Old February 19th, 2014, 10:56 AM   #121
old3
Might add more flex again but I think you might get away with that mount by adding spacers on the radial mounting bolts to move the cal out to the edge of the bigger rotor. Add appropriately longer bolts too of course. i.e. 10mm spacer, add 10mm to your bolts.
You get the look, maybe not the full benefit but the calipers are excellent quality. I agree, if you already have one, why not?
It should be mounted on the correct angle to hit the radius squarely right? Straight off the axle so to speak.
old3 is offline   Reply With Quote
Old February 19th, 2014, 09:28 PM   #122
mania
mania's Avatar
Motorcycle(s): 2013 250
Hmmm you know that is a good possibility I had not thought of.
I do not have one but they are available & not too pricey
After all as you say the angle should be correct
mania is offline   Reply With Quote
Old February 20th, 2014, 12:13 AM   #123
mania
mania's Avatar
You know while looking at Moto3 testing today
noticing the alternative to bigger rotors & calipers.
Of course these bikes are much lighter
But it would be nice to have this fork & front rim. ( of course )
Be able to run twin small disc with small strong caliper on each side
File Type: jpg 08miller_img_3988_jack-miller_original.jpg (85.5 KB, 31 views)
Old February 20th, 2014, 01:42 PM   #124
Xtina
Xtina's Avatar
Motorcycle(s): 2013 Ninja 300, 2007 Gsxr 600, R6-sold :(
I need bracket! JIM WHERE ARE THEY! /
Xtina is offline   Reply With Quote
Old February 20th, 2014, 01:57 PM   #125
DaveTheCanuck
Moo
DaveTheCanuck's Avatar
DaveTheCanuck is offline   Reply With Quote
Old February 20th, 2014, 03:47 PM   #126
old3
I'm waiting on SV Racing, sorry guys! If it makes you feel any better, I can't even ride my bike as I don't have my original custom bracket back yet.
Al for a good cause anyway. Last we wrote, Blair said he was almost done with it. I'm hoping to have it back for the Daytona SX trip I was planning on.
Old February 21st, 2014, 04:37 AM   #127
shadewalker
All the best.. Hope u get it in time..
shadewalker is offline   Reply With Quote
Old February 21st, 2014, 07:06 AM   #128
sharky nrk
Fighting Texas Aggie '05
sharky nrk's Avatar
MMMMMMMM love me some Moto3 bikes
Old February 21st, 2014, 10:40 PM   #129
Alkeplar
Motorcycle(s): 2013 Ninja 300ex SE(non-ABS)
One could only with O_o
Alkeplar is offline   Reply With Quote
Old February 26th, 2014, 07:46 AM   #130
DaveTheCanuck
Moo
*poke* anything?
Old February 26th, 2014, 09:00 AM   #131
old3
Not yet, I'll send him a request for that link today... See if we get anywhere.
Back as soon as I hear!
Old February 27th, 2014, 03:40 PM   #132
old3
Looks like I won't be able to use a SV Racing cal bracket after all!
320MM, full floater!
Thanks Mike!!!
BTW, I emailed SV, still no word back. I was expecting a link to let our members preorder brackets. I'll post up ASAP when I hear back!
Old February 27th, 2014, 05:51 PM   #133
mania
mania's Avatar
Looking good
Sure look proper now with a real caliper on there too
Old February 27th, 2014, 05:53 PM   #134
old3
I think I may have to bribe my machinist with a big bottle of booze or the GSXR front end I doubt I'll be using!
This thing should be nasty with that set up on there!
Thanks again buddy!
Old February 27th, 2014, 09:24 PM   #135
shadewalker
Thanks again buddy!
Wow wow wow.. This time of u do get it machined please keep the dimensions.. I might go for this setup too.. :-D
Old February 28th, 2014, 03:53 AM   #136
fast1075
Motorcycle(s): 2006 Ninja 250, 2004 Buell XB12s, Honda 110 Elite
Bad News
For those of you who may have been following this thread that have a Pre Gen that want a killer front brake by using the GSXR caliper, I have bad news.
