Old March 24th, 2012, 11:27 AM   #121
gstx
Motorcycle(s): 08 250r
Hey guys, so I was getting ready to do this mod but I noticed something different that the old owner probably did to the bike. First there isn't any small tube that runs from the 'vacuum controlled valve' to the 3 way T connector, only the 2 big tubes to the cylinder head and airbox.
Secondly, the 3 way T connector listed in the pictures.. one goes to the carb, one goes to the fuel petcock, and one goes into the fuel tank. I have no idea what that means, but since my setup is currently different from the instructions I don't want to really mess anything up. Will appreciate any advice, thanks!
gstx is offline   Reply With Quote
Old March 24th, 2012, 01:31 PM   #122
Todd250
Todd250's Avatar
Motorcycle(s): Ninja 250R (street) Feel Like a Pro Rental 250 (Race) Yamaha R6 (AMA Racebike)
hmm will have to look into this.
Todd250 is offline   Reply With Quote
Old July 6th, 2012, 05:09 PM   #123
htdub
Motorcycle(s): triumph
i had previously removed the kleen air system on the bike. Plugg'ed a couple of the hoses as you can see from the BB's used at the ends of the 2 hoses in the photo.
Installed a smog plate, and now bike doesn't want to run with the tank hooked up. Bike runs when it's hooked up to a gas container at the shop tho.
I'm wondering if one of the hoses is suppose to be connected still?
The the nipple at the top of airbox is capped off with the supplied piece.
htdub is offline   Reply With Quote
Old July 6th, 2012, 05:23 PM   #124
opc
opc's Avatar
Sounds to me like you removed the hose that runs from the vacuum source (on the carbs) to the fuel tank valve.
There is a built-in shut-off valve on the fuel tank that requires a negative pressure to open and allow fuel to flow. This negative pressure comes from the carbs. You'll need to reconnect the small hose that ran from the carbs to the fuel tank in order to get everything working.
Cheers,
Owen
opc is offline   Reply With Quote
Old July 6th, 2012, 06:29 PM   #125
htdub
I totally am lost on the hose routing
Old July 6th, 2012, 07:10 PM   #126
htdub
Can't remember which of the carb hoses went to the petcock
Old July 6th, 2012, 07:22 PM   #127
opc
opc's Avatar
I don't even have my bike any more, so I can't really confirm which it is...
I've circled the valve on the petcock that needs to be connected, and the two that I was able to narrow it down to on the carbs. If the hoses go to anywhere else on the carbs, then it's not that one. The hose in question used to run to a T connector, then off to the petcock and the Kleen Air system. If you removed the Kleen Air system and the petcock is disconnect, then you must have a hose coming off the carbs that goes nowhere.
See the attached pictures... Where do the two hoses circled in red go to?
Cheers,
Owen
Old July 6th, 2012, 07:27 PM   #128
htdub
I had the hose from the front middle of the carbs goto the circled petcock photo
The other 2 circled hoses, those just goto the Othe side of the carbs
Old July 6th, 2012, 07:41 PM   #129
opc
opc's Avatar
Ahh... sorry. I remember now. That is indeed correct the way you have it. You can attach the two ports indicated with the arrow directly to one another. That's the way I did it and it worked like a charm.
Are they well connected? Do you have a leak anywhere?
Make sure the hose is pushed fully onto the petcock and the carb.
If it's not that, then I really don't know. You might need to adjust your idle.
I had serious issues when I performed this modification (I went over them in detail several posts back) but installing a K&N pod filter an re-jetting solved the issue. With the stock airbox though, I had idle problems and times when I would completely lose power and the bike would stall.
Cheers,
Owen
Old July 6th, 2012, 10:23 PM   #130
htdub
I had that hose running to petcock
I think it's suppose to be a overflow and just run a open hose from it
Old July 7th, 2012, 01:48 PM   #131
opc
opc's Avatar
Nope... you definitely have it right. The overflow tube is much farther up the tank and comes directly out the side.
From what I remember, you can bypass the whole petcock negative pressure valve by just setting that switch on the petcock to "prime". You might want to try that and just rule out any possibility of leaks in that hose. If the bike runs fine with that valve in the prime position, but doesn't run with it in the "on" position, then you can be sure your problem is likely a leak in the vacuum system.
Another thing to try is to adjust your idle. You may need to increase it a little to get the bike to run in a stable manner. You can also try your choke to see if richening up the mixture helps.
