December 15th, 2012, 02:14 PM | #201 |
Area P
Join Date: Dec 2008 Motorcycle(s): Too many to list Posts: 439
December 15th, 2012, 03:53 PM | #202 |
Join Date: Nov 2012 Motorcycle(s): Ninja 300, KTM EXC610SMR Posts: 913
December 15th, 2012, 03:58 PM | #203 |
Area P
December 15th, 2012, 11:42 PM | #204 |
Join Date: May 2010 Motorcycle(s): 2009 Ninja 250R, 2013 Ninja 300 Posts: 279
Hi Kerry,
So I decided to go with the power commander 5 because I had to use an old store credit. I also got the quick shifter, rev limiter increase, and the ignition timing just for a liitle fun. I know on one of the post that there will be maps made for the power commander 5. Who would I get them from you guys or fuel moto? I want the stainless ultra high mount when it becomes available for pre-order. Also when will the pre-orders start? Thanks, David |
December 16th, 2012, 11:51 AM | #205 | |
Area P
December 16th, 2012, 01:00 PM | #206 | |
Fighting Texas Aggie '05
I currently have a quiet core full system on my ninjette which I love, and have been thinking about the possibility of getting your slip on for my 6R instead of another brand when I mod the bike in support of what your guys do for the small bike communitiy. No one here is ever going to group buy that product though. Anyways, just a thought . Keep up the great work . |
December 17th, 2012, 01:49 PM | #207 | |
Area P
If you would like to send a PM on which 6R you have and year, I can see what options may be available to you. |
December 18th, 2012, 08:30 AM | #208 | |
December 20th, 2012, 05:59 PM | #209 |
Join Date: Oct 2012 Motorcycle(s): 04' Ninja 250, 13' Ninja 300 Posts: 10
Hello. I'm curious when Fuelmoto/Area P may release some more R&D results. I am specifically interested in what benefit to the dyno curve the K&N pod filter may bring. I plan on going with the standard 18" quiet core, and am wondering if I should buy the pod filter or not. Obviously I am just being impatient since I have to wait for the exhaust anyhow lol. I received the fuelmoto FI programmer today and it looks like a very nice, high quality unit and nice connectors.
December 21st, 2012, 07:18 AM | #210 | |
Area P
December 23rd, 2012, 11:03 AM | #211 |
Area P
December 23rd, 2012, 08:19 PM | #212 |
@kbryant I saw on the page for the ultra hi mount you need a fender eliminator, and says you used the targa one, but I was wondering if the yoshimura eliminator would be usable? Also do we have to change the signals? Or can we use the stock ones on a eliminator?
December 23rd, 2012, 10:01 PM | #213 | |
Area P
January 11th, 2013, 01:43 PM | #214 |
Join Date: Sep 2012 Motorcycle(s): 2009 Ninja 250/2013 Ninja 300 Posts: 52
I thought I would post on here rather than email you so others can benifit from the answer. You set me up with a tuner for my M4 full exhaust system and K&N Panel Filter. I just ordered the K&N pod filter the "R-0990". Since you do not have a map for this yet, any idea what I should manually adjust my tuner to? Or should I just not even touch it until you have a chance to test it all out??
January 11th, 2013, 02:12 PM | #215 | |
Area P
1. Wait until we get it on the Dyno and write perfect maps without guessing or assuming later next month. Or... 2. Go ahead and install it, I can send you a richer map base for you to try. Then you can tell me what it's doing or not doing, and we can work from there. But again, it would be much more accurate and less risky if you wait until we actually test it later next month. |
January 11th, 2013, 02:40 PM | #216 |
Hmmm.. Maybe I will just wait to on the install until you get the base map made for it then, then I can "set it and forget it" then both of us dont need to hassle with the back and forth on a questionable map.
