April 22nd, 2013, 10:47 AM | #281 |
MOTM - Sep '18, Feb '16
Are the cam marks point away from each other and level with the head?
I had an engine that a shop had put the cam lines facing each other. And paint marked them. The engine would not start. I changed the cams around and it started. Did you by any chance mix up the cams. I don't know what that would do. I feel your pain here
April 22nd, 2013, 01:50 PM | #282 |
Board Member
the cam sprockets were removed by Web. I noted which sprocket and cam went where on paper before sending them out. when they came back, the sprockets no longer had their marks BUT the sprockets were made to only fit one cam (i.e. they will not fit on the other!). From there, I lined up the cams per the manual.
yes, the marks are level with the head and facing away from each other. |
April 22nd, 2013, 02:35 PM | #283 |
could the ignition pick up be mounted incorrectly? I am pulling at straws.
April 22nd, 2013, 03:53 PM | #284 |
Board Member
I never took it off!
Do I need the new head gasket? |
April 22nd, 2013, 05:35 PM | #285 |
The real answer is yes. But I just clean them off and re use them. I am only riding a mile though.
My secret thing is to use a scotch bright and clean the head gasket and base gasket. Then spray both sides with copper gasket spray. I let that dry befor using it.
April 22nd, 2013, 05:54 PM | #286 |
Board Member
That's ok. I haven't ridden anywhere.
April 22nd, 2013, 06:05 PM | #287 |
Join Date: Mar 2012 Motorcycle(s): Ninja 250r 2010 SE Posts: 573
Mike. When you found TDC did you use a piston stop or a dial indicator?
You get a few degrees of crankshaft rotation with the piston staying the same height. If you had to check you P/V clearance then you gonna need a new gasket, same if you pull the head off after being torqued. Just like x said, make sure the gasket surface is completely dry. I know professional engine assemblers that use copper spray gasket on 2000 hp deisels. It works for them so it gonna work for the ninja, not a substitute for an actual gasket but. Last futzed with by tubarney; April 23rd, 2013 at 03:30 AM. |
April 22nd, 2013, 07:52 PM | #288 |
if you used a dial indicator or the marks on the flywheel your cam timing is off.
You need a piston stop and a degree wheel. |
April 22nd, 2013, 08:00 PM | #289 | |
Also Mike, if you pull your head off, check that there is no play where the bolts go that could be causing sprockets to mis-align with the cam. I hope you get it started. Good luck. |
April 22nd, 2013, 08:11 PM | #290 |
here's how the cams look when they are installed the correct way. Unless web want to make things hard they would have made the ends like the stock ones.
You can see one end is completely round(intake) and the exhaust is not. |
April 23rd, 2013, 03:32 AM | #291 | |
April 23rd, 2013, 05:20 AM | #292 | |
Board Member
April 23rd, 2013, 05:24 AM | #293 |
Board Member
I pulled the head last night and checked tdc again with the dial and it aligns to the mark on the flywheel. Considering the amount of movement necessary to be off by one tooth this should be more than sufficient. Best I can tell so far is that there was too much oil in the cylinder. I cleaned them out completely.
Tonight I might reassemble....I will still clean the carbs....again. I should mention that when checking for top dead center using the dial indicator I came at it from both directions so that I would know where true top dead center was. |
April 23rd, 2013, 05:53 AM | #294 |
Sort of a delicate subject. Some will say yes others no. I think most people use it as extra protection for a new gasket. I was contemplating using the same gasket after checking P/V clearance because some will say you can use a gasket that has been through a torque cycle, just not a heat cycle. The guys that did my head said I could re-use it. Anyway I chose not to risk it over 50 dollars, depends on your circumstance I guess. Like I said before, sort of an iffy subject
April 23rd, 2013, 06:04 AM | #295 | |
All the best with the assembly tonight, hope it goes well. And with using copper gasket. To be honest, I think you would be fine but I really don't know because I haven't tried it before. |
April 23rd, 2013, 06:33 AM | #296 |
You need to really clean the gasket. Scrub it with break clean ad a scotch bright. Then coat the gasket both sides. Like you are spray painting it. Then let it dry. That is not as good as a new gasket. But it has worked OK so far.
April 23rd, 2013, 08:07 AM | #297 |
Board Member
I will get a new one then. I'm with tubarney on this one...no sense in risking it.
