April 21st, 2012, 12:00 PM | #241 |
touche kind ma'am. Carry on
April 21st, 2012, 12:15 PM | #242 |
Join Date: Feb 2012 Motorcycle(s): 2011 250R (Sold); 2012 Vulcan 900; 2009 Harley Iron 883; 2004 SV650s; and a bunch of others over the years... Posts: 470
Just got mine put on and unfortunately i cant take them for a ride. I know others have tracked them immediately with no ill effects but my kawi dealer told me to take it easy after install for 100 miles until the shiny anti corrosion crap comes off. That has made me a little apprehensive about riding aggressively "out the box" I can see what he means but i dont think it will take 100 miles, maybe 25...cant wait!
April 21st, 2012, 12:16 PM | #243 |
Ms. Personality
I scrubbed mine with Simple Green before my first ride. I'm going to be honest, these tires so so freakin sticky that even if they had Vasoline on them they'd still be better than the IRC tires.
April 21st, 2012, 05:08 PM | #244 |
Forgive my ignorance but when you say "scrubbed" do you mean literally scrubbing with a rag soaked in simple green? If so, never heard that method before
April 21st, 2012, 05:12 PM | #245 |
CBR250R Traitor
Join Date: Jun 2011 Motorcycle(s): 2011 Red CBR250R 2009 Ninja 250r SE(With 2008 Fairings)(sold) Posts: 924
Just take it easy and progressively lean more. Soon they'll be ready to go.
Posted via Mobile Device |
April 21st, 2012, 05:23 PM | #246 |
Ms. Personality
People refer to "scrubbing" as riding around gently on a new tire until it reaches a few heat cycles.
I literally scrubbed the outside of the tire with Simple Green. Posted via Mobile Device |
April 21st, 2012, 06:42 PM | #247 |
ok i have a 2012 what size close to stock front and rear and were to buy them
April 21st, 2012, 07:07 PM | #248 |
read the thread. It's only mentioned like 4 times...
April 22nd, 2012, 08:19 AM | #249 |
Internet Slut
Join Date: Sep 2010 Motorcycle(s): 04 FZ1, 07 FZ6 Posts: A lot.
It's not needed that much anymore. I had mine put on at the track then went out and killed it, first clean lap i had I took 8 seconds off my previous best time and ended up taking like 14 seconds off by the end of the day. Not all of it was the tires but they sure as he'll helped. They wear on then was even and they just stick. As for sizes inwent 110 front 140 rear.
April 22nd, 2012, 05:34 PM | #250 |
1/4 English, 3/4 Kick Ass
Join Date: Sep 2011 Motorcycle(s): 2002 Triumph Speed Triple 955i, '05 Suzuki SV650S(retired), '11 Ninja 250R(sold) Posts: A lot.
I just progressively broke mine in, with eventually more and more lean.
I just put 700 miles on this weekend. I will tell you now, if you have lots of straight highways and you do lots of mileage in a short period of time, you will burn through these tires quick. I have hit the 4,000 mile mark and they are already squaring out a bit. I have also gotten that worn rubber look that I talked about a while ago. I've concluded that's what happens when you ride on the same spot for a long period of time at 75mph. Still the best tires I've used, and I'm starting to see alot of other bikes with them too. |
April 22nd, 2012, 05:40 PM | #251 |
Ms. Personality
4k before squaring isn't too bad. I think I can live with that.
April 22nd, 2012, 05:41 PM | #252 |
CBR250R Traitor
I will probably pass on these then. As awesome as they sound most of my riding is straight commuting and weekend trips. I am riding over 1000 miles a month however(I don't drive my car).
I am looking at Michelin Pilot Activs now. Someone on the CBR forums got 12k out of them and they seem stickier than the IRCs. Anything is an improvement. |
April 22nd, 2012, 07:45 PM | #253 | |
These tires are freaking awesome, but it's to your judgment to what you think is best for you. |
April 22nd, 2012, 07:45 PM | #254 |
April 22nd, 2012, 08:01 PM | #255 |
CBR250R Traitor
I don't want to change my tires more than once a year.
April 22nd, 2012, 08:12 PM | #256 | |
Join Date: Mar 2012 Motorcycle(s): 2010 Ninja 250 -Blue Posts: 17
So by fitting you mean mounting the tire on the rims? Im about to buy some new tires, and wondering if I can mount the tire myself, or should I pay the dealer to do it for me? |
April 22nd, 2012, 08:15 PM | #257 |
April 22nd, 2012, 08:20 PM | #258 |
The shiny part on the edges of the tire that don't get used because you don't lean the whole way over to the edge
April 22nd, 2012, 09:08 PM | #259 |
Join Date: Dec 2011 Motorcycle(s): 2013 636 - ABS Posts: 173
I finally got mine installed last Friday. The bike feels completely different now, the tires are so sticky it takes a bit more effort to lean it over :X Well, it feels like it anyway.
