April 28th, 2017, 05:44 PM | #161 |
Join Date: Mar 2017 Motorcycle(s): '08 Kawasaki Ninja 250 Posts: 9
My problem isn't speed, it's that my bike doesn't feel stable above about 60 mph. It feels like the back tire shakes a bit but I'm not sure if that's what it is. This is the first and only bike I've ever ridden so I don't know if it's normal or not. Has anyone else experienced this?
April 29th, 2017, 07:21 AM | #162 |
Track Clown
MOTM - Sep '15
could be a few things, wheels out of balance, rear wheel not aligned or rear wheel not tightened to spec. could be more but those are what i would check first.
April 29th, 2017, 08:18 AM | #163 |
Join Date: Jan 2014 Motorcycle(s): SC28 Fireblade Posts: 463
Ive done about 105-110mph on 6 gear very close to the redline. I try not to go up that high, only when the conditions permit. I usually cruise from 80-95mph which is no problem for this short stroke engine.
I'm debating of taking out the airbox and getting another tune, but for now the little 250 great.
94 900RR 04 BMW Z4 2.5 M Package 01 R170 AMG Sport Package |
April 29th, 2017, 11:37 AM | #164 |
Cool, I'll see if I can get those things checked out. Hopefully it's an easy fix
April 30th, 2017, 10:48 PM | #165 |
Join Date: Feb 2017 Motorcycle(s): 2011 Ninja 250R Posts: 219
I haven't got a secluded road where I could attempt to achieve top speed, the local constabulary would appreciate the ensuing fund raising for the government's coffers though.
My does get 60kph at 13krpm in first though. I belive its around 100 at 13 in 3rd, maybe..... 15/42 |
May 1st, 2017, 06:22 AM | #166 |
And once you're up to about 25 mph or so, you can downshift and get in the powerband any time you like. I gotta put my 42 rear on (15 already on front)
May 1st, 2017, 07:28 AM | #167 | |
Check the date on the tires also. It could be time to replace them. Cycle tire last about 5 years, and degrade significantly after that. The date is on the sidewall of the tire - 4 digits in an oval like "2509". The first 2 are the week (25th week), the second are the last 2 digits of the year (2009). Also look for cracking inside the grooves and any "scalloping" of the tread. So if those are original tires from '08 (maybe produced in '07) it's time for new ones - doesn't matter how many miles are on them or how much tread is left. You are dealing with aging of the rubber only. Also confirm your chain is in good condition, lubed, and adjusted properly. There's a bunch of good How-To videos here - http://www.canyonchasers.net/video/ |
May 1st, 2017, 11:53 AM | #168 | |
Join Date: Feb 2012 Motorcycle(s): 2011 250R (Sold); 2012 Vulcan 900; 2009 Harley Iron 883; 2004 SV650s; and a bunch of others over the years... Posts: 470
When I started on my 250 years ago I made a similar post on this forum about how unstable my bike felt above 50mph. Turns out that all of that instability came from me and not the bike. My nervousness was causing me to grip tightly to the bars and the desire to provide continuous steering input on the handlebars out of fear that I would fly off the road or tip over at any moment. Your problem may be more real than imagined, but it likely is not a "problem". Relax your arms and take weight off of the handlebars at speed. That will help. More time in the saddle will make you more comfortable. But certainly check your tire pressure, tire condition, and wheel alignment. Its very likely that these things will correct any minor negative handling issues and you will be riding more comfortably in no time. Take your time and stay safe. |
May 1st, 2017, 12:36 PM | #169 |
A tire can be shot without visible damage.
When I bought my track bike at the end of the '15 season the tires looked like they might still have a day or two left in them, so I decided to defer the purchase of new tires until the following year and ride one day to get to know the bike. I got a serious vibration at about 80 mph. It was the rear tire. Despite still looking okay it was done. Fortunately I had a spare take-off with me so I swapped and bingo... perfect.
May 1st, 2017, 01:30 PM | #170 |
Good point. I bought a bike with what looked like good tires. No visible damage and lots of tread left. First ride I knew something was wrong. Turns out there was a hard spot in both tires where the bike rested during extended storage. Wouldn't have known it just looking at them but had I run my hand over the entire surface of the tire I wouldve certainly felt it.
May 15th, 2017, 06:50 AM | #171 |
Just did over 200 miles yesterday, 100+ each way to and from work. It wasn't super comfortable, not that I expected it to be but overall wasn't too bad. Speed limit is 70 majority of the way, I stayed around 80(according to speedo) most of the time which had my tach at about 9.5 - 10k. I did top it out going down a slight decline in full tuck early in the morning when the road was empty, hit 100-ish mph, redlined. Return trip was super windy but staying calm is key in those situations so nothing exciting IMO. Oil looks healthy through sight-glass but is too new to change so I'll have to wait to check filter, curious about it from recent shim job I did also. I pray I did no damage staying at those higher RPM's for such a long time, I finished the ride on surface streets and had all the power I had beforehand and everything sounded/felt great soooo fingers crossed!!!
May 15th, 2017, 06:54 AM | #172 | |
May 15th, 2017, 07:10 AM | #173 |
Assuming that nothing else is wrong with you bike, running at those RPMs for long periods of time is perfectly fine. Its what sportbikes are designed to do. Thats the whole point of having a red line. If running below red line was harmful to the engine and thus would cost Kawasaki money in warranty claims, you could bet they would move that line down. You get used to the sound of the engine dont worry.
May 15th, 2017, 07:11 AM | #174 |
Good point!
What is the AVG speed you do on the Highway | reroka | General Motorcycling Discussion | 45 | June 11th, 2014 05:41 AM |
Highway speed in relation to rpm.. | Rollingmenace | 1986 - 2007 Ninja 250R Tech Talk | 3 | August 5th, 2013 04:10 PM |
Speed wobbles on Highway | Heffdan | General Motorcycling Discussion | 14 | September 14th, 2012 10:17 PM |
[topix.net] - Motorcyclist dies, was driving the wrong way on highway | Ninjette Newsbot | Motorcycling News | 0 | December 17th, 2011 09:10 PM |
Question about Highway Driving! | atl-ninja250 | 2008 - 2012 Ninja 250R Tech Talk | 19 | May 11th, 2011 08:41 AM |