For the IAT sensor are you just going to drill a hole in the filter for it? I installed a smog block off already and it fixxed my decel popping issues.. I messaged you about this and you said my popping could be from a poor gasket or smog.. My problem was both I removed the smog and it still popped.. Then after re-torquing the system bolts the popping stopped.. As for the crank case breather would that also just need a mini air filter on it? I may need to relocate it higher to keep it dry, I ride ALOT in the rain so I want to keep everything dry. Or does the crank case vent need to be plumbed into the air filter as well? |
January 13th, 2013, 12:08 AM | #217 |
The A Team
Join Date: Aug 2012 Motorcycle(s): Z50, CB125, RZ500, MC22, R3. Posts: 394
Which system would be less likely to interfere with VERY high (50mm+ back/50mm+ up, track use only) rearsets?
January 14th, 2013, 07:15 AM | #218 | |
Area P
Yes, a small crankcase breather element will need to be installed onto the crankcase vent or vent tube. No, you do not want to vent it directly into the K&N air filter pod. |
January 14th, 2013, 07:36 AM | #219 |
Area P
Hard to say. That's alot (almost 2" both ways). It would depend on the backing plate design and clevis location for the brake slave cylinder. Most likely the standard mount. The ultra high mount of course has tigher tolerances inherent with this design. But there is some adjustement with both systems. We always try to keep rearsets in mind, as do the rearset designers themselves. But there are so many different combinations of rearsets, it's simply not possible to check them all.
January 14th, 2013, 11:54 AM | #220 |
Would it be possible NOT to install the IAT sensor into the back of the K&N pod filter? I would really like to use a outwear pre-filters on my pod filter.
http://www.outerwearsracing.com/prod....asp?prod=4128 But the IAT sensor would require cutting a hole into the pre-filter.. Can I just zip tie the sensor to the frame or something similar? |
January 14th, 2013, 01:53 PM | #221 |
My last post did not show up.. In short.. Is there a way NOT to mount the IAT sensor inside the pod filter? That would allow me to use a pre-filter..
I would really like to use a pre-filter to calm my nerves about riding in the crappy weather here in WA |
January 14th, 2013, 02:09 PM | #222 |
As a user of a K&N R-0990, unless you plan on going swimming with your ninjette, you'll be fine using it in rainy weather. I'm not sure why using a pre-filter over the outside of the R-0990 would restrict you from putting your IAT in the incoming air stream
January 14th, 2013, 02:18 PM | #223 |
I would have to cut a hole in the pre-filter to fit the iat sensor..
either that or extend the wires so there is enough wire to route the sensor to different location.. It would be nice if I could route it around and mount it to the front side of the filter, between the throttle bodies.. I dunno I just feel more comfortable with my open element filters if I have a pre-filter on them, I have them on all my vehicles which have aftermarket air intake systems. |
January 14th, 2013, 03:30 PM | #224 | |
Area P
Utilizing a filter charger or pre-filter wrap would not affect how it may be mounted anyway. Simple enough to cut a small slit and insert it so it closes around it anyway. Keep in mind the filter chargers are primarily for heavy dust areas and may also affect the intake flow (and the mapping) from a "non-wrapped" filter. They are not water proof (just "water repellent"). You are much better off simply paying attention to the condition of your filter, clean and oil it properly and you'll be fine. The filter assembly is not fully exposed to the elements. It's reasonably protected within the centerline of the bike, seat, tank, side covers, legs/knees, etc. |
January 14th, 2013, 03:54 PM | #225 |
gotcha.. just getting a head of myself on planning.. i tend to do that with parts on the way haha
I ripped out my air box over the weekend since my bike is having some down time.. What a pain to remove it!! Its really crammed in there!! |
January 19th, 2013, 08:47 PM | #226 |
Join Date: Jan 2013 Motorcycle(s): Honda CRF (2). Boardman SLR (ok so it's only a bicycle, but its carbon fibre) Posts: 9
Apologies in advance if this has been asked before, but I'd like to know if the ultra high mount will work with the SV Racing rearsets, and that there are no clearance issues. Anyone tried this combo yet?
January 20th, 2013, 08:50 AM | #227 | |
Area P
January 20th, 2013, 07:11 PM | #228 |
Thanks Kerry. I haven't actually got the rear sets yet. I'm still in the planning stages of the mods I'd like to do and wanted to check compatibility before committing to any purchases.