It will not fit. That is, if it is mounted so all of the swept surface of the disc is used. The pads exactly match the swept surface, as they should. If you mount the caliper in the position where it needs to be to align the pads properly, the caliper hits the wheel hub where the rotor bolts are located.
This is because the Pre Gen rotor is 30 mm smaller than the New Gen/300 rotor. The required larger rotor will not fit a Pre Gen wheel, and there is no alternative that I can find. If the larger rotor fit, all would be fine, and I would be doing stoppies today.
Other wise you would need to mount the caliper cocked up so only part of the pads grip the rotor. Not acceptable, at least to me. So without changing to new wheels, etc, (which I have no desire to spend a ton of money doing) unless there is a double top secret over size rotor that seems to not exist, I will be keeping it stock.
Is there a double top secret over size rotor for a Pre Gen?
"They don't pay me enough to ride this thing!" Kenny Roberts after winning the Indy Mile on the TZ750 powered Grand National bike.
fast1075 is offline   Reply With Quote
Old February 28th, 2014, 04:03 AM   #137
mania
mania's Avatar
I am not familiar with Pre gen but are you saying a custom adapter cannot be made?
Also how about Beet? Do they sell for Pre-Gens?
http://www.beet.co.jp/english/kawasa...50r/index.html
I see they have a 40 & 65mm adapter as well as bigger rotor kits
Not 320mm but 310 I think.
Old February 28th, 2014, 05:10 AM   #138
Somchai
Freedom for Germany
Motorcycle(s): Ninja 250R-FI
I know the website is in german language (Google will translate it for you) and also it looks like that you guys not often look for a german company (except the world-known like BMW i.e.), but here > http://mx-tec.eu/public/dyn_layer.as...6-3a3b54744ee0 < I got my rotor made like I needed it to be (296mm). So maybe you give it a try, since there you get everything you need and also this small company is very well known by german riders...
There's always a way to get what you need and the prices go from around 100 to 150 USD.
And if you need help with the translation just send me a message.
Old February 28th, 2014, 05:21 AM   #139
fast1075
Thanks for the links. Guess my Google-fu is not strong enough.
Making the adapter is no problem at all. The problem is the stock rotor is not large enough in diameter for the caliper to clear the wheel. It MIGHT be possible to machine the caliper down enough to clear, but I am not going that route. It looks like machining the caliper down might compromise the integrity of the caliper.
I will check out the links and see how that goes. Thanks!
Old March 3rd, 2014, 10:20 AM   #140
Xtina
Xtina's Avatar
Thanks Mike!!!
fffuuuuuuu!
Quitter
Old March 3rd, 2014, 11:03 AM   #141
Dude, your gold and your orange are clashing. Better get that fixed.
Old March 5th, 2014, 06:53 AM   #142
old3
Quitter? Xtina, never!
I'll stay on the case guys, as soon as Blair sends me the order info I'll pass it along here. It is going to be worth the wait!
Old March 5th, 2014, 08:23 AM   #143
mania
mania's Avatar
I am keeping my fingers crossed for the next adapter
Old March 5th, 2014, 08:28 AM   #144
mania
mania's Avatar
BTW: on the USD forks this one was just posted today here
an older 250 with 2003 zx6 fork & wheels as well as a swingarm off a 89 CBR400
I think it is way too much tire wise for a 250
but like the fork, brakes & swingarm
Old March 5th, 2014, 08:48 AM   #145
Xtina
Xtina's Avatar
It looks so bulky.
Old March 5th, 2014, 09:12 AM   #146
mania
mania's Avatar
It looks so bulky.
Yes way too much tire
Old March 13th, 2014, 04:56 AM   #147
mania
mania's Avatar
RSV has made a nice radial adapter for the Ninja running the 320mm front rotor
Only bummer is it is the 100mm adapter.
That means a pricey Brembo caliper & probably need the radial master pricey also
This bike is running both
Old March 13th, 2014, 07:03 AM   #148
sharky nrk
sharky nrk's Avatar
^^ I really like that, what we need is a bracket that will accept standard spacing radials, and a matching oem rotor at bolts on. Grab some takeoffs from someone who upgraded to those pricey Brembo bits
I love hand me down upgrades lol.
