April 9th, 2009, 10:21 PM | #241 |
Live 2 Ride Forced 2 Work
Join Date: Mar 2009 Motorcycle(s): 2008 RED 250r Posts: 386
#4s. Maybe the washers are the problem. I have the CA version btw so I double checked the hoses in your DIY and the 3 additional ones. At first I forgot the hose underneeath the tank to the fuel sender but after connecting that one I still found I had the same problem.
April 9th, 2009, 10:22 PM | #242 |
#4 or 4mm?
April 9th, 2009, 10:23 PM | #243 |
#4
April 9th, 2009, 10:27 PM | #244 |
that's the correct ones.
worst case, put everything back the way it was and see if the problem disappears. if the problem is still there, either something is damaged or not put back correctly. if you're a gambler, you can take one shim off each needle and see if that helps, instead. |
April 9th, 2009, 10:36 PM | #245 |
I noticed the fuel sender hose had a crimp in it the way it was positioned. I took off the tank and repositioned it to see if there is any change. Going for a test run now and Ill let you know.
April 9th, 2009, 10:52 PM | #246 |
Ok I still have the same problem. It just sputters in 1st never getting above 1k. I shut it off and started it in neutral and revved it and finally it went up to about 7k so I clicked it into 1st and rode home. It's probably a washer problem. The guy probably told me they were #4 but they're really 4mm.
April 9th, 2009, 10:54 PM | #247 |
Ramen Rider
Join Date: Jan 2009 Motorcycle(s): 2015 BMW R1200R, 08 Honda VFR800A (sold), 09 Ninja 250R (sold) Posts: A lot.
iirc, the #4's should be a relatively close fit around the needle.
also, you could measure the ID of the washer. it should be really close to 3 mm if it is a #4. i forget what a #4 exactly measures. i posted it up somewhere on this forum. |
April 9th, 2009, 11:00 PM | #248 |
chris, take a look at post #233... which of those pictures does yours look like?
April 9th, 2009, 11:03 PM | #249 |
Ok I think they're 4mm not #4. They look like the first picture. Is the plastic part inside the spring supposed to fit over the washers? The washers I have do not fit inside this part. I'm assuming that this is what the problem is.
April 9th, 2009, 11:06 PM | #250 |
yep, the plastic is supposed to fit over the washers. you def got the wrong size.
April 9th, 2009, 11:07 PM | #251 |
Ramen Rider
well, at least it is a simple fix. humbug part is that you gotta take everything apart again.
April 9th, 2009, 11:07 PM | #252 |
Join Date: Dec 2008 Motorcycle(s): 08 Ninja 250R in Green! (Sold) Now 2011 Triumph Daytona 675 SE Posts: 564
Yes, the white plastic part on the spring is supposed to fit over the washers. This was my issue and the needles were bouncing around causing the behaviour you are experiencing, except I couldn't even get out the criveway.
2008 GREEN Kawasaki Ninja 250R. AreaP Quiet Core Carbon Fibre : 8000k HIDs : Dynojet Jet kit : Double Bubble Windscreen |
April 9th, 2009, 11:16 PM | #253 |
Thx guys. That explains a lot! On my way to the store to get the right size. I'll let you know how it goes!
April 10th, 2009, 12:37 AM | #254 |
obviously, using the proper sized washers is a big problem here.
For future reference... 3MM metric washers or #4 ANSI washers should be used. Don't get the 2 confused. They are basically the same size, but using different standards and hence a different naming convention. specs for metric 3MM washers... System of Measurement- Metric Inside Diameter- 3.2 millimeters Outside Diameter- 7 millimeters Thickness- 0.5 millimeters Size Name- 3 specs for ANSI #4 washers System of Measurement- English Inside Diameter- .125 inches Outside Diameter- .312 inches Thickness- .031 inches Size Name- #4 to convert between metric and inches... http://www.worldwidemetric.com/metcal.htm |
April 10th, 2009, 01:41 AM | #255 |
Chris... any luck?
April 10th, 2009, 02:09 AM | #256 |
Ok I got new washers and was able to take it for a test spin. It ran a lot smoother in the lower gears. It almost felt like I gained an extra gear. 1st felt like 2nd etc. The bike just feels way more responsive. I also pulled the snorkel once I got her running pretty good and it feels like a whole new bike. The problem was definitely the washers. Once I swapped them out it started running like a champ!I haven't really gotten a chance to open her up past 3rd gear since I had to go somewhere and ran out of time to test it. Ill take it out when I get home and let you guys know. So far though its running way better than before. THX for all the help guys.
Posted via Mobile Device |
April 10th, 2009, 02:11 AM | #257 |
Ramen Rider
cool beans. glad to hear you solved your problem.
April 10th, 2009, 03:01 AM | #258 |
I'm lovin' it.
Join Date: Feb 2009 Motorcycle(s): '09 Black 250R Posts: A lot.
Good going Chris, hope the bike runs without any hiccups.
Son: When I grow up I want to ride a motorbike. Father: You can't do both son. |
April 10th, 2009, 06:56 AM | #259 |
Join Date: Jan 2009 Motorcycle(s): 08 Ninja 250 "Wasabi", 82 Yamaha xj650j Posts: A lot.
Chris. Was this with 2 washies? What exhaust? Still stock?
April 10th, 2009, 02:01 PM | #260 |
cool... Chris' problem is fixed.
