Old March 22nd, 2009, 04:23 PM   #1
Jiu Jitsu Player
Live 2 Ride Forced 2 Work
Jiu Jitsu Player's Avatar
Motorcycle(s): 2008 RED 250r
No choke, No problem?
Here's a pretty noob question but I was wondering- is it bad that I have never had to use the choke on my bike? Since its usually pretty warm here, I've never had any problems just starting it without the choke. I was just wondering whether I should just try using it once or twice for the hell of it or whether never using it would lead to some problems down the line. thanks.
SAVAGE MODE: [ON] OFF
www.7milesdown.com
Jiu Jitsu Player is offline   Reply With Quote
Old March 22nd, 2009, 04:37 PM   #2
DmbShn41
Wannabe Reborn
DmbShn41's Avatar
This is just puerly my experience:
I live in SW Ohio, and we have cold winters and hot summers. In the spring, such as now, I have to choke and warm up the bike in the mornings and later at night. In the summer, I normally let the bike warm up, with no choke, then ride.
If and when I use the choke, I really try not to ride with it, unless I absolutely have to. By the 2nd or 3rd stop light when the rpms climb at idle, I turn it off.
If you use every once in awhile just to check if its working, I don't think that would hurt anything. Use a little extra fuel I would guess, but just don't ride around with it.
Old March 22nd, 2009, 05:39 PM   #3
so, when you start the bike w/ no choke, what rpm does it idle at initially?
Old March 22nd, 2009, 06:03 PM   #4
Jiu Jitsu Player
1to 2 rpm then it creeps up to 2 to 3 after a while.
Posted via Mobile Device
Old March 22nd, 2009, 06:06 PM   #5
lol... that's a bit low. You mean between 1000- 2000rpm?
what is it when you first start up the bike after it's been sitting all night? 1-2K is such a wide range... it shouldn't do that. Which is it, 1k or 2k?
your idle should be 1500rpm after fully warm.
Old March 22nd, 2009, 09:39 PM   #6
Jiu Jitsu Player
After a cold start with no choke it idles @ around 1400 rpm. Once she's running and warm, idle is around 2400.
www.7milesdown.com
Old March 22nd, 2009, 09:46 PM   #7
That's the "problem". Idle should be set to 1500 after the bike is completely warm (10-15minutes of riding) by adjusting the idle adjustment knob on the side of the bike. If you were to do that, you'll find you will need to use the choke at start up or the bike won't idle.
Your idle speed is set too high right now, you need to adjust it.
Old March 22nd, 2009, 10:13 PM   #8
Jiu Jitsu Player
Where is this knob? Do you have any pics or a DIY link or something? Thanks
www.7milesdown.com
Old March 22nd, 2009, 11:19 PM   #9
look in your owner's manual on setting the idle speed.
it's on the left hand side of the bike, right below the black side panel.
Old March 22nd, 2009, 11:41 PM   #10
Buffalony
Buffalony's Avatar
around 1350 rpm. I idle mine around 1450. Just preference.
Anyone else here have to adjust it often!
Maybe just depends on the weather for me!
Old March 23rd, 2009, 12:01 AM   #11
I had to play with the idle a lot to get it to settle, but after a few times it got pretty stable. I do notice at work at 3500' level and a colder ambient temp, the bike is harder to start and to keep running from a cold start. Once lit, the choke can be used to regulate the idle speed.
Old March 23rd, 2009, 12:10 AM   #12
Buffalony
Buffalony's Avatar
Yeah I think it was when it started getting colder up here that I started to adjust more frequently. I remember using the choke the way you did . Isn't it bad to use the choke in this manner though? Just asking.
Old March 23rd, 2009, 12:11 AM   #13
in what manner? that's what it's for... to keep the bike running till it warms up.
Old March 23rd, 2009, 12:34 AM   #14
Buffalony
Buffalony's Avatar
As an alternate to adjusting the idle speed after the bike is warmed up.
Old March 23rd, 2009, 01:06 AM   #15
yes, I use the idle adjustment knob to set or reset the idle speed back to what I want depending on the conditions on a fully warmed engine. I use the choke to keep the bike revving during warmup above an rpm where the bike will stall due to it not being up to temp.
I would never use the choke as an aid to compensate the idle speed on a warm bike.
Old March 23rd, 2009, 02:51 AM   #16
Buffalony
Buffalony's Avatar
K. What does the idle actually control? The Butterfly? Would this over enrich the mix running like this? Your brain on tap.
Old March 23rd, 2009, 09:49 AM   #17
zeroth
weekend rider
zeroth's Avatar
Motorcycle(s): '05 Ninja 250
Maybe I'm not the one who should comment on this, but based on just looking at the idle adjust knob and what it does, it seems to adjust the minimum throttle open position. So yes the butterfly. I don't believe that would adjust the mixture, just the minimum amount of air+fuel that would enter the engine.
Does that sound right, Kelly?
zeroth is offline   Reply With Quote
Old March 23rd, 2009, 01:57 PM   #18
yes, the idle adjust only moves how much the butterfly can close and in turn regulates the amount of air being allowed to mix with the idle circuit gas. Other than idling at 2500 rpm, I don't think you can damage it, but it's not good to be idling at 2500 when hot. That's why they designed the choke.
On the other hand, to tell you the truth, I have no idea exactly how the choke circuit works on these bikes. I've never looked that up in the service manual.
Old March 23rd, 2009, 02:02 PM   #19
Buffalony
Buffalony's Avatar
Yeah I deff. would not idle that high. Thanks for the replys.
Old March 23rd, 2009, 02:15 PM   #20
g21-30
g21-30's Avatar
The choke circuit is NOT a plate like in automobile history, instead it is just another needle like circuit, referred to as an enrichener (see pic)
When you set the choke lever on the handlebar, you're just withdrawing the needle from the jet.
Old March 23rd, 2009, 02:25 PM   #21
Buffalony
Buffalony's Avatar
So if you open the choke some, and your withdrawing the needles. Then wouldnt that have an effect on mid-range. Or is it only affecting the idle circuit?
NM. I gotta get in there myself to see whats going on.
Old March 23rd, 2009, 02:33 PM   #22
Jiu Jitsu Player
Found the knob and adjusted my idle range to 1400. I haven't cold started the bike with the idle set at that rpm yet so I'll have to see if I need the choke or not.
www.7milesdown.com
Old March 23rd, 2009, 02:34 PM   #23
g21-30
g21-30's Avatar
I used the term needle loosely. The choke operates another needle in each carb. Not the needle that you shim with washers. Don't confuse yourself. There are links under the DIY section (where I found the above picture), which explain the internal operations of the Keihin carbs on our bikes.
Old March 23rd, 2009, 03:44 PM   #24
Buffalony
Buffalony's Avatar
k. I'll be in there soon. thanks
help! choke problem? tammyxpr 2008 - 2012 Ninja 250R Tech Talk 3 April 1st, 2014 02:33 PM
Odd choke problem mrb 2008 - 2012 Ninja 250R Tech Talk 3 August 29th, 2013 06:17 PM
To choke or not to choke? Greyfox 2008 - 2012 Ninja 250R Tech Talk 14 May 9th, 2012 08:03 PM
Never using choke kano6280 2008 - 2012 Ninja 250R Tech Talk 22 March 29th, 2012 03:26 PM