UPDATE: So i bought two new ones....just in case. But this will delay me another week. Anything I could check in the meantime? Now that I'm not under the gun I'm going to throw some modeling clay in the cylinders and double check the P/V clearances with the "old" gasket. The valve clearances have been triple checked now and they are good. I also looked at both the pistons and valves and neither have marks from contact so that is good. NOTE TO OTHERS: Once you're done fitting the pistons into the cylinder, clean the oil ALL out! Even though the service manual says to leave the pistons lubricated liberally. I still think this is/was my issue. |
April 23rd, 2013, 09:47 AM | #298 |
Join Date: Jan 2012 Motorcycle(s): Race bikes:08 Ninja 250,11 R6,16 ZX6,SV650.3 HD-1947,2-2003,2010. 1946 Indian and a lot of dirt bikes.2 Posts: 999
April 23rd, 2013, 10:05 AM | #299 | |
Board Member
Back to the drawing board folks! I will have this #&%$# thing running within two weeks! I am dying to ride it. |
April 23rd, 2013, 11:17 AM | #300 | |
But I put a used head gasket in my current motor. Just to get through my first race. Four races and 60 nitrous pulls later it is still in there. I don't really recommend using old gaskets.
April 23rd, 2013, 11:23 AM | #301 |
Join Date: Apr 2011 Motorcycle(s): '09 250R, '13 CBR500R Posts: 709
You still have time. The weather in mke is just starting to get warmer. It's a late start to riding season this year.
Mods: 636 front suspension conversion, wc clip ons, bohemian rear sets, FP jets, k&n filter, and AP full race exhaust |
April 23rd, 2013, 01:07 PM | #302 |
Board Member
April 23rd, 2013, 01:14 PM | #303 |
I'm at school and I'm almost 3 hours from home. The Ninja stays at home because there's no fun roads out here, there's no protected parking, and it's constantly windy enough to knock the bike over in the parking lots. I only am able to ride on the nice days from 3 months of the year; half of May, June, July, and half of August.
I know exactly how you feel. |
April 23rd, 2013, 02:34 PM | #304 |
Maybe I should think twice about moving to Ohio.
April 23rd, 2013, 03:06 PM | #305 |
Nah, before I was at college, I was able to ride for a good 7-8 months on fun roads through the parks. The only thing that sucks about being in the NW corner of OH is that it's all flat and boring.
SE OH is absolutely beautiful with all the hills and woods. |
April 23rd, 2013, 04:18 PM | #306 |
i was out in DC/Baltimore last weekend. 75-80 degs and sunny. so many bikes and few ninjette sightings. i was so jealous.
April 23rd, 2013, 05:32 PM | #307 |
And you didn't stop by?
April 23rd, 2013, 06:29 PM | #308 |
it was more like flying through BWI en route to DC. so actual time in Baltimore was less than an hour. next time for sure. would love to see the world's fastest ninjette in person.
April 24th, 2013, 06:40 AM | #309 | |
This assembly has been interesting to say the least. The transmission wanted to stuff around for 5 hours and 7 attempts later until it finally went together correctly without me doing anything different, wtf! Then I glued the crank to the case and had to reseal the cases, that was fun. Its going to take me another 2 weeks to because now I need new rings and I have to order them from the US. All because of 1 ring. Will teach me to be a tight ass and not buy a ring expander tool. I guess I'm learning a few lessons on how not to f*** things up. I'm sure next time it will go a lot smoother though. |
April 24th, 2013, 07:29 AM | #310 |
The only people that don't make mistakes. Are people that don't do anything.
April 24th, 2013, 08:08 AM | #311 | |
Board Member
otherwise, keep going and take your time. it will go together just fine. |
April 24th, 2013, 10:57 AM | #312 |
My gaskets should be in today, but I doubt I will have the time to install the motor and start it up. The only thing I have on the cylinders are just assembly lube. from when I installed the pistons. I don't see how oil on the cylinders would stop your bike from starting.
April 24th, 2013, 11:43 AM | #313 |
Board Member
plugs dont fire in oil. the oil mist that you get from worn rings or leaking seals is not very much and it is mixing in an already established and hostile environment.
April 25th, 2013, 08:43 AM | #314 | |
The rings are their way. Should have them end of next week. Its pretty amazing when you can get parts from California to western Sydney in only 6 days. Cost a bit, but at this point I'm willing do to just about anything to get back on the road before winter hits. It only drops to 50F here in winter but its still not ideal for starting a cold engine. I would prefer a 100F summer day. |
April 26th, 2013, 08:51 PM | #315 |
If your wondering how much my build cost it was the same if I was to upgrade to a 300. Only my 250 is quicker.