Cheers,
Owen
Old July 7th, 2012, 01:57 PM   #132
htdub
Tried prime and didn't want run that well at all. Going to check all the connections again.
Old July 7th, 2012, 02:14 PM   #133
opc
opc's Avatar
Now that I look a little closer, I'm pretty sure you have a California bike with the significantly more elaborate Kleen Air system.
The pictures of your removed system don't look like mine at all.
Look closely at the first post in this thread, and notice that the normal Kleen Air system only has three hoses coming off it. One goes to the cylinder head, one goes to the carb, and one goes to the airbox.
At the bottom of that post, there are pictures of the California model with several more hoses and another box tucked away.
Based on the pictures you've posted I'm guessing that's what you've got, which requires a whole different procedure for removal.
Cheers,
Owen
Old September 10th, 2012, 07:20 PM   #134
jgo564
Just wanted to give credit to the OP. This is my first post on this forum so as a quick intro, live in the DFW area and decided to pick up riding about 3 months ago as a new hobby, but more to save on $$ on fuel costs and went and purchased a new 2012 Ninja 250r and shorty took the MSF course and the rest is history.
My first mod was to change the exhaust as to stand out more and be heard... Didn't really do it for a performance increase. Like most, the exhaust began popping and backfiring and did start get on the annoying side. I decided to take the plunge and give this mod a shot, take in mind that my mechanical skills is very novice, but the instructions seemed pretty straight forward. Only thing that took me for surprise was that I didn't think I was going to have to remove the gas tank. Probably a good thing though or I may have decided not to attempt it, but after having taking everything apart, decided to keep modding.
The result ended with the popping/backfiring was greatly reduced, but not completely eliminated. I only tested it out for a short ride, but I'll see how well it worked on my ride to work tomorrow morning.
Thanks, kkim, for the write up!
jgo564 is offline   Reply With Quote
Old December 13th, 2012, 04:51 PM   #135
Superninja
Motorcycle(s): 08 monster 250r
Kleen air
Has anyone had any problems after removing the system and i mean mechanical such as to much pressure or blowing gaskets?
Superninja is offline   Reply With Quote
Old December 13th, 2012, 05:07 PM   #136
rojoracing53
Fast-Guy wannabe
rojoracing53's Avatar
MOTM - Jan '13
no
Old December 15th, 2012, 09:51 AM   #137
htdub
My bike runs only as a track bike and it runs very well.
Old January 13th, 2013, 08:42 AM   #138
LNasty
Daily Jap rider
LNasty's Avatar
Question kleen air system???
Bought my bike in Texas, 2012. Does it have the Kleen air system a well?
Old January 13th, 2013, 11:23 AM   #139
opc
opc's Avatar
yup... they all have it as far as I know.
California bikes have a more elaborate version with a few more connections and another module involved, but I think all other versions are the same type as what you see in this thread.
Cheers,
Owen
Old January 13th, 2013, 11:49 AM   #140
rojoracing53
Fast-Guy wannabe
MOTM - Jan '13
Just a note but some bikes sold in other states are actually CA models. It's not uncommon for the factory to setup a few to many bikes as CA models then ship them off to other states in need more bikes.
Old February 22nd, 2013, 12:52 PM   #141
BMXmonster14
Motorcycle(s): ninja 250r and fz6
so do I need to cap the crankcase "chimney" too?
BMXmonster14 is offline   Reply With Quote
Old April 20th, 2013, 11:29 AM   #142
RacerX113
Motorcycle(s): Triumph Thruxton, Ninja 250
Brining up an old thread.
Why is the airbox hose attachment blocked off?
Thanks,
Doug
RacerX113 is offline   Reply With Quote
Old April 20th, 2013, 11:51 AM   #143
dino74
dino74's Avatar
Thanks,
Doug
It attaches to the clean air side of the airbox.
snorkel intake -> air filter -> clean air -> carbs
If you don't block it off, you run the risk of dirt getting into your carbs, because it by passed the air filter.
CVMA #55
Old April 20th, 2013, 11:53 AM   #144
RacerX113
aha... didn't realize it was on the other side of the air filter.