April 23rd, 2012, 10:37 AM | #261 |
You should really feel much of a change, in fact it should be a more gradual lean than falling into it. I hated the stock tires, because I could hold a steady line.
April 24th, 2012, 08:36 PM | #262 |
Got 75 miles of easy riding out of the way during my commute today then turned up the dial a bit on some back roads. While driving conservatively I could feel no difference between the PDRII's and the stock tires. I was thinking I had just wasted $350.
But once I began riding a little harder I was really impressed. I was wondering whether what I was feeling was actually happening or if I was inventing it because I wanted it to be true. But I felt as though my lean angle had been decreased when cornering in the PDRII's. I could shift my body weight and the bike would fall into the turn then stick when I got on the throttle. It felt great but last only 15 miles before I had to head home. I can't wait to really put these to the test. |
April 24th, 2012, 08:37 PM | #263 |
Ms. Personality
The harder you ride them the better they feel.
April 26th, 2012, 08:46 AM | #264 | |
As for opening it up in the twisties, there is one hell of a difference. Never knew a street tire could grip on some of the stuff I've taken. Be safe out there man, let them warm up a bit before pushing them. |
April 26th, 2012, 09:18 AM | #265 | |
CVMA / AFM / M1GP #250
Join Date: Sep 2009 Motorcycle(s): 2009 Ninja 250r, 2011 Zero S, 2009 KLR 650 Posts: A lot.
The lean angle you can get on these is ridiculous for a 250. |
April 26th, 2012, 09:34 AM | #266 | ||
Nooblet
Join Date: Jul 2011 Motorcycle(s): 2011 Ninja 250R FI Posts: A lot.
MOTM - Oct '13
http://www.bugmenot.com/view/caliphotography.com Very handy website! |
April 26th, 2012, 09:41 AM | #267 |
Join Date: Apr 2011 Motorcycle(s): 2010 Ninja 250r Track bike, Honda CRF250r Dirt bike Posts: 137
is that guy in the photo using the DRII's in the front and rear? or is he using the supercorsa in the front? either way that is still impressive! especially if he is using the street DRII in the front!
April 26th, 2012, 10:09 AM | #268 | |
does that work on fbook accounts and emails??? |
April 26th, 2012, 08:26 PM | #271 |
not me on the bike, but still a good shot. Thats lean with a supercorsa front diablo rosso 2 rear. You shoulda seen his toe sliders, good thing he had the metal ones!
April 26th, 2012, 10:13 PM | #272 |
yeah damn good lean angle...
April 26th, 2012, 11:40 PM | #273 |
Join Date: Oct 2011 Motorcycle(s): 2008 Ninja 250, 2007 GSXR 600 Posts: 232
i'm assuming he has either adjusters, or aftermarket rearsets. right?
April 27th, 2012, 12:36 AM | #274 |
Gear crash test dummy
Join Date: May 2011 Motorcycle(s): 2010 Ninja 250 race bike, 2014 ZX-636r Posts: A lot.
He has aftermarket. When you start making a race bike stock parts for the most part become laughable.
April 27th, 2012, 08:11 AM | #275 |
Join Date: Jul 2011 Motorcycle(s): 2011 Kawasaki Ninja 250R Posts: 36
April 27th, 2012, 01:19 PM | #276 |
Join Date: Nov 2010 Motorcycle(s): 2009 Ninja 250R Posts: 194
Just got mine installed....
One word... WOW! Although i did have a question since i am coming from the stock IRCs. Did anyone notice the drastic overall feel of the bike when making sharp slow turns? It just felt different and took some getting use too. Maybe i am going crazy.. after all set and done i will never go back to IRCs though! These are that great at speed. |
April 27th, 2012, 01:20 PM | #277 |
Ms. Personality
Radial vs bias ply. They will feel a little different.
April 27th, 2012, 02:15 PM | #278 | |
April 27th, 2012, 03:41 PM | #279 |
April 28th, 2012, 07:34 AM | #280 |
They feel amazing... got about 100km on them so far and man I can definitely feel the difference immediately. They feel so planted and sticky on the road, and are extremely confidence inspiring...
Love them, worth every penny! |
Diablo Rosso ll tires | quadcrazy | 2013 - 2017 Ninja 300 Tech Talk | 19 | January 22nd, 2014 02:59 PM |
Pirelli Diablo Rosso II takeoff | Trailerboy531 | Motorcycle-related | 29 | November 14th, 2013 10:58 AM |
[sportrider - latest stories] - Pirelli Diablo Rosso II Tires and the 2012 Confederat | Ninjette Newsbot | Motorcycling News | 0 | September 4th, 2012 11:50 AM |
Pirelli Diablo Rosso II | OzzyDevil | 2008 - 2012 Ninja 250R Tech Talk | 14 | August 18th, 2012 01:16 PM |
[motorcyclistonline] - Pirelli Diablo Rosso II Tires | MC Tested | Ninjette Newsbot | Motorcycling News | 0 | July 26th, 2011 02:00 AM |
