided to check the 300 out. I haven't ridden one but I've always wondered if it that much better than the 250. Still, I would be careful about investing a large amount of $ on the 250. The stock package is actually pretty doggone good. Tires first would be my advice.
235 MPG ![]() ![]() Last futzed with by greenaero; February 13th, 2014 at 03:49 PM. |
#128 |
Yes, tires are my first priority. I'm also returning the slip-on I ordered and will probably invest in a full exhaust system. Is that something someone can do themselves, with minimal tech know-how?
Also, I keep hearing about clip-ons and rearsets. Why do people get these? |
#129 |
Private Joker
MOTM - Mar '14
clip ons and rearsets are for a sportier seating position so that when you're pushing it the ergos are more natural. They are the fairly important mods if you're into track riding or riding hard in general.
#130 | |
I think my first priorities will be new tires and SS brake lines. Then I'll go from there. |
#131 |
Private Joker
MOTM - Mar '14
#132 |
#133 |
Private Joker
MOTM - Mar '14
#134 |
antiant
MOTM - Oct '14
A stand makes everything easier.
#135 |
Just read up on rejetting. Ugh, don't think it's worth the extra ounces of power. Can it damage the bike if I install a new full exhaust system without rejetting? Or will my fuel economy worsen?
#136 |
Private Joker
MOTM - Mar '14
I don't know for sure, I can't think of any reason why it would do any damage though. I'd know if I ever had the money to install a full exhaust system. I can't imagine it being any different than just installing a slip on to the fuel economy or engine. The reasoning is that the backpressure change is the only thing that would really affect the engine which is minimal at best if you're swapping to an exhaust that is meant for the bike.
#137 | |
Ninja chick
Join Date: Jun 2009 Motorcycle(s): '13 Ninja 300 Posts: A lot.
MOTM - Dec '13, Feb '15
Sometimes it's the journey that teaches you a lot about your destination. ~Drake Check out my Appalachian Trail journal, 2015! Postwhores are COOL! ~Allyson |
#138 |
Join Date: Apr 2011 Motorcycle(s): 2002 Honda 919, 2004 Ninja 500R NAKED Posts: A lot.
The bike runs lean from the factory, installing a full exhaust without jetting will make it run extremely lean. You're not really going to gain much power with a full exhaust without a rejet either, maybe a little but at the expense of your engine running like **** too. It's not all about peak power, it's about how power is made too. If you gain 1-2 hp on the top end but your bottom and mid range suffer, your bike is going to actually be slower. You'd probably honestly gain more performance from just rejetting the carbs with a stock exhaust. Jetting isn't that big of a deal though... once you do it you'll never be scared of it again. Carburetors really aren't that bad to disassemble and reassemble, not as easy as FI but hey a jet kit is $80 or so vs $250 for an efi controller lol. At the very least shim the needles (easy) and mess around with your pilot screw or whatever it's called and that'll get it running a bit better.
Oh and for the record I am not a noob! Flashing lights at people has been something I've been doing for years without ill results, the only signal I've ever seen for "go ahead" is people literally waving their hands to gesture it. Flashing lights is supposed to mean "I want to pass you" hence why certain faster bikes have a little flasher switch built in. Though I believe in WA that's illegal to do. Regardless, I'd rather not have someone mistakenly think I'm telling them to go ahead when I'm trying to say the exact opposite lol. |
#139 | |
#140 |
Okay, so I made some calculations, and if I stay with the 250, based on the money I have now, I can get some new Diablo Rossi II's, a nice full exhaust system, some SS brake lines (in on the group buy), and a gorgeous Translogic gauge, and still have a nice chunk of $$ left.
I don't see the upside to moving up anymore. Being as it's a commuter bike and not a ride-her-hard toy, I think I'll be okay with the 250. Want to say thanks, though, to all you guys for your awesome tips, advice, and spankings (those are valuable too). ![]() |
#141 | |
as for exhaust check out Area P. best exhausts evah. |
#142 |
Join Date: Nov 2012 Motorcycle(s): Ninja 300, KTM EXC610SMR Posts: 913
Try Duro HF 918 tires. Much better than the stockers, about $130 shipped for both.