I could of sold my 250 for $5000 second hand with all my mods and 6000 miles, 300 are $7500 brand new. But if I bought a stock 300 I would loose all my mods and have to spend more money getting an exhaust and or things like rearsets,clip-ons,brake lines,suspension,tires to name a few. So i decided to spend the $2500 on my 250. Head - $900 - 700 for porting, 200 for valve seats and new guides Pistons - $300 Cams - $400 Fresh crosshatch in bores - $30 Balance crankshaft - $400 - Would have been $200 if I didn't knife edge it. Micro-polishing crankshaft - $100 Thats comes to $2100. Plus $300 for bearings and gaskets. Now I have a brand new 250cc engine for the same as a stock 300. Only mine has better everything and is faster. If I was to buy a 300 then put an exhaust for 800 I could get more hp but for another 1500 I could turbo this thing using a 300 fuel injection system, so either way upgrading to a 300 is stupid is stupid if you have spent money on your 250 that you will not get back when you sell it. Also this is my second engine. Its going to be something special. The engine cost me 300 for the complete engine. Its a 2008. I got it from Paul at wet4uracing. It starts and runs. Last futzed with by tubarney; April 27th, 2013 at 05:03 AM. |
April 26th, 2013, 09:03 PM | #316 |
Join Date: Oct 2012 Motorcycle(s): 2008 Kawasaki Ninja 250r, 2009 Suzuki GSX-R750 Posts: 85
You forgot about the farkles!! Digital gauges and stuff too.
April 26th, 2013, 09:50 PM | #317 | |
Thats the main reason I didn't upgrade. The money spent was the same, I just didn't want to loose all the mods and upgrades I have made, only to have to start from scratch again. At least in Aus, you won't get your money back for extras when you sell it. Plus I finally have my ninja at a point where I am actually extremely happy with the set-up. Yes a 300 has a slipper clutch, but if you need one on a 250 you don't know how to downshift or brake, also I don't want abs and I would remove it anyway because I go to the track quite often, plus I learnt how to use the brakes. If your wondering why I didn't turbo mine now. It is because with my current motorcycle license and some strict laws over in Aus I can't ride a turbo and it would be too obvious for me to do so. I have to wait a year before I get off restrictions(3 years of this crap). In the meantime I will slowly put this thing together and install it when it is legal for me to do so. Its going to be a while before anything happens to this one. Right now I'm focusing on the 1 I'm rebuilding now. |
April 26th, 2013, 10:46 PM | #318 |
Join Date: Sep 2012 Motorcycle(s): zzr250 gt650r zxr250 ninja 300 Posts: 114
you only on your Ls mate? you doing a front end swap? any special fairings or anything?
April 27th, 2013, 04:58 AM | #319 | |
The ninja is a 2010 special edition, it will have around 150kw/tonne power to weight. Same as a $90 000 v8 Holden Commodore 325. I bought the second engine because I don't want to have to take my bike off the road in order to do mods, I can take my time and slowly get things done when I have time and money. I won't be starting that build for a while yet so I'm going to put the engine in the shed for now. The bike mods before the engine work included: 2 bros exhausts CR carbs Race Tech Emulators, Springs Sato Pre-load adjusters Fender Eliminator Proton Flushmount Indicators, Led rear indicators, Led Brake light Sato Rearsets ( My favourite Mod) Woodcraft clip-ons Pazzo Levers D.I.D erv3 chain Supersprox sprockets, different gearing 14/45 Braided brake lines Ferodo brake pads Pirelli diabllo rosso II Koso x2 I thinks thats everything. I know theres people out there with more, mainly rojo and mgentz so I can't be completely crazy. |
April 27th, 2013, 05:42 AM | #320 |
yeah ive got a 1 1/2yrs to go myself, your right about nsw lol. should put some pics up.
Shin's 250r Build Thread | Shintoxica | 1986 - 2007 Ninja 250R Farkles | 3 | August 22nd, 2013 11:10 AM |
My 250R Race Bike Build | icbm | Pictures | 5 | August 16th, 2012 11:06 AM |
Is the ninja 250r the ultimate beginner bike, or should I settle for something else? | Mulholland | General Motorcycling Discussion | 188 | April 15th, 2012 09:28 PM |
[topix.net] - Freestyler Josh Borne guest stars on Discovery's Ultimate Car Build Off | Ninjette Newsbot | Motorcycling News | 0 | June 25th, 2010 07:50 AM |
I want to buy or build an 08+ 250R racer. | Seanslides | Ninjettes At Speed | 20 | March 1st, 2010 07:34 AM |