January 22nd, 2013, 03:58 AM | #229 | |
January 22nd, 2013, 04:04 AM | #230 |
Join Date: Jan 2012 Motorcycle(s): Ninja 250r - Track whore, Ninja 300 - SOLD, KTM RC390 - Orange Hulk, Ducati 899 Panigale - Red Devil. Posts: A lot.
Thanks for the update David, is there any chance you can take pics in better light? I can't see the sensor at all in your pics.
January 22nd, 2013, 05:31 AM | #231 |
you don't see the sensor he added to the air filter??? You can see 1 filter has a device on it, while the other doesn't.. that device is it.
January 22nd, 2013, 09:25 AM | #232 |
diwhiteii it looks like it's coming along nicely! I see lots of aftermarket stuff on that bike.
Your solution to the IAT sensor is the same that many of the EcoTrons users have done. I chose to place mine in the runner so I didn't have to place the sensor in the filter (that way it was easier if I ever decided to go back to the airbox) but some have done it the same way you did without any issue. Looking good. |
January 22nd, 2013, 01:38 PM | #233 | |
January 22nd, 2013, 11:43 PM | #234 |
January 23rd, 2013, 06:51 AM | #235 |
January 23rd, 2013, 07:26 AM | #236 |
@kbryant,
Maybe I missed it, but last I read, you guys were still waiting on your tuner for maps to use with the K&N Pod filters. Have you guys gotten that all sorted out? I've been reading more about clean air from the airbox vs dirty air from pod filters and which gives more power vs consistent fueling. It's all rather confusing and theoretical. I was just wondering what you guys have found on that front in the form of dyno results and AFR changes when switching to pods. |
January 23rd, 2013, 12:14 PM | #237 | |
Area P
Primarily in posts 144 & 210 - We're the actual designers, manufactor and "Tuners". But our partner with the FI Micro Programmer (Fuel Moto) will be getting our first production system later next month and will doing the next level of testing/mapping with the airbox removed & filter pod installed, as well as more maps created in better air. We'll then have a really large base of maps to work with. Although the 300 will adjust somewhat to changing conditions, it does not have a "closed-loop" system and/or wideband capacity (as stock/supplied). So we're creating alot of map bases to work with from enviornment changes as well. We currently have 9 or 10 different maps, and that does not count the individual map changes we make for a person's particular enviornment or conditions. We have the bike lined up for Fuel Moto when we send them the first system later next month. There is a dramatic difference in available intake volume & sometimes intake velocity between the oem box and filter pods. We did enough preliminary testing to determine that opening up the airbox and further new mapping yielded even better results. So we know the Filter Pod and correct mapping will yield further improvements as well. There's also obvious differences in temps (cool air/hot air), but let's try to keep it simply since we have a fairly simple intake design, in a non-ram air scenario There is a large difference in mapping the A/F curve between these. For a simple comparision, look at the differences between the 250 with/without the airbox. Carburated of course, but primarily on the main jet side of things, it's very common to go up 4 or 5 sizes. That's alot! The filter pods don't have "dirty air" per say (or you better hope they don't...). You are correct when you say "It's all rather confusing and theoretical", but we try very hard to take most of the "theoretical" out of the equation through "less talking, more testing" |
January 23rd, 2013, 07:25 PM | #238 |
Very cool, thanks Kerry.
January 24th, 2013, 12:12 AM | #239 |
Here is a better picture of the IAT sensor and a picture of my crankcase breather filter. Also just a FYI... I have a california model and needed to ground out the purge valve sensor and the air switching valve to fix the service light from remaining on and for the bike to run properly with my dynojet autotune.
January 24th, 2013, 12:30 AM | #240 |
Thanks. You will need to remove the side panels that attach right under the seat for cleaning, but not the main fairings. I have mine off because I am heading to Motion Pro tomorrow to have custom cables made for their revolver throttle kit and they need the bike stripped down, even the tank must come off.
FS: Area-P solo exhaust bracket for Ninja 300 w/stock exhaust | c-dog | Motorcycle-related | 2 | September 12th, 2014 10:48 AM |