Old March 13th, 2014, 07:32 AM   #149
mania
mania's Avatar
Actually I know RSV did one for standard rotor & Nissin radial
But do not know if it was a one off or a stocked item
Here is a pic
Old March 13th, 2014, 08:28 AM   #150
sharky nrk
sharky nrk's Avatar
Here is a pic
lol, they don't have a US distribution arm though do they?
Old March 13th, 2014, 09:12 AM   #151
DeltaFoxtrotZulu
Motorcycle(s): 2013 Kawasaki Ninja 300
Wonder where they got the 320 rotor? From another Kawasaki or something custom they sell?
Starting to worry about this SVR adapter not coming...
DeltaFoxtrotZulu is offline   Reply With Quote
Old March 13th, 2014, 09:45 AM   #152
mania
mania's Avatar
We have them here in Thailand
I bought one too
It was marketed under Nassert Beet name but is not their product
Does seem a good rotor though IMO
Although my stock caliper looks really tiny now
I am looking to change soon to Axial 4 pot Nissin or Tokico
As soon as I can suss the mount out
Old March 13th, 2014, 10:53 AM   #153
old3
Production takes time, I just emailed him a few minutes ago and will let you know what he says. He runs a pretty nice sized business and all his stuff is beautiful, anodized and precision. I have no doubt these will be excellent brackets, nothing like the brick I sent him!
Patience, he needs to build jigs to be able to reproduce these reliably, then send them for the color coating. It'll be worth the wait IMO.
Old March 13th, 2014, 01:45 PM   #154
old3
Here is the actual reply I got today,
"Hi Jim, I was just at the shop this morning, it is all in final production fitting now. It will be a redesign of what your guy did and I think you will appreciate the differences once you see them."
So, it is coming!!! Don't fret!!! Save your quarters, dimes and nickels and be ready to pounce on them when they are released!
Old March 14th, 2014, 07:28 AM   #155
Han Solo 1
Motorcycle(s): Had a 2008 Ninja 250, til some low-life stole it. Now riding a 2013 red cbr250.
Just went through most of this thread.
Is this something that someone can install themselves without a lot of wrenching knowledge? Or is it better to take it in to a shop?
Han Solo 1 is offline   Reply With Quote
Old March 14th, 2014, 07:34 AM   #156
allanoue
allanoue's Avatar
MOTM - Sep '14
it is easier to do then the bearings.
Old March 14th, 2014, 07:35 AM   #157
Han Solo 1
Cool.
Old March 14th, 2014, 10:20 AM   #158
old3
Super easy job. Read up on bleeding brakes. I can do it alone, but a friend to work the brake lever helps. The actual caliper install will be a snap.
1. Remove brake hose at caliper, be ready to catch/mop up brake fluid
2. Remove 2 bolts securing caliper to fork and remove caliper
3. Bolt on adapter/caliper. I haven't seen the new part so you might bolt them together first or after the bracket is on the bike. Check the pads are outside the rotor, one on each side.
4. Attach brake hose
5. Bleed brake at caliper
I'd suggest adding a SS braided hose while you are there if you have a stock hose. You are half way done already, just remove it from master cylinder and replace it.
This is no more than a 30 minute job from start to clean up.
Old March 14th, 2014, 10:21 AM   #159
Han Solo 1
Super easy job. ..............
Wow. If it's really that much of a difference in braking power, I might go ahead and do this.
Old March 14th, 2014, 10:29 AM   #160
DeltaFoxtrotZulu
What do you use for bleeding. I've tried a few things and the hoses are always too narrow I cannot get them onto the caliper bleed screw. I'm thinking one of those reverse pumps might be the best route.
2002 GSXR 600 TELEFONICA street/track bike, w/ lots of goodies in CA chugs Motorcycle-related 0 November 13th, 2013 06:17 PM
Mounted Her today ;D StephenA 2013 - 2017 Ninja 300 General Discussion 40 October 12th, 2012 10:41 AM
Where to get tires mounted? Betlog 2008 - 2012 Ninja 250R Tech Talk 4 December 28th, 2009 01:59 AM