Thanks,
Old April 1st, 2014, 01:16 PM   #145
wthammond
Motorcycle(s): 1998 Ninja 250R; 2001 Aprila Scarabeo 50; 2009 Aprilia Mana
Smile Reinstalling CA emissions
Trawling up an old thread here. I recently bought a 1998 250 with 1100 miles that a title search showed had never been anywhere but TX (where I live), yet it had a CA tank but no CA emission equipment. Possible that the tank was a replacement but can't be sure. Plus the L side panel had the CA emissions hose diagram that suggests it was a CA spec bike.
I originally capped off the red line as suggested by many others on the forum, but didn't like the idea of that becoming a source of leakage. So I got on eBay and found a complete set of emissions for $33, went to the local auto parts store and constructed a 'T' line between the carbs and plugged it all up per the routing diagram. The Haynes manual suggests testing it by putting 20 mL fuel in the top of the separator and seeing if it makes it to the blue return. Everything seems to be working so far, so I have not done it.
Has anyone done something similar? If so were there any problems? Or am I the only idiot who actually re-installed emission control equipment in pursuit of 'keeping it original'?
Thanks! And thanks to all for this great forum which helped me figure this out in the first place!
wthammond
Magnolia TX,
Current Stable: 2009 Aprilia Mana 850, 2001 Aprila Scarabeo 50, 1998 Kawasaki Ninja 250.
wthammond is offline   Reply With Quote
Old August 23rd, 2014, 07:34 PM   #146
broilmebk
broilmebk's Avatar
Motorcycle(s): '12 ninja 250r
Can anybody help me with the ca emissions version? I tried following OP as best as I could but as pointed out the CA model has some extra connections. I'm currently left with a hose out of carb to a T connection, one end capped, the other end to petcock. Air box and chimney are capped. My issue is with the gas tank connections. There are 3 connections on the gas tank. Only the overflow is connected. The other 2 are capped. Is one of the other connections supposed to go somewhere?
broilmebk is offline   Reply With Quote
Old August 24th, 2014, 04:28 AM   #147
Linkin
Down Under
Linkin's Avatar
Motorcycle(s): Kawasaki ZXR250C Ninja
Hi all,
In regards to removing the kleen system. If you've done it, does it stop the bike from backfiring loudly when turning on? My bike does that from time to time and it sounds like a gunshot. I'd rather not wake up the whole street at 4:30am with it too...
Linkin is offline   Reply With Quote
Old August 24th, 2014, 04:14 PM   #148
broilmebk
broilmebk's Avatar
This answered my question. Middle vent needs to stay open.
Originally Posted by Linkin View Post
Hi all,
Not sure that it does, but the backfire at startup is notorious with our bikes
Old March 15th, 2019, 12:15 PM   #149
Tooch
Tooch's Avatar
Motorcycle(s): 2008 Ninja 250, 2015 zx10r, 2010 Ducati 848
Hate bringing up a VERY VERY old thread, but I always think it's best to had as much info in one thread as possible, as opposed to a hundred I pulled the clean air system, and after reading all the pages here I'm still slightly confused is it best to VENT this, or CAP it. Thanks!
Tooch is offline   Reply With Quote
Old March 15th, 2019, 02:39 PM   #150
Kitdog
Kitdog's Avatar
Motorcycle(s): 2009 Ninja 250r, 1996 Yahmaha YZ 125... Both in Blue the coolest color
I capped mine, didn;t want an opening into my engine.
"Well you know, for me, the action IS the juice"
Kitdog is offline   Reply With Quote
Old March 15th, 2019, 06:10 PM   #151
Ceeloo Yello
Motorcycle(s): 250
Mine I put a little breather on.
Old March 15th, 2019, 06:55 PM   #152
Tooch
Tooch's Avatar
This is what I went with...
Old March 15th, 2019, 07:37 PM   #153
Ceeloo Yello
Motorcycle(s): 250
Yeah like that but mine points straight up.
For Sale: Kleen Air System Jiggles Motorcycle-related 23 February 10th, 2014 07:07 AM
Removing the Kleen Air System on a stock bike oblivion007 2008 - 2012 Ninja 250R Tech Talk 3 January 25th, 2014 04:28 PM
Kleen Air System - Breather Filter DmbShn41 2008 - 2012 Ninja 250R Tech Talk 3 October 20th, 2013 07:51 AM
Who's taken off their Kleen Air System? walty87 2008 - 2012 Ninja 250R Tech Talk 10 January 29th, 2012 10:37 AM
Kleen Air system mxnello 2008 - 2012 Ninja 250R Tech Talk 6 April 13th, 2009 01:32 PM
