View Poll Results: What's your average MPG? | |||
less than 20 mpg |
4 | 0.65% |
21 mpg - 30 mpg |
10 | 1.64% |
31 mpg - 40 mpg |
32 | 5.24% |
41 mpg - 50 mpg |
186 | 30.44% |
51 mpg - 60 mpg |
262 | 42.88% |
61 mpg - 70 mpg |
98 | 16.04% |
71 mpg - 80 mpg |
11 | 1.80% |
81 mpg - 90 mpg |
1 | 0.16% |
more than 90 mpg |
7 | 1.15% |
Voters: 611. You may not vote on this poll |
Thread Tools |
#321 | |
Mine isn't working right at the moment. Strong smell of gas when I first start it. Mileage is down to only 53 the last I checked. And the last time I filled it, it was over $4/gallon. Gotta do something about that.
My Ninja Blog ![]() Proud member of ABATE.My NYC Road Rage documentary - CENSORED! |
#322 |
Hmmm I think I might have shot my mileage in the foot...
I re-jetted to work with my intake and exhaust. 108 mains are right where it's at. Pull like a banshee at the top. with 1 washer, it was popping, crackling, and struggling. 2 washers was just a little surging, and some crackling. 3 washers feels pretty darn good and responds really well, but the occasional stumble at high rpms with the throttle about 1/2 open. I might try a 4th washer over Easter break... But overall, I haven't had a chance to really do any mileage calculations since I had to drain my tank and replace my petcock, but I'm guessing I'm solidly in the low-mid 50's. My style of riding the last couple days has been slightly enthusiastic since I've been off the bike since November and at the same time am testing jets... ![]() |
#323 |
Why was it necessary to replace your petcock? Was it broken?
#324 |
Yepp. Broken
![]() It didn't leak out the part the fuel line attached to into the engine, but when I left it on "on" or "reserve" it would leak out of some part of it and I would get fuel running down all over the outside of the lines, and dripping down onto the left side of the engine and fairings and whatnot. I spent a while trying to get it sealed and trying to figure out what was leaking exactly, but just gave up and bought a new one from ron ayers. The annoying part is I just rebuilt that one last season because it used to leak from the fuel nipple when left on. After I rebuilt it, it worked perfectly. Then I accidentally thumped it on the floor one day when I set the tank down on an old tire. Ever since then, it leaks on the outside. ![]() |
#325 |
It seems that a lot of the petcocks are bad. There is a nylon/teflon/plastic sealing ring that is often not a complete circle. Mine leaks too.
#326 |
That's the weird thing though. I couldn't actually pinpoint one particular spot where there was gas leaking. It just showed up from the backside of where the diaphragm is in the petcock somewhere... whatever. I got a new one now that works. No more annoyances!
#327 |
When the membrane goes bad, gas will leak out from two places - the vacuum line and the weep hole. The weep hole is a little hole drilled in the side of the membrane. Did you change your membrane when you rebuilt yours?
I've got something wrong with my bike in that area. After starting, there is a strong gas smell, but not before. I started to rebuild the petcock, but when I tested it, there was nothing wrong with it. Now I'm leaning toward the carbs. Also, no matter how cold it is, it starts without the choke and will run for about 10 seconds with no additional throttle or choke. So that says there is gas getting in there some how.
#328 |
No, just the diaphragm and the little rubber circle thing behind the selector knob were the only 2 parts that were dried up and cracked. Took it to the shop to have it tested, and it was fine once I got the right parts in it. It started leaking right after I bonked it on the floor. The internals of it were fine. Never got any gas out of the vacuum line of weep hole, and never out the fuel line except when there was supposed to be gas coming out.
That's why I bought a new one. Less headbanging trying to diagnose it, more riding without smelling gas. |
#329 |
Join Date: May 2011 Motorcycle(s): 09 Ninja 250, 2011 Honda CBR250R, 07 Ninja 650 Posts: 212
66 mpgUS at 65 mph. 2009 Ninja250 with idle mixture screws tuned. Still very cold blooded. Zero Gravity Sport touring windshield might be costing me a couple mpg. My CBR250R gets 87 on the same commute.
#330 |
1/4 English, 3/4 Kick Ass
Join Date: Sep 2011 Motorcycle(s): 2002 Triumph Speed Triple 955i, '05 Suzuki SV650S(retired), '11 Ninja 250R(sold) Posts: A lot.
How in the world do you manage that??? I try riding as conservatively as possible and the best I can get is 52.
#331 | |
. http://www.ninjette.org/forums/showt...068#post454068 |
#332 |
Join Date: Jun 2011 Motorcycle(s): 2011 Kawasaki Ninja 250R (sold), 2007 SV650s (deer wrecked), 2010 Suzuki SV650S Posts: 334
I have an Area P exhaust with Dynojets, #100, e-clip on the 3rd notch. My pilots are 3.5 turns out and its getting me 39.5 MPG. I don't know what I'm doing wrong.