Tim how are you doing with yours? |
April 10th, 2009, 02:49 PM | #261 |
Join Date: Dec 2008 Motorcycle(s): 2009 SE Ninja 250R Posts: 796
yup yup. All done on my end too. Since the stores were closed, I fab'd my own smaller washers from the 4mm But they fit and all revs are nice and smooth again
Specs: leovince slip on, snorkel NOT removed, and 2 washers each. Thanks again for the help guys. |
April 10th, 2009, 02:52 PM | #262 |
cool... now take the snorkel out.
April 10th, 2009, 03:07 PM | #263 |
April 10th, 2009, 03:11 PM | #264 | |
the snorkel removed allows the bike to rev freely to redline. I would think that's what you paid for instead. Personally, I could care less about what it sounds like if removing it enhances the bike's ability to make power. |
April 10th, 2009, 04:06 PM | #265 |
IMO, the sound with the snorkel out is much better, it actually sounds like a bigger bike because it has a sort of rumble and the difference in power and response is worth it.
April 10th, 2009, 05:18 PM | #266 |
Join Date: Feb 2009 Motorcycle(s): 2008 ninja 250 2007 ZX6R Posts: 30
How many washers for stock exhaust and snorkel removed?
April 10th, 2009, 05:33 PM | #267 |
April 10th, 2009, 06:49 PM | #268 |
I'm rolling with stock exhaust (for now), 2 washers, and snorkel out. The bike is definitely alot louder without the snorkel and the extra air intake really makes a difference. I can't wait to get a full system exhaust on!
April 10th, 2009, 07:03 PM | #269 | |
Right now she's reving perfectly to redline with the 2 washers in. Plus I would drive myself crazy if I had to listen to a whiny exhaust everyday... esp one that I had to pay extra for lol |
April 10th, 2009, 08:48 PM | #270 |
April 24th, 2009, 02:29 PM | #271 |
So I'm finally going to try it myself.... I had been planning to do a re-jet, but after considering the cost/benefit potential of this mod, raided the change drawer in my office. I'm currently all stock (no plans to change pipe). I plan to go with 2 washers, as that seems to be what most go with. Although I am curious about the snorkel removal, I really don't want to add noise.
I just ran around to a few different places and only one person had even heard of JIS drivers, and only because one person had asked about them once.... I see them online, but hate to delay projects for stupid things..... Hopefully it won't be an issue. |
April 24th, 2009, 04:03 PM | #272 |
If you can't find JIS, I found something in the shape of an S - like an allen key with two ends. The number 2 fit in and I was able to get the rest of the screws off no problem.
April 24th, 2009, 06:20 PM | #273 |
I think I ended up using a Pozidrive bit, this seemed to fit a little tighter. I pressed down and had no problems.
Install seemed to go fairly smooth and I just got back from a test ride. My initial impression is that it is a little livelier off the line and the gears [seemed] a little taller. It was rush-hour, so I didn't have much time or space to play. The weather is changing too, so theoretically this MAY have played a factor in some of the difference from earlier in the day..... we shall see. But hey, so far the best 20 cents I have spent on the thing! One thing I was concerned about though, is I got to see just how thin the diaphrams are, and one shifted while working on it.... if by chance one didn't seat right, or even tore, what symptoms would I see? |
April 24th, 2009, 06:21 PM | #274 |
did you yank the snorkel?
April 24th, 2009, 06:31 PM | #275 |
Naw, I didn't.... keeping the noise down.
April 24th, 2009, 06:50 PM | #276 |
the bike wouldn't rev properly/smoothly. if your bike is running well, don't worry about it.
April 24th, 2009, 07:11 PM | #277 |
As far as I can tell it is fine then.... should I expect any difference in mpg (even slight)?
April 24th, 2009, 07:37 PM | #278 |
most likely a slight hit in mpg. (5 mpg??)
how much will depend on how much fun you're going to be having twisting the throttle. no kidding... the bike will be a lot more fun now. |
April 24th, 2009, 09:26 PM | #279 | |
I'm getting around to this. I just got the 3mm washers and some other stainless parts from desmoparts. good company. I forgot to order the stinkin bolt for the covers though and shipping is $6 argh!
April 24th, 2009, 09:39 PM | #280 |
It doesn't really matter. When you shim the needles, you are letting more fuel into the mixture at the carbs, so more will get sucked up at any comparable throttle setting from idle to about midrange. You might see a greater hit with an exhaust due to the freer flowing benefits of a full exhaust system, but the main mpg decrease would be from the needles in the carbs being higher.
Shimming the Carb Needles... Is it for You? | kkim | 2008 - 2012 Ninja 250R Tech Talk | 93 | June 10th, 2018 05:25 PM |
Shimming the carb needles | kfilla | General Motorcycling Discussion | 2 | July 2nd, 2014 06:14 PM |
DJ Needles instead of shimming | mxman38 | 2008 - 2012 Ninja 250R Tech Talk | 7 | May 30th, 2012 07:09 PM |
Need help on shimming carb needles | RedNinja21 | 2008 - 2012 Ninja 250R Tech Talk | 6 | October 27th, 2011 10:16 AM |
FREE!!! 3MM Washers for Shimming Your Carb Needles | kkim | 2008 - 2012 Ninja 250R Tech Talk | 1 | September 10th, 2010 02:26 AM |