#143 | |
#144 |
#145 |
Private Joker
MOTM - Mar '14
You may want to consider Bridgestone BT-45s they have good commuter life and sporty grip. They're what I'm looking into getting for my 300 since tire life is more important than absolute grip limits for my skill level.
#146 |
I pounded them and got 3500 miles. Riding easy I'd bet you easily double that.
#147 |
$1000 should do nicely.
In order of priority: 1) Full exhaust (I highly recommend the AreaP Quiet Core) AND rejet AND keen air + snorkel delete AND K&N panel filter... you do all these at the same time because they're all interrelated. Do just one and you'll have to go back in anyway. You can do the whole thing in a relaxed day, or an afternoon if you're already familiar with working on the bike. The hardest part is pulling the carbs out. 2) Tires. I sold my bike before I needed new shoes, but had I kept it I would have gone Pirelli. 3) Ergos (clipons and rearset adjusters, which simply move your stock rearsets... way cheaper) 4) Brake lines? Pass until it's time to replace 'em anyway. Yeah, they'll improve your brake feel but the other mods will give a more noticeable improvement in the way the bike feels overall. Here's the thing about rejetting and doing the exhaust. It's FAR more than "ounces of power." You get a real, measurable improvement of power and torque that you can absolutely feel. The bike is TRANSFORMED by this. I liked it before I did it. I LOVED it after. You don't have a stand? Get spools. Get stands. Now. Before anything else. They make working on the bike MUCH easier AND safer! You CAN do all the engine and exhaust work without lifting the bike, but it's much easier if you do. I pulled my carbs out of the left side of the bike (a lot easier than working on them if they're still installed) and that's a PITA if the bike's on its side stand. This stuff is not rocket science, but it is certainly more involved than, say, changing spark plugs. Just be patient and take it step by step. Oh, and... go get the factory maintenance manual. Seriously. Do it.
#148 |
Join Date: Apr 2013 Motorcycle(s): 2005 Ninja 250, 2006 SV650N Posts: 642
It would be pointless to do so without rejetting performance wise. Adding pods, new exhaust, and rejetting will get you at least 5 extra hp which is significant for such a small bike. Pods and rejetting by itself will yield the most performance gains vs just doing the exhaust.
#149 |
You guys are going to laugh, even though I feel like crying. . .
My motorcycle got stolen last night. It's gone. |
#150 |
And no, I'm not trolling.
Freaking thieves. |
#151 |
Insurance? Did the guy ever come look at your bike? If so it was probably him.
#152 |
MOTM - Sep '14
wow that sucks
#153 | |
No, the guy never looked at it. I texted him and told him I'd changed my mind about selling. He didn't know where I live or work, so highly doubtful. This totally sucks. |
#154 | |
Private Joker
MOTM - Mar '14
This is why Theft & Fire insurance packages are a must buy with bikes. Though the risk for fire isn't really that high unless you crash theft is horridly common. ![]() |
#155 |
That sucks! I hope you get a decent amount for it. When I crashed and totaled a bike I got more than I paid for it with the insurance pay out. Had a $500 deductible as well. You might get more than you think.
People can be real jerks! Karma will get the person responsible someday. And what kind of life is it to go around stealing bikes? No better than a crack dealers life in my mind. Keep a positive rider's attitude and don't let it get you down. ![]() On another note: I know you weren't wowed by the 300, but it is reasonable affordable and easier to hop up since it's fuel injected. That I think is the biggest plus of the 300, fuel injection. The extra power is nice, and it looks good too. Don't count it out. Maybe if you feel inclined go test ride the one you rode again with a new perspective. I just really like the 300 and thinking I'll get one again in the next year or two to replace the one I sold. |
#156 | |
I'm not sure how long the insurance process will take, and I'm not very optimistic I won't get screwed. But we'll see what happens. |
The GoPro Tape Trick | Jiggles | General Motorcycling Discussion | 22 | November 7th, 2012 07:49 AM |
Trick Italian Bits | kavo | Ninjettes At Speed | 17 | May 24th, 2012 01:04 PM |
My dog learned a new trick | Jiggles | Off-Topic | 5 | March 28th, 2012 12:31 PM |
How about some football trick shots... | dubojr1 | Off-Topic | 6 | February 15th, 2011 09:10 PM |