#333 |
performance parts =/= fuel economy necessarily.
If you lean your idle and mid-range a little bit (like it felt stock) that will help a ton with mileage. |
#334 |
Join Date: Mar 2012 Motorcycle(s): '88 Hurricane 600, '09 Ninja 250 Posts: 237
2009 box stock averaging right at 60mpg over the first 800 miles. It's odd though in the fact that it doesn't matter how I ride. Rode the last 200 miles in a tuck(with small backpack on) and was expecting/hoping for around 65..................nope 61. Riding like a wild man, winding it out, running through gears like crazy, expexting 55................nope 59. Long commute(1 hour each way) only 3 places I have to stop, riding upright, getting quickly to 6th and cruising at 60mph........you guessed it......60mpg
While no trees were harmed in making this post, a large number of electrons were severely inconvenienced. |
#335 |
Join Date: Apr 2012 Motorcycle(s): Ninja 250, 87 & 99 Concours, Buell 1125CR Posts: 34
Just put my second tank in (since I got the bike) and I'm getting 66 mpg. Mixed riding, commuting to work and a ride of about 100 miles. Had the carbs rebuilt by a guy I know (uses a sonic cleaner with H2O, Dawn, and ammonia), the rest of the bike is stock.
![]() Bumpty,bumpty, bump |
#336 |
ninjette.org newbie 2,000
Join Date: Jan 2011 Motorcycle(s): Ninja 250r Posts: 160
I forgot my "mpg" but with my old 2010 Ninja 250r, I was getting close to 200km per gas tank.
Now with my second 2010 Ninja 250r, I'm getting close to 300km per gas tank. Does this have to do with idling? Coz I ride pretty much the same. There's time where I would ride it hard and still get 200+ km. |
#337 |
My guess is that the fuel gauge is behaving differently on your new bike, allowing you to go further into the tank before you feel like you have to fill up.
#338 |
Lays er down
Join Date: Apr 2012 Motorcycle(s): 2008 Lime green Ninja 250R Posts: A lot.
when i first got my bike i got 55 mpg. but i lubed the chain a couple weeks ago and idk what happened but im getting 50 mpg now.
And what type of fuel should i use? ive been using 89, should i use 91? |
#339 |
CBR250R Traitor
Join Date: Jun 2011 Motorcycle(s): 2011 Red CBR250R 2009 Ninja 250r SE(With 2008 Fairings)(sold) Posts: 924
87 works fine for these bikes.
Chain lube didn't affect your MPGs, your riding did. ![]() |
#340 |
Newb..... on a steeek! :D
Join Date: Feb 2009 Motorcycle(s): 2012 Harley Davidson XL883L Sportster Superlow Posts: A lot.
I'm happy averaging about 47mpg atm on my Harley. I've gotten 53mpg out of her on a nice cruise that was not light to light like my daily commute.
![]() Last futzed with by sombo; May 2nd, 2012 at 01:19 PM. |
#341 |
Lays er down
#342 |
CBR250R Traitor
Np. It's what the owner's manual recommends anyways. No point in putting anything else in.
#343 |
Join Date: Jun 2010 Motorcycle(s): '09 Ninja 250r Posts: 63
Is something seriously wrong with my bike if I can't go 100 miles on a full tank averaging 85 mph? I have an hmf slip on exhaust with my needles shimmed with three washers. I remember reading that shimming didn't do much to gas milage but I guess that was wrong
#344 |
Are you sure you're filling the tank up all the way?
#345 |
I usually wait until the gas starts overflowing all over my bike when I fill up so yeah...
#346 | |
Want to help your mpg? Lower your rpm speed by changing sprockets. |
#347 | |
240.0 miles/ 2.377 gallonsUS = 101.0 mpgUS
http://www.fuelly.com/driver/sendler/cbr250r |
#348 |
Join Date: Mar 2012 Motorcycle(s): 08 Ninja 250R (FI) Posts: 169
interesting thred
![]() my average is 4l/100km... about 60mpg. when in city I`m riding around 6-7k rpm, when out 9-redline gearing front stock, rear 43 (and it is stock... ?!?) |
#349 |
Join Date: Mar 2012 Motorcycle(s): 2012 Ninja 250 J Posts: 18
New 2012 bike mpg
I've filled up 5 and a half times. My first fill-up I inserted the pump all the way in and pumped until the pump stopped. I was so confused when the gauge read that it was only half full.
