Old September 8th, 2012, 05:37 PM   #281
Racer x
Racer x's Avatar
MOTM - Sep '18, Feb '16
The bottom end of the ninja 250 is very well made. The people I talk to say it is good to over 60 hp per rod. That is based on the power they got from the old 500 four. it all depends how you apply the power. Turbo boost comes on gradually and will not shock things. I try to ease the nitrous on to save the clutch.
But the drag race guys I know slam the power on the motors and they have been doing it for years, With a lock up clutch and wheelie bars big fat slick tires. Most problems are rod and piston failures. But they are not playing with a 26hp motor from a learner bike.
personally I have only had valve problems. And that was because of the Boss Noss Junk I tryed to use in 2011.
Worlds fastest 250 ninja
Old September 14th, 2012, 07:26 PM   #282
thomason2wheels
thomason2wheels's Avatar
Motorcycle(s): dl650
Talking
Originally Posted by CThunder-blue View Post
Eric, I'm curious why the bearing in the engine would dictate what kind of bearing a turbo would need?
You also have to be sure the muffler bearings match the turbo and crank bearings otherwise you end up with an unbearable mess.
I was with Alex.S and Jiggles last night and they had sex....the video is on utube. :-)
thomason2wheels is offline   Reply With Quote
Old September 14th, 2012, 09:28 PM   #283
Racer x
Racer x's Avatar
Different bearing types have different oil pressure readings. You just need to make sure the turbo requirements match.
Getting oil to AND FROM the turbo is critical. If you mount the turbo in the wrong position you can have problems.
SPORTISI's NINJA 250/300EFI TURBOCHARGER KIT bprayogo 2013 - 2017 Ninja 300 Tech Talk 135 January 17th, 2020 10:47 AM
Turbo install swarfman64 1986 - 2007 Ninja 250R Tech Talk 171 September 2nd, 2016 05:10 AM
[motorcycle.com] - Suzuki Patents Recursion Concepts Turbocharger Design Ninjette Newsbot Motorcycling News 0 March 26th, 2015 01:30 PM
Turbo? Yes, TURBO! Somchai General Motorcycling Discussion 7 December 26th, 2013 12:06 PM
Turbo 250! dyeforever General Motorcycling Discussion 3 May 1st, 2011 07:07 PM
