Old September 20th, 2012, 04:21 AM   #201
kawaracer
Motorcycle(s): kawasaki ninja 250r
alright cheers guy so basically i need to either manually put in the tire circumference settings into the koso rx2?? using the buttons on it for a semi accurate reading or not use the adapter and install the magnets and sensor to get an accurate reading correct??
kawaracer is offline   Reply With Quote
Old September 29th, 2012, 09:07 PM   #202
No one is saying that one is more accurate than the other. The reason the mechanical adapter exists is because it's easier for people with compatible mechanical pickups. The reason it isn't included with all of them is because not everyone has them and the magnets work with anything. My pregen has no pickup because there is a custom spacer there instead to fit newgen wheels, so I will be using the magnets.
Old October 17th, 2012, 05:27 PM   #203
sleepless
Motorcycle(s): '11 250 SE
Just finished the install, I took the very lazy draw-it-out-over-weeks approach. It looks awesome!
Tip for installing the water temp sensor in the radiator hose-
1. Unscrew the bolt that connects the upper radiator cap assembly to the frame so its free to move.
2. Loosen the two radiator hose clamps
3. Remove radiator cap (Not when engine is hot!)
4. Using a straw, siphon off fluid from the hose and into a nearby cup/bucket. Remove enough until the fluid level is a good bit below the upper edge of the hose.
5. Carefully disconnect the upper end of the hose (wiggling helps) and twist it sideways into your cup/bucket, letting it drain fully.
6. Now you are able to remove the hose entirely, cut in half, remove about a 1/2"-1" from the middle, and install the sensor. Use supplied clamps on each end.
7. Reinstall hose, reassemble everything. Attach wire to Koso gauge.
I also reused the coolant by pouring it back in the radiator cap once the install was done. Pretty quick and painless. (This assumes you have the plug&play kit)
sleepless is offline   Reply With Quote
Old September 13th, 2013, 12:18 PM   #204
jarquin305
Motorcycle(s): Kawasaki ninja 250R
what is the size of your tire?
jarquin305 is offline   Reply With Quote
Old September 13th, 2013, 03:46 PM   #205
NevadaWolf
Certified looney toon
NevadaWolf's Avatar
MOTM Jul '13, Jul '14
Juan!!
I use the speedo adapter to keep the stock mechanical cable that came with the bike. I have my Koso set to 714 6P and the speedo is within rounding distance of my DeLorme GPS speed (i.e. GPS reads 49.6, speedo reads 50). I have Pirelli Rosso II 110/70 on the front and it's been consistant with my GPS for over 10k miles.
The folks at @RaceTech Electric put together a good video with some settings displayed at the end that works for them.
<-- Linky
Old September 19th, 2013, 11:31 AM   #206
jarquin305
thank you, actually with the plug and play kit koso provides you instructions where it says the recommend settings
Old September 19th, 2013, 03:59 PM   #207
NevadaWolf
NevadaWolf's Avatar
Yep, that's what I set mine too after trying RaceTech's number and coming out with 120 MPH in a 25 zone. Wheeeeeee
<-- Linky
Old March 30th, 2017, 03:50 PM   #208
Ralgha
Ralgha's Avatar
Just installed this gauge on my Ninja and discovered an important tip. Put teflon tape on both the water and oil temperature sensors, they will leak otherwise.
Koso RX-1N guage install help UnshavenCanuck 1986 - 2007 Ninja 250R Farkles 5 May 12th, 2014 10:12 AM
need help with install Koso DL spedometer! rawbert625 2008 - 2012 Ninja 250R Tech Talk 6 July 7th, 2012 11:38 PM
Koso gauge install question randomwalk101 2008 - 2012 Ninja 250R Tech Talk 6 February 17th, 2012 01:54 PM
Koso gauge & gear Indicator install randomwalk101 2008 - 2012 Ninja 250R Tech Talk 4 February 20th, 2011 10:32 PM
For the next person to install a Koso gauge cluster... headshrink 2008 - 2012 Ninja 250R Tech Talk 8 October 26th, 2010 06:25 AM