My first real fillup was 55.71mpg, following the break-in procedure of <= 4k rpm. I didn't measure my second fillup. My third fill-up was 63.29mpg, which was after I tightened and lubed the chain and had given up on the break-in. I still never go over 8.5k rpm, though. My fourth fill-up was 65.93mpg, which was highway driving in the rain, mostly full tuck. My fifth fill-up was 76.06mpg (150.0 miles / 1.972g)! I always drive very conservatively, but perhaps it was because I shifted at 6k and attempted to cruise at 4k rpm, except when I was cruising at 50mph. This was also mostly state highway riding with some occasional light rain (so the roads were a bit damp). The bike is totally stock- no modifications. All mpg calculations are done in US units using the prescribed method (trip-meter + gas station receipt). |
#350 | |
#351 |
Join Date: Mar 2012 Motorcycle(s): 2012 Ninja 250R, 2007 Husky TE 250, 2002 KTM EXC 250r Posts: 217
Hmmn, I have a TYGA full exhaust, Dynojet #98 main, #4 clip, 3 turns on pilot and my last tank was 39.5 mpg. If I really try to coax max mpg I was able to squeeze out 43.5 mpg. The bike runs pretty damn good, but I kind of miss riding it "like I stole it" and getting 50 mpg.
#352 |
Join Date: Sep 2011 Motorcycle(s): 1986 Goldwing, 1996 CR500, 2011 Ninja 250, 2009 Harley Heritage Softail, 1941 Suzuki Gerbil 250 Posts: 427
I've documented 90% of my fill ups since I bought the bike new in September 2011. I have about 5,000 miles on it so far and average 60 mpg mixed freeway and surface streets. The bike is stock.
I know there's a 7th gear here somewhere... Changing to 15T/41T, now I'll get that 7th gear, lol. |
#353 |
Join Date: Apr 2011 Motorcycle(s): 2011 Green 250R Posts: 346
Since I put on a full Area-P exhaust with 100 mains and 3rd notch, I've checked it twice while just riding around town and have gotten 59 mpg both times, last weekend I rode it from Peoria to Indy, all interstate the whole way going 70mph at 8500rpm's and got 52 mpg.
#354 | |
Join Date: Apr 2012 Motorcycle(s): '12 ninja 250r Posts: 762
#355 | |
Just for fun, on the last tank I ran as much highway as I could (around 80%) and kept the speed around 65-70 mph. I got 50 mpg.
#356 |
crash 250, get supersport
Join Date: Apr 2010 Motorcycle(s): 2010 250R SE (Sold 6/9/14), 2009 ZX-6R (Sold 6/25/14), Subaru BRZ Posts: A lot.
Lowest MPG I've gotten was 52 and highest was 60. Although recently I have been doing 0-60 pulls getting on the freeway going through the first 4 gears to redline I've gotten the same average MPG of 55 as when I rode conservatively and shifted at 8k.
Will be putting on an Area P mid-high full system this weekend along with a rejet so I'll see how that affects my future fillups. EDIT: After an Area-P full exhaust and a rejet to 112 mains I got 58.6MPG with the same conservative riding with hard pulls to redline to get on the freeway, wut. Last futzed with by menikmati; September 6th, 2012 at 08:23 PM. |
#357 | |
oh yeah.....
#358 | |
#359 | |
Jigglin' your Jiglets
MOTM - Apr '13
Even though I'm on top of her I can barely contain her excitement and together we embark on a journey of ecstatic ecstasy. The longer I ride her the louder she gets. She's screaming at the top of her lungs and our neighbors are coming out of their houses to investigate but we don't care, let them watch this beautiful act. Her gears are grinding, wet and ready, her heart is racing and with a final twist and a push she achieves sexual transcendence and the earth shattering moan she let out brought a tear to my eye. Slowly and gently I bring her back down from her lofty euphoria and we enter back into reality. Everyone is looking, she is still moaning and we both feel overwhelming satisfaction and a slight amount of embarrasement. And that is the first time I ![]()
If the Ninja 250 doesn't have enough power for you, then you don't know how to ride it. AFM #676 ![]() Supersports are for n00bs |
#360 |
So, where's the reverse?
Premature fuel ejaculation huh? Gotta suck
This is some crappy gas mileage | 250rr | Off-Topic | 1 | September 4th, 2013 05:08 PM |
Low Gas Mileage, why? | Dhillon92 | 2008 - 2012 Ninja 250R Tech Talk | 32 | July 27th, 2013 04:51 PM |
what's your worst gas mileage? | boyonfire | 1986 - 2007 Ninja 250R Tech Talk | 24 | October 25th, 2012 06:46 AM |
Gas Mileage: New vs Old Gen | SmithSwede | General Motorcycling Discussion | 9 | June 12th, 2012 01:07 PM |
gas mileage | motorcycle_munge | General Motorcycling Discussion | 23 | May 16th, 2009 01:54 PM |
